Unable to log in after update, both X and Wayland. (First time in more than two years!)
I changed the title to be more reflective of the situation.
Hi all!
I admit that I might have been a bit overeager on applying the latest updates.
But, in my defense, everything looked good. All the mirrors reported OK for syncing, the update announcement didn’t have anything nefarious. Everything looked good. Well, I saw that it was kind of small, < 1GB if I remember correctly. So I went ahead and applied the update.
After it downloaded and installed everything, I checked for .pacnew files, found a few (can’t remember which now.) merged them, and finally rebooted. Well, then the fun started. If by fun you mean unable to boot. No worries, since I have timeshift set up. So I grabbed my trusty thumb drive and boot into a Manjaro Live seession.
At first I thought I missed something, so I did a chroot into my environment and re-ran the update/sync. No dice. I can’t remember if it did anything or not, but upon reboot, nothing.
So I rebooted into the live environment again, and this time restored the Timeshift snapshot. It looked like it worked, but Timeshift reported “Done with errors.” Or something like that, anyway. But seeing there were no error displayed in the GUI window, I rebooted. The same nothing happened.
So I rebooted into the live environment again, we were old friends by now, and tried restoring to an earlier snapshot. But I noticed an error because this time I used the CLI:
...mp3 failed verification -- update discarded.
…and seeing as it’s only music, I rebooted and got same result.
I then entered the live environment again, and entered a chroot environment again, and just ran the update. But I was feeling nervous now, luckily my data is seperate from my OS, for this exact reason. So I tried doing the update with
pacman -Syyuu
…in the chroot environment, not the live environment. Afterwards checked for, and merged all .pacnew files. Rebooted. The same. So, back into the live environment I go, not really knowing what to do from here…
A lot of chroot ing, a lot of pacman later, a day later, and still nothing. Still unable to boot.
I am seriously considering just reinstalling Manjaro. I have tried everything I know of, and while I know it’s not everything, I also know it’s more than most. So I’m considering cutting my losses.
But I am unable to skip that 1 either to skip the file causing the error in Timeshift GUI, the containing directory, or ignore the error and continue. My suspiucion is that that’s possibly thee error the GUI reports.
(Needless to say, a due to the backups restoring, I don’t really have any log files anymore.)
So, does anyone have any ideas as what to do? I am in a live environment, a chroot environmeent is open and waiting for action.
I don't think it's neccessary, but FWIW here's my `inxi --full --admin --filter --width` output from the `chroot` environment
$ inxi --full --admin --filter --width
12System:
  12Kernel 6.1.30-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 12.2.1
    12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_KDE_2213 quiet systemd.show_status=1
    splash driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  12Desktop KDE Plasma 12v 5.27.5 12tk Qt 12v 5.15.9 12wm kwin_x11 12dm N/A
    12Distro Manjaro Linux 12base Arch Linux
12Machine:
  12Type Desktop 12System Gigabyte 12product Z370 HD3 12v N/A 12serial N/A
  12Mobo Gigabyte 12model Z370 HD3-CF 12v x.x 12serial N/A 12UEFI American Megatrends
    12v F5 12date 10/30/2017
12CPU:
  12Info 12model Intel Core i7-8700 12socket LGA1151 (U3E1) 12note check 12bits 64
    12type MT MCP 12arch Coffee Lake 12gen core 8 12level v3 12note check 12built 2018
    12process Intel 14nm 12family 6 12model-id 0x9E (158) 12stepping 0xA (10)
    12microcode 0x70
  12Topology 12cpus 1x 12cores 6 12tpc 2 12threads 12 12smt enabled 12cache 12L1 384 KiB
    12desc d-6x32 KiB; i-6x32 KiB 12L2 1.5 MiB 12desc 6x256 KiB 12L3 12 MiB 12desc 1x12 MiB
  12Speed (MHz) 12avg 3200 12min/max 800/4600 12base/boost 4300/8300 12scaling
    12driver intel_pstate 12governor powersave 12volts 1.1 V 12ext-clock 100 MHz 12cores
    121 3200 122 3200 123 3200 124 3200 125 3200 126 3200 127 3200 128 3200 129 3200 1210 3200
    1211 3200 1212 3200 12bogomips 76831
  12Flags avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  12Vulnerabilities
  12Type itlb_multihit 12status KVM: VMX disabled
  12Type l1tf 12mitigation PTE Inversion; VMX: conditional cache flushes, SMT
    vulnerable
  12Type mds 12status Vulnerable: Clear CPU buffers attempted, no microcode; SMT
    vulnerable
  12Type meltdown 12mitigation PTI
  12Type mmio_stale_data 12status Vulnerable: Clear CPU buffers attempted, no
    microcode; SMT vulnerable
  12Type retbleed 12status Vulnerable
  12Type spec_store_bypass 12status Vulnerable
  12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer
  12Type spectre_v2 12mitigation Retpolines, STIBP: disabled, RSB filling,
    PBRSB-eIBRS: Not affected
  12Type srbds 12status Vulnerable: No microcode
  12Type tsx_async_abort 12status Vulnerable: Clear CPU buffers attempted, no
12Graphics:
  12Device-1 NVIDIA GM206 [GeForce GTX 960] 12vendor Gigabyte 12driver nouveau
    12v kernel 12non-free 530.xx+ 12status current (as of 2023-05) 12arch Maxwell
    12code GMxxx 12process TSMC 28nm 12built 2014-19 12pcie 12gen 1 12speed 2.5 GT/s
    12lanes 16 12link-max 12gen 3 12speed 8 GT/s 12ports 12active DVI-I-1,HDMI-A-1
    12empty DP-1,DVI-D-1 12bus-ID 01:00.0 12chip-ID 10de:1401 12class-ID 0300
    12temp 25.0 C
  12Display 12server X.Org 12v 21.1.8 12compositor kwin_x11 12driver 12X 12loaded nvidia
    12gpu nouveau 12display-ID :0 12screens 1
  12Screen-1 0 12s-res 5120x1080 12s-dpi 96 12s-size 1354x285mm (53.31x11.22")
    12s-diag 1384mm (54.48")
  12Monitor-1 DVI-I-1 12pos primary,left 12model LG (GoldStar) ULTRAWIDE
    12serial <filter> 12built 2016 12res 2560x1080 12hz 60 12dpi 97 12gamma 1.2
    12size 673x284mm (26.5x11.18") 12diag 730mm (28.8") 12modes 12max 2560x1080
    12min 720x400
  12Monitor-2 HDMI-A-1 12mapped HDMI-1 12pos right 12model LG (GoldStar) ULTRAWIDE
    12min 720x400
  12API OpenGL 12v 4.3 Mesa 23.0.4 12renderer NV126 12direct-render Yes
12Audio:
  12Device-1 Intel 200 Series PCH HD Audio 12vendor Gigabyte 12driver snd_hda_intel
    12v kernel 12bus-ID 00:1f.3 12chip-ID 8086:a2f0 12class-ID 0403
  12Device-2 NVIDIA GM206 High Definition Audio 12vendor Gigabyte
    12driver snd_hda_intel 12v kernel 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 16 12link-max
    12gen 3 12speed 8 GT/s 12bus-ID 01:00.1 12chip-ID 10de:0fba 12class-ID 0403
  12API ALSA 12v k6.1.30-1-MANJARO 12status kernel-api 12with aoss 12type oss-emulator
    12tools alsactl,alsamixer,amixer
  12Server-1 JACK 12v 1.9.22 12status off 12tools N/A
  12Server-2 PipeWire 12v 0.3.70 12status n/a (root, process)
    12with pipewire-media-session 12status off 12tools pw-cli
  12Server-3 PulseAudio 12v 16.1 12status active (root, process) 12with
    121 pulseaudio-alsa 12type plugin 122 pulseaudio-jack 12type module 12tools pacat,pactl
12Network:
  12Device-1 Intel Ethernet I219-V 12vendor Gigabyte 12driver e1000e 12v kernel
    12port N/A 12bus-ID 00:1f.6 12chip-ID 8086:15b8 12class-ID 0200
  12IF enp0s31f6 12state up 12speed 1000 Mbps 12duplex full 12mac <filter>
12Drives:
  12Local Storage 12total 8.47 TiB 12used 126.83 GiB (1.5%)
  12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Samsung 12model SSD 960 EVO 250GB
    12size 232.89 GiB 12block-size 12physical 512 B 12logical 512 B 12speed 31.6 Gb/s
    12lanes 4 12tech SSD 12serial <filter> 12fw-rev 3B7QCXE7 12temp 23.9 C
  12SMART yes 12health PASSED 12on 180d 20h 12cycles 2,574
    12read-units 50,527,743 [25.8 TB] 12written-units 37,549,092 [19.2 TB]
  12ID-2 /dev/sda 12maj-min 8:0 12vendor Seagate 12model ST4000DM000-1F2168
    12family Desktop HDD.15 12size 3.64 TiB 12block-size 12physical 4096 B 12logical 512 B
    12sata 3.1 12speed 6.0 Gb/s 12tech HDD 12rpm 5900 12serial <filter> 12fw-rev CC54
    12temp 27 C
  12SMART yes 12state enabled 12health PASSED 12on 3y 81d 0h 12cycles 2886
    12read 122.3 TiB 12written 61.81 TiB 12Old-Age 12UDMA CRC errors 13567
    12alert Bad cable/connection? 12Pre-Fail 12end-to-end 99 12threshold 99
    12alert FAILING_NOW 12attribute Spin_Retry_Count 12value 100 12worst 100
    12threshold 97
  12ID-3 /dev/sdb 12maj-min 8:16 12vendor Seagate 12model ST5000VX0011-1T317X
    12family Surveillance 12size 4.55 TiB 12block-size 12physical 4096 B 12logical 512 B
    12sata 3.1 12speed 6.0 Gb/s 12tech HDD 12rpm 7200 12serial <filter> 12fw-rev VN02
    12temp 30 C
  12SMART yes 12state enabled 12health PASSED 12on 1y 171d 16h 12cycles 1954
    12read 77.64 TiB 12written 16.79 TiB 12Pre-Fail 12attribute Spin_Retry_Count
    12value 100 12worst 100 12threshold 97
  12ID-4 /dev/sdc 12maj-min 8:32 12vendor SanDisk 12model USB 3.2Gen1 12size 57.3 GiB
    12block-size 12physical 512 B 12logical 512 B 12type USB 12rev 2.1 12spd 480 Mb/s 12lanes 1
    12mode 2.0 12tech N/A 12serial <filter> 12fw-rev 1.00
  12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
12Partition:
  12ID-1 / 12raw-size 224.58 GiB 12size 220 GiB (97.96%) 12used 126.83 GiB (57.6%)
    12fs ext4 12block-size 4096 B 12dev /dev/nvme0n1p2 12maj-min 259:2
12Swap:
  12Alert No swap data was found.
12Sensors:
  12System Temperatures 12cpu 23.0 C 12mobo N/A 12gpu nouveau 12temp 24.0 C
  12Fan Speeds (RPM) N/A 12gpu nouveau 12fan 1275
12Info:
  12Processes 286 12Uptime 1h 30m 12wakeups 0 12Memory 12available 15.58 GiB
  12used 2.88 GiB (18.5%) 12Init systemd 12v 253 12default graphical 12tool systemctl
  12Compilers 12gcc 13.1.1 12clang 15.0.7 12Packages 12pm pacman 12pkgs 1945 12libs 462
  12tools pamac 12Client Unknown Client: systemd 12inxi 3.3.27
You have the choice to either spend weeks trying to fix manjaro,
or 30 minutes to reinstall and weeks to reconfigure it.
At least there is a script from linux-aarhus
Summary
HOW TO keep my apps which I love, while switching PC or reinstalling linux from scratch
linux-aarhus
Computer Veteran | Coder | SysAdmin | DevSecOps
Create a list of installed packages
From Arch wiki Pacman Tips and Tricks
List explicitly installed packages not in the base meta package or base-devel package group:
$ comm -23 <(pacman -Qqe | sort) <({ pacman -Qqg base-devel; expac -l '\n' '%E' base; } | sort -u)
( comm -23 <(pacman -Qqe | sort) <({ pacman -Qqg base-devel; expac -l ‘\n’ ‘%E’ base; } | sort -u) > ~/packages.txt)
Pipe the output into a text file (e.g. packages.txt in your home) by appending > ~/packages.txt to above command.
Backup your dot-files/-folders to an USB device.
Edit the the list and remove unwanted packages leaving only those you want to install at a later point and save it to the same device.
When you have reinstalled your Manjaro system
  • copy the saved files and folders back and use pacman to install the content of your packages.txt
sudo pacman -Syu - <~/packages.txt
alternativ:
sudo yay -Syyu --needed < packages.txt
You tested, whether the sound settings refer to the correct sources?
I never even mentioned sound here :stuck_out_tongue:
And seeing as I don’t use sound because of a hearing problem, I wouldn’t know, now would I?
Edit:
That’s why I’m considering cutting my losses and reinstalling. So I figured I’d just get an opinion here, from the experts.
Without showing what are the exact errors when booting, which files you merged, etc. it’s impossible to troubleshoot.
I would always advise to try and fix it before reinstalling - you learn nothing with reinstall.
I know. That’s why I haven’t done it, yet.
As for the errors, it doesn’t show anything. It starts up until the (SDDM?) login screen. When I enter my password, apparently it is the correct one and I’m greeted with the splash screen after that. The loading spinner spins and after a while it stops, almost like it hangs, but there it stops and doesn’t go any further.
You could try sudo “mkinitcpio -P” and then sudo “update-grub” and yes I know you don’t need sudo in a chroot.
I would also reinstall the nvidia stuff as I think it is probably this that is not starting.
Then you don’t even need chrooting, you can just switch to different tty and operate there?
Some logs from the chroot environment:
journalctl -b-1 -e --grep='kwin':
Jul 06 12:32:49 Mirdarthos-PC kwin_x11[32139]: kwin_core: XCB error: 152 (BadDamage), sequence: 10655, resource id: 115404209, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Jul 06 12:30:14 Mirdarthos-PC kwin_x11[32139]: kwin_core: XCB error: 152 (BadDamage), sequence: 6408, resource id: 115399802, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Jul 06 12:27:17 Mirdarthos-PC kwin_x11[32139]: kwin_core: XCB error: 152 (BadDamage), sequence: 50574, resource id: 115393929, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Jul 06 12:27:13 Mirdarthos-PC kwin_x11[32139]: kwin_core: XCB error: 3 (BadWindow), sequence: 47440, resource id: 121634826, major code: 129 (SHAPE), minor code: 3 (Combine)
Jul 06 12:27:13 Mirdarthos-PC kwin_x11[32139]: kwin_core: XCB error: 3 (BadWindow), sequence: 47439, resource id: 121634826, major code: 129 (SHAPE), minor code: 3 (Combine)
Jul 06 12:27:13 Mirdarthos-PC kwin_x11[32139]: kwin_core: XCB error: 3 (BadWindow), sequence: 47422, resource id: 121634826, major code: 129 (SHAPE), minor code: 3 (Combine)
Jul 06 12:27:13 Mirdarthos-PC kwin_x11[32139]: kwin_core: XCB error: 3 (BadWindow), sequence: 47421, resource id: 121634826, major code: 129 (SHAPE), minor code: 3 (Combine)
Jul 06 12:27:13 Mirdarthos-PC kwin_x11[32139]: kwin_core: XCB error: 3 (BadWindow), sequence: 47361, resource id: 121634826, major code: 129 (SHAPE), minor code: 5 (Extents)
Jul 06 12:27:13 Mirdarthos-PC kwin_x11[32139]: kwin_core: XCB error: 3 (BadWindow), sequence: 47360, resource id: 121634826, major code: 129 (SHAPE), minor code: 6 (Input)
Jul 06 12:27:13 Mirdarthos-PC kwin_x11[32139]: kwin_core: Failed to focus 0x740000a (error 3)
Jul 06 12:27:13 Mirdarthos-PC kwin_x11[32139]: kwin_core: XCB error: 152 (BadDamage), sequence: 47196, resource id: 115393648, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Jul 06 12:24:53 Mirdarthos-PC kwin_x11[32139]: kwin_core: XCB error: 152 (BadDamage), sequence: 40693, resource id: 115387968, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Jul 06 12:20:12 Mirdarthos-PC kwin_x11[32139]: kwin_core: XCB error: 152 (BadDamage), sequence: 7867, resource id: 115374953, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Jul 06 12:19:03 Mirdarthos-PC kwin_x11[32139]: kwin_core: XCB error: 152 (BadDamage), sequence: 31125, resource id: 115371760, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Jul 06 12:09:55 Mirdarthos-PC dbus-daemon[686]: [session uid=1000 pid=686] Activating service name='org.kde.KSplash' requested by ':1.168' (uid=1000 pid=32139 comm="kwin_x11 --replace")
Jul 06 12:09:54 Mirdarthos-PC kwin_x11[32139]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
Jul 06 12:09:54 Mirdarthos-PC systemd[664]: plasma-kwin_x11.service: Consumed 1min 8.676s CPU time.
Jul 06 12:09:54 Mirdarthos-PC kwin_x11[32139]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Jul 06 12:09:54 Mirdarthos-PC kwin_x11[32139]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Jul 06 12:09:52 Mirdarthos-PC systemd[664]: Failed to start kwin_x11.
Jul 06 12:09:52 Mirdarthos-PC systemd[664]: app-kwin_x11-e2ee3d1d4c0749e3ae5ad64d8b7505f7.scope: Failed with result 'resources'.
Jul 06 12:09:52 Mirdarthos-PC systemd[664]: app-kwin_x11-e2ee3d1d4c0749e3ae5ad64d8b7505f7.scope: Failed to add PIDs to scope's control group: No such process
Jul 06 12:09:52 Mirdarthos-PC systemd[664]: app-kwin_x11-e2ee3d1d4c0749e3ae5ad64d8b7505f7.scope: Couldn't move process 32138 to requested cgroup '/user.slice/user-1000.slice/user@1000.service/app.slice/app-kwin_x11-e2ee3d1d4c0749e3ae5ad64d8b7505f7.scope': No such process
Jul 06 09:19:33 Mirdarthos-PC kwin_x11[766]: kwin_core: XCB error: 152 (BadDamage), sequence: 12109, resource id: 16782689, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Jul 06 09:15:24 Mirdarthos-PC kwin_x11[766]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
Jul 06 09:13:38 Mirdarthos-PC kwin_x11[766]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Jul 06 09:13:38 Mirdarthos-PC kwin_x11[766]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
journalctl -b-1 -e --grep='sddm':
# journalctl -b-1 -e --grep='sddm'
Jul 10 08:31:18 Mirdarthos-PC sddm-helper[662]: pam_unix(sddm:session): session closed for user mirdarthos
Jul 06 09:13:46 Mirdarthos-PC (sd-pam)[594]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Jul 06 09:13:36 Mirdarthos-PC sddm-helper[662]: Starting: "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Jul 06 09:13:36 Mirdarthos-PC sddm[551]: Auth: sddm-helper exited successfully
Jul 06 09:13:36 Mirdarthos-PC sddm-helper[662]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Jul 06 09:13:36 Mirdarthos-PC sddm-helper[591]: pam_unix(sddm-greeter:session): session closed for user sddm
Jul 06 09:13:35 Mirdarthos-PC sddm-helper[662]: pam_unix(sddm:session): session opened for user mirdarthos(uid=1000) by mirdarthos(uid=0)
Jul 06 09:13:35 Mirdarthos-PC sddm-helper[662]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Jul 06 09:13:35 Mirdarthos-PC sddm-helper[662]: pam_kwallet5(sddm:auth): pam_kwallet5: pam_sm_authenticate
Jul 06 09:13:35 Mirdarthos-PC sddm-helper[662]: pam_systemd_home(sddm:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jul 06 09:13:35 Mirdarthos-PC dbus-daemon[492]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.25' (uid=0 pid=662 comm="/usr/lib/sddm/sddm-helper --socket /tmp/sddm-autha")
Jul 06 09:13:18 Mirdarthos-PC sddm-greeter[601]: file:///usr/share/sddm/themes/Utterly-Nord/components/VirtualKeyboard.qml:12:1: Type InputPanel unavailable
Jul 06 09:13:18 Mirdarthos-PC sddm-greeter[601]: Loading file:///usr/share/sddm/themes/Utterly-Nord/Main.qml...
Jul 06 09:13:18 Mirdarthos-PC dbus-daemon[492]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service' requested by ':1.22' (uid=967 pid=601 comm="/usr/bin/sddm-greeter --socket /tmp/sddm-:0-ouEpOe")
Jul 06 09:13:17 Mirdarthos-PC dbus-daemon[492]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service' requested by ':1.22' (uid=967 pid=601 comm="/usr/bin/sddm-greeter --socket /tmp/sddm-:0-ouEpOe")
Jul 06 09:13:17 Mirdarthos-PC sddm-greeter[601]: Loading file:///usr/share/sddm/themes/Utterly-Nord/Main.qml...
Jul 06 09:13:17 Mirdarthos-PC sddm-greeter[601]: Loading theme configuration from "/usr/share/sddm/themes/Utterly-Nord/theme.conf"
Jul 06 09:13:17 Mirdarthos-PC systemd[1]: Started Session c1 of User sddm.
Jul 06 09:13:17 Mirdarthos-PC (systemd)[593]: pam_unix(systemd-user:session): session opened for user sddm(uid=967) by sddm(uid=0)
Jul 06 09:13:17 Mirdarthos-PC (systemd)[593]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Jul 06 09:13:17 Mirdarthos-PC systemd-logind[502]: New session c1 of user sddm.
Jul 06 09:13:17 Mirdarthos-PC sddm-helper[591]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=967) by (uid=0)
Jul 06 09:13:17 Mirdarthos-PC sddm[551]: Loading theme configuration from "/usr/share/sddm/themes/Utterly-Nord/theme.conf"
Jul 06 09:13:17 Mirdarthos-PC sddm[551]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Jul 06 09:13:15 Mirdarthos-PC sddm[551]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{793a850f-19af-40a4-9b75-6abc4f4f1eea} -noreset -displayfd 17
Jul 06 09:13:15 Mirdarthos-PC sddm[551]: Adding cookie to "/var/run/sddm/{793a850f-19af-40a4-9b75-6abc4f4f1eea}"
_I don't know how helpful they'd be, but there they are._
Tried it. For some reason my keyboard isn’t working properly there. Double keystrokes just about everywhere. Couldn’t even get past the password.
Did you try a fresh user account? Does it hang there?
Thank you for reminding me. Didn’t. Just tried to, but now it complains about unmountable /boot/efi.
timeshift and mp3 ?
The usage scenario for timeshift is usually system restore points - that does not include
That is quite broad - as there is absolutely no hints what-so-ever …
There is a couple of ways you can gather more information - e.g. edit the default grub and remove everything but the absolute necessities.
Remove the plymount hook from mkinitcpio.conf and regenerate init.
Disable the display manager will make it even more obvious where to search for the culprit.
In chroot run fsck on your root partition
Don’t use Plymouth. Quite happy with it like this and don’t want the complex and problematic plymouth, thankyouverymuch:
$ grep -i ply /etc/mkinitcpio.conf
$ cat /etc/mkinitcpio.conf
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run.  Advanced users may wish to specify all system modules
# in this array.  For instance:
#     MODULES=(usbhid xhci_hcd)
MODULES=()
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image.  This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way.  This is useful for config files.
FILES=()
# HOOKS
# This is the most important setting in this file.  The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added.  Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
##   This setup specifies all modules in the MODULES setting above.
##   No RAID, lvm2, or encrypted root is needed.
#    HOOKS=(base)
##   This setup will autodetect all modules for your system and should
##   work as a sane default
#    HOOKS=(base udev autodetect modconf block filesystems fsck)
##   This setup will generate a 'full' image which supports most systems.
##   No autodetection is done.
#    HOOKS=(base udev modconf block filesystems fsck)
##   This setup assembles a mdadm array with an encrypted root file system.
##   Note: See 'mkinitcpio -H mdadm_udev' for more information on RAID devices.
#    HOOKS=(base udev modconf keyboard keymap consolefont block mdadm_udev encrypt filesystems fsck)
##   This setup loads an lvm2 volume group.
#    HOOKS=(base udev modconf block lvm2 filesystems fsck)
##   NOTE: If you have /usr on a separate partition, you MUST include the
#    usr and fsck hooks.
HOOKS=(base udev autodetect modconf kms keyboard keymap block filesystems fsck)
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
#COMPRESSION="zstd"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
# MODULES_DECOMPRESS
# Decompress kernel modules during initramfs creation.
# Enable to speedup boot process, disable to save RAM
# during early userspace. Switch (yes/no).
#MODULES_DECOMPRESS="yes"
Edit:
Yes, I know. I don’t know where it came from. All my data is on a separate drive, and shouldn’t be visible to timeshift. Nevertheless, I still think that is the cause of it.
Disable the display manager while in chroot
systemctl disable sddm
Also run fsck on your root partition
Then reboot and login to the console.
I suspect you are the victim of plasma backend changed to much for your theme to handle - but that is just a guess.
It seems there is CLI methods available to apply theming - which could be handy in this case
plasma-apply-colorscheme
plasma-apply-cursortheme
plasma-apply-desktoptheme
plasma-apply-lookandfeel
plasma-apply-wallpaperimage
usage example:
plasma-apply-desktoptheme --list-themes
plasma-apply-desktoptheme breeze-dark
GitHub - shalva97/kde-configuration-files: KDE plasma configuration files
The result:
$  lsblk -f        [...]
nvme0n1
├─nvme0n1p1 swap     1                                 1b3f894f-5481-4241-ace5-c129a0cdb412
├─nvme0n1p2 ext4     1.0                               9a26c8d0-43f4-44ad-a7d3-861d6f6cdbfa
└─nvme0n1p3 vfat     FAT32                             D563-DAB7
So, I ran:
$ sudo fsck.ext4 /dev/nvme0n1p2        e2fsck 1.47.0 (5-Feb-2023)
/dev/nvme0n1p2: clean, 1229982/14721024 files, 34445536/58872748 blocks
$ sudo fsck.exfat /dev/nvme0n1p3
exfatprogs version : 1.2.0
Bad fs_name in boot sector, which does not describe a valid exfat filesystem
$ sudo fsck.vfat /dev/nvme0n1p3
fsck.fat 4.2 (2021-01-31)
/dev/nvme0n1p3: 5 files, 75/127746 clusters
I see the error on /dev/nvme0n1p3 but am not sure if it’s anything to worry about…
I’ll do the reboot now and see
it is not - because the filesystem on efi partition is always fat32 not exfat
That’s what I figured, yes. And why I ran the test again.
Also, I think this is more of a clue as to what’s going on. From the chroot environment:
$ journalctl -x -p 3 -b -1 -e
-- A start job for unit systemd-timesyncd.service has finished with a failure.
-- Defined-By: systemd
-- Support: https://forum.manjaro.org/c/support
-- The job identifier is 1093 and the job result is failed.
