I see a black screen with/with no 3 dots loader while trying to boot the:
manjaro-kde-dev-24.04-development-unstable-240422-linux68.iso,
manjaro-kde-23.1.4-240406-linux66.iso images.
But I was able to load the previous stable ISO of manjaro-kde-23.1.3-240113-linux66.iso. Got inxi output on it.
To boot ISOs I use the ventoy 1.0.97 (UEFI) tool.
It is the fanless mini PC with AMD Ryzen 7730U CPU ( Topton FU02 fanless mini PC is now available with up to a Ryzen 7 7730U processor - Liliputing ).
An SSD is currently not installed):
sudo inxy -Fazy1
Kernel: 6.6.10-1-MANJARO
arch: x86_64
bits: 64
compiler: gcc
v: 13.2.1
clocksource: tsc
available: hpet,acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro misolabel=MANJARO_KDE_2313 quiet systemd.show_status=1 splash driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma
v: 5.27.10
tk: Qt
v: 5.15.12
wm: kwin_x11
dm: SDDM
Distro: Manjaro Linux
base: Arch Linux
Type: Desktop
Mobo: N/A
model: N/A
serial: N/A
UEFI: American Megatrends LLC.
v: DS2203.002
date: 03/26/2023
Device-1: hidpp_battery_0
model: Logitech Wireless Keyboard K360
serial: <filter>
charge: 100% (should be ignored)
rechargeable: yes
status: discharging
Device-2: hidpp_battery_1
model: Logitech Wireless Mouse
serial: <filter>
charge: 55% (should be ignored)
rechargeable: yes
status: discharging
model: AMD Ryzen 7 7730U with Radeon Graphics
socket: FP6
bits: 64
type: MT MCP
arch: Zen 3
gen: 4
level: v3
note: check
built: 2021-22
process: TSMC n7 (7nm)
family: 0x19 (25)
model-id: 0x50 (80)
stepping: 0
microcode: 0xA50000D
Topology:
cpus: 1
cores: 8
tpc: 2
threads: 16
smt: enabled
cache:
L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB
L2: 4 MiB
desc: 8x512 KiB
L3: 16 MiB
desc: 1x16 MiB
Speed (MHz):
avg: 524
high: 1397
min/max: 400/4546
base/boost: 2000/4550
scaling:
driver: amd-pstate-epp
governor: powersave
volts: 1.2 V
ext-clock: 100 MHz
cores:
1: 400
2: 400
3: 400
4: 400
5: 400
6: 400
7: 400
8: 400
9: 400
10: 400
11: 1397
12: 400
13: 400
14: 400
15: 1397
16: 400
bogomips: 63905
Type: gather_data_sampling
status: Not affected
Type: itlb_multihit
Type: l1tf
Type: mds
Type: meltdown
Type: mmio_stale_data
Type: retbleed
Type: spec_rstack_overflow
status: Vulnerable: Safe RET, no microcode
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Type: srbds
Type: tsx_async_abort
Device-1: AMD Barcelo
driver: amdgpu
v: kernel
arch: GCN-5
code: Vega
process: GF 14nm
built: 2017-20
pcie:
gen: 3
speed: 8 GT/s
lanes: 16
link-max:
gen: 4
speed: 16 GT/s
ports:
active: HDMI-A-2
empty: DP-1,DP-2,HDMI-A-1
bus-ID: 03:00.0
chip-ID: 1002:15e7
class-ID: 0300
temp: 39.0 C
Display:
server: X.Org
v: 21.1.10
with: Xwayland
v: 23.2.3
compositor: kwin_x11
driver:
X:
loaded: amdgpu
unloaded: modesetting
alternate: fbdev,vesa
dri: radeonsi
gpu: amdgpu
display-ID: :0
screens: 1
Screen-1: 0
s-res: 1920x1080
s-dpi: 96
