Desktop pc.
OS :Manjaro Linux x86-64
Kernel:5.15.57-2-MANJARO
DE : Cinnamon 5.4.8
WM:Mutter
CPU :AMD Ryzen 5 3600 (12) @ 3.600GHz
GPU:RX550 4go
RAM :16go
No fingerprint reader
Certain to be on the correct keyboard layout (fr) and not to have caps lock activated.
User: root and me
Hello everyone, I am writing here because I have had a problem for some time that sometimes, not all the time, occurs when my machine gets locked. And I will need a hand to fix this.
My concern is this: I’m sure I’m entering the correct password but it’s being counted as wrong. I tried via virtual keyboard to be sure but no there too it is counted as fake.
So I went to a TTY to try, again it was counted wrong, finally it was especially indicated to me that following 3 consecutive errors I was put on hold for 3 minutes.
After these 3 minutes I try again, sometimes it passes and sometimes it starts telling me that my password is wrong. In the last case I reboot my machine to solve the problem and not have to wait.
Miscellaneous informations that may be helpful:
About a month ago I wanted to change my password via Cinnamon’s built-in option, I couldn’t do it that way, in fact the field where I had to enter the current password told me that the password was wrong (though I’m 100% sure I’m entering the correct one), so I proceeded via CLI with passwd {$myuser}
, which was successful. I then had to modify it in kwallet and gnome keyring (yes I have both because of Keyweb, which is not a problem on my manjaro KDE machine).
I have never managed to install the virtualbox-guest-ext package from a file because virtualbox asks me for a password which is constantly false when I return. My workaround was to install this pack from the AUR repositories.
This bug(?) also happened to me before upgrading to Cinnamon 5.4.
My research first led me to a problem with PAM and results that were at least a year old. Then to a problem related to a fingerprint reader, which I do not have on my machine but the symptoms stick surprisingly well.
As you can imagine I’m a little lost, I really thank you in advance for your help and your time.
In French
Bonjour à tous et toutes, je viens écrire ici, car j’ai depuis quelque temps un problème qui survient parfois, pas tout le temps, lorsque ma machine se voit verrouiller. Et j’aurai besoin d’un coup de main pour réparer ça.
Mon souci est le suivant : je suis sûr d’entrer le bon mot de passe mais celui-ci est compté comme faux. J’ai essayé via le clavier virtuel pour être sûr de sûr, mais non là aussi il est compté comme faux.
Je suis donc passé sur un TTY pour essayer, là aussi il m’est compté faux, enfin il m’est surtout indiqué que suite à 3 erreurs consécutives je suis mis en attente 3 minutes.
Au bout de ces 3 minutes je ré-essais, parfois ça passe et parfois cela recommence à me dire que mon mot de passe est faux. Dans le derniers cas je reboot ma machine pour résoudre le problème et ne pas avoir à attendre.
Divers informations pouvant être utiles :
Il y a cela un mois environ j’ai voulu modifier mon password via l’option intégrée de Cinnamon, je n’ai pas pu le faire ainsi, en effet le champ où je devais entrer le password actuel me disait que le mot de passe était faux (je suis pourtant sûr à 100 % d’entrer le bon), j’ai donc procédé via CLI avec passwd {$myuser}
, ce qui à été un succès. J’ai eu ensuite à le modifier dans kwallet et gnome keyring (oui j’ai les deux à cause de Keyweb, ce qui ne pose pas de souci sur ma machine manjaro KDE).
Je n’ai jamais réussi à installer depuis un fichier le pack virtualbox-guest-ext
car virtualbox me demande un mot de passe qui est constamment faux quand je rentre. Mon contournement a été d’installer ce pack via les dépôts AUR.
Ce bug(?) m’est aussi arrivé avant la mise à niveau vers Cinnamon 5.4.
Mes recherches m’ont mené dans un premier temps vers un problème avec PAM est des résultats ayant au moins un an d’anciennetés. Puis vers un problème lié à un lecteur d’empreinte digitale, que je n’ai pas sur ma machine mais les symptômes collent étonnamment bien.
Comme vous pouvez vous en doutez je suis un peu perdu, je vous remercie vraiment par avance pour votre aide et votre temps.