Jul 19 11:54:46 Mirdarthos-PC systemd[1]: Failed to start Network Time Synchronization.
-- Subject: A start job for unit systemd-timesyncd.service has failed
-- The job identifier is 1101 and the job result is failed.
Jul 19 11:55:01 Mirdarthos-PC kernel: ext4: Unknown parameter 'umask'
Jul 19 11:55:01 Mirdarthos-PC systemd[1]: Failed to mount /boot/efi.
-- Subject: A start job for unit boot-efi.mount has failed
-- A start job for unit boot-efi.mount has finished with a failure.
-- The job identifier is 1155 and the job result is failed.
Jul 19 11:55:01 Mirdarthos-PC systemd[1]: Failed to start Network Time Synchronization.
-- The job identifier is 1192 and the job result is failed.
-- The job identifier is 1369 and the job result is failed.
-- The job identifier is 1377 and the job result is failed.
-- The job identifier is 1385 and the job result is failed.
-- The job identifier is 1393 and the job result is failed.
-- The job identifier is 1401 and the job result is failed.
Jul 19 11:55:27 Mirdarthos-PC kernel: watchdog: watchdog0: watchdog did not stop!
Seems there is something amiss with my efi partition, so I think I have to restore again, this time making doubly sure the efi gets restored, not to root, but to the right partition.
Edit:
OK, so the latest restore worked…up to a point. @megavolt I tested login of another user. The answer is no. Surprisingly, it’s actually very different. Upon entering the password, it looks as if it is it switches to a black screen and looks as if it’s working. Only to show the login screen again. So it ends up in the infamous login loop kind of thing.
So, I’m back in the Live environment, with the chroot open and ready to rumble. Here are updated logs, from the chroot environment:
grep -i ply /etc/mkinitcpio.confgrep -i ply /etc/mkinitcpio.conf:
cat /etc/mkinitcpio.conf:
# vim:set ft=sh
# MODULES
MODULES=()
# BINARIES
BINARIES=()
# FILES
FILES=()
# HOOKS
# Examples:
#    HOOKS=(base)
# COMPRESSION
#COMPRESSION="gzip"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
#COMPRESSION="zstd"
journalctl -b-1 -p3:
Jul 19 13:27:50 Mirdarthos-PC kernel: x86/cpu: SGX disabled by BIOS.
Jul 19 13:27:50 Mirdarthos-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT0._GTF.DSSP], AE_NOT_FOUND (20230331/psargs-330)
Jul 19 13:27:50 Mirdarthos-PC kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT0._GTF due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
Jul 19 13:27:50 Mirdarthos-PC kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT1._GTF.DSSP], AE_NOT_FOUND (20230331/psargs-330)
Jul 19 13:27:50 Mirdarthos-PC kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT1._GTF due to previous error (AE_NOT_FOUND) (20230331/psparse-529)
Jul 19 13:27:51 Mirdarthos-PC kernel:
Jul 19 13:27:53 Mirdarthos-PC smartd[518]: Device: /dev/sda [SAT], 40 Currently unreadable (pending) sectors
Jul 19 13:27:53 Mirdarthos-PC smartd[518]: Device: /dev/sda [SAT], 40 Offline uncorrectable sectors
Jul 19 13:27:53 Mirdarthos-PC smartd[518]: Device: /dev/sda [SAT], Failed SMART usage Attribute: 184 End-to-End_Error.
Jul 19 13:27:53 Mirdarthos-PC colord-sane[596]: io/hpmud/pp.c 627: unable to read device-id ret=-1
Jul 19 13:27:56 Mirdarthos-PC nmbd[637]: [2023/07/19 13:27:56.145356,  0] ../../source3/nmbd/nmbd.c:901(main)
Jul 19 13:27:56 Mirdarthos-PC nmbd[637]:   nmbd version 4.18.4 started.
Jul 19 13:27:56 Mirdarthos-PC nmbd[637]:   Copyright Andrew Tridgell and the Samba Team 1992-2023
Jul 19 13:28:19 Mirdarthos-PC nmbd[637]: [2023/07/19 13:28:19.876514,  0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
Jul 19 13:28:19 Mirdarthos-PC nmbd[637]:   *****
Jul 19 13:28:19 Mirdarthos-PC nmbd[637]:   Samba name server MIRDARTHOS-PC is now a local master browser for workgroup DISCWORLD on subnet 10.0.0.20
Jul 19 13:28:54 Mirdarthos-PC nmbd[637]: [2023/07/19 13:28:54.276025,  0] ../../source3/nmbd/nmbd.c:59(terminate)
Jul 19 13:28:54 Mirdarthos-PC nmbd[637]:   Got SIGTERM: going down...
journalctl -b-1 -p4 --no-pager --grep='sddm':
$  journalctl -b-1 -p4 --no-pager --grep='sddm'
Jul 19 13:27:55 Mirdarthos-PC sddm-greeter[626]: Could not locate plasma theme "Arc-Dark" in plasma/desktoptheme/ using search path ("/var/lib/sddm/.local/share", "/usr/local/share", "/usr/share")
Jul 19 13:27:55 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/Main.qml:443:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jul 19 13:27:55 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/VirtualKeyboard.qml:23:1: Type InputPanel unavailable
Jul 19 13:27:55 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/Login.qml:95:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jul 19 13:27:55 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/Login.qml:144:5: QML DropShadow: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
Jul 19 13:28:05 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/Login.qml:144:5: QML DropShadow: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
Jul 19 13:28:06 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/Login.qml:144:5: QML DropShadow: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
Jul 19 13:28:08 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/Login.qml:144:5: QML DropShadow: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
Jul 19 13:28:09 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/Login.qml:144:5: QML DropShadow: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
Jul 19 13:28:10 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/Login.qml:144:5: QML DropShadow: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
Jul 19 13:28:11 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/Login.qml:144:5: QML DropShadow: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
Jul 19 13:28:12 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/Login.qml:144:5: QML DropShadow: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/Main.qml:454: ReferenceError: footerRight is not defined
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/Main.qml:417: TypeError: Cannot read property 'smallSpacing' of null
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/ActionButton.qml:64: TypeError: Cannot read property 'smallSpacing' of null
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/ActionButton.qml:34: TypeError: Cannot read property 'gridUnit' of null
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/ActionButton.qml:36: TypeError: Cannot read property 'largeSpacing' of null
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/ActionButton.qml:37: TypeError: Cannot read property 'smallSpacing' of null
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/SessionManagementScreen.qml:83: TypeError: Cannot read property 'gridUnit' of null
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/SessionManagementScreen.qml:112: TypeError: Cannot read property 'smallSpacing' of null
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/SessionManagementScreen.qml:98: TypeError: Cannot read property 'gridUnit' of null
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/SessionManagementScreen.qml:99: TypeError: Cannot read property 'gridUnit' of null
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/SessionManagementScreen.qml:89: TypeError: Cannot read property 'gridUnit' of null
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/UserList.qml:25: TypeError: Cannot read property 'gridUnit' of null
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/UserList.qml:26: TypeError: Cannot read property 'gridUnit' of null
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/UserDelegate.qml:118: TypeError: Cannot read property 'largeSpacing' of null
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/UserDelegate.qml:44: TypeError: Cannot read property 'smallSpacing' of null
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/UserDelegate.qml:84: TypeError: Cannot read property 'largeSpacing' of null
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/UserDelegate.qml:110: TypeError: Cannot read property 'gridUnit' of null
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/UserDelegate.qml:90: TypeError: Cannot read property 'longDuration' of null
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/UserDelegate.qml:50: TypeError: Cannot read property 'longDuration' of null
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/Main.qml:171: TypeError: Cannot read property 'longDuration' of null
Jul 19 13:28:13 Mirdarthos-PC sddm-greeter[626]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/Main.qml:422: TypeError: Cannot read property 'longDuration' of null
Jul 19 13:28:54 Mirdarthos-PC sddm[570]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Jul 19 13:28:54 Mirdarthos-PC sddm[570]: Auth: sddm-helper (--socket /tmp/sddm-auth-2df5efe2-2490-4ca2-a98f-fde7e947380a --id 1 --start /usr/bin/startplasma-x11 --user mirdarthos) crashed (exit code 1)
Jul 19 13:28:54 Mirdarthos-PC sddm[570]: Auth: sddm-helper exited with 1
I might be wrong, but to me it looks like something to do with authehntication, ot even SDDM itself.
Here’s what I could find, that I think is relevant in pacman.log:
[2023-07-11T13:09:17+0200] [PACMAN] Running 'pacman -S pacman>=6.0.2-11'
[2023-07-11T14:56:34+0200] [ALPM] transaction started
[2023-07-11T14:56:34+0200] [ALPM] installed librewolf-bin (115.0.1-1)
[2023-07-11T14:56:34+0200] [ALPM-SCRIPTLET] >>    Remember to check for changes in /usr/lib/librewolf/librewolf.cfg.pacnew
[2023-07-11T14:56:34+0200] [ALPM-SCRIPTLET] >>    as those will not automatically overwrite your existing librewolf.cfg.
[2023-07-11T14:56:34+0200] [ALPM-SCRIPTLET] >>    We would encourage you to migrate your own changes to the new overrides file
[2023-07-11T14:56:34+0200] [ALPM-SCRIPTLET] >>    at ~/.librewolf/librewolf.overrides.cfg instead, so making changes directly
[2023-07-11T14:56:34+0200] [ALPM-SCRIPTLET] >>    in your librewolf.cfg is not necessary anymore (in most cases at least).
[2023-07-11T14:56:34+0200] [ALPM-SCRIPTLET] >>    Check out https://gitlab.com/librewolf-community/settings/-/merge_requests/13
[2023-07-11T14:56:34+0200] [ALPM-SCRIPTLET] >>    for more information on this.
[2023-07-11T14:56:34+0200] [ALPM] transaction completed
[2023-07-11T14:56:34+0200] [ALPM] running '30-systemd-update.hook'...
[2023-07-11T14:56:34+0200] [ALPM] running '90-packagekit-refresh.hook'...
[2023-07-11T14:56:34+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2023-07-11T14:56:35+0200] [ALPM] running 'pacman-backup.hook'...
[2023-07-11T14:56:35+0200] [ALPM] running 'pacnew-notifier.hook'...
[2023-07-11T14:56:35+0200] [ALPM] running 'update-desktop-database.hook'...
[2023-07-12T08:37:18+0200] [PAMAC] synchronizing package lists
[2023-07-12T08:43:46+0200] [ALPM] transaction started
[2023-07-12T08:43:46+0200] [ALPM] upgraded archlinux-keyring (20230504-1 -> 20230704-1)
[2023-07-12T08:43:46+0200] [ALPM-SCRIPTLET] ==> Appending keys from archlinux.gpg...
[2023-07-12T08:43:49+0200] [ALPM-SCRIPTLET] ==> Disabling revoked keys in keyring...
[2023-07-12T08:43:49+0200] [ALPM-SCRIPTLET]   -> Disabled 2 keys.
[2023-07-12T08:43:49+0200] [ALPM-SCRIPTLET] ==> Updating trust database...
[2023-07-12T08:43:49+0200] [ALPM-SCRIPTLET] gpg: key 786C63F330D7CB92: no user ID for key signature packet of class 10
[2023-07-12T08:43:49+0200] [ALPM-SCRIPTLET] gpg: key 1EB2638FF56C0C53: no user ID for key signature packet of class 10
[2023-07-12T08:43:49+0200] [ALPM-SCRIPTLET] gpg: marginals needed: 3  completes needed: 1  trust model: pgp
[2023-07-12T08:43:49+0200] [ALPM-SCRIPTLET] gpg: depth: 0  valid:   1  signed:  25  trust: 0-, 0q, 0n, 0m, 0f, 1u
[2023-07-12T08:43:49+0200] [ALPM-SCRIPTLET] gpg: depth: 1  valid:  25  signed:  98  trust: 0-, 0q, 0n, 25m, 0f, 0u
[2023-07-12T08:43:49+0200] [ALPM-SCRIPTLET] gpg: depth: 2  valid:  73  signed:  27  trust: 73-, 0q, 0n, 0m, 0f, 0u
[2023-07-12T08:43:49+0200] [ALPM-SCRIPTLET] gpg: next trustdb check due at 2023-10-27
[2023-07-12T08:43:49+0200] [ALPM] transaction completed
[2023-07-12T08:43:49+0200] [ALPM] running '30-systemd-daemon-reload.hook'...
[2023-07-12T08:43:50+0200] [ALPM] running '30-systemd-update.hook'...
[2023-07-12T08:43:50+0200] [ALPM] running '90-packagekit-refresh.hook'...
[2023-07-12T08:43:50+0200] [ALPM] running 'pacnew-notifier.hook'...
[2023-07-12T08:43:50+0200] [ALPM] running 'rebuild-detector.hook'...
[2023-07-12T08:43:50+0200] [ALPM-SCRIPTLET] parallel: Warning: $HOME not set. Using /tmp.
[2023-07-12T08:43:51+0200] [ALPM-SCRIPTLET] foreign	gwe
[2023-07-12T08:43:51+0200] [ALPM-SCRIPTLET] foreign	python-injector
[2023-07-12T08:43:51+0200] [ALPM-SCRIPTLET] foreign	python-py3nvml
[2023-07-12T08:43:51+0200] [ALPM-SCRIPTLET] foreign	python-pynput
[2023-07-12T08:56:32+0200] [PAMAC] synchronizing package lists
[2023-07-12T08:57:49+0200] [ALPM] running '60-mkinitcpio-remove.hook'...
[2023-07-12T08:57:49+0200] [ALPM] running '71-dkms-remove.hook'...
[2023-07-12T08:57:49+0200] [ALPM-SCRIPTLET] ==> dkms remove --no-depmod vboxhost/7.0.8_OSE -k 6.1.31-2-MANJARO
[2023-07-12T08:57:50+0200] [ALPM-SCRIPTLET] ==> dkms remove --no-depmod vboxhost/7.0.8_OSE -k 6.3.5-2-MANJARO
[2023-07-12T08:57:50+0200] [ALPM-SCRIPTLET] ==> dkms remove --no-depmod vboxhost/7.0.8_OSE -k 5.15.114-2-MANJARO
[2023-07-12T08:57:50+0200] [ALPM-SCRIPTLET] ==> depmod 6.1.31-2-MANJARO
[2023-07-12T08:57:54+0200] [ALPM-SCRIPTLET] ==> depmod 6.3.5-2-MANJARO
[2023-07-12T08:57:57+0200] [ALPM-SCRIPTLET] ==> depmod 5.15.114-2-MANJARO
[2023-07-12T08:58:05+0200] [ALPM] running 'firefox-dev-pre.hook'...
[2023-07-12T08:58:05+0200] [ALPM] running 'ghc-unregister.hook'...
[2023-07-12T08:58:06+0200] [ALPM] running 'kernel-alive-pre.hook'...
[2023-07-12T08:58:06+0200] [ALPM] transaction started
[2023-07-12T08:58:06+0200] [ALPM] upgraded iana-etc (20230405-1 -> 20230524-1)
[2023-07-12T08:58:06+0200] [ALPM] upgraded a52dec (0.8.0-1 -> 0.8.0-2)
[2023-07-12T08:58:06+0200] [ALPM] upgraded xorgproto (2022.2-1 -> 2023.2-1)
[2023-07-12T08:58:06+0200] [ALPM] upgraded libx11 (1.8.4-1 -> 1.8.6-1)
[2023-07-12T08:58:06+0200] [ALPM] upgraded ncurses (6.4-1 -> 6.4_20230520-1)
[2023-07-12T08:58:06+0200] [ALPM] upgraded zlib (1:1.2.13-2 -> 1:1.2.13-3)
[2023-07-12T08:58:06+0200] [ALPM] upgraded libxcrypt (4.4.33-1 -> 4.4.36-1)
[2023-07-12T08:58:06+0200] [ALPM] upgraded util-linux-libs (2.38.1-4 -> 2.39.1-1)
[2023-07-12T08:58:07+0200] [ALPM] upgraded openssl (3.0.8-1 -> 3.1.1-1)
[2023-07-12T08:58:07+0200] [ALPM] upgraded pam (1.5.3-1 -> 1.5.3-3)
[2023-07-12T08:58:07+0200] [ALPM] upgraded systemd-libs (253.4-1 -> 253.5-2)
[2023-07-12T08:58:07+0200] [ALPM] upgraded procps-ng (3.3.17-1 -> 4.0.3-1)
[2023-07-12T08:58:07+0200] [ALPM] upgraded aalib (1.4rc5-15 -> 1.4rc5-17)
[2023-07-12T08:58:07+0200] [ALPM] upgraded vulkan-icd-loader (1.3.245-1 -> 1.3.255-1)
[2023-07-12T08:58:07+0200] [ALPM] upgraded icu (72.1-2 -> 73.2-1)
[2023-07-12T08:58:07+0200] [ALPM] upgraded libxml2 (2.10.4-4 -> 2.11.4-1)
[2023-07-12T08:58:07+0200] [ALPM] upgraded egl-wayland (2:1.1.11-4 -> 2:1.1.12-1)
[2023-07-12T08:58:07+0200] [ALPM] upgraded dbus (1.14.6-2 -> 1.14.8-1)
[2023-07-12T08:58:07+0200] [ALPM] upgraded libepoxy (1.5.10-1 -> 1.5.10-2)
[2023-07-12T08:58:07+0200] [ALPM] upgraded nettle (3.9-1 -> 3.9.1-1)
[2023-07-12T08:58:07+0200] [ALPM] upgraded libpng (1.6.39-1 -> 1.6.40-2)
[2023-07-12T08:58:07+0200] [ALPM] upgraded libsysprof-capture (3.48.0-1 -> 3.48.0-2)
[2023-07-12T08:58:07+0200] [ALPM] upgraded glib2 (2.76.2-1 -> 2.76.4-1)
[2023-07-12T08:58:07+0200] [ALPM] upgraded harfbuzz (7.3.0-1 -> 7.3.0-2)
[2023-07-12T08:58:07+0200] [ALPM] upgraded freetype2 (2.13.0-1 -> 2.13.1-1)
[2023-07-12T08:58:07+0200] [ALPM-SCRIPTLET]   The "Infinality" TrueType interpreter version has been removed.
[2023-07-12T08:58:07+0200] [ALPM-SCRIPTLET]   If you've previously configured "truetype:interpreter-version=38",
[2023-07-12T08:58:07+0200] [ALPM-SCRIPTLET]   please update your choice in /etc/profile.d/freetype2.sh .
[2023-07-12T08:58:07+0200] [ALPM] upgraded kbd (2.5.1-2 -> 2.6.1-1)
[2023-07-12T08:58:07+0200] [ALPM] upgraded hwdata (0.370-1 -> 0.372-1)
[2023-07-12T08:58:07+0200] [ALPM] upgraded util-linux (2.38.1-4 -> 2.39.1-1)
[2023-07-12T08:58:07+0200] [ALPM] upgraded libnghttp2 (1.53.0-1 -> 1.54.0-1)
[2023-07-12T08:58:07+0200] [ALPM] upgraded libssh2 (1.10.0-3 -> 1.11.0-1)
[2023-07-12T08:58:07+0200] [ALPM] upgraded libp11-kit (0.24.1-1 -> 0.25.0-1)
[2023-07-12T08:58:07+0200] [ALPM] upgraded p11-kit (0.24.1-1 -> 0.25.0-1)
[2023-07-12T08:58:07+0200] [ALPM] upgraded ca-certificates-mozilla (3.89.1-1 -> 3.91-1)
[2023-07-12T08:58:07+0200] [ALPM] upgraded systemd (253.4-1 -> 253.5-2)
[2023-07-12T08:58:08+0200] [ALPM] upgraded libgudev (237-2 -> 238-1)
[2023-07-12T08:58:08+0200] [ALPM] upgraded xkeyboard-config (2.38-1 -> 2.39-1)
[2023-07-12T08:58:09+0200] [ALPM] upgraded nvidia-utils (530.41.03-4 -> 535.54.03-1)
[2023-07-12T08:58:10+0200] [ALPM-SCRIPTLET] xorg configuration symlink valid...
[2023-07-12T08:58:10+0200] [ALPM-SCRIPTLET] If you run into trouble with CUDA not being available, run nvidia-modprobe first.