s-size: 508x285mm (20.00x11.22")
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-2
mapped: HDMI-A-1
model: Philips PHL 242E2F
serial: <filter>
built: 2021
res: 1920x1080
hz: 60
dpi: 93
gamma: 1.2
size: 527x296mm (20.75x11.65")
diag: 604mm (23.8")
ratio: 16:9
modes:
max: 1920x1080
min: 720x400
API: EGL
v: 1.5
hw:
drv: amd radeonsi
platforms:
device: 0
drv: radeonsi
device: 1
drv: swrast
surfaceless:
drv: radeonsi
x11:
drv: radeonsi
inactive: gbm,wayland
API: OpenGL
v: 4.6
compat-v: 4.5
vendor: amd mesa
v: 23.3.3-manjaro1.1
glx-v: 1.4
direct-render: yes
renderer: AMD Radeon Graphics (radeonsi renoir LLVM 16.0.6 DRM 3.54 6.6.10-1-MANJARO)
device-ID: 1002:15e7
memory: 500 MiB
unified: no
API: Vulkan
v: 1.3.274
layers: N/A
device: 0
type: integrated-gpu
name: AMD Radeon Graphics (RADV RENOIR)
driver: mesa radv
surfaces: xcb,xlib
Device-1: AMD Renoir Radeon High Definition Audio
driver: snd_hda_intel
v: kernel
pcie:
gen: 3
speed: 8 GT/s
lanes: 16
link-max:
gen: 4
speed: 16 GT/s
bus-ID: 03:00.1
chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh
pcie:
gen: 3
speed: 8 GT/s
lanes: 16
link-max:
gen: 4
speed: 16 GT/s
bus-ID: 03:00.5
chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio
v: kernel
pcie:
gen: 3
speed: 8 GT/s
lanes: 16
link-max:
gen: 4
speed: 16 GT/s
bus-ID: 03:00.6
chip-ID: 1022:15e3
class-ID: 0403
API: ALSA
v: k6.6.10-1-MANJARO
status: kernel-api
with: aoss
type: oss-emulator
Server-1: JACK
v: 1.9.22
status: off
tools: N/A
Server-2: PipeWire
v: 1.0.0
status: n/a (root, process)
with:
1: pipewire-pulse
status: active
2: wireplumber
status: active
3: pipewire-alsa
type: plugin
driver: r8169
v: kernel
pcie:
gen: 1
speed: 2.5 GT/s
lanes: 1
port: f000
bus-ID: 01:00.0
chip-ID: 10ec:8168
class-ID: 0200
IF: enp1s0
state: down
mac: <filter>
driver: r8169
v: kernel
pcie:
gen: 1
speed: 2.5 GT/s
lanes: 1
port: e000
bus-ID: 02:00.0
chip-ID: 10ec:8168
class-ID: 0200
IF-ID-1: eno1
state: down
mac: <filter>
Local Storage:
total: 119.38 GiB
used: 0 KiB (0.0%)
ID-1: /dev/sdb
maj-min: 8:16
vendor: Generic
model: MassStorageClass
block-size:
physical: 512 B
logical: 512 B
type: USB
rev: 3.2
spd: 5 Gb/s
lanes: 1
mode: 3.2 gen-1x1
tech: N/A
serial: <filter>
fw-rev: 1538
scheme: GPT
Message: No partition data found.
System Temperatures:
cpu: 43.8 C
mobo: N/A
gpu: amdgpu
temp: 39.0 C
Fan Speeds (rpm): N/A
Processes: 290
Uptime: 12m
wakeups: 0
total: 64 GiB
note: est.
available: 62.23 GiB
used: 2 GiB (3.2%)
Init: systemd
v: 255
default: graphical
tool: systemctl
Compilers:
gcc: 13.2.1
clang: 16.0.6
Packages:
pm: pacman
pkgs: 1215
libs: 327
tools: pamac
pm: flatpak
pkgs: 0
Shell: Sudo (sudo)
v: 1.9.15p5
default: Bash
v: 5.2.21
running-in: konsole
inxi: 3.3.31
@philm , @Yochanan , @linux-aarhus , please note that current problem.
What should I do to trace the bootup error while trying to load latest ISOs on this hardware?
