I am unable to launch winetricks from Application Menu as well as the terminal. Previously, I followed a YouTube guideline to install a program with wine. Winetricks was launched with WINEARCH=win32 WINEPREFIX=~/wine/winworm winetricks. The installed program can still be launched and function properly. But winetricks setting cannot be launced. The following is an extract from the terminal. What could be the cause to this? Thank you.
[simwc@sim-manjaro ~]$ WINEARCH=win32 WINEPREFIX=~/wine/winworm winetricks
Executing mkdir -p /home/simwc/wine
Using winetricks 20201206 - sha256sum: e403ec830c40675225e1d6c1b78cc2da54376ddbeea0405b62b1b9576bba49d1 with wine-5.22 and WINEARCH=win32
(process:4868): Gtk-WARNING **: 08:56:04.966: Locale not supported by C library.
Using the fallback 'C' locale.
(zenity:4868): Gtk-WARNING **: 08:56:05.124: Theme parsing error: gtk.css:2:33: Failed to import: Error opening file /home/simwc/.config/gtk-3.0/window_decorations.css: No such file or directory
winetricks GUI enabled, using zenity 3.32.0
(process:4882): Gtk-WARNING **: 08:56:05.541: Locale not supported by C library.
(zenity:4882): Gtk-WARNING **: 08:56:05.603: Theme parsing error: gtk.css:2:33: Failed to import: Error opening file /home/simwc/.config/gtk-3.0/window_decorations.css: No such file or directory
This option is not available. Please see --help for all possible usages.
yes. that’s the name of the wine prefix or wine bottle. I tried install wine on a different laptop which has not been installed with wine. It gave the same error Error opening file /home/simwc/.config/gtk-3.0/window_decorations.css. What is this actually? I never see this previously where I can run winetricks and install some windows programs.