[2023-07-12T08:58:10+0200] [ALPM-SCRIPTLET] If you use GDM on Wayland, you might have to run systemctl enable --now nvidia-resume.service
[2023-07-12T08:58:10+0200] [ALPM] upgraded mesa (23.0.4-1 -> 23.0.4-2)
[2023-07-12T08:58:10+0200] [ALPM] upgraded duktape (2.7.0-5 -> 2.7.0-6)
[2023-07-12T08:58:10+0200] [ALPM] upgraded libproxy (0.4.18-3 -> 0.5.3-1)
[2023-07-12T08:58:10+0200] [ALPM] upgraded avahi (0.8+22+gfd482a7-4 -> 1:0.8+r22+gfd482a7-1)
[2023-07-12T08:58:10+0200] [ALPM] upgraded libcups (1:2.4.2-7 -> 1:2.4.6-1)
[2023-07-12T08:58:10+0200] [ALPM] upgraded qt5-translations (5.15.9-1 -> 5.15.10-1)
[2023-07-12T08:58:10+0200] [ALPM] upgraded qt5-base (5.15.9+kde+r151-1 -> 5.15.10+kde+r130-1)
[2023-07-12T08:58:10+0200] [ALPM] upgraded kitemmodels (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:10+0200] [ALPM] upgraded libplist (2.3.0-1 -> 2.3.0-2)
[2023-07-12T08:58:10+0200] [ALPM] upgraded libusbmuxd (2.0.2-2 -> 2.0.2-3)
[2023-07-12T08:58:10+0200] [ALPM] upgraded libimobiledevice (1.3.0-8 -> 1.3.0-9)
[2023-07-12T08:58:10+0200] [ALPM] upgraded upower (1.90.0-4 -> 1.90.2-1)
[2023-07-12T08:58:10+0200] [ALPM] upgraded libatasmart (0.19-5 -> 0.19-6)
[2023-07-12T08:58:10+0200] [ALPM] upgraded mpfr (4.2.0.p7-2 -> 4.2.0.p9-1)
[2023-07-12T08:58:10+0200] [ALPM] upgraded libbytesize (2.7-2 -> 2.8-2)
[2023-07-12T08:58:10+0200] [ALPM] upgraded nss (3.89.1-1 -> 3.91-1)
[2023-07-12T08:58:10+0200] [ALPM] upgraded libassuan (2.5.5-2 -> 2.5.6-1)
[2023-07-12T08:58:10+0200] [ALPM] upgraded libksba (1.6.3-1 -> 1.6.4-1)
[2023-07-12T08:58:10+0200] [ALPM] upgraded lib32-libxcrypt (4.4.33-1 -> 4.4.36-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded lib32-openssl (1:3.0.8-1 -> 1:3.1.1-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded libblockdev (2.28-2 -> 2.28-4)
[2023-07-12T08:58:11+0200] [ALPM] upgraded udisks2 (2.9.4-1 -> 2.9.4-4)
[2023-07-12T08:58:11+0200] [ALPM] upgraded solid (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded kcoreaddons (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded kwidgetsaddons (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded qt5-x11extras (5.15.9-1 -> 5.15.10-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded kjobwidgets (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded kdbusaddons (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded kconfig (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded kwindowsystem (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded kcrash (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded kglobalaccel (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded qt5-svg (5.15.9+kde+r8-1 -> 5.15.10+kde+r8-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded kauth (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded kcodecs (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded qt5-declarative (5.15.9+kde+r25-1 -> 5.15.10+kde+r26-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded qt5-wayland (5.15.9+kde+r55-1 -> 5.15.10+kde+r51-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded kguiaddons (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded ki18n (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded kconfigwidgets (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded karchive (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded kiconthemes (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded kitemviews (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded kxmlgui (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded kbookmarks (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded libxslt (1.1.37-3 -> 1.1.38-1)
[2023-07-12T08:58:11+0200] [ALPM] upgraded gstreamer (1.22.2-1 -> 1.22.4-2)
[2023-07-12T08:58:11+0200] [ALPM] upgraded orc (0.4.33-1 -> 0.4.34-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded gst-plugins-base-libs (1.22.2-1 -> 1.22.4-2)
[2023-07-12T08:58:12+0200] [ALPM] upgraded libtheora (1.1.1-5 -> 1.1.1-6)
[2023-07-12T08:58:12+0200] [ALPM] upgraded fribidi (1.0.12-1 -> 1.0.13-2)
[2023-07-12T08:58:12+0200] [ALPM] upgraded libdatrie (0.2.13-2 -> 0.2.13-4)
[2023-07-12T08:58:12+0200] [ALPM] upgraded libthai (0.1.29-2 -> 0.1.29-3)
[2023-07-12T08:58:12+0200] [ALPM] upgraded gst-plugins-base (1.22.2-1 -> 1.22.4-2)
[2023-07-12T08:58:12+0200] [ALPM] upgraded flac (1.4.2-1 -> 1.4.3-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded qt5-multimedia (5.15.9+kde+r3-1 -> 5.15.10+kde+r3-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded qt5-speech (5.15.9+kde+r1-1 -> 5.15.10+kde+r1-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded knotifications (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded kservice (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded kwallet (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded kcompletion (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded sonnet (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded ktextwidgets (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded kded (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded kio (5.106.0-1 -> 5.107.0-2)
[2023-07-12T08:58:12+0200] [ALPM] upgraded kpackage (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded kdeclarative (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded kcmutils (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded signon-kwallet-extension (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded libtiff (4.5.0-3 -> 4.5.1-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded librsvg (2:2.56.0-1 -> 2:2.56.2-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded libavc1394 (0.5.4-5 -> 0.5.4-6)
[2023-07-12T08:58:12+0200] [ALPM] upgraded dav1d (1.2.0-1 -> 1.2.1-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded gperftools (2.10-1 -> 2.10-3)
[2023-07-12T08:58:12+0200] [ALPM] upgraded imath (3.1.7-2 -> 3.1.9-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded openexr (3.1.7-1 -> 3.1.9-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded libjxl (0.8.1-1 -> 0.8.2-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded libmfx (23.1.6-1 -> 23.2.2-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded libopenmpt (0.7.1-1 -> 0.7.2-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded rav1e (0.6.3-1 -> 0.6.6-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded libwebp (1.3.0-2 -> 1.3.1-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded ocl-icd (2.3.1-1 -> 2.3.2-1)
[2023-07-12T08:58:12+0200] [ALPM] upgraded hidapi (0.13.1-2 -> 0.14.0-1)
[2023-07-12T08:58:13+0200] [ALPM] upgraded sdl2 (2.26.5-2 -> 2.28.1-1)
[2023-07-12T08:58:13+0200] [ALPM] upgraded srt (1.5.1-3 -> 1.5.2-1)
[2023-07-12T08:58:13+0200] [ALPM] upgraded svt-av1 (1.5.0-1 -> 1.6.0-1)
[2023-07-12T08:58:13+0200] [ALPM] upgraded v4l-utils (1.24.1-1 -> 1.24.1-2)
[2023-07-12T08:58:13+0200] [ALPM] upgraded ffmpeg (2:6.0-6 -> 2:6.0-8)
[2023-07-12T08:58:13+0200] [ALPM] upgraded minizip (1:1.2.13-2 -> 1:1.2.13-3)
[2023-07-12T08:58:13+0200] [ALPM] upgraded qt5-webchannel (5.15.9+kde+r3-1 -> 5.15.10+kde+r3-1)
[2023-07-12T08:58:13+0200] [ALPM] upgraded qt5-location (5.15.9+kde+r4-1 -> 5.15.10+kde+r4-2)
[2023-07-12T08:58:13+0200] [ALPM] upgraded noto-fonts (20230501-1 -> 1:23.7.1-1)
[2023-07-12T08:58:13+0200] [ALPM] upgraded ttf-dejavu (2.37+18+g9b5d1b2f-3 -> 2.37+18+g9b5d1b2f-4)
[2023-07-12T08:58:14+0200] [ALPM] upgraded qt5-webengine (5.15.13-2 -> 5.15.14-4)
[2023-07-12T08:58:14+0200] [ALPM] upgraded kaccounts-integration (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:14+0200] [ALPM] upgraded libakonadi (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:14+0200] [ALPM] upgraded liburing (2.3-1 -> 2.4-1)
[2023-07-12T08:58:14+0200] [ALPM] upgraded mariadb-libs (10.11.3-1 -> 11.0.2-2)
[2023-07-12T08:58:14+0200] [ALPM] upgraded mariadb-clients (10.11.3-1 -> 11.0.2-2)
[2023-07-12T08:58:14+0200] [ALPM] warning: directory permissions differ on /usr/lib/mysql/plugin/auth_pam_tool_dir/
filesystem: 700  package: 755
[2023-07-12T08:58:14+0200] [ALPM] upgraded mariadb (10.11.3-1 -> 11.0.2-2)
[2023-07-12T08:58:14+0200] [ALPM-SCRIPTLET] :: MariaDB was updated to a new feature release. To update the data run:
[2023-07-12T08:58:14+0200] [ALPM-SCRIPTLET]    systemctl restart mariadb.service && mariadb-upgrade -u root -p
[2023-07-12T08:58:14+0200] [ALPM] upgraded akonadi (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:14+0200] [ALPM] upgraded kmime (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:14+0200] [ALPM] upgraded akonadi-mime (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:14+0200] [ALPM] upgraded ksmtp (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:14+0200] [ALPM] upgraded libical (3.0.16-4 -> 3.0.16-5)
[2023-07-12T08:58:14+0200] [ALPM] upgraded kcalendarcore (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded kcontacts (1:5.106.0-1 -> 1:5.107.0-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded libkgapi (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded qtkeychain-qt5 (0.14.0-1 -> 0.14.1-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded kmailtransport (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded syntax-highlighting (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded kpimtextedit (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded kidentitymanagement (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded kcalutils (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded zxing-cpp (2.0.0-2 -> 2.1.0-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded prison (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded attica (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded syndication (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded knewstuff (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded grantleetheme (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded akonadi-contacts (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded akonadi-calendar (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded akonadi-notes (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded kactivities (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded kwayland (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded qt5-quickcontrols (5.15.9-1 -> 5.15.10-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded qt5-quickcontrols2 (5.15.9+kde+r6-1 -> 5.15.10+kde+r6-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded qt5-graphicaleffects (5.15.9-1 -> 5.15.10-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded kirigami2 (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded plasma-framework (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded threadweaver (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded krunner (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded akonadi-search (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded kparts (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded kontactinterface (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded libkdepim (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded kimap (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded kldap (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded purpose (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded ktextaddons (1.3.1-1 -> 1.3.2-1)
[2023-07-12T08:58:15+0200] [ALPM] upgraded pimcommon (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:16+0200] [ALPM] upgraded libgravatar (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:16+0200] [ALPM] upgraded kmbox (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:16+0200] [ALPM] upgraded libkleo (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:16+0200] [ALPM] upgraded messagelib (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:16+0200] [ALPM] upgraded knotifyconfig (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:16+0200] [ALPM] upgraded akregator (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:16+0200] [ALPM] installed db (6.2.32-1)
[2023-07-12T08:58:16+0200] [ALPM] upgraded perl (5.36.1-1 -> 5.36.1-2)
[2023-07-12T08:58:17+0200] [ALPM] upgraded python (3.11.3-1 -> 3.11.3-2)
[2023-07-12T08:58:17+0200] [ALPM] upgraded python-certifi (2022.12.07-3 -> 2023.05.07-1)
[2023-07-12T08:58:17+0200] [ALPM] warning: /etc/pacman.conf installed as /etc/pacman.conf.pacnew
[2023-07-12T08:58:17+0200] [ALPM] upgraded pacman (6.0.2-10 -> 6.0.2-11)
[2023-07-12T08:58:17+0200] [ALPM] upgraded alma-git (r117.ac97608-1 -> r173.b3d6b09-1)
[2023-07-12T08:58:17+0200] [ALPM] installed abseil-cpp (20230125.3-1)
[2023-07-12T08:58:17+0200] [ALPM] upgraded protobuf (21.12-2 -> 23.4-1)
[2023-07-12T08:58:17+0200] [ALPM] upgraded android-tools (34.0.1-1 -> 34.0.1-2)
[2023-07-12T08:58:17+0200] [ALPM] upgraded apparmor (3.1.3-2 -> 3.1.6-1)
[2023-07-12T08:58:17+0200] [ALPM] upgraded at-spi2-core (2.48.2-1 -> 2.48.3-2)
[2023-07-12T08:58:17+0200] [ALPM] upgraded glib-networking (1:2.76.0-1 -> 1:2.76.1-1)
[2023-07-12T08:58:17+0200] [ALPM] upgraded tracker3 (3.5.2-1 -> 3.5.3-2)
[2023-07-12T08:58:17+0200] [ALPM] upgraded gtk-update-icon-cache (1:4.10.3-2 -> 1:4.10.4-1)
[2023-07-12T08:58:17+0200] [ALPM] upgraded gtk3 (1:3.24.37-1 -> 1:3.24.38-1)
[2023-07-12T08:58:17+0200] [ALPM] upgraded appstream-glib (0.8.2-2 -> 0.8.2-3)
[2023-07-12T08:58:18+0200] [ALPM] upgraded archlinux-appstream-data (20230421-1 -> 20230526-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded kpty (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded libzip (1.9.2-1 -> 1.10.0-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded ark (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded audiofile (0.3.6-7 -> 0.3.6-8)
[2023-07-12T08:58:18+0200] [ALPM] upgraded babl (0.1.104-1 -> 0.1.106-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded exiv2 (0.27.6-1 -> 0.28.0-3)
[2023-07-12T08:58:18+0200] [ALPM] upgraded poppler (23.05.0-1 -> 23.06.0-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded poppler-qt5 (23.05.0-1 -> 23.06.0-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded taglib (1.13-1 -> 1.13.1-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded libtommath (1.2.0-3 -> 1.2.0-4)
[2023-07-12T08:58:18+0200] [ALPM] upgraded kfilemetadata (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded kidletime (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded baloo (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded baloo-widgets (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded libuv (1.44.2-1 -> 1.46.0-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded bind (9.18.14-1 -> 9.18.16-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded binutils (2.40-5 -> 2.40-6)
[2023-07-12T08:58:18+0200] [ALPM] upgraded bison (3.8.2-5 -> 3.8.2-6)
[2023-07-12T08:58:18+0200] [ALPM] warning: directory permissions differ on /etc/bluetooth/
filesystem: 755  package: 555
[2023-07-12T08:58:18+0200] [ALPM] upgraded bluez (5.66-1 -> 5.68-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded bluez-qt (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded bluedevil (1:5.27.5-1 -> 1:5.27.6-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded bluez-libs (5.66-1 -> 5.68-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded bluez-utils (5.66-1 -> 5.68-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded boost-libs (1.81.0-6 -> 1.81.0-7)
[2023-07-12T08:58:18+0200] [ALPM] upgraded bottom (0.9.1-2 -> 0.9.3-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded frameworkintegration (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:18+0200] [ALPM] upgraded kdecoration (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:20+0200] [ALPM] upgraded breeze-icons (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:20+0200] [ALPM] upgraded breeze (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:20+0200] [ALPM] upgraded btrfs-progs (6.3-2 -> 6.3.2-1)
[2023-07-12T08:58:20+0200] [ALPM] upgraded c-ares (1.19.0-1 -> 1.19.1-1)
[2023-07-12T08:58:20+0200] [ALPM] upgraded kholidays (1:5.106.0-1 -> 1:5.107.0-1)
[2023-07-12T08:58:20+0200] [ALPM] upgraded calendarsupport (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:21+0200] [ALPM] installed electron22 (22.3.16-1)
[2023-07-12T08:58:22+0200] [ALPM] upgraded caprine (2.57.4-1 -> 2.57.4-4)
[2023-07-12T08:58:23+0200] [ALPM] upgraded chromium (114.0.5735.198-1 -> 114.0.5735.198-2)
[2023-07-12T08:58:23+0200] [ALPM] upgraded code (1.78.2-1 -> 1.79.2-1)
[2023-07-12T08:58:23+0200] [ALPM] upgraded cowsay (3.04-2 -> 3.04-3)
[2023-07-12T08:58:23+0200] [ALPM] upgraded cpupower (6.2-1 -> 6.3-2)
[2023-07-12T08:58:23+0200] [ALPM] upgraded qpdf (11.3.0-1 -> 11.4.0-2)
[2023-07-12T08:58:23+0200] [ALPM] upgraded libexif (0.6.24-1 -> 0.6.24-2)
[2023-07-12T08:58:23+0200] [ALPM] upgraded cups-filters (1.28.17-3 -> 1.28.17-4)
[2023-07-12T08:58:23+0200] [ALPM] upgraded libpaper (2.1.0-1 -> 2.1.1-1)
[2023-07-12T08:58:23+0200] [ALPM] warning: /etc/cups/cupsd.conf installed as /etc/cups/cupsd.conf.pacnew
[2023-07-12T08:58:23+0200] [ALPM] upgraded cups (1:2.4.2-7 -> 1:2.4.6-1)
[2023-07-12T08:58:23+0200] [ALPM] upgraded dbus-glib (0.112-2 -> 0.112-3)
[2023-07-12T08:58:23+0200] [ALPM] upgraded dbus-python (1.2.18-5 -> 1.3.2-2)
[2023-07-12T08:58:23+0200] [ALPM] upgraded diffutils (3.9-1 -> 3.10-1)
[2023-07-12T08:58:23+0200] [ALPM] upgraded djvulibre (3.5.28-4 -> 3.5.28-5)
[2023-07-12T08:58:23+0200] [ALPM] upgraded patch (2.7.6-9 -> 2.7.6-10)
[2023-07-12T08:58:23+0200] [ALPM] upgraded gc (8.2.2-1 -> 8.2.4-1)
[2023-07-12T08:58:23+0200] [ALPM] upgraded dkms (3.0.11-1 -> 3.0.11-2)
[2023-07-12T08:58:23+0200] [ALPM] upgraded kdnssd (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:23+0200] [ALPM] upgraded libmd (1.0.4-1 -> 1.1.0-1)
[2023-07-12T08:58:23+0200] [ALPM] upgraded libwbclient (4.18.2-2 -> 4.18.4-1)
[2023-07-12T08:58:23+0200] [ALPM] upgraded smbclient (4.18.2-2 -> 4.18.4-1)
[2023-07-12T08:58:23+0200] [ALPM] upgraded libkexiv2 (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:23+0200] [ALPM] upgraded kio-extras (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:24+0200] [ALPM] upgraded dolphin (23.04.1-1.1 -> 23.04.3-1)
[2023-07-12T08:58:24+0200] [ALPM] upgraded dolphin-plugins (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:24+0200] [ALPM] upgraded dragon (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:24+0200] [ALPM] installed electron25 (25.2.1-1)
[2023-07-12T08:58:24+0200] [ALPM] upgraded electron (22.3.3-1 -> 1:25-1)
[2023-07-12T08:58:24+0200] [ALPM] upgraded elinks (0.16.1-1 -> 0.16.1.1-1)
[2023-07-12T08:58:24+0200] [ALPM] upgraded enca (1.19-4 -> 1.19-5)
[2023-07-12T08:58:24+0200] [ALPM] upgraded enchant (2.3.4-1 -> 2.3.4-2)
[2023-07-12T08:58:24+0200] [ALPM] upgraded eventviews (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:24+0200] [ALPM] upgraded extra-cmake-modules (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:24+0200] [ALPM] upgraded f2fs-tools (1.16.0-1 -> 1.16.0-2)
[2023-07-12T08:58:24+0200] [ALPM] upgraded falkon (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:24+0200] [ALPM] upgraded ffmpeg4.4 (4.4.3-2 -> 4.4.4-1)
[2023-07-12T08:58:25+0200] [ALPM] upgraded ffmpegthumbs (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:25+0200] [ALPM] upgraded qqc2-desktop-style (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:25+0200] [ALPM] upgraded kquickcharts (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:25+0200] [ALPM] upgraded filelight (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:25+0200] [ALPM] upgraded libfilezilla (1:0.42.2-1 -> 1:0.44.0-1)
[2023-07-12T08:58:25+0200] [ALPM] upgraded filezilla (3.64.0-1 -> 3.64.0-3)
[2023-07-12T08:58:25+0200] [ALPM] upgraded mailcap (2.1.53-1 -> 2.1.54-1)
[2023-07-12T08:58:25+0200] [ALPM] upgraded firefox-developer-edition (114.0b5-1 -> 116.0b2-1)
[2023-07-12T08:58:26+0200] [ALPM] upgraded libpipewire (1:0.3.70-2 -> 1:0.3.73-1)
[2023-07-12T08:58:26+0200] [ALPM] upgraded fluidsynth (2.3.2-1 -> 2.3.3-1)
[2023-07-12T08:58:26+0200] [ALPM] upgraded libgusb (0.4.5-1 -> 0.4.6-1)
[2023-07-12T08:58:26+0200] [ALPM] upgraded libjcat (0.1.13-2 -> 0.1.14-1)
[2023-07-12T08:58:26+0200] [ALPM] upgraded gcab (1.5-1 -> 1.6-1)
[2023-07-12T08:58:26+0200] [ALPM] upgraded protobuf-c (1.4.1-1 -> 1.4.1-2)
[2023-07-12T08:58:26+0200] [ALPM] upgraded fwupd (1.9.1-1 -> 1.9.2-2)
[2023-07-12T08:58:26+0200] [ALPM] upgraded libraw (0.21.1-1 -> 0.21.1-2)
[2023-07-12T08:58:26+0200] [ALPM] upgraded libspiro (1:20221101-1 -> 1:20221101-2)
[2023-07-12T08:58:26+0200] [ALPM] upgraded luajit (2.1.0.beta3.r471.g224129a8-1 -> 2.1.0.beta3.r481.g51fb2f2c-1)
[2023-07-12T08:58:26+0200] [ALPM] upgraded poppler-glib (23.05.0-1 -> 23.06.0-1)
[2023-07-12T08:58:26+0200] [ALPM] upgraded suitesparse (7.0.1-2 -> 7.1.0-1)
[2023-07-12T08:58:26+0200] [ALPM] upgraded gegl (0.4.44-1 -> 0.4.46-1)
[2023-07-12T08:58:27+0200] [ALPM] upgraded ghostscript (10.01.1-1 -> 10.01.2-1)
[2023-07-12T08:58:27+0200] [ALPM] upgraded libgexiv2 (0.14.0-4 -> 0.14.1-1)
[2023-07-12T08:58:27+0200] [ALPM] upgraded libde265 (1.0.11-2 -> 1.0.12-1)
[2023-07-12T08:58:27+0200] [ALPM] upgraded libheif (1.16.1-2 -> 1.16.2-1)
[2023-07-12T08:58:27+0200] [ALPM] upgraded gimp (2.10.34-1 -> 2.10.34-2)
[2023-07-12T08:58:28+0200] [ALPM] upgraded git (2.40.1-1 -> 2.41.0-1)
[2023-07-12T08:58:28+0200] [ALPM] upgraded github-cli (2.29.0-1 -> 2.31.0-1)
[2023-07-12T08:58:28+0200] [ALPM] upgraded python-ujson (5.7.0-2 -> 5.8.0-1)
[2023-07-12T08:58:28+0200] [ALPM] upgraded glances (3.4.0.2-1 -> 3.4.0.3-1)
[2023-07-12T08:58:28+0200] [ALPM] upgraded glslang (12.1.0-2 -> 12.2.0-1)
[2023-07-12T08:58:28+0200] [ALPM] upgraded gnustep-base (1.29.0-1 -> 1.29.0-2)
[2023-07-12T08:58:30+0200] [ALPM] upgraded go (2:1.20.4-1 -> 2:1.20.5-1)
[2023-07-12T08:58:30+0200] [ALPM] upgraded iputils (20221126-1 -> 20221126-2)
[2023-07-12T08:58:30+0200] [ALPM] upgraded gping (1.8.0-1 -> 1.12.0-1)
[2023-07-12T08:58:30+0200] [ALPM] upgraded groff (1.22.4-10 -> 1.23.0-1)
[2023-07-12T08:58:30+0200] [ALPM] upgraded grub (2.06.r499.ge67a551a4-2 -> 2.06.r499.ge67a551a4-4)
[2023-07-12T08:58:30+0200] [ALPM] upgraded gspell (1.12.1-1 -> 1.12.1-2)
[2023-07-12T08:58:30+0200] [ALPM] upgraded gst-libav (1.22.2-1 -> 1.22.4-2)
[2023-07-12T08:58:30+0200] [ALPM] upgraded gupnp (1:1.6.3-1 -> 1:1.6.4-1)
[2023-07-12T08:58:30+0200] [ALPM] upgraded gst-plugins-bad-libs (1.22.2-1 -> 1.22.4-2)
[2023-07-12T08:58:30+0200] [ALPM] upgraded libdc1394 (2.2.6-2 -> 2.2.7-1)
[2023-07-12T08:58:30+0200] [ALPM] upgraded libdca (0.0.7-1 -> 0.0.7-2)
[2023-07-12T08:58:30+0200] [ALPM] upgraded libgme (0.6.3-2 -> 0.6.3-4)
[2023-07-12T08:58:30+0200] [ALPM] upgraded libdv (1.0.0-10 -> 1.0.0-11)
[2023-07-12T08:58:30+0200] [ALPM] upgraded mjpegtools (2.2.1-1 -> 2.2.1-2)
[2023-07-12T08:58:30+0200] [ALPM] upgraded libmpcdec (1:0.1+r475-3 -> 1:0.1+r475-4)
[2023-07-12T08:58:30+0200] [ALPM] upgraded neon (0.32.5-1 -> 0.32.5-2)
[2023-07-12T08:58:30+0200] [ALPM] upgraded libdvdread (6.1.3-1 -> 6.1.3-2)
[2023-07-12T08:58:30+0200] [ALPM] upgraded libdvdnav (6.1.1-1 -> 6.1.1-2)
[2023-07-12T08:58:30+0200] [ALPM] upgraded spandsp (0.0.6-4 -> 0.0.6-5)
[2023-07-12T08:58:30+0200] [ALPM] upgraded wildmidi (0.4.5-1 -> 0.4.5-2)
[2023-07-12T08:58:31+0200] [ALPM] upgraded openssh (9.3p1-1 -> 9.3p1-2)
[2023-07-12T08:58:31+0200] [ALPM] upgraded openmpi (4.1.5-1 -> 4.1.5-2)
[2023-07-12T08:58:31+0200] [ALPM] upgraded imagemagick (7.1.1.9-1 -> 7.1.1.12-1)
[2023-07-12T08:58:31+0200] [ALPM] upgraded zbar (0.23.90-2 -> 0.23.90-3)
[2023-07-12T08:58:31+0200] [ALPM] upgraded raptor (2.0.16-2 -> 2.0.16-3)
[2023-07-12T08:58:31+0200] [ALPM] upgraded gst-plugins-bad (1.22.2-1 -> 1.22.4-2)
[2023-07-12T08:58:31+0200] [ALPM] upgraded libcaca (0.99.beta20-1 -> 0.99.beta20-2)
[2023-07-12T08:58:31+0200] [ALPM] upgraded gst-plugins-good (1.22.2-1 -> 1.22.4-2)
[2023-07-12T08:58:31+0200] [ALPM] upgraded libmpeg2 (0.5.1-7 -> 0.5.1-8)
[2023-07-12T08:58:31+0200] [ALPM] upgraded gst-plugins-ugly (1.22.2-1 -> 1.22.4-2)
[2023-07-12T08:58:31+0200] [ALPM] upgraded gtk4 (1:4.10.3-2 -> 1:4.10.4-1)
[2023-07-12T08:58:31+0200] [ALPM] upgraded libcdio-paranoia (10.2+2.0.1-2 -> 10.2+2.0.1-3)
[2023-07-12T08:58:31+0200] [ALPM] upgraded gvfs (1.50.4-3 -> 1.50.5-1)
[2023-07-12T08:58:31+0200] [ALPM] upgraded gvfs-afc (1.50.4-3 -> 1.50.5-1)
[2023-07-12T08:58:31+0200] [ALPM] upgraded gvfs-gphoto2 (1.50.4-3 -> 1.50.5-1)
[2023-07-12T08:58:31+0200] [ALPM] upgraded gvfs-mtp (1.50.4-3 -> 1.50.5-1)
[2023-07-12T08:58:31+0200] [ALPM] upgraded gvfs-nfs (1.50.4-3 -> 1.50.5-1)
[2023-07-12T08:58:31+0200] [ALPM] upgraded gvfs-smb (1.50.4-3 -> 1.50.5-1)
[2023-07-12T08:58:31+0200] [ALPM] upgraded harfbuzz-icu (7.3.0-1 -> 7.3.0-2)
[2023-07-12T08:58:31+0200] [ALPM] upgraded haskell-base-orphans (0.8.7-50 -> 0.8.7-54)
[2023-07-12T08:58:31+0200] [ALPM] upgraded haskell-onetuple (0.3.1-53 -> 0.3.1-55)
[2023-07-12T08:58:31+0200] [ALPM] upgraded haskell-splitmix (0.1.0.4-132 -> 0.1.0.4-136)
[2023-07-12T08:58:31+0200] [ALPM] upgraded haskell-random (1.2.1.1-103 -> 1.2.1.1-109)
[2023-07-12T08:58:31+0200] [ALPM] upgraded haskell-quickcheck (2.14.2-405 -> 2.14.3-8)
[2023-07-12T08:58:31+0200] [ALPM] upgraded haskell-data-array-byte (0.1.0.1-11 -> 0.1.0.1-15)
[2023-07-12T08:58:31+0200] [ALPM] upgraded haskell-hashable (1.4.2.0-17 -> 1.4.2.0-23)
[2023-07-12T08:58:31+0200] [ALPM] upgraded haskell-primitive (0.7.4.0-67 -> 0.7.4.0-71)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-scientific (0.3.7.0-91 -> 0.3.7.0-93)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-attoparsec (0.14.4-52 -> 0.14.4-54)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-base-compat-batteries (0.12.2-42 -> 0.12.2-46)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-data-fix (0.3.2-80 -> 0.3.2-82)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-dlist (1.0-208 -> 1.0-211)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-unordered-containers (0.2.19.1-64 -> 0.2.19.1-69)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-vector (0.13.0.0-39 -> 0.13.0.0-43)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-indexed-traversable-instances (0.1.1.1-45 -> 0.1.1.2-2)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-distributive (0.6.2.1-184 -> 0.6.2.1-188)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-comonad (5.0.8-182 -> 5.0.8-186)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-bifunctors (5.5.15-3 -> 5.5.15-7)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-semigroupoids (5.3.7-95 -> 5.3.7-100)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-assoc (1.0.2-182 -> 1.0.2-186)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-these (1.1.1.1-183 -> 1.1.1.1-187)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-semialign (1.2.0.1-112 -> 1.2.0.1-118)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-strict (0.4.0.1-156 -> 0.4.0.1-160)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-text-short (0.1.5-57 -> 0.1.5-59)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-time-compat (1.9.6.1-75 -> 1.9.6.1-77)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-uuid-types (1.0.5-95 -> 1.0.5-97)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-witherable (0.4.2-53 -> 0.4.2-59)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-aeson (2.1.2.0-9 -> 2.1.2.1-5)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-diff (0.4.1-53 -> 0.4.1-55)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-fgl (5.8.1.1-4 -> 5.8.1.1-6)
[2023-07-12T08:58:32+0200] [ALPM] upgraded haskell-regex-tdfa (1.3.2-45 -> 1.3.2.1-2)
[2023-07-12T08:58:32+0200] [ALPM] upgraded python-gobject (3.44.1-3 -> 3.44.1-4)
[2023-07-12T08:58:32+0200] [ALPM] upgraded perl-alien-build (2.78-1 -> 2.80-1)
[2023-07-12T08:58:32+0200] [ALPM] upgraded hplip (1:3.23.3-3 -> 1:3.23.5-1)
[2023-07-12T08:58:32+0200] [ALPM] upgraded perl-uri (5.18-1 -> 5.19-1)
[2023-07-12T08:58:32+0200] [ALPM] upgraded perl-net-http (6.22-2 -> 6.23-1)
[2023-07-12T08:58:32+0200] [ALPM] upgraded hwinfo (22.2-2 -> 23.1-1)
[2023-07-12T08:58:32+0200] [ALPM] upgraded incidenceeditor (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:32+0200] [ALPM] upgraded intel-ucode (20230516-1 -> 20230613-1)
[2023-07-12T08:58:32+0200] [ALPM] upgraded inxi (3.3.27.1-1 -> 3.3.28.1-2)
[2023-07-12T08:58:32+0200] [ALPM] upgraded iproute2 (6.3.0-2 -> 6.4.0-1)
[2023-07-12T08:58:32+0200] [ALPM] upgraded python-prompt_toolkit (3.0.38-2 -> 3.0.39-1)
[2023-07-12T08:58:33+0200] [ALPM] upgraded ipython (8.13.2-1 -> 8.14.0-1)
[2023-07-12T08:58:33+0200] [ALPM] upgraded libkcddb (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:33+0200] [ALPM] upgraded libburn (1.5.4-1 -> 1.5.6-1)
[2023-07-12T08:58:33+0200] [ALPM] upgraded k3b (1:23.04.1-1 -> 1:23.04.3-1)
[2023-07-12T08:58:33+0200] [ALPM] upgraded kaccounts-providers (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:33+0200] [ALPM] upgraded kactivities-stats (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:33+0200] [ALPM] upgraded kactivitymanagerd (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:33+0200] [ALPM] upgraded kamera (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:33+0200] [ALPM] upgraded ktexteditor (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:33+0200] [ALPM] upgraded kate (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:33+0200] [ALPM] upgraded kcalc (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:33+0200] [ALPM] upgraded kcolorchooser (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:33+0200] [ALPM] upgraded kdav (1:5.106.0-1 -> 1:5.107.0-1)
[2023-07-12T08:58:33+0200] [ALPM] upgraded kdesu (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:34+0200] [ALPM] upgraded kde-cli-tools (5.27.5.1-1 -> 5.27.6-1)
[2023-07-12T08:58:34+0200] [ALPM] upgraded kde-gtk-config (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:34+0200] [ALPM] upgraded kirigami-addons (0.8.0-1 -> 0.9.0-1)
[2023-07-12T08:58:34+0200] [ALPM] upgraded modemmanager-qt (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:34+0200] [ALPM] upgraded kpeople (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:34+0200] [ALPM] upgraded kdeconnect (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:34+0200] [ALPM] upgraded kdegraphics-mobipocket (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:34+0200] [ALPM] upgraded libkdcraw (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:34+0200] [ALPM] upgraded kdegraphics-thumbnailers (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:34+0200] [ALPM] upgraded kunitconversion (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:34+0200] [ALPM] upgraded kemoticons (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:34+0200] [ALPM] upgraded kdelibs4support (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:35+0200] [ALPM] upgraded samba (4.18.2-2 -> 4.18.4-1)
[2023-07-12T08:58:35+0200] [ALPM] upgraded kdenetwork-filesharing (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:35+0200] [ALPM] upgraded qt5-networkauth (5.15.9-1 -> 5.15.10-1)
[2023-07-12T08:58:35+0200] [ALPM] upgraded xerces-c (3.2.4-2 -> 3.2.4-3)
[2023-07-12T08:58:35+0200] [ALPM] upgraded kdepim-runtime (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:35+0200] [ALPM] upgraded libksysguard (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:35+0200] [ALPM] upgraded ksystemstats (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:35+0200] [ALPM] upgraded libqalculate (4.6.1-1 -> 4.7.0-1)
[2023-07-12T08:58:35+0200] [ALPM] upgraded xorg-xrdb (1.2.1-1 -> 1.2.2-1)
[2023-07-12T08:58:35+0200] [ALPM] upgraded milou (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:35+0200] [ALPM] upgraded layer-shell-qt (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:35+0200] [ALPM] upgraded libkscreen (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:35+0200] [ALPM] upgraded kscreenlocker (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:36+0200] [ALPM] upgraded pipewire (1:0.3.70-2 -> 1:0.3.73-1)
[2023-07-12T08:58:36+0200] [ALPM] upgraded kwin (5.27.5-2 -> 5.27.6-1)
[2023-07-12T08:58:36+0200] [ALPM] upgraded ttf-hack (3.003-3 -> 3.003-6)
[2023-07-12T08:58:36+0200] [ALPM] upgraded plasma-integration (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:36+0200] [ALPM] upgraded kpipewire (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:36+0200] [ALPM] upgraded qt5-tools (5.15.9+kde+r1-1 -> 5.15.10+kde+r3-1)
[2023-07-12T08:58:36+0200] [ALPM] upgraded oxygen-sounds (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:37+0200] [ALPM] upgraded plasma-workspace (5.27.5-1 -> 5.27.6-2)
[2023-07-12T08:58:37+0200] [ALPM] upgraded kdeplasma-addons (5.27.5-1 -> 5.27.6-2)
[2023-07-12T08:58:37+0200] [ALPM] upgraded kdialog (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:37+0200] [ALPM] upgraded kdoctools (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:37+0200] [ALPM] upgraded keditbookmarks (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:37+0200] [ALPM] upgraded kfind (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:37+0200] [ALPM] upgraded systemsettings (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:37+0200] [ALPM] upgraded kgamma5 (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:38+0200] [ALPM] upgraded kget (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:38+0200] [ALPM] upgraded kjs (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:38+0200] [ALPM] upgraded khtml (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:38+0200] [ALPM] upgraded khelpcenter (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:38+0200] [ALPM] upgraded khotkeys (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:38+0200] [ALPM] upgraded kimageformats (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:58:38+0200] [ALPM] upgraded vulkan-tools (1.3.245-1 -> 1.3.255-1)
[2023-07-12T08:58:38+0200] [ALPM] upgraded wayland-utils (1.1.0-1 -> 1.2.0-1)
[2023-07-12T08:58:38+0200] [ALPM] upgraded kinfocenter (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:38+0200] [ALPM] upgraded kmenuedit (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:38+0200] [ALPM] upgraded ksanecore (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:38+0200] [ALPM] upgraded libksane (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:38+0200] [ALPM] upgraded kolourpaint (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:38+0200] [ALPM] upgraded libkomparediff2 (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:38+0200] [ALPM] upgraded kompare (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:38+0200] [ALPM] upgraded konsole (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:39+0200] [ALPM] upgraded korganizer (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:39+0200] [ALPM] upgraded kpmcore (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:39+0200] [ALPM] upgraded minizip-ng (3.0.10-1 -> 4.0.0-2)
[2023-07-12T08:58:39+0200] [ALPM] upgraded opencolorio (2.2.1-7 -> 2.2.1-10)
[2023-07-12T08:58:40+0200] [ALPM] upgraded krita (5.1.5-7 -> 5.1.5-10)
[2023-07-12T08:58:40+0200] [ALPM] upgraded qt5-sensors (5.15.9-1 -> 5.15.10-1)
[2023-07-12T08:58:40+0200] [ALPM] upgraded kscreen (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:40+0200] [ALPM] upgraded ksshaskpass (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:40+0200] [ALPM] upgraded ksystemlog (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:40+0200] [ALPM] upgraded kwallet-pam (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:40+0200] [ALPM] upgraded kwalletmanager (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:40+0200] [ALPM] upgraded kwayland-integration (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:40+0200] [ALPM] upgraded kwrited (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:58:40+0200] [ALPM] upgraded lib32-systemd (253.4-1 -> 253.5-1)
[2023-07-12T08:58:40+0200] [ALPM] upgraded lib32-dbus (1.14.6-2 -> 1.14.8-1)
[2023-07-12T08:58:40+0200] [ALPM] upgraded lib32-util-linux (2.38.1-1 -> 2.39.1-1)
[2023-07-12T08:58:40+0200] [ALPM] upgraded lib32-glib2 (2.76.2-1 -> 2.76.4-1)
[2023-07-12T08:58:40+0200] [ALPM] upgraded lib32-libx11 (1.8.4-1 -> 1.8.6-1)
[2023-07-12T08:58:40+0200] [ALPM] upgraded lib32-icu (72.1-2 -> 73.2-1)
[2023-07-12T08:58:40+0200] [ALPM] upgraded lib32-libxml2 (2.10.4-4 -> 2.11.4-1)
[2023-07-12T08:58:40+0200] [ALPM] upgraded lib32-at-spi2-core (2.48.2-1 -> 2.48.3-1)
[2023-07-12T08:58:41+0200] [ALPM] upgraded lib32-brotli (1.0.9-5 -> 1.0.9-12)
[2023-07-12T08:58:41+0200] [ALPM] upgraded lib32-libssh2 (1.10.0-2 -> 1.11.0-1)
[2023-07-12T08:58:41+0200] [ALPM] upgraded lib32-curl (8.1.0-1 -> 8.1.2-1)
[2023-07-12T08:58:41+0200] [ALPM] upgraded lib32-flac (1.4.2-1 -> 1.4.3-1)
[2023-07-12T08:58:41+0200] [ALPM] upgraded lib32-vulkan-icd-loader (1.3.245-1 -> 1.3.255-1)
[2023-07-12T08:58:41+0200] [ALPM] upgraded lib32-ncurses (6.4-1 -> 6.4_20230520-1)
[2023-07-12T08:58:41+0200] [ALPM] upgraded lib32-mesa (23.0.4-1 -> 23.0.4-2)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-nvidia-utils (530.41.03-1 -> 535.54.03-1)
[2023-07-12T08:58:42+0200] [ALPM-SCRIPTLET] xorg configuration symlink valid...
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-sdl2 (2.26.5-1 -> 2.28.1-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-libpipewire (1:0.3.70-1 -> 1:0.3.73-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-fluidsynth (2.3.2-1 -> 2.3.3-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-libpng (1.6.39-1 -> 1.6.40-2)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-harfbuzz (7.3.0-1 -> 7.3.0-2)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-freetype2 (2.13.0-1 -> 2.13.1-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-fribidi (1.0.12-1 -> 1.0.13-2)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-libtiff (4.5.0-3 -> 4.5.1-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-nettle (3.8.1-1 -> 3.9.1-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-p11-kit (0.24.1-1 -> 0.25.0-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-libcups (2.4.2-2 -> 2.4.6-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-librsvg (2:2.56.0-1 -> 2:2.56.2-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-gtk3 (1:3.24.37-1 -> 1:3.24.38-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-gstreamer (1.22.2-1 -> 1.22.4-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-orc (0.4.33-1 -> 0.4.34-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-gst-plugins-base-libs (1.22.2-1 -> 1.22.4-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-libva-mesa-driver (23.0.4-1 -> 23.0.4-2)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-libxcrypt-compat (4.4.33-1 -> 4.4.36-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-libxslt (1.1.37-2 -> 1.1.38-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-sqlite (3.41.2-1 -> 3.42.0-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-nss (3.89.1-1 -> 3.91-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-ocl-icd (2.3.1-1 -> 2.3.2-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded lib32-pipewire (1:0.3.70-1 -> 1:0.3.73-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded libdbusmenu-glib (16.04.0-5 -> 16.04.0.r498-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded libdbusmenu-gtk3 (16.04.0-5 -> 16.04.0.r498-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded libappindicator-gtk3 (12.10.0.r298-1 -> 12.10.0.r298-2)
[2023-07-12T08:58:42+0200] [ALPM] upgraded libcdr (0.1.7-5 -> 0.1.7-6)
[2023-07-12T08:58:42+0200] [ALPM] upgraded libe-book (0.1.3-13 -> 0.1.3-14)
[2023-07-12T08:58:42+0200] [ALPM] upgraded libisofs (1.5.4-1 -> 1.5.6-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded libisoburn (1.5.4-2 -> 1.5.6-1)
[2023-07-12T08:58:42+0200] [ALPM] upgraded libktorrent (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:58:43+0200] [ALPM] upgraded liblouis (3.25.0-2 -> 3.26.0-1)
[2023-07-12T08:58:43+0200] [ALPM] upgraded libmanette (0.2.6-4 -> 0.2.6-5)
[2023-07-12T08:58:43+0200] [ALPM] upgraded libmediainfo (23.04-1 -> 23.06-1)
[2023-07-12T08:58:43+0200] [ALPM] upgraded libmicrohttpd (0.9.76-1 -> 0.9.77-1)
[2023-07-12T08:58:43+0200] [ALPM] upgraded libmspub (0.1.4-13 -> 0.1.4-14)
[2023-07-12T08:58:43+0200] [ALPM] upgraded libpamac (11.5.4-1 -> 11.5.7-1)
[2023-07-12T08:58:43+0200] [ALPM] upgraded libpgm (5.3.128-2 -> 5.3.128-3)
[2023-07-12T08:58:43+0200] [ALPM] upgraded libqxp (0.0.2-9 -> 0.0.2-10)
[2023-07-12T08:58:43+0200] [ALPM] upgraded libvisio (0.1.7-8 -> 0.1.7-9)
[2023-07-12T08:58:43+0200] [ALPM] upgraded libzmf (0.0.2-13 -> 0.0.2-14)
[2023-07-12T08:58:46+0200] [ALPM] upgraded libreoffice-fresh (7.5.3-2 -> 7.5.4-3)
[2023-07-12T08:58:46+0200] [ALPM] upgraded libreoffice-fresh-af (7.5.3-1 -> 7.5.4-1)
[2023-07-12T08:58:46+0200] [ALPM] upgraded libreoffice-fresh-en-gb (7.5.3-1 -> 7.5.4-1)
[2023-07-12T08:58:47+0200] [ALPM] upgraded libreoffice-fresh-en-za (7.5.3-1 -> 7.5.4-1)
[2023-07-12T08:58:47+0200] [ALPM] upgraded libsidplayfp (2.4.2-1 -> 2.5.0-2)
[2023-07-12T08:58:47+0200] [ALPM] upgraded libtraceevent (1:1.7.2-1 -> 1:1.7.3-1)
[2023-07-12T08:58:47+0200] [ALPM] upgraded libtracefs (1.6.4-2 -> 1.7.0-1)
[2023-07-12T08:58:47+0200] [ALPM] upgraded libva-mesa-driver (23.0.4-1 -> 23.0.4-2)
[2023-07-12T08:58:47+0200] [ALPM] upgraded libxcrypt-compat (4.4.33-1 -> 4.4.36-1)
[2023-07-12T08:58:47+0200] [ALPM] upgraded libxklavier (5.4-4 -> 5.4-5)
[2023-07-12T08:58:47+0200] [ALPM] upgraded libxnvctrl (530.41.03-3 -> 535.54.03-1)
[2023-07-12T08:58:47+0200] [ALPM] upgraded linux-firmware-whence (20230404.2e92a49f-1 -> 20230625.ee91452d-2)
[2023-07-12T08:58:49+0200] [ALPM] upgraded linux-firmware (20230404.2e92a49f-1 -> 20230625.ee91452d-2)
[2023-07-12T08:58:49+0200] [ALPM] upgraded linux-firmware-qlogic (20230404.2e92a49f-1 -> 20230625.ee91452d-2)
[2023-07-12T08:58:49+0200] [ALPM] upgraded mkinitcpio-busybox (1.35.0-1 -> 1.36.1-1)
[2023-07-12T08:58:49+0200] [ALPM] upgraded mkinitcpio (35.2-2 -> 36-2)
[2023-07-12T08:58:51+0200] [ALPM] upgraded linux515 (5.15.114-2 -> 5.15.120-1)
[2023-07-12T08:58:54+0200] [ALPM] upgraded linux515-headers (5.15.114-2 -> 5.15.120-1)
[2023-07-12T08:58:54+0200] [ALPM] upgraded linux515-nvidia (530.41.03-13 -> 535.54.03-5)
[2023-07-12T08:59:02+0200] [ALPM] upgraded linux61 (6.1.31-2 -> 6.1.38-1)
[2023-07-12T08:59:05+0200] [ALPM] upgraded linux61-headers (6.1.31-2 -> 6.1.38-1)
[2023-07-12T08:59:05+0200] [ALPM] upgraded linux61-nvidia (530.41.03-13 -> 535.54.03-6)
[2023-07-12T08:59:08+0200] [ALPM] upgraded linux63 (6.3.5-2 -> 6.3.12-1)
[2023-07-12T08:59:11+0200] [ALPM] upgraded linux63-headers (6.3.5-2 -> 6.3.12-1)
[2023-07-12T08:59:11+0200] [ALPM] upgraded linux63-nvidia (530.41.03-11 -> 535.54.03-12)
[2023-07-12T08:59:14+0200] [ALPM] upgraded lua-lpeg (1.0.2-4 -> 1.1.0-1)
[2023-07-12T08:59:14+0200] [ALPM] upgraded manjaro-settings-manager (0.5.7-14 -> 0.5.7-16)
[2023-07-12T08:59:14+0200] [ALPM] upgraded manjaro-settings-manager-kcm (0.5.7-14 -> 0.5.7-16)
[2023-07-12T08:59:14+0200] [ALPM] upgraded manjaro-settings-manager-knotifier (0.5.7-14 -> 0.5.7-16)
[2023-07-12T08:59:14+0200] [ALPM] upgraded mediainfo (23.04-1 -> 23.06-1)
[2023-07-12T08:59:14+0200] [ALPM] upgraded mhwd-nvidia (530.41.03-4 -> 535.54.03-1)
[2023-07-12T08:59:14+0200] [ALPM] upgraded mhwd-nvidia-390xx (390.157-6 -> 390.157-7)
[2023-07-12T08:59:14+0200] [ALPM] upgraded mhwd-nvidia-470xx (470.182.03-2 -> 470.199.02-2)
[2023-07-12T08:59:14+0200] [ALPM] upgraded mhwd-db (0.6.5-25 -> 0.6.5-26)
[2023-07-12T08:59:14+0200] [ALPM] upgraded mhwd (0.6.5-25 -> 0.6.5-26)
[2023-07-12T08:59:14+0200] [ALPM-SCRIPTLET] xorg configuration symlink valid...
[2023-07-12T08:59:14+0200] [ALPM] upgraded mpd (0.23.12-3 -> 0.23.13-2)
[2023-07-12T08:59:14+0200] [ALPM] upgraded namcap (3.4.0-3 -> 3.4.2-1)
[2023-07-12T08:59:14+0200] [ALPM] upgraded pcsclite (1.9.9-3 -> 2.0.0-1)
[2023-07-12T08:59:14+0200] [ALPM] upgraded openconnect (1:9.10-1 -> 1:9.12-1)
[2023-07-12T08:59:14+0200] [ALPM] upgraded networkmanager-openconnect (1.2.8-2 -> 1.2.10-1)
[2023-07-12T08:59:14+0200] [ALPM] upgraded openvpn (2.6.4-1 -> 2.6.5-1)
[2023-07-12T08:59:14+0200] [ALPM] upgraded networkmanager-openvpn (1.10.2-1 -> 1.10.2-3)
[2023-07-12T08:59:14+0200] [ALPM] upgraded zeromq (4.3.4-2 -> 4.3.4-4)
[2023-07-12T08:59:14+0200] [ALPM] upgraded networkmanager-qt (5.106.0-1 -> 5.107.0-1)
[2023-07-12T08:59:14+0200] [ALPM] upgraded nmap (7.93-1 -> 7.94-1)
[2023-07-12T08:59:14+0200] [ALPM] upgraded nodejs (20.2.0-1 -> 20.3.1-2)
[2023-07-12T08:59:14+0200] [ALPM] upgraded nodejs-nopt (7.1.0-1 -> 7.2.0-1)
[2023-07-12T08:59:14+0200] [ALPM] upgraded node-gyp (9.3.1-1 -> 9.4.0-1)
[2023-07-12T08:59:15+0200] [ALPM] upgraded noto-fonts-extra (20230501-1 -> 1:23.7.1-1)
[2023-07-12T08:59:15+0200] [ALPM] upgraded npm (8.19.2-2 -> 9.8.0-1)
[2023-07-12T08:59:15+0200] [ALPM] upgraded ntp (4.2.8.p15-3 -> 4.2.8.p17-1)
[2023-07-12T08:59:15+0200] [ALPM] upgraded nvidia-settings (530.41.03-3 -> 535.54.03-1)
[2023-07-12T08:59:15+0200] [ALPM] installed libnvme (1.5-1)
[2023-07-12T08:59:15+0200] [ALPM] upgraded nvme-cli (2.4-2 -> 2.5-1)
[2023-07-12T08:59:16+0200] [ALPM] upgraded okular (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:59:16+0200] [ALPM] upgraded opencl-headers (2:2022.09.30-1 -> 2:2023.04.17-2)
[2023-07-12T08:59:16+0200] [ALPM] upgraded opencl-nvidia (530.41.03-4 -> 535.54.03-1)
[2023-07-12T08:59:16+0200] [ALPM] upgraded openresolv (3.13.1-1 -> 3.13.2-1)
[2023-07-12T08:59:16+0200] [ALPM] upgraded openssl-1.1 (1.1.1.t-1 -> 1.1.1.u-1)
[2023-07-12T08:59:16+0200] [ALPM] upgraded oxygen (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:59:17+0200] [ALPM] upgraded oxygen-icons (1:5.106.0-1 -> 1:5.107.0-1)
[2023-07-12T08:59:17+0200] [ALPM] upgraded pamac-cli (10.5.1-2 -> 11.0.0-2)
[2023-07-12T08:59:17+0200] [ALPM] installed libadwaita (1:1.3.3-1)
[2023-07-12T08:59:17+0200] [ALPM] upgraded pamac-gtk (10.5.1-2 -> 11.0.1-2)
[2023-07-12T08:59:17+0200] [ALPM] upgraded pamac-tray-icon-plasma (0.1.2-4 -> 0.1.3-1)
[2023-07-12T08:59:17+0200] [ALPM] upgraded parallel (20230422-1 -> 20230622-1)
[2023-07-12T08:59:17+0200] [ALPM] upgraded partitionmanager (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:59:17+0200] [ALPM] upgraded perl-io-socket-ssl (2.081-1 -> 2.083-1)
[2023-07-12T08:59:17+0200] [ALPM] upgraded polkit-kde-agent (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:59:17+0200] [ALPM] upgraded powerdevil (5.27.5-3 -> 5.27.6-3)
[2023-07-12T08:59:17+0200] [ALPM] upgraded plasma-desktop (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:59:17+0200] [ALPM] upgraded plasma-nm (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:59:17+0200] [ALPM] upgraded plasma-pa (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:59:17+0200] [ALPM] upgraded plasma-systemmonitor (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:59:18+0200] [ALPM] upgraded plasma-workspace-wallpapers (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:59:18+0200] [ALPM] upgraded plocate (1.1.18-1 -> 1.1.19-1)
[2023-07-12T08:59:18+0200] [ALPM] upgraded print-manager (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:59:18+0200] [ALPM] upgraded python-shiboken2 (5.15.9-5 -> 5.15.10-1)
[2023-07-12T08:59:18+0200] [ALPM] upgraded pyside2 (5.15.9-5 -> 5.15.10-1)
[2023-07-12T08:59:18+0200] [ALPM] upgraded vulkan-headers (1:1.3.248-1 -> 1:1.3.256-1)
[2023-07-12T08:59:18+0200] [ALPM] upgraded qt6-translations (6.5.0-1 -> 6.5.1-1)
[2023-07-12T08:59:18+0200] [ALPM] upgraded qt6-base (6.5.0-3 -> 6.5.1-5)
[2023-07-12T08:59:19+0200] [ALPM] upgraded qt6-declarative (6.5.0-2 -> 6.5.1-2)
[2023-07-12T08:59:19+0200] [ALPM] upgraded shiboken6 (6.5.0-2 -> 6.5.1.1-4)
[2023-07-12T08:59:19+0200] [ALPM] upgraded pyside6 (6.5.0-2 -> 6.5.1.1-4)
[2023-07-12T08:59:19+0200] [ALPM] upgraded python-cairo (1.23.0-4 -> 1.23.0-6)
[2023-07-12T08:59:19+0200] [ALPM] upgraded python-click (8.1.3-3 -> 8.1.4-1)
[2023-07-12T08:59:19+0200] [ALPM] upgraded python-numpy (1.24.3-2 -> 1.25.0-1)
[2023-07-12T08:59:19+0200] [ALPM] upgraded python-contourpy (1.0.7-3 -> 1.1.0-1)
[2023-07-12T08:59:19+0200] [ALPM] upgraded python-cryptography (40.0.2-1 -> 41.0.1-2)
[2023-07-12T08:59:19+0200] [ALPM] upgraded python-fastjsonschema (2.16.3-4 -> 2.17.1-1)
[2023-07-12T08:59:19+0200] [ALPM] upgraded python-fonttools (4.39.4-1 -> 4.40.0-1)
[2023-07-12T08:59:19+0200] [ALPM] upgraded python-typing_extensions (4.5.0-4 -> 4.7.0-1)
[2023-07-12T08:59:19+0200] [ALPM] upgraded python-pydantic (1.10.7-4 -> 1.10.9-1)
[2023-07-12T08:59:19+0200] [ALPM] upgraded python-inflect (6.0.4-2 -> 6.1.0-1)
[2023-07-12T08:59:19+0200] [ALPM] upgraded python-jaraco.functools (3.6.0-3 -> 3.8.0-1)
[2023-07-12T08:59:19+0200] [ALPM] upgraded tmux (3.3_a-3 -> 3.3_a-7)
[2023-07-12T08:59:19+0200] [ALPM] upgraded python-libtmux (0.21.1-2 -> 0.22.1-1)
[2023-07-12T08:59:19+0200] [ALPM] upgraded python-markupsafe (2.1.2-3 -> 2.1.3-1)
[2023-07-12T08:59:20+0200] [ALPM] upgraded python-pillow (9.5.0-2 -> 10.0.0-1)
[2023-07-12T08:59:20+0200] [ALPM] upgraded python-pooch (1.7.0-2 -> 1.7.0-3)
[2023-07-12T08:59:20+0200] [ALPM] upgraded python-pyopenssl (23.1.1-2 -> 23.2.0-1)
[2023-07-12T08:59:20+0200] [ALPM] upgraded python-pysmbc (1.0.23-4 -> 1.0.25.1-1)
[2023-07-12T08:59:20+0200] [ALPM] upgraded python-scipy (1.10.1-3 -> 1.11.1-1)
[2023-07-12T08:59:20+0200] [ALPM] upgraded python-trove-classifiers (2023.4.25-1 -> 2023.7.6-1)
[2023-07-12T08:59:20+0200] [ALPM] upgraded python-validate-pyproject (0.12.2-4 -> 0.13-1)
[2023-07-12T08:59:20+0200] [ALPM] upgraded python-setuptools (1:67.7.0-1 -> 1:68.0.0-1)
[2023-07-12T08:59:20+0200] [ALPM] upgraded qemu-img (8.0.0-1 -> 8.0.2-1)
[2023-07-12T08:59:20+0200] [ALPM] upgraded qt5-charts (5.15.9-1 -> 5.15.10-1)
[2023-07-12T08:59:23+0200] [ALPM] upgraded qt5-doc (5.15.8-1 -> 5.15.10-1)
[2023-07-12T08:59:23+0200] [ALPM] upgraded qt5-imageformats (5.15.9+kde+r9-1 -> 5.15.10+kde+r9-1)
[2023-07-12T08:59:23+0200] [ALPM] upgraded qt5-remoteobjects (5.15.9-1 -> 5.15.10-1)
[2023-07-12T08:59:23+0200] [ALPM] upgraded qt5-script (5.15.13-2 -> 5.15.14-2)
[2023-07-12T08:59:23+0200] [ALPM] upgraded qt5-virtualkeyboard (5.15.9-1 -> 5.15.10-1)
[2023-07-12T08:59:23+0200] [ALPM] upgraded qt5-websockets (5.15.9+kde+r2-1 -> 5.15.10+kde+r2-1)
[2023-07-12T08:59:23+0200] [ALPM] upgraded qt5-xmlpatterns (5.15.9-1 -> 5.15.10-1)
[2023-07-12T08:59:23+0200] [ALPM] upgraded qt6-multimedia-ffmpeg (6.5.0-1 -> 6.5.1-1)
[2023-07-12T08:59:23+0200] [ALPM] upgraded qt6-multimedia (6.5.0-1 -> 6.5.1-1)
[2023-07-12T08:59:23+0200] [ALPM] upgraded qt6-positioning (6.5.0-1 -> 6.5.1-1)
[2023-07-12T08:59:23+0200] [ALPM] upgraded qt6-svg (6.5.0-1 -> 6.5.1-1)
[2023-07-12T08:59:23+0200] [ALPM] upgraded qt6-webchannel (6.5.0-1 -> 6.5.1-1)
[2023-07-12T08:59:24+0200] [ALPM] upgraded qt6-webengine (6.5.0-2 -> 6.5.1-2)
[2023-07-12T08:59:25+0200] [ALPM] upgraded rclone (1.62.2-2 -> 1.63.0-1)
[2023-07-12T08:59:25+0200] [ALPM] upgraded rpi-imager (1.7.4.1-1 -> 1.7.5-1)
[2023-07-12T08:59:25+0200] [ALPM] upgraded ruby-test-unit (3.5.8-1 -> 3.5.9-1)
[2023-07-12T08:59:25+0200] [ALPM] upgraded ruby-bundler (2.4.12-1 -> 2.4.13-1)
[2023-07-12T08:59:25+0200] [ALPM] warning: /etc/pam.d/sddm installed as /etc/pam.d/sddm.pacnew
[2023-07-12T08:59:25+0200] [ALPM] upgraded sddm (0.19.0-9 -> 0.20.0-1)
[2023-07-12T08:59:25+0200] [ALPM] upgraded sddm-kcm (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:59:25+0200] [ALPM] upgraded sdl12-compat (1.2.60-1 -> 1.2.64-1)
[2023-07-12T08:59:25+0200] [ALPM] upgraded shellcheck (0.9.0-37 -> 0.9.0-44)
[2023-07-12T08:59:25+0200] [ALPM] upgraded shiny-mirrors (r246.094dc04-1 -> r264.2e08146-1)
[2023-07-12T08:59:25+0200] [ALPM] upgraded skanlite (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:59:25+0200] [ALPM] upgraded smplayer (22.7.0-2 -> 23.6.0-1)
[2023-07-12T08:59:25+0200] [ALPM] upgraded speedtest-cli (2.1.3-6 -> 2.1.3-7)
[2023-07-12T08:59:25+0200] [ALPM] upgraded squashfuse (0.1.105-1 -> 0.2.0-1)
[2023-07-12T08:59:25+0200] [ALPM] upgraded startup-notification (0.12-7 -> 0.12-8)
[2023-07-12T08:59:25+0200] [ALPM] upgraded usbutils (015-2 -> 015-3)
[2023-07-12T08:59:25+0200] [ALPM] upgraded xdg-desktop-portal-kde (5.27.5-1 -> 5.27.6-1)
[2023-07-12T08:59:26+0200] [ALPM] upgraded steam (1.0.0.78-1 -> 1.0.0.78-2)
[2023-07-12T08:59:26+0200] [ALPM] upgraded strawberry (1.0.17-2 -> 1.0.18-2)
[2023-07-12T08:59:26+0200] [ALPM] upgraded syncthing (1.23.4-2 -> 1.23.6-1)
[2023-07-12T08:59:26+0200] [ALPM] upgraded systemd-sysvcompat (253.4-1 -> 253.5-2)
[2023-07-12T08:59:26+0200] [ALPM] upgraded vte-common (0.72.1-1 -> 0.72.2-2)
[2023-07-12T08:59:26+0200] [ALPM] upgraded vte3 (0.72.1-1 -> 0.72.2-2)
[2023-07-12T08:59:26+0200] [ALPM] upgraded xapp (2.4.3-2 -> 2.6.1-1)
[2023-07-12T08:59:26+0200] [ALPM] upgraded timeshift (22.11.2-1 -> 23.06.2-1)
[2023-07-12T08:59:26+0200] [ALPM-SCRIPTLET] TimeShift automatic backups require the cronie.service to be running.
[2023-07-12T08:59:26+0200] [ALPM-SCRIPTLET] Try:
[2023-07-12T08:59:26+0200] [ALPM-SCRIPTLET]   systemctl enable --now cronie.service
[2023-07-12T08:59:26+0200] [ALPM] upgraded tmuxp (1.27.1-4 -> 1.28.1-1)
[2023-07-12T08:59:26+0200] [ALPM] upgraded tree (2.1.0-1 -> 2.1.1-1)
[2023-07-12T08:59:26+0200] [ALPM] upgraded ttf-nerd-fonts-symbols-common (3.0.1-1 -> 3.0.2-1)
[2023-07-12T08:59:26+0200] [ALPM] upgraded ttf-nerd-fonts-symbols (3.0.1-1 -> 3.0.2-1)
[2023-07-12T08:59:29+0200] [ALPM] upgraded ttf-noto-nerd (3.0.1-1 -> 3.0.2-1)
[2023-07-12T08:59:29+0200] [ALPM] upgraded unarchiver (1.10.7-8 -> 1.10.7-9)
[2023-07-12T08:59:30+0200] [ALPM] upgraded webkit2gtk (2.40.1-2 -> 2.40.3-1)
[2023-07-12T08:59:30+0200] [ALPM] upgraded webkit2gtk-4.1 (2.40.1-2 -> 2.40.3-1)
[2023-07-12T08:59:30+0200] [ALPM] upgraded wget (1.21.3-1 -> 1.21.4-1)
[2023-07-12T08:59:33+0200] [ALPM] upgraded wine-staging (8.8-1 -> 8.11-1)
[2023-07-12T08:59:35+0200] [ALPM] upgraded wine-mono (7.4.0-1 -> 8.0.0-1)
[2023-07-12T08:59:35+0200] [ALPM] upgraded xclip (0.13-3 -> 0.13-4)
[2023-07-12T08:59:35+0200] [ALPM] upgraded xfsprogs (6.2.0-1 -> 6.3.0-2)
[2023-07-12T08:59:35+0200] [ALPM] upgraded xterm (380-1 -> 383-1)
[2023-07-12T08:59:35+0200] [ALPM] upgraded yad (12.3-1 -> 13.0-1)
[2023-07-12T08:59:35+0200] [ALPM] upgraded yakuake (23.04.1-1 -> 23.04.3-1)
[2023-07-12T08:59:35+0200] [ALPM] upgraded yt-dlp (2023.03.04-2 -> 2023.07.06-1)
[2023-07-12T08:59:35+0200] [ALPM] upgraded zsh (5.9-3 -> 5.9-4)
[2023-07-12T08:59:35+0200] [ALPM] upgraded zsh-theme-powerlevel10k (1.18.0-1 -> 1.19.0-1)
[2023-07-12T08:59:36+0200] [ALPM] transaction completed
[2023-07-12T08:59:45+0200] [ALPM] running '20-systemd-sysusers.hook'...
[2023-07-12T08:59:45+0200] [ALPM] running '30-systemd-binfmt.hook'...
[2023-07-12T08:59:45+0200] [ALPM] running '30-systemd-catalog.hook'...
[2023-07-12T08:59:45+0200] [ALPM] running '30-systemd-daemon-reload.hook'...
[2023-07-12T08:59:46+0200] [ALPM] running '30-systemd-hwdb.hook'...
[2023-07-12T08:59:46+0200] [ALPM] running '30-systemd-sysctl.hook'...
[2023-07-12T08:59:46+0200] [ALPM] running '30-systemd-tmpfiles.hook'...
[2023-07-12T08:59:46+0200] [ALPM] running '30-systemd-udev-reload.hook'...
[2023-07-12T08:59:47+0200] [ALPM] running '30-systemd-update.hook'...
[2023-07-12T08:59:47+0200] [ALPM] running '30-update-mime-database.hook'...
[2023-07-12T08:59:47+0200] [ALPM] running '40-update-ca-trust.hook'...
[2023-07-12T08:59:48+0200] [ALPM] running '60-depmod.hook'...
[2023-07-12T09:00:01+0200] [ALPM] running '70-dkms-install.hook'...
[2023-07-12T09:00:01+0200] [ALPM-SCRIPTLET] ==> dkms install --no-depmod vboxhost/7.0.8_OSE -k 5.15.120-1-MANJARO
[2023-07-12T09:00:07+0200] [ALPM-SCRIPTLET] ==> dkms install --no-depmod vboxhost/7.0.8_OSE -k 6.3.12-1-MANJARO
[2023-07-12T09:00:12+0200] [ALPM-SCRIPTLET] ==> dkms install --no-depmod vboxhost/7.0.8_OSE -k 6.1.38-1-MANJARO
[2023-07-12T09:00:18+0200] [ALPM-SCRIPTLET] ==> depmod 6.1.38-1-MANJARO
[2023-07-12T09:00:21+0200] [ALPM-SCRIPTLET] ==> depmod 5.15.120-1-MANJARO
[2023-07-12T09:00:28+0200] [ALPM-SCRIPTLET] ==> depmod 6.3.12-1-MANJARO
[2023-07-12T09:00:31+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2023-07-12T09:00:31+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
[2023-07-12T09:00:31+0200] [ALPM-SCRIPTLET] ==> Using configuration file: '/etc/mkinitcpio.conf'
[2023-07-12T09:00:31+0200] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
[2023-07-12T09:00:31+0200] [ALPM-SCRIPTLET] ==> Starting build: '5.15.120-1-MANJARO'
[2023-07-12T09:00:31+0200] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-07-12T09:00:31+0200] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-07-12T09:00:32+0200] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2023-07-12T09:00:32+0200] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-07-12T09:00:32+0200] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2023-07-12T09:00:33+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-07-12T09:00:34+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-07-12T09:00:34+0200] [ALPM-SCRIPTLET] loadkeys: Unable to open file: za: No such file or directory
[2023-07-12T09:00:34+0200] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-07-12T09:00:34+0200] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-07-12T09:00:34+0200] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-07-12T09:00:35+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-07-12T09:00:35+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-5.15-x86_64.img'
[2023-07-12T09:00:35+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-07-12T09:00:35+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
[2023-07-12T09:00:35+0200] [ALPM-SCRIPTLET] ==> Using configuration file: '/etc/mkinitcpio.conf'
[2023-07-12T09:00:35+0200] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
[2023-07-12T09:00:35+0200] [ALPM-SCRIPTLET] ==> Starting build: '5.15.120-1-MANJARO'
[2023-07-12T09:00:35+0200] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-07-12T09:00:35+0200] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-07-12T09:00:35+0200] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-07-12T09:00:35+0200] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2023-07-12T09:00:37+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'ast'
[2023-07-12T09:00:40+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-07-12T09:00:41+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-07-12T09:00:41+0200] [ALPM-SCRIPTLET] loadkeys: Unable to open file: za: No such file or directory
[2023-07-12T09:00:41+0200] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-07-12T09:00:43+0200] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-07-12T09:00:44+0200] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-07-12T09:00:47+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-07-12T09:00:47+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-5.15-x86_64-fallback.img'
[2023-07-12T09:00:48+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-07-12T09:00:48+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
[2023-07-12T09:00:48+0200] [ALPM-SCRIPTLET] ==> Using configuration file: '/etc/mkinitcpio.conf'
[2023-07-12T09:00:48+0200] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64.img
[2023-07-12T09:00:48+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.1.38-1-MANJARO'
[2023-07-12T09:00:48+0200] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-07-12T09:00:48+0200] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-07-12T09:00:48+0200] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2023-07-12T09:00:48+0200] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-07-12T09:00:48+0200] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2023-07-12T09:00:50+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-07-12T09:00:50+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2023-07-12T09:00:50+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-07-12T09:00:50+0200] [ALPM-SCRIPTLET] loadkeys: Unable to open file: za: No such file or directory
[2023-07-12T09:00:50+0200] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-07-12T09:00:51+0200] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-07-12T09:00:51+0200] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-07-12T09:00:51+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-07-12T09:00:51+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.1-x86_64.img'
[2023-07-12T09:00:51+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-07-12T09:00:51+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
[2023-07-12T09:00:51+0200] [ALPM-SCRIPTLET] ==> Using configuration file: '/etc/mkinitcpio.conf'
[2023-07-12T09:00:51+0200] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect
[2023-07-12T09:00:51+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.1.38-1-MANJARO'
[2023-07-12T09:00:51+0200] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-07-12T09:00:52+0200] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-07-12T09:00:52+0200] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-07-12T09:00:52+0200] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2023-07-12T09:00:54+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'ast'
[2023-07-12T09:00:56+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-07-12T09:00:56+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2023-07-12T09:00:57+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-07-12T09:00:57+0200] [ALPM-SCRIPTLET] loadkeys: Unable to open file: za: No such file or directory
[2023-07-12T09:00:57+0200] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-07-12T09:00:59+0200] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-07-12T09:01:00+0200] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-07-12T09:01:01+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-07-12T09:01:01+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.1-x86_64-fallback.img'
[2023-07-12T09:01:02+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-07-12T09:01:02+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux63.preset: 'default'
[2023-07-12T09:01:02+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2023-07-12T09:01:02+0200] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.3-x86_64 -g /boot/initramfs-6.3-x86_64.img --microcode /boot/intel-ucode.img
[2023-07-12T09:01:02+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.3.12-1-MANJARO'
[2023-07-12T09:01:02+0200] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-07-12T09:01:02+0200] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-07-12T09:01:03+0200] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2023-07-12T09:01:03+0200] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-07-12T09:01:03+0200] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2023-07-12T09:01:05+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-07-12T09:01:05+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2023-07-12T09:01:05+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-07-12T09:01:05+0200] [ALPM-SCRIPTLET] loadkeys: Unable to open file: za: No such file or directory
[2023-07-12T09:01:05+0200] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-07-12T09:01:06+0200] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-07-12T09:01:06+0200] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-07-12T09:01:06+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-07-12T09:01:06+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.3-x86_64.img'
[2023-07-12T09:01:06+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-07-12T09:01:06+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux63.preset: 'fallback'
[2023-07-12T09:01:06+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2023-07-12T09:01:06+0200] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.3-x86_64 -g /boot/initramfs-6.3-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
[2023-07-12T09:01:06+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.3.12-1-MANJARO'
[2023-07-12T09:01:06+0200] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-07-12T09:01:06+0200] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-07-12T09:01:07+0200] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-07-12T09:01:07+0200] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2023-07-12T09:01:09+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'ast'
[2023-07-12T09:01:12+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-07-12T09:01:12+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2023-07-12T09:01:12+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-07-12T09:01:12+0200] [ALPM-SCRIPTLET] loadkeys: Unable to open file: za: No such file or directory
[2023-07-12T09:01:12+0200] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-07-12T09:01:15+0200] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-07-12T09:01:15+0200] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-07-12T09:01:17+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-07-12T09:01:17+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.3-x86_64-fallback.img'
[2023-07-12T09:01:17+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-07-12T09:01:17+0200] [ALPM] running '90-nvidia-utils.hook'...
[2023-07-12T09:01:17+0200] [ALPM] running '90-packagekit-refresh.hook'...
[2023-07-12T09:01:17+0200] [ALPM] running '90-update-appstream-cache.hook'...
[2023-07-12T09:01:18+0200] [ALPM-SCRIPTLET]
[2023-07-12T09:01:18+0200] [ALPM-SCRIPTLET] ** (appstreamcli:274596): WARNING **: 09:01:18.682: Found icon of unknown type 'unknown' in 'system/flatpak/flatpak/cc.nift.nsm/*', skipping it.
[2023-07-12T09:01:19+0200] [ALPM-SCRIPTLET] ✔ Metadata cache was updated successfully.
[2023-07-12T09:01:19+0200] [ALPM] running '99-grub.hook'...
[2023-07-12T09:01:20+0200] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2023-07-12T09:01:20+0200] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/Stylish/theme.txt
[2023-07-12T09:01:20+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-6.3-x86_64
[2023-07-12T09:01:20+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.3-x86_64.img
[2023-07-12T09:01:20+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-6.3-x86_64-fallback.img
[2023-07-12T09:01:20+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-6.1-x86_64
[2023-07-12T09:01:20+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
[2023-07-12T09:01:20+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
[2023-07-12T09:01:20+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.15-x86_64
[2023-07-12T09:01:20+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
[2023-07-12T09:01:20+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
[2023-07-12T09:01:20+0200] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2023-07-12T09:01:20+0200] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2023-07-12T09:01:21+0200] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2023-07-12T09:01:21+0200] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2023-07-12T09:01:21+0200] [ALPM-SCRIPTLET] /usr/bin/grub-probe: warning: unknown device type nvme0n1.
[2023-07-12T09:01:21+0200] [ALPM-SCRIPTLET] done
[2023-07-12T09:01:21+0200] [ALPM] running 'code-marketplace.hook'...
[2023-07-12T09:01:21+0200] [ALPM] running 'dbus-reload.hook'...
[2023-07-12T09:01:21+0200] [ALPM] running 'detect-old-perl-modules.hook'...
[2023-07-12T09:01:21+0200] [ALPM] running 'firefox-dev-post.hook'...
[2023-07-12T09:01:21+0200] [ALPM] running 'fontconfig.hook'...
[2023-07-12T09:01:22+0200] [ALPM] running 'fontconfig-32.hook'...
[2023-07-12T09:01:22+0200] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2023-07-12T09:01:22+0200] [ALPM] running 'gdk-pixbuf-query-loaders-32.hook'...
[2023-07-12T09:01:22+0200] [ALPM] running 'ghc-register.hook'...
[2023-07-12T09:01:23+0200] [ALPM] running 'gio-querymodules.hook'...
[2023-07-12T09:01:23+0200] [ALPM] running 'glib-compile-schemas.hook'...
[2023-07-12T09:01:23+0200] [ALPM] running 'gtk-query-immodules-3.0.hook'...
[2023-07-12T09:01:23+0200] [ALPM] running 'gtk-query-immodules-3.0-32.hook'...
[2023-07-12T09:01:24+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2023-07-12T09:01:24+0200] [ALPM] running 'gtk4-querymodules.hook'...
[2023-07-12T09:01:24+0200] [ALPM] running 'gvfsd.hook'...
[2023-07-12T09:01:24+0200] [ALPM] running 'kernel-alive-post.hook'...
[2023-07-12T09:01:24+0200] [ALPM-SCRIPTLET]
[2023-07-12T09:01:24+0200] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m Warning:
[2023-07-12T09:01:24+0200] [ALPM-SCRIPTLET] 	 -> This computer hasn't been restarted for a while.
[2023-07-12T09:01:24+0200] [ALPM-SCRIPTLET] 	 -> You are running an old kernel. In order to use a
[2023-07-12T09:01:24+0200] [ALPM-SCRIPTLET] 	 -> new version of the kernel, please restart your
[2023-07-12T09:01:24+0200] [ALPM-SCRIPTLET] 	 -> computer as soon as possible.
[2023-07-12T09:01:24+0200] [ALPM-SCRIPTLET] 	e[1;0m
[2023-07-12T09:01:24+0200] [ALPM] running 'manjaro-printer.hook'...
[2023-07-12T09:01:24+0200] [ALPM] running 'pacman-backup.hook'...
[2023-07-12T09:01:24+0200] [ALPM] running 'pacnew-notifier.hook'...
[2023-07-12T09:01:25+0200] [ALPM-SCRIPTLET] e[1m.pac* files found:e[0m
[2023-07-12T09:01:25+0200] [ALPM-SCRIPTLET] /etc/cups/cupsd.conf.pacnew
[2023-07-12T09:01:25+0200] [ALPM-SCRIPTLET] /etc/pacman.conf.pacnew
[2023-07-12T09:01:25+0200] [ALPM-SCRIPTLET] /etc/pam.d/sddm.pacnew
[2023-07-12T09:01:25+0200] [ALPM-SCRIPTLET] e[1mPlease check and mergee[0m
[2023-07-12T09:01:25+0200] [ALPM] running 'rebuild-detector.hook'...
[2023-07-12T09:01:25+0200] [ALPM-SCRIPTLET] parallel: Warning: $HOME not set. Using /tmp.
[2023-07-12T09:01:45+0200] [ALPM-SCRIPTLET] foreign	electron19
[2023-07-12T09:01:45+0200] [ALPM-SCRIPTLET] foreign	gwe
[2023-07-12T09:01:45+0200] [ALPM-SCRIPTLET] foreign	librewolf-bin
[2023-07-12T09:01:45+0200] [ALPM-SCRIPTLET] foreign	pineapple-pictures
[2023-07-12T09:01:45+0200] [ALPM-SCRIPTLET] foreign	python-injector
[2023-07-12T09:01:45+0200] [ALPM-SCRIPTLET] foreign	python-py3nvml
[2023-07-12T09:01:45+0200] [ALPM-SCRIPTLET] foreign	python-pynput
[2023-07-12T09:01:45+0200] [ALPM-SCRIPTLET] foreign	qt5-webkit
[2023-07-12T09:01:45+0200] [ALPM-SCRIPTLET] foreign	teamviewer14
[2023-07-12T09:01:45+0200] [ALPM-SCRIPTLET] foreign	waterfox-g5-bin
[2023-07-12T09:01:45+0200] [ALPM] running 'texinfo-install.hook'...
[2023-07-12T09:01:45+0200] [ALPM] running 'update-desktop-database.hook'...
[2023-07-12T09:02:16+0200] [PAMAC] synchronizing package lists
[2023-07-12T09:06:33+0200] [ALPM] transaction started
[2023-07-12T09:06:33+0200] [ALPM] upgraded ckb-next (0.5.0-3 -> 0.6.0-1)
[2023-07-12T09:06:33+0200] [ALPM] upgraded google-chrome (114.0.5735.106-1 -> 114.0.5735.198-1)
[2023-07-12T09:06:35+0200] [ALPM] upgraded android-platform (33_r02-1 -> 34_r01-1)
[2023-07-12T09:06:35+0200] [ALPM] upgraded lutris-wine-meta (2.1.0-4 -> 2.1.0-5)
[2023-07-12T09:06:36+0200] [ALPM] upgraded skypeforlinux-stable-bin (8.98.0.206-1 -> 8.99.0.403-1)
[2023-07-12T09:06:36+0200] [ALPM] upgraded ntfsprogs-ntfs3 (2022.10.3-1 -> 2022.10.3-3)
[2023-07-12T09:06:36+0200] [ALPM] upgraded tor-browser (12.0.6-1 -> 12.5.1-1)
[2023-07-12T09:06:36+0200] [ALPM-SCRIPTLET]
[2023-07-12T09:06:36+0200] [ALPM-SCRIPTLET] ==> The copy of Tor Browser in your home directory will be upgraded at the
[2023-07-12T09:06:36+0200] [ALPM-SCRIPTLET] ==> first time you run it as your normal user. Just start it and have fun!
[2023-07-12T09:06:36+0200] [ALPM] upgraded pineapple-pictures (0.6.9-1 -> 0.7.1-1)
[2023-07-12T09:06:36+0200] [ALPM] upgraded rustdesk-bin (1.1.9-3 -> 1.2.0-2)
[2023-07-12T09:06:36+0200] [ALPM] upgraded signal-desktop-beta-bin (6.20.0beta.1-1 -> 6.25.0beta.1-1)
[2023-07-12T09:06:37+0200] [ALPM] upgraded brave-bin (1:1.52.117-1 -> 1:1.52.130-1)
[2023-07-12T09:06:38+0200] [ALPM] upgraded github-desktop-bin (3.2.1_linux1-1 -> 3.2.5_linux1-1)
[2023-07-12T09:06:38+0200] [ALPM] transaction completed
[2023-07-12T09:06:38+0200] [ALPM] running '30-systemd-daemon-reload.hook'...
[2023-07-12T09:06:38+0200] [ALPM] running '30-systemd-udev-reload.hook'...
[2023-07-12T09:06:39+0200] [ALPM] running '30-systemd-update.hook'...
[2023-07-12T09:06:39+0200] [ALPM] running '90-packagekit-refresh.hook'...
[2023-07-12T09:06:39+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2023-07-12T09:06:39+0200] [ALPM] running 'pacnew-notifier.hook'...
[2023-07-12T09:06:39+0200] [ALPM-SCRIPTLET] e[1m.pac* files found:e[0m
[2023-07-12T09:06:39+0200] [ALPM-SCRIPTLET] /etc/cups/cupsd.conf.pacnew
[2023-07-12T09:06:39+0200] [ALPM-SCRIPTLET] /etc/pacman.conf.pacnew
[2023-07-12T09:06:39+0200] [ALPM-SCRIPTLET] /etc/pam.d/sddm.pacnew
[2023-07-12T09:06:39+0200] [ALPM-SCRIPTLET] e[1mPlease check and mergee[0m
[2023-07-12T09:06:39+0200] [ALPM] running 'rebuild-detector.hook'...
[2023-07-12T09:06:39+0200] [ALPM-SCRIPTLET] parallel: Warning: $HOME not set. Using /tmp.
[2023-07-12T09:06:41+0200] [ALPM-SCRIPTLET] foreign	gwe
[2023-07-12T09:06:41+0200] [ALPM-SCRIPTLET] foreign	python-injector
[2023-07-12T09:06:41+0200] [ALPM-SCRIPTLET] foreign	python-py3nvml
[2023-07-12T09:06:41+0200] [ALPM-SCRIPTLET] foreign	python-pynput
[2023-07-12T09:06:41+0200] [ALPM] running 'update-desktop-database.hook'...
[2023-07-12T09:25:26+0200] [PAMAC] synchronizing package lists
[2023-07-12T09:25:51+0200] [ALPM] transaction started
[2023-07-12T09:25:51+0200] [ALPM] installed etc-update (2.3.99-2)
[2023-07-12T09:25:51+0200] [ALPM] installed dialog (1:1.3_20230209-1)
[2023-07-12T09:25:51+0200] [ALPM] transaction completed
[2023-07-12T09:25:51+0200] [ALPM] running '30-systemd-update.hook'...
[2023-07-12T09:25:51+0200] [ALPM] running '90-packagekit-refresh.hook'...
[2023-07-12T09:25:51+0200] [ALPM] running 'pacman-backup.hook'...
[2023-07-12T09:25:51+0200] [ALPM] running 'pacnew-notifier.hook'...
[2023-07-12T09:25:51+0200] [ALPM-SCRIPTLET] e[1m.pac* files found:e[0m
[2023-07-12T09:25:51+0200] [ALPM-SCRIPTLET] /etc/pacman.conf.pacnew
[2023-07-12T09:25:51+0200] [ALPM-SCRIPTLET] /etc/pam.d/sddm.pacnew
[2023-07-12T09:25:51+0200] [ALPM-SCRIPTLET] e[1mPlease check and mergee[0m
[2023-07-12T09:43:23+0200] [PACMAN] Running 'pacman -Syy'
[2023-07-12T09:43:23+0200] [PACMAN] synchronizing package lists
[2023-07-12T09:43:26+0200] [PACMAN] Running 'pacman -S linux64 linux64-headers linux64-nvidia'
[2023-07-12T09:43:50+0200] [ALPM] transaction started
[2023-07-12T09:43:51+0200] [ALPM] installed linux64 (6.4.2-3)
[2023-07-12T09:43:52+0200] [ALPM] installed linux64-headers (6.4.2-3)
[2023-07-12T09:43:52+0200] [ALPM] installed linux64-nvidia (535.54.03-12)
[2023-07-12T09:43:55+0200] [ALPM] transaction completed
[2023-07-12T09:43:55+0200] [ALPM] running '30-systemd-update.hook'...
[2023-07-12T09:43:55+0200] [ALPM] running '60-depmod.hook'...
[2023-07-12T09:43:58+0200] [ALPM] running '70-dkms-install.hook'...
[2023-07-12T09:43:58+0200] [ALPM-SCRIPTLET] ==> dkms install --no-depmod vboxhost/7.0.8_OSE -k 6.4.2-3-MANJARO
[2023-07-12T09:44:03+0200] [ALPM-SCRIPTLET] ==> depmod 6.4.2-3-MANJARO
[2023-07-12T09:44:06+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2023-07-12T09:44:06+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux64.preset: 'default'
[2023-07-12T09:44:06+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2023-07-12T09:44:06+0200] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.4-x86_64 -g /boot/initramfs-6.4-x86_64.img --microcode /boot/intel-ucode.img
[2023-07-12T09:44:06+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.4.2-3-MANJARO'
[2023-07-12T09:44:06+0200] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-07-12T09:44:06+0200] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-07-12T09:44:06+0200] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2023-07-12T09:44:06+0200] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-07-12T09:44:06+0200] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2023-07-12T09:44:08+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-07-12T09:44:08+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2023-07-12T09:44:08+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-07-12T09:44:08+0200] [ALPM-SCRIPTLET] loadkeys: Unable to open file: za: No such file or directory
[2023-07-12T09:44:08+0200] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-07-12T09:44:09+0200] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-07-12T09:44:09+0200] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-07-12T09:44:09+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-07-12T09:44:09+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.4-x86_64.img'
[2023-07-12T09:44:10+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-07-12T09:44:10+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux64.preset: 'fallback'
[2023-07-12T09:44:10+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2023-07-12T09:44:10+0200] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.4-x86_64 -g /boot/initramfs-6.4-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
[2023-07-12T09:44:10+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.4.2-3-MANJARO'
[2023-07-12T09:44:10+0200] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-07-12T09:44:10+0200] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-07-12T09:44:10+0200] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-07-12T09:44:10+0200] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2023-07-12T09:44:13+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'ast'
[2023-07-12T09:44:15+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-07-12T09:44:15+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2023-07-12T09:44:16+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-07-12T09:44:16+0200] [ALPM-SCRIPTLET] loadkeys: Unable to open file: za: No such file or directory
[2023-07-12T09:44:16+0200] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-07-12T09:44:18+0200] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-07-12T09:44:19+0200] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-07-12T09:44:20+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-07-12T09:44:20+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.4-x86_64-fallback.img'
[2023-07-12T09:44:21+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-07-12T09:44:21+0200] [ALPM] running '90-nvidia-utils.hook'...
[2023-07-12T09:44:21+0200] [ALPM] running '90-packagekit-refresh.hook'...
[2023-07-12T09:44:21+0200] [ALPM] running '99-grub.hook'...
[2023-07-12T09:44:22+0200] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2023-07-12T09:44:22+0200] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/Stylish/theme.txt
[2023-07-12T09:44:22+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-6.4-x86_64
[2023-07-12T09:44:22+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.4-x86_64.img
[2023-07-12T09:44:22+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-6.4-x86_64-fallback.img
[2023-07-12T09:44:22+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-6.3-x86_64
[2023-07-12T09:44:22+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.3-x86_64.img
[2023-07-12T09:44:22+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-6.3-x86_64-fallback.img
[2023-07-12T09:44:22+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-6.1-x86_64
[2023-07-12T09:44:22+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
[2023-07-12T09:44:22+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
[2023-07-12T09:44:22+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.15-x86_64
[2023-07-12T09:44:22+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
[2023-07-12T09:44:22+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
[2023-07-12T09:44:23+0200] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2023-07-12T09:44:23+0200] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2023-07-12T09:44:24+0200] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2023-07-12T09:44:24+0200] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2023-07-12T09:44:24+0200] [ALPM-SCRIPTLET] /usr/bin/grub-probe: warning: unknown device type nvme0n1.
[2023-07-12T09:44:24+0200] [ALPM-SCRIPTLET] done
[2023-07-12T09:44:24+0200] [ALPM] running 'pacman-backup.hook'...
[2023-07-12T09:44:24+0200] [ALPM] running 'pacnew-notifier.hook'...
[2023-07-12T09:47:07+0200] [PACMAN] Running 'pacman -R linux63 linux63-headers linux63-nvidia'
[2023-07-12T09:47:12+0200] [ALPM] running '60-mkinitcpio-remove.hook'...
[2023-07-12T09:47:12+0200] [ALPM] running '71-dkms-remove.hook'...
[2023-07-12T09:47:12+0200] [ALPM-SCRIPTLET] ==> dkms remove --no-depmod vboxhost/7.0.8_OSE -k 6.3.12-1-MANJARO
[2023-07-12T09:47:12+0200] [ALPM-SCRIPTLET] ==> depmod 6.3.12-1-MANJARO
[2023-07-12T09:47:16+0200] [ALPM] transaction started
[2023-07-12T09:47:16+0200] [ALPM] removed linux63-nvidia (535.54.03-12)
[2023-07-12T09:47:18+0200] [ALPM] removed linux63-headers (6.3.12-1)
[2023-07-12T09:47:18+0200] [ALPM] removed linux63 (6.3.12-1)
[2023-07-12T09:47:19+0200] [ALPM] transaction completed
[2023-07-12T09:47:19+0200] [ALPM] running '30-systemd-update.hook'...
[2023-07-12T09:47:19+0200] [ALPM] running '60-depmod.hook'...
[2023-07-12T09:47:19+0200] [ALPM] running '90-nvidia-utils.hook'...
[2023-07-12T09:47:19+0200] [ALPM] running '90-packagekit-refresh.hook'...
[2023-07-12T09:47:19+0200] [ALPM] running '99-grub.hook'...
[2023-07-12T09:47:19+0200] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2023-07-12T09:47:19+0200] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/Stylish/theme.txt
[2023-07-12T09:47:19+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-6.4-x86_64
[2023-07-12T09:47:19+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.4-x86_64.img
[2023-07-12T09:47:19+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-6.4-x86_64-fallback.img
[2023-07-12T09:47:19+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-6.1-x86_64
[2023-07-12T09:47:19+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
[2023-07-12T09:47:20+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
[2023-07-12T09:47:20+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.15-x86_64
[2023-07-12T09:47:20+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
[2023-07-12T09:47:20+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
[2023-07-12T09:47:20+0200] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2023-07-12T09:47:20+0200] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2023-07-12T09:47:21+0200] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2023-07-12T09:47:21+0200] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2023-07-12T09:47:21+0200] [ALPM-SCRIPTLET] /usr/bin/grub-probe: warning: unknown device type nvme0n1.
[2023-07-12T09:47:21+0200] [ALPM-SCRIPTLET] done
[2023-07-12T09:47:21+0200] [ALPM] running 'pacman-backup.hook'...
[2023-07-12T09:47:21+0200] [ALPM] running 'pacnew-notifier.hook'...
[2023-07-12T16:21:29+0200] [PACMAN] Running 'pacman -Syy'
[2023-07-12T16:21:29+0200] [PACMAN] synchronizing package lists
[2023-07-12T16:22:32+0200] [PAMAC] synchronizing package lists
[2023-07-13T12:17:44+0200] [ALPM] transaction started
[2023-07-13T12:17:44+0200] [ALPM] upgraded qt5-webkit (5.212.0alpha4-19 -> 5.212.0alpha4-20)
[2023-07-13T12:17:44+0200] [ALPM] transaction completed
[2023-07-13T12:17:44+0200] [ALPM] running '30-systemd-update.hook'...
[2023-07-13T12:17:44+0200] [ALPM] running '90-packagekit-refresh.hook'...
[2023-07-13T12:17:44+0200] [ALPM] running 'pacnew-notifier.hook'...
[2023-07-13T12:17:44+0200] [ALPM] running 'rebuild-detector.hook'...
[2023-07-13T12:17:44+0200] [ALPM-SCRIPTLET] parallel: Warning: $HOME not set. Using /tmp.
[2023-07-13T12:17:45+0200] [ALPM-SCRIPTLET] foreign	gwe
[2023-07-13T12:17:45+0200] [ALPM-SCRIPTLET] foreign	python-injector
[2023-07-13T12:17:45+0200] [ALPM-SCRIPTLET] foreign	python-py3nvml
[2023-07-13T12:17:45+0200] [ALPM-SCRIPTLET] foreign	python-pynput
[2023-07-14T09:10:41+0200] [ALPM] running 'texinfo-remove.hook'...
[2023-07-14T09:10:41+0200] [ALPM] transaction started
[2023-07-14T09:10:41+0200] [ALPM] removed python-build (0.10.0-4)
[2023-07-14T09:10:41+0200] [ALPM] removed libhandy (1.8.2-1)
[2023-07-14T09:10:41+0200] [ALPM] removed ttf-noto-nerd (3.0.2-1)
[2023-07-14T09:10:41+0200] [ALPM] removed python-pyproject-hooks (1.0.0-5)
[2023-07-14T09:10:41+0200] [ALPM] removed electron19 (19.1.9-5)
[2023-07-14T09:10:41+0200] [ALPM] removed electron (1:25-1)
[2023-07-14T09:10:41+0200] [ALPM] removed electron25 (25.2.1-1)
[2023-07-14T09:10:41+0200] [ALPM] removed python-pynput (1.7.6-2)
[2023-07-14T09:10:41+0200] [ALPM] removed libindicator-gtk3 (12.10.1-10)
[2023-07-14T09:10:41+0200] [ALPM] removed python-installer (0.7.0-3)
[2023-07-14T09:10:42+0200] [ALPM] removed qt5-doc (5.15.10-1)
[2023-07-14T09:10:42+0200] [ALPM] removed libsidplay (1.36.59-10)
[2023-07-14T09:10:42+0200] [ALPM] removed gperf (3.1-4)
[2023-07-14T09:10:42+0200] [ALPM] removed wimlib (1.14.1-1)
[2023-07-14T09:10:42+0200] [ALPM] removed go (2:1.20.5-1)
[2023-07-14T09:10:42+0200] [ALPM] removed extra-cmake-modules (5.107.0-1)
[2023-07-14T09:10:43+0200] [ALPM] removed cmake (3.26.4-1)
[2023-07-14T09:10:43+0200] [ALPM] removed rhash (1.4.3-1)
[2023-07-14T09:10:43+0200] [ALPM] transaction completed
[2023-07-14T09:10:43+0200] [ALPM] running '30-systemd-update.hook'...
[2023-07-14T09:10:43+0200] [ALPM] running '30-update-mime-database.hook'...
[2023-07-14T09:10:43+0200] [ALPM] running '90-packagekit-refresh.hook'...
[2023-07-14T09:10:43+0200] [ALPM] running 'fontconfig.hook'...
[2023-07-14T09:10:43+0200] [ALPM] running 'fontconfig-32.hook'...
[2023-07-14T09:10:43+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2023-07-14T09:10:44+0200] [ALPM] running 'pacman-backup.hook'...
[2023-07-14T09:10:44+0200] [ALPM] running 'pacnew-notifier.hook'...
[2023-07-14T09:10:44+0200] [ALPM] running 'update-desktop-database.hook'...
[2023-07-14T09:12:05+0200] [PAMAC] synchronizing package lists
[2023-07-14T09:12:43+0200] [ALPM] transaction started
[2023-07-14T09:12:43+0200] [ALPM] upgraded chromium (114.0.5735.198-2 -> 115.0.5790.90-1)
[2023-07-14T09:12:43+0200] [ALPM] installed libsecp256k1 (1:0.3.2-2)
[2023-07-14T09:12:44+0200] [ALPM] installed opendht (1:2.5.5-1)
[2023-07-14T09:12:44+0200] [ALPM] installed jami-daemon (20230323-2)
[2023-07-14T09:12:44+0200] [ALPM] installed qt6-5compat (6.5.1-2)
[2023-07-14T09:12:44+0200] [ALPM] installed qt6-shadertools (6.5.1-1)
[2023-07-14T09:12:44+0200] [ALPM] installed jami-qt (20230323-2)
[2023-07-14T09:12:44+0200] [ALPM] transaction completed
[2023-07-14T09:12:44+0200] [ALPM] running '30-systemd-daemon-reload.hook'...
[2023-07-14T09:12:44+0200] [ALPM] running '30-systemd-update.hook'...
[2023-07-14T09:12:44+0200] [ALPM] running '90-packagekit-refresh.hook'...
[2023-07-14T09:12:44+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2023-07-14T09:12:44+0200] [ALPM] running 'pacman-backup.hook'...
[2023-07-14T09:12:44+0200] [ALPM] running 'pacnew-notifier.hook'...
[2023-07-14T09:12:44+0200] [ALPM] running 'rebuild-detector.hook'...
[2023-07-14T09:12:44+0200] [ALPM-SCRIPTLET] parallel: Warning: $HOME not set. Using /tmp.
[2023-07-14T09:12:45+0200] [ALPM-SCRIPTLET] foreign	gwe
[2023-07-14T09:12:45+0200] [ALPM-SCRIPTLET] foreign	python-injector
[2023-07-14T09:12:45+0200] [ALPM-SCRIPTLET] foreign	python-py3nvml
[2023-07-14T09:12:45+0200] [ALPM] running 'update-desktop-database.hook'...
[2023-07-14T17:08:19+0200] [PAMAC] synchronizing package lists
[2023-07-14T17:08:45+0200] [ALPM] transaction started
[2023-07-14T17:08:45+0200] [ALPM] upgraded networkmanager-strongswan (1.6.0-1 -> 1.6.0-1.0)
[2023-07-14T17:08:45+0200] [ALPM] transaction completed
[2023-07-14T17:08:45+0200] [ALPM] running '30-systemd-update.hook'...
[2023-07-14T17:08:45+0200] [ALPM] running '90-packagekit-refresh.hook'...
[2023-07-14T17:08:45+0200] [ALPM] running 'pacnew-notifier.hook'...
[2023-07-14T17:08:46+0200] [ALPM] running 'rebuild-detector.hook'...
[2023-07-14T17:08:46+0200] [ALPM-SCRIPTLET] parallel: Warning: $HOME not set. Using /tmp.
[2023-07-14T17:08:47+0200] [ALPM-SCRIPTLET] foreign	gwe
[2023-07-14T17:08:47+0200] [ALPM-SCRIPTLET] foreign	python-injector
[2023-07-14T17:08:47+0200] [ALPM-SCRIPTLET] foreign	python-py3nvml
[2023-07-14T17:09:03+0200] [ALPM] transaction started
[2023-07-14T17:09:04+0200] [ALPM] upgraded signal-desktop-beta-bin (6.25.0beta.1-1 -> 6.26.0beta.1-1)
[2023-07-14T17:09:04+0200] [ALPM] transaction completed
[2023-07-14T17:09:04+0200] [ALPM] running '30-systemd-update.hook'...
[2023-07-14T17:09:04+0200] [ALPM] running '90-packagekit-refresh.hook'...
[2023-07-14T17:09:04+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2023-07-14T17:09:04+0200] [ALPM] running 'pacnew-notifier.hook'...
[2023-07-14T17:09:04+0200] [ALPM] running 'rebuild-detector.hook'...
[2023-07-14T17:09:04+0200] [ALPM-SCRIPTLET] parallel: Warning: $HOME not set. Using /tmp.
[2023-07-14T17:09:05+0200] [ALPM-SCRIPTLET] foreign	gwe
[2023-07-14T17:09:05+0200] [ALPM-SCRIPTLET] foreign	python-injector
[2023-07-14T17:09:05+0200] [ALPM-SCRIPTLET] foreign	python-py3nvml
[2023-07-14T17:09:05+0200] [ALPM] running 'update-desktop-database.hook'...
[2023-07-15T10:42:13+0200] [ALPM] transaction started
[2023-07-15T10:42:13+0200] [ALPM] reinstalled librewolf-bin (115.0.1-1)
[2023-07-15T10:42:13+0200] [ALPM-SCRIPTLET] >>    Remember to check for changes in /usr/lib/librewolf/librewolf.cfg.pacnew
[2023-07-15T10:42:13+0200] [ALPM-SCRIPTLET] >>    as those will not automatically overwrite your existing librewolf.cfg.
[2023-07-15T10:42:13+0200] [ALPM-SCRIPTLET] >>    We would encourage you to migrate your own changes to the new overrides file
[2023-07-15T10:42:13+0200] [ALPM-SCRIPTLET] >>    at ~/.librewolf/librewolf.overrides.cfg instead, so making changes directly
[2023-07-15T10:42:13+0200] [ALPM-SCRIPTLET] >>    in your librewolf.cfg is not necessary anymore (in most cases at least).
[2023-07-15T10:42:13+0200] [ALPM-SCRIPTLET] >>    Check out https://gitlab.com/librewolf-community/settings/-/merge_requests/13
[2023-07-15T10:42:13+0200] [ALPM-SCRIPTLET] >>    for more information on this.
[2023-07-15T10:42:13+0200] [ALPM] transaction completed
[2023-07-15T10:42:13+0200] [ALPM] running '30-systemd-update.hook'...
[2023-07-15T10:42:13+0200] [ALPM] running '90-packagekit-refresh.hook'...
[2023-07-15T10:42:13+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2023-07-15T10:42:13+0200] [ALPM] running 'pacnew-notifier.hook'...
[2023-07-15T10:42:13+0200] [ALPM] running 'rebuild-detector.hook'...
[2023-07-15T10:42:13+0200] [ALPM-SCRIPTLET] parallel: Warning: $HOME not set. Using /tmp.
[2023-07-15T10:42:14+0200] [ALPM-SCRIPTLET] foreign	gwe
[2023-07-15T10:42:14+0200] [ALPM-SCRIPTLET] foreign	librewolf-bin
[2023-07-15T10:42:14+0200] [ALPM-SCRIPTLET] foreign	python-injector
[2023-07-15T10:42:14+0200] [ALPM-SCRIPTLET] foreign	python-py3nvml
[2023-07-15T10:42:14+0200] [ALPM] running 'update-desktop-database.hook'...
[2023-07-15T10:46:23+0200] [ALPM] transaction started
[2023-07-15T10:46:23+0200] [ALPM] installed ninja (1.11.1-3)
[2023-07-15T10:46:23+0200] [ALPM] installed python-tqdm (4.65.0-3)
[2023-07-15T10:46:24+0200] [ALPM] installed meson (1.1.1-1)
[2023-07-15T10:46:24+0200] [ALPM] transaction completed
[2023-07-15T10:46:24+0200] [ALPM] running '30-systemd-update.hook'...
[2023-07-15T10:46:24+0200] [ALPM] running '90-packagekit-refresh.hook'...
[2023-07-15T10:46:24+0200] [ALPM] running 'pacman-backup.hook'...
[2023-07-15T10:46:24+0200] [ALPM] running 'pacnew-notifier.hook'...
[2023-07-15T10:46:41+0200] [ALPM] transaction started
[2023-07-15T10:46:41+0200] [ALPM] reinstalled python-py3nvml (0.2.7-1)
[2023-07-15T10:46:41+0200] [ALPM] reinstalled python-injector (0.20.1-2)
[2023-07-15T10:46:41+0200] [ALPM] transaction completed
[2023-07-15T10:46:41+0200] [ALPM] running '30-systemd-update.hook'...
[2023-07-15T10:46:41+0200] [ALPM] running '90-packagekit-refresh.hook'...
[2023-07-15T10:46:41+0200] [ALPM] running 'pacnew-notifier.hook'...
[2023-07-15T10:46:41+0200] [ALPM] running 'rebuild-detector.hook'...
[2023-07-15T10:46:41+0200] [ALPM-SCRIPTLET] parallel: Warning: $HOME not set. Using /tmp.
[2023-07-15T10:46:42+0200] [ALPM-SCRIPTLET] foreign	gwe
[2023-07-15T10:46:50+0200] [ALPM] transaction started
[2023-07-15T10:46:50+0200] [ALPM] reinstalled gwe (0.15.5-3)
[2023-07-15T10:46:50+0200] [ALPM] transaction completed
[2023-07-15T10:46:50+0200] [ALPM] running '30-systemd-update.hook'...
[2023-07-15T10:46:50+0200] [ALPM] running '90-packagekit-refresh.hook'...
[2023-07-15T10:46:50+0200] [ALPM] running 'glib-compile-schemas.hook'...
[2023-07-15T10:46:50+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2023-07-15T10:46:50+0200] [ALPM] running 'pacnew-notifier.hook'...
[2023-07-15T10:46:50+0200] [ALPM] running 'rebuild-detector.hook'...
[2023-07-15T10:46:50+0200] [ALPM-SCRIPTLET] parallel: Warning: $HOME not set. Using /tmp.
[2023-07-15T10:46:51+0200] [ALPM] running 'update-desktop-database.hook'...
You could try to compare the files in the efi-partition against those on the live-manjaro.
But this indicates, that your system
  • has booted with grub
  • has loaded the kernels (you could try to boot another kernel)
  • found an initramdisk (you could try to boot with fallback)
  • startet the system (so you can switch to a terminal ?)
  • startet xorg
  • started sddm
In this case your logs of xorg may help to find the problem
:footprints:
P.S. : In one of my systems there has been an pacnew-file in /root/.zshrc.pacnew
So please try terminal first with your normal user, then sudo :wink:
Updated with the latest info. Apparently it’s not that…
Well, to be totally honest, I don’t really know what to look for (although I’d love it if someone could tell me), so here are a few files:
cat /var/log/Xorg.0.log:
[     7.750] (--) Log file renamed from "/var/log/Xorg.pid-684.log" to "/var/log/Xorg.0.log"
[     7.752]
X.Org X Server 1.21.1.8
[     7.752] Current Operating System: Linux Mirdarthos-PC 5.15.120-1-MANJARO #1 SMP PREEMPT Wed Jul 5 21:45:37 UTC 2023 x86_64
[     7.752] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=9a26c8d0-43f4-44ad-a7d3-861d6f6cdbfa rw quiet udev.log_priority=3
[     7.752]
[     7.752] Current version of pixman: 0.42.2
[     7.752]    Before reporting problems, check http://wiki.x.org
[     7.752] Markers: (--) probed, (**) from config file, (==) default setting,
[     7.752] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jul 19 15:16:34 2023
[     7.754] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     7.754] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     7.755] (==) ServerLayout "layout"
[     7.755] (**) |-->Screen "Screen0" (0)
[     7.755] (**) |   |-->Monitor "Monitor0"
[     7.755] (**) |   |-->Device "Device0"
[     7.755] (==) Automatically adding devices
[     7.755] (==) Automatically enabling devices
[     7.755] (==) Automatically adding GPU devices
[     7.755] (==) Automatically binding GPU devices
[     7.755] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     7.757] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     7.757]    Entry deleted from font path.
[     7.757] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     7.757] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     7.757] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     7.757] (==) FontPath set to:
        /usr/share/fonts/misc,
        /usr/share/fonts/TTF
[     7.757] (==) ModulePath set to "/usr/lib/xorg/modules"
[     7.757] (II) The server relies on udev to provide the list of input devices.
[     7.757] (II) Module ABI versions:
[     7.757]    X.Org ANSI C Emulation: 0.4
[     7.757]    X.Org Video Driver: 25.2
[     7.757]    X.Org XInput driver : 24.4
[     7.757]    X.Org Server Extension : 10.0
[     7.758] (++) using VT number 2
[     7.758] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     7.758] (II) xfree86: Adding drm device (/dev/dri/card0)
[     7.758] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[     7.759] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     7.759] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     7.760] (--) PCI:*(1@0:0:0) 10de:1401:1458:36bd rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[     7.760] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     7.760] (II) "glx" will be loaded. This was enabled by default and also specified in the config file.
[     7.760] (II) LoadModule: "dbe"
[     7.760] (II) Module "dbe" already built-in
[     7.760] (II) LoadModule: "extmod"
[     7.760] (II) Module "extmod" already built-in
[     7.760] (II) LoadModule: "glx"
[     7.762] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     7.769] (II) Module glx: vendor="X.Org Foundation"
[     7.769]    compiled for 1.21.1.8, module version = 1.0.0
[     7.769]    ABI class: X.Org Server Extension, version 10.0
[     7.769] (II) LoadModule: "nvidia"
[     7.769] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[     7.773] (II) Module nvidia: vendor="NVIDIA Corporation"
[     7.773]    compiled for 1.6.99.901, module version = 1.0.0
[     7.773]    Module class: X.Org Video Driver
[     7.773] (II) NVIDIA dlloader X Driver  535.54.03  Tue Jun  6 22:23:02 UTC 2023
[     7.773] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[     7.778] (II) Loading sub module "fb"
[     7.778] (II) LoadModule: "fb"
[     7.778] (II) Module "fb" already built-in
[     7.778] (II) Loading sub module "wfb"
[     7.778] (II) LoadModule: "wfb"
[     7.778] (II) Loading /usr/lib/xorg/modules/libwfb.so
[     7.779] (II) Module wfb: vendor="X.Org Foundation"
[     7.779]    compiled for 1.21.1.8, module version = 1.0.0
[     7.779]    ABI class: X.Org ANSI C Emulation, version 0.4
[     7.779] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[     7.779] (==) NVIDIA(0): RGB weight 888
[     7.779] (==) NVIDIA(0): Default visual is TrueColor
[     7.779] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[     7.779] (**) Option "AllowNVIDIAGpuScreens"
[     7.779] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[     7.779] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[     7.779] (**) NVIDIA(0): Enabling 2D acceleration
[     7.779] (II) Loading sub module "glxserver_nvidia"
[     7.779] (II) LoadModule: "glxserver_nvidia"
[     7.779] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[     7.809] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[     7.809]    compiled for 1.6.99.901, module version = 1.0.0
[     7.809]    Module class: X.Org Server Extension
[     7.809] (II) NVIDIA GLX Module  535.54.03  Tue Jun  6 22:23:41 UTC 2023
[     7.810] (II) NVIDIA: The X server supports PRIME Render Offload.
[     8.862] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[     8.862] (--) NVIDIA(0):     CRT-0
[     8.862] (--) NVIDIA(0):     DFP-0
[     8.862] (--) NVIDIA(0):     DFP-1 (boot)
[     8.862] (--) NVIDIA(0):     DFP-2
[     8.862] (--) NVIDIA(0):     DFP-3
[     8.862] (--) NVIDIA(0):     DFP-4
[     8.863] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce GTX 960 (GM206-A) at PCI:1:0:0
[     8.863] (II) NVIDIA(0):     (GPU-0)
[     8.863] (--) NVIDIA(0): Memory: 2097152 kBytes
[     8.863] (--) NVIDIA(0): VideoBIOS: 84.06.14.40.22
[     8.863] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[     8.970] (--) NVIDIA(GPU-0): CRT-0: disconnected
[     8.970] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[     9.123] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): connected
[     9.123] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): Internal TMDS
[     9.123] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): 600.0 MHz maximum pixel clock
[     9.169] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-1): connected
[     9.169] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-1): Internal TMDS
[     9.169] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-1): 600.0 MHz maximum pixel clock
[     9.169] (--) NVIDIA(GPU-0): DFP-2: disconnected
[     9.169] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[     9.169] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[     9.169] (--) NVIDIA(GPU-0): DFP-3: disconnected
[     9.169] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[     9.169] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[     9.169] (--) NVIDIA(GPU-0): DFP-4: disconnected
[     9.169] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[     9.169] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[     9.173] (==) NVIDIA(0):
[     9.173] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[     9.173] (==) NVIDIA(0):     will be used as the requested mode.
[     9.173] (II) NVIDIA(0): Validated MetaModes:
[     9.173] (II) NVIDIA(0):     "DFP-1:nvidia-auto-select,DFP-0:nvidia-auto-select"
[     9.173] (II) NVIDIA(0): Virtual screen size determined to be 5120 x 1080
[     9.177] (--) NVIDIA(0): DPI set to (97, 97); computed from "UseEdidDpi" X config
[     9.177] (--) NVIDIA(0):     option
[     9.177] (II) NVIDIA: Reserving 6144.00 MB of virtual memory for indirect memory
[     9.177] (II) NVIDIA:     access.
[     9.179] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[     9.179] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[     9.179] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[     9.179] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[     9.179] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[     9.179] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[     9.179] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[     9.179] (II) NVIDIA(0):     Config Options in the README.
[     9.191] (II) NVIDIA(0): Setting mode "DFP-1:nvidia-auto-select,DFP-0:nvidia-auto-select"
[     9.344] (==) NVIDIA(0): Disabling shared memory pixmaps
[     9.344] (==) NVIDIA(0): Backing store enabled
[     9.344] (==) NVIDIA(0): Silken mouse enabled
[     9.344] (**) NVIDIA(0): DPMS enabled
[     9.344] (II) Loading sub module "dri2"
[     9.344] (II) LoadModule: "dri2"
[     9.344] (II) Module "dri2" already built-in
[     9.344] (II) NVIDIA(0): [DRI2] Setup complete
[     9.344] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[     9.344] (II) Initializing extension Generic Event Extension
[     9.344] (II) Initializing extension SHAPE
[     9.344] (II) Initializing extension MIT-SHM
[     9.345] (II) Initializing extension XInputExtension
[     9.345] (II) Initializing extension XTEST
[     9.345] (II) Initializing extension BIG-REQUESTS
[     9.345] (II) Initializing extension SYNC
[     9.345] (II) Initializing extension XKEYBOARD
[     9.345] (II) Initializing extension XC-MISC
[     9.345] (II) Initializing extension SECURITY
[     9.345] (II) Initializing extension XFIXES
[     9.345] (II) Initializing extension RENDER
[     9.345] (II) Initializing extension RANDR
[     9.345] (II) Initializing extension COMPOSITE
[     9.345] (II) Initializing extension DAMAGE
[     9.345] (II) Initializing extension MIT-SCREEN-SAVER
[     9.345] (II) Initializing extension DOUBLE-BUFFER
[     9.345] (II) Initializing extension RECORD
[     9.345] (II) Initializing extension DPMS
[     9.345] (II) Initializing extension Present
[     9.346] (II) Initializing extension DRI3
[     9.346] (II) Initializing extension X-Resource
[     9.346] (II) Initializing extension XVideo
[     9.346] (II) Initializing extension XVideo-MotionCompensation
[     9.346] (II) Initializing extension GLX
[     9.346] (II) Indirect GLX disabled.
[     9.346] (II) GLX: Another vendor is already registered for screen 0
[     9.346] (II) Initializing extension XFree86-VidModeExtension
[     9.346] (II) Initializing extension XFree86-DGA
[     9.346] (II) Initializing extension XFree86-DRI
[     9.346] (II) Initializing extension DRI2
[     9.346] (II) Initializing extension NV-GLX
[     9.346] (II) Initializing extension NV-CONTROL
[     9.346] (II) Initializing extension XINERAMA
[     9.447] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[     9.447] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     9.447] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     9.447] (**) Power Button: Applying InputClass "system-keyboard"
[     9.447] (II) LoadModule: "libinput"
[     9.447] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     9.451] (II) Module libinput: vendor="X.Org Foundation"
[     9.451]    compiled for 1.21.1.8, module version = 1.3.0
[     9.451]    Module class: X.Org XInput Driver
[     9.451]    ABI class: X.Org XInput driver, version 24.4
[     9.451] (II) Using input driver 'libinput' for 'Power Button'
[     9.451] (**) Power Button: always reports core events
[     9.451] (**) Option "Device" "/dev/input/event2"
[     9.455] (II) event2  - Power Button: is tagged by udev as: Keyboard
[     9.455] (II) event2  - Power Button: device is a keyboard
[     9.455] (II) event2  - Power Button: device removed
[     9.470] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[     9.470] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     9.470] (**) Option "xkb_model" "pc105"
[     9.470] (**) Option "xkb_layout" "za"
[     9.480] (II) event2  - Power Button: is tagged by udev as: Keyboard
[     9.480] (II) event2  - Power Button: device is a keyboard
[     9.481] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     9.481] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     9.481] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     9.481] (**) Power Button: Applying InputClass "system-keyboard"
[     9.481] (II) Using input driver 'libinput' for 'Power Button'
[     9.481] (**) Power Button: always reports core events
[     9.481] (**) Option "Device" "/dev/input/event1"
[     9.481] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     9.481] (II) event1  - Power Button: device is a keyboard
[     9.481] (II) event1  - Power Button: device removed
[     9.510] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[     9.510] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[     9.510] (**) Option "xkb_model" "pc105"
[     9.510] (**) Option "xkb_layout" "za"
[     9.510] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     9.510] (II) event1  - Power Button: device is a keyboard
[     9.511] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[     9.511] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[     9.511] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[     9.511] (**) Sleep Button: Applying InputClass "system-keyboard"
[     9.511] (II) Using input driver 'libinput' for 'Sleep Button'
[     9.511] (**) Sleep Button: always reports core events
[     9.511] (**) Option "Device" "/dev/input/event0"
[     9.511] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[     9.511] (II) event0  - Sleep Button: device is a keyboard
[     9.511] (II) event0  - Sleep Button: device removed
[     9.536] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[     9.536] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[     9.536] (**) Option "xkb_model" "pc105"
[     9.536] (**) Option "xkb_layout" "za"
[     9.537] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[     9.537] (II) event0  - Sleep Button: device is a keyboard
[     9.537] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event10)
[     9.537] (II) No input driver specified, ignoring this device.
[     9.537] (II) This device may have been added with another device file.
[     9.538] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event11)
[     9.538] (II) No input driver specified, ignoring this device.
[     9.538] (II) This device may have been added with another device file.
[     9.538] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event13)
[     9.538] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event15)
[     9.538] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event17)
[     9.539] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event18)
[     9.539] (II) No input driver specified, ignoring this device.
[     9.539] (II) This device may have been added with another device file.
[     9.539] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event9)
[     9.539] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP Mouse (/dev/input/event4)
[     9.539] (**) ROCCAT ROCCAT Kone EMP Mouse: Applying InputClass "evdev pointer catchall"
[     9.539] (**) ROCCAT ROCCAT Kone EMP Mouse: Applying InputClass "libinput pointer catchall"
[     9.539] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP Mouse'
[     9.539] (**) ROCCAT ROCCAT Kone EMP Mouse: always reports core events
[     9.539] (**) Option "Device" "/dev/input/event4"
[     9.540] (II) event4  - ROCCAT ROCCAT Kone EMP Mouse: is tagged by udev as: Mouse
[     9.540] (II) event4  - ROCCAT ROCCAT Kone EMP Mouse: device is a pointer
[     9.541] (II) event4  - ROCCAT ROCCAT Kone EMP Mouse: device removed
[     9.616] (II) libinput: ROCCAT ROCCAT Kone EMP Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[     9.616] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:1E7D:2E24.0001/input/input4/event4"
[     9.616] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP Mouse" (type: MOUSE, id 9)
[     9.616] (**) Option "AccelerationScheme" "none"
[     9.616] (**) ROCCAT ROCCAT Kone EMP Mouse: (accel) selected scheme none/0
[     9.616] (**) ROCCAT ROCCAT Kone EMP Mouse: (accel) acceleration factor: 2.000
[     9.616] (**) ROCCAT ROCCAT Kone EMP Mouse: (accel) acceleration threshold: 4
[     9.617] (II) event4  - ROCCAT ROCCAT Kone EMP Mouse: is tagged by udev as: Mouse
[     9.617] (II) event4  - ROCCAT ROCCAT Kone EMP Mouse: device is a pointer
[     9.618] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP Mouse (/dev/input/mouse0)
[     9.618] (II) No input driver specified, ignoring this device.
[     9.618] (II) This device may have been added with another device file.
[     9.618] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP Consumer Control (/dev/input/event5)
[     9.618] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "evdev keyboard catchall"
[     9.618] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "libinput keyboard catchall"
[     9.618] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "system-keyboard"
[     9.618] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP Consumer Control'
[     9.618] (**) ROCCAT ROCCAT Kone EMP Consumer Control: always reports core events
[     9.618] (**) Option "Device" "/dev/input/event5"
[     9.619] (II) event5  - ROCCAT ROCCAT Kone EMP Consumer Control: is tagged by udev as: Keyboard
[     9.619] (II) event5  - ROCCAT ROCCAT Kone EMP Consumer Control: device is a keyboard
[     9.619] (II) event5  - ROCCAT ROCCAT Kone EMP Consumer Control: device removed
[     9.643] (II) libinput: ROCCAT ROCCAT Kone EMP Consumer Control: needs a virtual subdevice
[     9.643] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:1E7D:2E24.0001/input/input5/event5"
[     9.643] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP Consumer Control" (type: MOUSE, id 10)
[     9.643] (**) Option "AccelerationScheme" "none"
[     9.643] (**) ROCCAT ROCCAT Kone EMP Consumer Control: (accel) selected scheme none/0
[     9.643] (**) ROCCAT ROCCAT Kone EMP Consumer Control: (accel) acceleration factor: 2.000
[     9.643] (**) ROCCAT ROCCAT Kone EMP Consumer Control: (accel) acceleration threshold: 4
[     9.644] (II) event5  - ROCCAT ROCCAT Kone EMP Consumer Control: is tagged by udev as: Keyboard
[     9.644] (II) event5  - ROCCAT ROCCAT Kone EMP Consumer Control: device is a keyboard
[     9.645] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP System Control (/dev/input/event6)
[     9.645] (**) ROCCAT ROCCAT Kone EMP System Control: Applying InputClass "evdev keyboard catchall"
[     9.645] (**) ROCCAT ROCCAT Kone EMP System Control: Applying InputClass "libinput keyboard catchall"
[     9.645] (**) ROCCAT ROCCAT Kone EMP System Control: Applying InputClass "system-keyboard"
[     9.645] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP System Control'
[     9.645] (**) ROCCAT ROCCAT Kone EMP System Control: always reports core events
[     9.645] (**) Option "Device" "/dev/input/event6"
[     9.645] (II) event6  - ROCCAT ROCCAT Kone EMP System Control: is tagged by udev as: Keyboard
[     9.646] (II) event6  - ROCCAT ROCCAT Kone EMP System Control: device is a keyboard
[     9.646] (II) event6  - ROCCAT ROCCAT Kone EMP System Control: device removed
[     9.670] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:1E7D:2E24.0001/input/input6/event6"
[     9.670] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP System Control" (type: KEYBOARD, id 11)
[     9.670] (**) Option "xkb_model" "pc105"
[     9.670] (**) Option "xkb_layout" "za"
[     9.671] (II) event6  - ROCCAT ROCCAT Kone EMP System Control: is tagged by udev as: Keyboard
[     9.671] (II) event6  - ROCCAT ROCCAT Kone EMP System Control: device is a keyboard
[     9.671] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP (/dev/input/event7)
[     9.671] (II) No input driver specified, ignoring this device.
[     9.671] (II) This device may have been added with another device file.
[     9.672] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP (/dev/input/event8)
[     9.672] (**) ROCCAT ROCCAT Kone EMP: Applying InputClass "evdev keyboard catchall"
[     9.672] (**) ROCCAT ROCCAT Kone EMP: Applying InputClass "libinput keyboard catchall"
[     9.672] (**) ROCCAT ROCCAT Kone EMP: Applying InputClass "system-keyboard"
[     9.672] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP'
[     9.672] (**) ROCCAT ROCCAT Kone EMP: always reports core events
[     9.672] (**) Option "Device" "/dev/input/event8"
[     9.673] (II) event8  - ROCCAT ROCCAT Kone EMP: is tagged by udev as: Keyboard
[     9.673] (II) event8  - ROCCAT ROCCAT Kone EMP: device is a keyboard
[     9.673] (II) event8  - ROCCAT ROCCAT Kone EMP: device removed
[     9.736] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:1E7D:2E24.0002/input/input8/event8"
[     9.736] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP" (type: KEYBOARD, id 12)
[     9.736] (**) Option "xkb_model" "pc105"
[     9.736] (**) Option "xkb_layout" "za"
[     9.737] (II) event8  - ROCCAT ROCCAT Kone EMP: is tagged by udev as: Keyboard
[     9.737] (II) event8  - ROCCAT ROCCAT Kone EMP: device is a keyboard
[     9.738] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event12)
[     9.738] (II) No input driver specified, ignoring this device.
[     9.738] (II) This device may have been added with another device file.
[     9.738] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event16)
[     9.738] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event20)
[     9.738] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event22)
[     9.739] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event24)
[     9.739] (II) No input driver specified, ignoring this device.
[     9.739] (II) This device may have been added with another device file.
[     9.739] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event25)
[     9.739] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event26)
[     9.739] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event27)
[     9.740] (II) config/udev: Adding input device PC Speaker (/dev/input/event3)
[     9.740] (II) No input driver specified, ignoring this device.
[     9.740] (II) This device may have been added with another device file.
[     9.741] (II) config/udev: Adding input device ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB (/dev/input/event14)
[     9.741] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: Applying InputClass "evdev keyboard catchall"
[     9.741] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: Applying InputClass "libinput keyboard catchall"
[     9.741] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: Applying InputClass "system-keyboard"
[     9.741] (II) Using input driver 'libinput' for 'ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB'
[     9.741] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: always reports core events
[     9.741] (**) Option "Device" "/dev/input/event14"
[     9.742] (II) event14 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: is tagged by udev as: Keyboard
[     9.742] (II) event14 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device is a keyboard
[     9.742] (II) event14 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device removed
[     9.776] (**) Option "config_info" "udev:/sys/devices/virtual/input/input28/event14"
[     9.776] (II) XINPUT: Adding extended input device "ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB" (type: KEYBOARD, id 13)
[     9.776] (**) Option "xkb_model" "pc105"
[     9.776] (**) Option "xkb_layout" "za"
[     9.777] (II) event14 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: is tagged by udev as: Keyboard
[     9.777] (II) event14 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device is a keyboard
[     9.777] (II) config/udev: Adding input device ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM (/dev/input/event19)
[     9.777] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: Applying InputClass "evdev pointer catchall"
[     9.777] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: Applying InputClass "libinput pointer catchall"
[     9.777] (II) Using input driver 'libinput' for 'ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM'
[     9.777] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: always reports core events
[     9.777] (**) Option "Device" "/dev/input/event19"
[     9.778] (II) event19 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: is tagged by udev as: Mouse
[     9.778] (II) event19 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device is a pointer
[     9.778] (II) event19 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device removed
[     9.830] (II) libinput: ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: Step value 0 was provided, libinput Fallback acceleration function is used.
[     9.830] (**) Option "config_info" "udev:/sys/devices/virtual/input/input29/event19"
[     9.830] (II) XINPUT: Adding extended input device "ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM" (type: MOUSE, id 14)
[     9.830] (**) Option "AccelerationScheme" "none"
[     9.830] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: (accel) selected scheme none/0
[     9.830] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: (accel) acceleration factor: 2.000
[     9.830] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: (accel) acceleration threshold: 4
[     9.830] (II) event19 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: is tagged by udev as: Mouse
[     9.830] (II) event19 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device is a pointer
[     9.831] (II) config/udev: Adding input device ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM (/dev/input/mouse1)
[     9.831] (II) No input driver specified, ignoring this device.
[     9.831] (II) This device may have been added with another device file.
[     9.833] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "evdev keyboard catchall"
[     9.833] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "libinput keyboard catchall"
[     9.833] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "system-keyboard"
[     9.833] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP Consumer Control'
[     9.833] (**) ROCCAT ROCCAT Kone EMP Consumer Control: always reports core events
[     9.833] (**) Option "Device" "/dev/input/event5"
[     9.833] (II) libinput: ROCCAT ROCCAT Kone EMP Consumer Control: is a virtual subdevice
[     9.834] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:1E7D:2E24.0001/input/input5/event5"
[     9.834] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP Consumer Control" (type: KEYBOARD, id 15)
[     9.834] (**) Option "xkb_model" "pc105"
[     9.834] (**) Option "xkb_layout" "za"
[     9.834] (II) config/udev: Adding input device ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM (/dev/input/mouse1)
[     9.834] (II) No input driver specified, ignoring this device.
[     9.834] (II) This device may have been added with another device file.
[     9.834] (II) config/udev: removing device ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM
[     9.834] (II) event19 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device removed
[     9.896] (II) UnloadModule: "libinput"
[     9.896] (II) config/udev: Adding input device ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM (/dev/input/event19)
[     9.896] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: Applying InputClass "evdev pointer catchall"
[     9.896] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: Applying InputClass "libinput pointer catchall"
[     9.897] (II) Using input driver 'libinput' for 'ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM'
[     9.897] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: always reports core events
[     9.897] (**) Option "Device" "/dev/input/event19"
[     9.897] (II) event19 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: is tagged by udev as: Mouse
[     9.897] (II) event19 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device is a pointer
[     9.897] (II) event19 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device removed
[     9.950] (II) libinput: ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: Step value 0 was provided, libinput Fallback acceleration function is used.
[     9.950] (**) Option "config_info" "udev:/sys/devices/virtual/input/input29/event19"
[     9.950] (II) XINPUT: Adding extended input device "ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM" (type: MOUSE, id 14)
[     9.950] (**) Option "AccelerationScheme" "none"
[     9.950] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: (accel) selected scheme none/0
[     9.950] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: (accel) acceleration factor: 2.000
[     9.950] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: (accel) acceleration threshold: 4
[     9.950] (II) event19 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: is tagged by udev as: Mouse
[     9.950] (II) event19 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device is a pointer
[     9.950] (II) config/udev: removing device ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB
[     9.950] (II) event14 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device removed
[     9.976] (II) UnloadModule: "libinput"
[     9.977] (II) config/udev: Adding input device ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB (/dev/input/event14)
[     9.977] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: Applying InputClass "evdev keyboard catchall"
[     9.977] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: Applying InputClass "libinput keyboard catchall"
[     9.977] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: Applying InputClass "system-keyboard"
[     9.977] (II) Using input driver 'libinput' for 'ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB'
[     9.977] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: always reports core events
[     9.977] (**) Option "Device" "/dev/input/event14"
[     9.977] (II) event14 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: is tagged by udev as: Keyboard
[     9.977] (II) event14 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device is a keyboard
[     9.977] (II) event14 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device removed
[    10.003] (**) Option "config_info" "udev:/sys/devices/virtual/input/input28/event14"
[    10.003] (II) XINPUT: Adding extended input device "ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB" (type: KEYBOARD, id 13)
[    10.003] (**) Option "xkb_model" "pc105"
[    10.003] (**) Option "xkb_layout" "za"
[    10.004] (II) event14 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: is tagged by udev as: Keyboard
[    10.004] (II) event14 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device is a keyboard
[    70.451] (II) event2  - Power Button: device removed
[    70.477] (II) event1  - Power Button: device removed
[    70.496] (II) event0  - Sleep Button: device removed
[    70.520] (II) event4  - ROCCAT ROCCAT Kone EMP Mouse: device removed
[    70.590] (II) event6  - ROCCAT ROCCAT Kone EMP System Control: device removed
[    70.630] (II) event8  - ROCCAT ROCCAT Kone EMP: device removed
[    70.710] (II) event5  - ROCCAT ROCCAT Kone EMP Consumer Control: device removed
[    70.750] (II) event19 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device removed
[    70.776] (II) event14 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device removed
[    70.805] (II) UnloadModule: "libinput"
[    71.678] (II) NVIDIA(GPU-0): Deleting GPU-0
[    71.686] (II) Server terminated successfully (0). Closing log file.
cat /var/log/Xorg.1.log:
[ 85487.160] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[ 85487.160] _XSERVTransMakeAllCOTSServerListeners: server already running
[ 85487.160] (--) Log file renamed from "/var/log/Xorg.pid-650070.log" to "/var/log/Xorg.1.log"
[ 85487.160]
[ 85487.160] Current Operating System: Linux Mirdarthos-PC 6.4.2-3-MANJARO #1 SMP PREEMPT_DYNAMIC Fri Jul  7 19:19:45 UTC 2023 x86_64
[ 85487.160] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.4-x86_64 root=UUID=9a26c8d0-43f4-44ad-a7d3-861d6f6cdbfa rw quiet udev.log_priority=3
[ 85487.160]
[ 85487.160] Current version of pixman: 0.42.2
[ 85487.160]    Before reporting problems, check http://wiki.x.org
[ 85487.160] Markers: (--) probed, (**) from config file, (==) default setting,
[ 85487.160] (==) Log file: "/var/log/Xorg.1.log", Time: Thu Jul 13 09:30:00 2023
[ 85487.161] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 85487.161] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 85487.162] (==) ServerLayout "layout"
[ 85487.162] (**) |-->Screen "Screen0" (0)
[ 85487.162] (**) |   |-->Monitor "Monitor0"
[ 85487.162] (**) |   |-->Device "Device0"
[ 85487.162] (==) Automatically adding devices
[ 85487.162] (==) Automatically enabling devices
[ 85487.162] (==) Automatically adding GPU devices
[ 85487.162] (==) Automatically binding GPU devices
[ 85487.162] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 85487.162] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 85487.162]    Entry deleted from font path.
[ 85487.162] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 85487.162] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 85487.162] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 85487.162] (==) FontPath set to:
[ 85487.162] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 85487.162] (II) The server relies on udev to provide the list of input devices.
[ 85487.162] (II) Module ABI versions:
[ 85487.162]    X.Org ANSI C Emulation: 0.4
[ 85487.162]    X.Org Video Driver: 25.2
[ 85487.162]    X.Org XInput driver : 24.4
[ 85487.162]    X.Org Server Extension : 10.0
[ 85487.162] (++) using VT number 1
[ 85487.162] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 85487.163] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 85487.163] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[ 85487.163] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 85487.163] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 85487.164] (--) PCI:*(1@0:0:0) 10de:1401:1458:36bd rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 85487.164] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 85487.164] (II) "glx" will be loaded. This was enabled by default and also specified in the config file.
[ 85487.164] (II) LoadModule: "dbe"
[ 85487.165] (II) Module "dbe" already built-in
[ 85487.165] (II) LoadModule: "extmod"
[ 85487.165] (II) Module "extmod" already built-in
[ 85487.165] (II) LoadModule: "glx"
[ 85487.165] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 85487.166] (II) Module glx: vendor="X.Org Foundation"
[ 85487.166]    compiled for 1.21.1.8, module version = 1.0.0
[ 85487.166]    ABI class: X.Org Server Extension, version 10.0
[ 85487.166] (II) LoadModule: "nvidia"
[ 85487.166] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 85487.166] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 85487.166]    compiled for 1.6.99.901, module version = 1.0.0
[ 85487.166]    Module class: X.Org Video Driver
[ 85487.166] (II) NVIDIA dlloader X Driver  535.54.03  Tue Jun  6 22:23:02 UTC 2023
[ 85487.166] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 85488.315] (II) Loading sub module "fb"
[ 85488.315] (II) LoadModule: "fb"
[ 85488.315] (II) Module "fb" already built-in
[ 85488.315] (II) Loading sub module "wfb"
[ 85488.315] (II) LoadModule: "wfb"
[ 85488.315] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 85488.315] (II) Module wfb: vendor="X.Org Foundation"
[ 85488.315]    compiled for 1.21.1.8, module version = 1.0.0
[ 85488.315]    ABI class: X.Org ANSI C Emulation, version 0.4
[ 85488.315] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 85488.315] (==) NVIDIA(0): RGB weight 888
[ 85488.315] (==) NVIDIA(0): Default visual is TrueColor
[ 85488.315] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 85488.315] (**) Option "AllowNVIDIAGpuScreens"
[ 85488.315] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 85488.315] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 85488.315] (**) NVIDIA(0): Enabling 2D acceleration
[ 85488.315] (II) Loading sub module "glxserver_nvidia"
[ 85488.315] (II) LoadModule: "glxserver_nvidia"
[ 85488.316] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 85488.324] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 85488.324]    compiled for 1.6.99.901, module version = 1.0.0
[ 85488.324]    Module class: X.Org Server Extension
[ 85488.324] (II) NVIDIA GLX Module  535.54.03  Tue Jun  6 22:23:41 UTC 2023
[ 85488.324] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 85488.324] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 85488.325] (--) NVIDIA(0):     CRT-0
[ 85488.325] (--) NVIDIA(0):     DFP-0
[ 85488.325] (--) NVIDIA(0):     DFP-1 (boot)
[ 85488.325] (--) NVIDIA(0):     DFP-2
[ 85488.325] (--) NVIDIA(0):     DFP-3
[ 85488.325] (--) NVIDIA(0):     DFP-4
[ 85488.326] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce GTX 960 (GM206-A) at PCI:1:0:0
[ 85488.326] (II) NVIDIA(0):     (GPU-0)
[ 85488.326] (--) NVIDIA(0): Memory: 2097152 kBytes
[ 85488.326] (--) NVIDIA(0): VideoBIOS: 84.06.14.40.22
[ 85488.326] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 85488.526] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 85488.526] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 85488.813] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): connected
[ 85488.813] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): Internal TMDS
[ 85488.813] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-0): 600.0 MHz maximum pixel clock
[ 85488.904] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-1): connected
[ 85488.904] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-1): Internal TMDS
[ 85488.904] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-1): 600.0 MHz maximum pixel clock
[ 85488.904] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 85488.904] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 85488.904] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 85488.904] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 85488.904] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 85488.904] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 85488.904] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 85488.904] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 85488.904] (--) NVIDIA(GPU-0): DFP-4: 330.0 MHz maximum pixel clock
[ 85488.911] (==) NVIDIA(0):
[ 85488.911] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 85488.911] (==) NVIDIA(0):     will be used as the requested mode.
[ 85488.911] (II) NVIDIA(0): Validated MetaModes:
[ 85488.911] (II) NVIDIA(0):     "DFP-1:nvidia-auto-select,DFP-0:nvidia-auto-select"
[ 85488.911] (II) NVIDIA(0): Virtual screen size determined to be 5120 x 1080
[ 85488.917] (--) NVIDIA(0): DPI set to (97, 97); computed from "UseEdidDpi" X config
[ 85488.917] (--) NVIDIA(0):     option
[ 85488.918] (II) NVIDIA: Reserving 6144.00 MB of virtual memory for indirect memory
[ 85488.918] (II) NVIDIA:     access.
[ 85488.920] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 85488.920] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[ 85488.920] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[ 85488.920] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[ 85488.920] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[ 85488.920] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[ 85488.920] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[ 85488.920] (II) NVIDIA(0):     Config Options in the README.
[ 85488.937] (II) NVIDIA(0): Setting mode "DFP-1:nvidia-auto-select,DFP-0:nvidia-auto-select"
[ 85489.032] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 85489.032] (==) NVIDIA(0): Backing store enabled
[ 85489.032] (==) NVIDIA(0): Silken mouse enabled
[ 85489.032] (**) NVIDIA(0): DPMS enabled
[ 85489.032] (II) Loading sub module "dri2"
[ 85489.032] (II) LoadModule: "dri2"
[ 85489.032] (II) Module "dri2" already built-in
[ 85489.032] (II) NVIDIA(0): [DRI2] Setup complete
[ 85489.032] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[ 85489.032] (II) Initializing extension Generic Event Extension
[ 85489.032] (II) Initializing extension SHAPE
[ 85489.032] (II) Initializing extension MIT-SHM
[ 85489.032] (II) Initializing extension XInputExtension
[ 85489.032] (II) Initializing extension XTEST
[ 85489.032] (II) Initializing extension BIG-REQUESTS
[ 85489.032] (II) Initializing extension SYNC
[ 85489.033] (II) Initializing extension XKEYBOARD
[ 85489.033] (II) Initializing extension XC-MISC
[ 85489.033] (II) Initializing extension SECURITY
[ 85489.033] (II) Initializing extension XFIXES
[ 85489.033] (II) Initializing extension RENDER
[ 85489.033] (II) Initializing extension RANDR
[ 85489.033] (II) Initializing extension COMPOSITE
[ 85489.033] (II) Initializing extension DAMAGE
[ 85489.033] (II) Initializing extension MIT-SCREEN-SAVER
[ 85489.033] (II) Initializing extension DOUBLE-BUFFER
[ 85489.033] (II) Initializing extension RECORD
[ 85489.033] (II) Initializing extension DPMS
[ 85489.033] (II) Initializing extension Present
[ 85489.033] (II) Initializing extension DRI3
[ 85489.033] (II) Initializing extension X-Resource
[ 85489.033] (II) Initializing extension XVideo
[ 85489.033] (II) Initializing extension XVideo-MotionCompensation
[ 85489.033] (II) Initializing extension GLX
[ 85489.034] (II) Initializing extension GLX
[ 85489.034] (II) Indirect GLX disabled.
[ 85489.034] (II) GLX: Another vendor is already registered for screen 0
[ 85489.034] (II) Initializing extension XFree86-VidModeExtension
[ 85489.034] (II) Initializing extension XFree86-DGA
[ 85489.034] (II) Initializing extension XFree86-DRI
[ 85489.034] (II) Initializing extension DRI2
[ 85489.034] (II) Initializing extension NV-GLX
[ 85489.034] (II) Initializing extension NV-CONTROL
[ 85489.034] (II) Initializing extension XINERAMA
[ 85489.084] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 85489.084] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 85489.084] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 85489.084] (**) Power Button: Applying InputClass "system-keyboard"
[ 85489.084] (II) LoadModule: "libinput"
[ 85489.084] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 85489.085] (II) Module libinput: vendor="X.Org Foundation"
[ 85489.085]    compiled for 1.21.1.8, module version = 1.3.0
[ 85489.085]    Module class: X.Org XInput Driver
[ 85489.085]    ABI class: X.Org XInput driver, version 24.4
[ 85489.085] (II) Using input driver 'libinput' for 'Power Button'
[ 85489.085] (**) Power Button: always reports core events
[ 85489.085] (**) Option "Device" "/dev/input/event2"
[ 85489.088] (II) event2  - Power Button: is tagged by udev as: Keyboard
[ 85489.088] (II) event2  - Power Button: device is a keyboard
[ 85489.088] (II) event2  - Power Button: device removed
[ 85489.128] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 85489.128] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 85489.128] (**) Option "xkb_model" "pc105"
[ 85489.128] (**) Option "xkb_layout" "za"
[ 85489.139] (II) event2  - Power Button: is tagged by udev as: Keyboard
[ 85489.139] (II) event2  - Power Button: device is a keyboard
[ 85489.139] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 85489.139] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 85489.139] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 85489.139] (**) Power Button: Applying InputClass "system-keyboard"
[ 85489.139] (II) Using input driver 'libinput' for 'Power Button'
[ 85489.139] (**) Power Button: always reports core events
[ 85489.139] (**) Option "Device" "/dev/input/event1"
[ 85489.140] (II) event1  - Power Button: is tagged by udev as: Keyboard
[ 85489.140] (II) event1  - Power Button: device is a keyboard
[ 85489.140] (II) event1  - Power Button: device removed
[ 85489.174] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 85489.174] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 85489.174] (**) Option "xkb_model" "pc105"
[ 85489.174] (**) Option "xkb_layout" "za"
[ 85489.175] (II) event1  - Power Button: is tagged by udev as: Keyboard
[ 85489.175] (II) event1  - Power Button: device is a keyboard
[ 85489.176] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 85489.176] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 85489.176] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 85489.176] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 85489.176] (II) Using input driver 'libinput' for 'Sleep Button'
[ 85489.176] (**) Sleep Button: always reports core events
[ 85489.176] (**) Option "Device" "/dev/input/event0"
[ 85489.176] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[ 85489.176] (II) event0  - Sleep Button: device is a keyboard
[ 85489.176] (II) event0  - Sleep Button: device removed
[ 85489.214] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[ 85489.214] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[ 85489.214] (**) Option "xkb_model" "pc105"
[ 85489.215] (**) Option "xkb_layout" "za"
[ 85489.215] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[ 85489.215] (II) event0  - Sleep Button: device is a keyboard
[ 85489.216] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event10)
[ 85489.216] (II) No input driver specified, ignoring this device.
[ 85489.216] (II) This device may have been added with another device file.
[ 85489.216] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event13)
[ 85489.216] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event14)
[ 85489.217] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event9)
[ 85489.217] (II) No input driver specified, ignoring this device.
[ 85489.217] (II) This device may have been added with another device file.
[ 85489.217] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP Mouse (/dev/input/event4)
[ 85489.217] (**) ROCCAT ROCCAT Kone EMP Mouse: Applying InputClass "evdev pointer catchall"
[ 85489.217] (**) ROCCAT ROCCAT Kone EMP Mouse: Applying InputClass "libinput pointer catchall"
[ 85489.217] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP Mouse'
[ 85489.217] (**) ROCCAT ROCCAT Kone EMP Mouse: always reports core events
[ 85489.217] (**) Option "Device" "/dev/input/event4"
[ 85489.218] (II) event4  - ROCCAT ROCCAT Kone EMP Mouse: is tagged by udev as: Mouse
[ 85489.218] (II) event4  - ROCCAT ROCCAT Kone EMP Mouse: device is a pointer
[ 85489.218] (II) event4  - ROCCAT ROCCAT Kone EMP Mouse: device removed
[ 85489.254] (II) libinput: ROCCAT ROCCAT Kone EMP Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 85489.254] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:1E7D:2E24.0001/input/input4/event4"
[ 85489.254] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP Mouse" (type: MOUSE, id 9)
[ 85489.255] (**) Option "AccelerationScheme" "none"
[ 85489.255] (**) ROCCAT ROCCAT Kone EMP Mouse: (accel) selected scheme none/0
[ 85489.255] (**) ROCCAT ROCCAT Kone EMP Mouse: (accel) acceleration factor: 2.000
[ 85489.255] (**) ROCCAT ROCCAT Kone EMP Mouse: (accel) acceleration threshold: 4
[ 85489.255] (II) event4  - ROCCAT ROCCAT Kone EMP Mouse: is tagged by udev as: Mouse
[ 85489.256] (II) event4  - ROCCAT ROCCAT Kone EMP Mouse: device is a pointer
[ 85489.256] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP Mouse (/dev/input/mouse0)
[ 85489.256] (II) No input driver specified, ignoring this device.
[ 85489.256] (II) This device may have been added with another device file.
[ 85489.257] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP Consumer Control (/dev/input/event5)
[ 85489.257] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 85489.257] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 85489.257] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "system-keyboard"
[ 85489.257] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP Consumer Control'
[ 85489.257] (**) ROCCAT ROCCAT Kone EMP Consumer Control: always reports core events
[ 85489.257] (**) Option "Device" "/dev/input/event5"
[ 85489.258] (II) event5  - ROCCAT ROCCAT Kone EMP Consumer Control: is tagged by udev as: Keyboard
[ 85489.258] (II) event5  - ROCCAT ROCCAT Kone EMP Consumer Control: device is a keyboard
[ 85489.258] (II) event5  - ROCCAT ROCCAT Kone EMP Consumer Control: device removed
[ 85489.288] (II) libinput: ROCCAT ROCCAT Kone EMP Consumer Control: needs a virtual subdevice
[ 85489.288] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:1E7D:2E24.0001/input/input5/event5"
[ 85489.288] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP Consumer Control" (type: MOUSE, id 10)
[ 85489.288] (**) Option "AccelerationScheme" "none"
[ 85489.288] (**) ROCCAT ROCCAT Kone EMP Consumer Control: (accel) selected scheme none/0
[ 85489.288] (**) ROCCAT ROCCAT Kone EMP Consumer Control: (accel) acceleration factor: 2.000
[ 85489.288] (**) ROCCAT ROCCAT Kone EMP Consumer Control: (accel) acceleration threshold: 4
[ 85489.289] (II) event5  - ROCCAT ROCCAT Kone EMP Consumer Control: is tagged by udev as: Keyboard
[ 85489.289] (II) event5  - ROCCAT ROCCAT Kone EMP Consumer Control: device is a keyboard
[ 85489.290] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP System Control (/dev/input/event6)
[ 85489.290] (**) ROCCAT ROCCAT Kone EMP System Control: Applying InputClass "evdev keyboard catchall"
[ 85489.290] (**) ROCCAT ROCCAT Kone EMP System Control: Applying InputClass "libinput keyboard catchall"
[ 85489.290] (**) ROCCAT ROCCAT Kone EMP System Control: Applying InputClass "system-keyboard"
[ 85489.290] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP System Control'
[ 85489.290] (**) ROCCAT ROCCAT Kone EMP System Control: always reports core events
[ 85489.290] (**) Option "Device" "/dev/input/event6"
[ 85489.290] (II) event6  - ROCCAT ROCCAT Kone EMP System Control: is tagged by udev as: Keyboard
[ 85489.291] (II) event6  - ROCCAT ROCCAT Kone EMP System Control: device is a keyboard
[ 85489.291] (II) event6  - ROCCAT ROCCAT Kone EMP System Control: device removed
[ 85489.304] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:1E7D:2E24.0001/input/input6/event6"
[ 85489.304] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP System Control" (type: KEYBOARD, id 11)
[ 85489.304] (**) Option "xkb_model" "pc105"
[ 85489.304] (**) Option "xkb_layout" "za"
[ 85489.305] (II) event6  - ROCCAT ROCCAT Kone EMP System Control: is tagged by udev as: Keyboard
[ 85489.306] (II) event6  - ROCCAT ROCCAT Kone EMP System Control: device is a keyboard
[ 85489.306] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP (/dev/input/event7)
[ 85489.306] (II) No input driver specified, ignoring this device.
[ 85489.306] (II) This device may have been added with another device file.
[ 85489.307] (II) config/udev: Adding input device ROCCAT ROCCAT Kone EMP (/dev/input/event8)
[ 85489.307] (**) ROCCAT ROCCAT Kone EMP: Applying InputClass "evdev keyboard catchall"
[ 85489.307] (**) ROCCAT ROCCAT Kone EMP: Applying InputClass "libinput keyboard catchall"
[ 85489.307] (**) ROCCAT ROCCAT Kone EMP: Applying InputClass "system-keyboard"
[ 85489.307] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP'
[ 85489.307] (**) ROCCAT ROCCAT Kone EMP: always reports core events
[ 85489.307] (**) Option "Device" "/dev/input/event8"
[ 85489.308] (II) event8  - ROCCAT ROCCAT Kone EMP: is tagged by udev as: Keyboard
[ 85489.308] (II) event8  - ROCCAT ROCCAT Kone EMP: device is a keyboard
[ 85489.308] (II) event8  - ROCCAT ROCCAT Kone EMP: device removed
[ 85489.354] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:1E7D:2E24.0002/input/input8/event8"
[ 85489.354] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP" (type: KEYBOARD, id 12)
[ 85489.354] (**) Option "xkb_model" "pc105"
[ 85489.354] (**) Option "xkb_layout" "za"
[ 85489.355] (II) event8  - ROCCAT ROCCAT Kone EMP: is tagged by udev as: Keyboard
[ 85489.356] (II) event8  - ROCCAT ROCCAT Kone EMP: device is a keyboard
[ 85489.356] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event11)
[ 85489.356] (II) No input driver specified, ignoring this device.
[ 85489.356] (II) This device may have been added with another device file.
[ 85489.356] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event12)
[ 85489.357] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event15)
[ 85489.357] (II) No input driver specified, ignoring this device.
[ 85489.357] (II) This device may have been added with another device file.
[ 85489.357] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event16)
[ 85489.357] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event17)
[ 85489.357] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event18)
[ 85489.358] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event19)
[ 85489.358] (II) No input driver specified, ignoring this device.
[ 85489.358] (II) This device may have been added with another device file.
[ 85489.358] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event20)
[ 85489.358] (II) config/udev: Adding input device PC Speaker (/dev/input/event3)
[ 85489.360] (II) config/udev: Adding input device ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB (/dev/input/event21)
[ 85489.360] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: Applying InputClass "evdev keyboard catchall"
[ 85489.360] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: Applying InputClass "libinput keyboard catchall"
[ 85489.360] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: Applying InputClass "system-keyboard"
[ 85489.360] (II) Using input driver 'libinput' for 'ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB'
[ 85489.360] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: always reports core events
[ 85489.360] (**) Option "Device" "/dev/input/event21"
[ 85489.361] (II) event21 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: is tagged by udev as: Keyboard
[ 85489.361] (II) event21 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device is a keyboard
[ 85489.361] (II) event21 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device removed
[ 85489.384] (**) Option "config_info" "udev:/sys/devices/virtual/input/input25/event21"
[ 85489.384] (II) XINPUT: Adding extended input device "ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB" (type: KEYBOARD, id 13)
[ 85489.384] (**) Option "xkb_model" "pc105"
[ 85489.384] (**) Option "xkb_layout" "za"
[ 85489.385] (II) event21 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: is tagged by udev as: Keyboard
[ 85489.385] (II) event21 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device is a keyboard
[ 85489.385] (II) config/udev: Adding input device ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM (/dev/input/event22)
[ 85489.385] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: Applying InputClass "evdev pointer catchall"
[ 85489.385] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: Applying InputClass "libinput pointer catchall"
[ 85489.385] (II) Using input driver 'libinput' for 'ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM'
[ 85489.385] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: always reports core events
[ 85489.385] (**) Option "Device" "/dev/input/event22"
[ 85489.386] (II) event22 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: is tagged by udev as: Mouse
[ 85489.386] (II) event22 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device is a pointer
[ 85489.386] (II) event22 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device removed
[ 85489.431] (II) libinput: ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 85489.431] (**) Option "config_info" "udev:/sys/devices/virtual/input/input26/event22"
[ 85489.431] (II) XINPUT: Adding extended input device "ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM" (type: MOUSE, id 14)
[ 85489.431] (**) Option "AccelerationScheme" "none"
[ 85489.431] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: (accel) selected scheme none/0
[ 85489.431] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: (accel) acceleration factor: 2.000
[ 85489.431] (**) ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: (accel) acceleration threshold: 4
[ 85489.432] (II) event22 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: is tagged by udev as: Mouse
[ 85489.432] (II) event22 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device is a pointer
[ 85489.432] (II) config/udev: Adding input device ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM (/dev/input/mouse1)
[ 85489.432] (II) No input driver specified, ignoring this device.
[ 85489.432] (II) This device may have been added with another device file.
[ 85489.432] (II) config/udev: Adding input device GaminggearUhidKeyboard (/dev/input/event23)
[ 85489.432] (**) GaminggearUhidKeyboard: Applying InputClass "evdev keyboard catchall"
[ 85489.432] (**) GaminggearUhidKeyboard: Applying InputClass "libinput keyboard catchall"
[ 85489.432] (**) GaminggearUhidKeyboard: Applying InputClass "system-keyboard"
[ 85489.432] (II) Using input driver 'libinput' for 'GaminggearUhidKeyboard'
[ 85489.432] (**) GaminggearUhidKeyboard: always reports core events
[ 85489.432] (**) Option "Device" "/dev/input/event23"
[ 85489.433] (II) event23 - GaminggearUhidKeyboard: is tagged by udev as: Keyboard
[ 85489.433] (II) event23 - GaminggearUhidKeyboard: device is a keyboard
[ 85489.433] (II) event23 - GaminggearUhidKeyboard: device removed
[ 85489.461] (**) Option "config_info" "udev:/sys/devices/virtual/misc/uhid/0003:1E7D:FFFF.0005/input/input27/event23"
[ 85489.461] (II) XINPUT: Adding extended input device "GaminggearUhidKeyboard" (type: KEYBOARD, id 15)
[ 85489.461] (**) Option "xkb_model" "pc105"
[ 85489.461] (**) Option "xkb_layout" "za"
[ 85489.462] (II) event23 - GaminggearUhidKeyboard: is tagged by udev as: Keyboard
[ 85489.462] (II) event23 - GaminggearUhidKeyboard: device is a keyboard
[ 85489.462] (II) config/udev: Adding input device GaminggearUhidMouse (/dev/input/event24)
[ 85489.462] (**) GaminggearUhidMouse: Applying InputClass "evdev pointer catchall"
[ 85489.462] (**) GaminggearUhidMouse: Applying InputClass "libinput pointer catchall"
[ 85489.462] (II) Using input driver 'libinput' for 'GaminggearUhidMouse'
[ 85489.462] (**) GaminggearUhidMouse: always reports core events
[ 85489.462] (**) Option "Device" "/dev/input/event24"
[ 85489.463] (II) event24 - GaminggearUhidMouse: is tagged by udev as: Mouse
[ 85489.463] (II) event24 - GaminggearUhidMouse: device is a pointer
[ 85489.463] (II) event24 - GaminggearUhidMouse: device removed
[ 85489.494] (II) libinput: GaminggearUhidMouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 85489.494] (**) Option "config_info" "udev:/sys/devices/virtual/misc/uhid/0003:1E7D:FFFF.0006/input/input28/event24"
[ 85489.494] (II) XINPUT: Adding extended input device "GaminggearUhidMouse" (type: MOUSE, id 16)
[ 85489.494] (**) Option "AccelerationScheme" "none"
[ 85489.494] (**) GaminggearUhidMouse: (accel) selected scheme none/0
[ 85489.494] (**) GaminggearUhidMouse: (accel) acceleration factor: 2.000
[ 85489.494] (**) GaminggearUhidMouse: (accel) acceleration threshold: 4
[ 85489.495] (II) event24 - GaminggearUhidMouse: is tagged by udev as: Mouse
[ 85489.495] (II) event24 - GaminggearUhidMouse: device is a pointer
[ 85489.496] (II) config/udev: Adding input device GaminggearUhidMouse (/dev/input/mouse2)
[ 85489.496] (II) No input driver specified, ignoring this device.
[ 85489.496] (II) This device may have been added with another device file.
[ 85489.496] (II) config/udev: Adding input device GaminggearUhidMultimedia (/dev/input/event25)
[ 85489.496] (**) GaminggearUhidMultimedia: Applying InputClass "evdev keyboard catchall"
[ 85489.496] (**) GaminggearUhidMultimedia: Applying InputClass "libinput keyboard catchall"
[ 85489.496] (**) GaminggearUhidMultimedia: Applying InputClass "system-keyboard"
[ 85489.496] (II) Using input driver 'libinput' for 'GaminggearUhidMultimedia'
[ 85489.496] (**) GaminggearUhidMultimedia: always reports core events
[ 85489.496] (**) Option "Device" "/dev/input/event25"
[ 85489.497] (II) event25 - GaminggearUhidMultimedia: is tagged by udev as: Keyboard
[ 85489.497] (II) event25 - GaminggearUhidMultimedia: device is a keyboard
[ 85489.497] (II) event25 - GaminggearUhidMultimedia: device removed
[ 85489.525] (II) libinput: GaminggearUhidMultimedia: needs a virtual subdevice
[ 85489.525] (**) Option "config_info" "udev:/sys/devices/virtual/misc/uhid/0003:1E7D:FFFF.0007/input/input29/event25"
[ 85489.525] (II) XINPUT: Adding extended input device "GaminggearUhidMultimedia" (type: MOUSE, id 17)
[ 85489.525] (**) Option "AccelerationScheme" "none"
[ 85489.525] (**) GaminggearUhidMultimedia: (accel) selected scheme none/0
[ 85489.525] (**) GaminggearUhidMultimedia: (accel) acceleration factor: 2.000
[ 85489.525] (**) GaminggearUhidMultimedia: (accel) acceleration threshold: 4
[ 85489.525] (II) event25 - GaminggearUhidMultimedia: is tagged by udev as: Keyboard
[ 85489.525] (II) event25 - GaminggearUhidMultimedia: device is a keyboard
[ 85489.529] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 85489.529] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 85489.529] (**) ROCCAT ROCCAT Kone EMP Consumer Control: Applying InputClass "system-keyboard"
[ 85489.529] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Kone EMP Consumer Control'
[ 85489.529] (**) ROCCAT ROCCAT Kone EMP Consumer Control: always reports core events
[ 85489.529] (**) Option "Device" "/dev/input/event5"
[ 85489.529] (II) libinput: ROCCAT ROCCAT Kone EMP Consumer Control: is a virtual subdevice
[ 85489.529] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:1E7D:2E24.0001/input/input5/event5"
[ 85489.529] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Kone EMP Consumer Control" (type: KEYBOARD, id 18)
[ 85489.529] (**) Option "xkb_model" "pc105"
[ 85489.529] (**) Option "xkb_layout" "za"
[ 85489.529] (**) GaminggearUhidMultimedia: Applying InputClass "evdev keyboard catchall"
[ 85489.529] (**) GaminggearUhidMultimedia: Applying InputClass "libinput keyboard catchall"
[ 85489.529] (**) GaminggearUhidMultimedia: Applying InputClass "system-keyboard"
[ 85489.529] (II) Using input driver 'libinput' for 'GaminggearUhidMultimedia'
[ 85489.529] (**) GaminggearUhidMultimedia: always reports core events
[ 85489.529] (**) Option "Device" "/dev/input/event25"
[ 85489.529] (II) libinput: GaminggearUhidMultimedia: is a virtual subdevice
[ 85489.529] (**) Option "config_info" "udev:/sys/devices/virtual/misc/uhid/0003:1E7D:FFFF.0007/input/input29/event25"
[ 85489.529] (II) XINPUT: Adding extended input device "GaminggearUhidMultimedia" (type: KEYBOARD, id 19)
[ 85495.703] (II) event2  - Power Button: device removed
[ 85495.725] (II) event1  - Power Button: device removed
[ 85495.751] (II) event0  - Sleep Button: device removed
[ 85495.758] (II) event4  - ROCCAT ROCCAT Kone EMP Mouse: device removed
[ 85495.841] (II) event6  - ROCCAT ROCCAT Kone EMP System Control: device removed
[ 85495.858] (II) event8  - ROCCAT ROCCAT Kone EMP: device removed
[ 85495.931] (II) event21 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vKB: device removed
[ 85495.961] (II) event22 - ckb1: CORSAIR K68 RGB Mechanical Gaming Keyboard vM: device removed
[ 85495.995] (II) event23 - GaminggearUhidKeyboard: device removed
[ 85496.014] (II) event24 - GaminggearUhidMouse: device removed
[ 85496.074] (II) event25 - GaminggearUhidMultimedia: device removed
[ 85496.104] (II) event5  - ROCCAT ROCCAT Kone EMP Consumer Control: device removed
[ 85496.149] (II) UnloadModule: "libinput"
[ 85496.150] (II) UnloadModule: "libinput"
[ 85496.568] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 85496.573] (II) Server terminated successfully (0). Closing log file.
These are from the chroot environment.
One of the first things I did. All the kernelsz behave the same.
Including these.
I am able to switch, I just can’t remember if it is with F1 or F2, but once there I am unable to log in. See:
Seeems as if it did, but I have no way to be sure.
Additionally, there is this in journalctl:
$ journalctl -b-1 -p  4 --no-pager --grep='sddm'
Jul 19 15:15:20 Mirdarthos-PC sddm-greeter[698]: Could not locate plasma theme "Arc-Dark" in plasma/desktoptheme/ using search path ("/var/lib/sddm/.local/share", "/usr/local/share", "/usr/share")
Jul 19 15:15:21 Mirdarthos-PC sddm-greeter[698]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/Main.qml:443:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jul 19 15:15:21 Mirdarthos-PC sddm-greeter[698]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/components/VirtualKeyboard.qml:23:1: Type InputPanel unavailable
Jul 19 15:15:21 Mirdarthos-PC sddm-greeter[698]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/Login.qml:95:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jul 19 15:15:21 Mirdarthos-PC sddm-greeter[698]: file:///usr/share/sddm/themes/Sweet-Ambar-Blue/Login.qml:144:5: QML DropShadow: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
Jul 19 15:15:45 Mirdarthos-PC sddm[648]: Auth: sddm-helper (--socket /tmp/sddm-auth-b9701947-aa59-491c-95b4-e1bd285677ec --id 2 --start /usr/bin/sddm-greeter --socket /tmp/sddm-:0-vudhEd --theme /usr/share/sddm/themes/Sweet-Ambar-Blue --user sddm --greeter) crashed (exit code 1)
Jul 19 15:15:45 Mirdarthos-PC sddm[648]: Auth: sddm-helper exited with 1
I have no unmerged .pacnew files. From the chroot environment:
[manjaro /]# pacdiff
[manjaro /]#
I know one of the settings could have been the cause (perhaps the sudoers one?) but sadly don’t know which one.
