I am new to Linux and Manjaro. After the system update today, the Add or Remove Program (pacman-manager) cannot be launched. Whenever it is clicked, a small icon is jumping next to the cursor and an icon shows up in the “taskbar” but simply disappear without the pacman-manager windows shows up.
What could be the cause? Is there anything that I can do to correct the issue?
Hi, I have removed the pamac manager and installed the one with -dev
sudo pacman -S pamac-gtk-dev pamac-cli-dev pamac-common-dev
Now there is chance that the pamac-manager launches. Sometimes yes and sometimes no. This is the message returned if I start it from the terminal if it doesn’t launch.
** Message: 07:34:01.569: flatpak_plugin.vala:345: last flathub appstream refresh is older than 6
** Message: 07:34:01.571: flatpak_plugin.vala:346: refreshing flathub appstream data
(process:4324): GLib-GIO-WARNING **: 07:34:02.391: /etc/xdg/kde-mimeapps.list contains a [Added Associations] group, but it is not permitted here. Only the non-desktop-specific mimeapps.list file may add or remove associations.
I was having the same issue. removing flatpak and snap plugin solved the issue.
when I ran pamac-manager in terminal I got this message.
** Message: 17:46:37.217: flatpak_plugin.vala:125: last flathub appstream refresh is older than 6
** Message: 17:46:37.217: flatpak_plugin.vala:126: refreshing flathub appstream data
(process:5712): GLib-GIO-WARNING **: 17:46:37.526: /etc/xdg/kde-mimeapps.list contains a [Added Associations] group, but it is not permitted here. Only the non-desktop-specific mimeapps.list file may add or remove associations.
(pamac-manager:5712): GLib-GIO-CRITICAL **: 17:46:37.528: g_application_run: assertion 'acquired_context' failed
Hi, these two plugins are no longer installed. I removed the original version and switched to those with -dev version (10.0.0beta-2). It does launch, but sometimes yes and sometimes no. The files currently installed are:
I got the following message when I try to run manjaro-hello from the terminal.
(manjaro-hello:7373): Gtk-WARNING **: 08:07:32.609: Theme parsing error: gtk.css:2:33: Failed to import: Error opening file /home/simwc/.config/gtk-3.0/window_decorations.css: No such file or directory.
(manjaro-hello:7373): Gtk-WARNING **: 08:07:32.622: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(manjaro-hello:7373): Gtk-WARNING **: 08:07:32.623: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(manjaro-hello:7373): Gtk-WARNING **: 08:07:32.624: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
File "/usr/bin/manjaro-hello", line 409, in <module>
hello = Hello()
File "/usr/bin/manjaro-hello", line 172, in __init__
manager.get_modules(self)
File "/usr/bin/manjaro-hello", line 30, in get_modules
app.load(window)
File "/usr/bin/manjaro-hello", line 80, in load
from application_utility.browser.application_browser import ApplicationBrowser
File "/usr/lib/python3.8/site-packages/application_utility/browser/application_browser.py", line 26, in <module>
from application_utility.config.hello_config import HelloConfig
File "/usr/lib/python3.8/site-packages/application_utility/config/hello_config.py", line 25, in <module>
from application_utility.browser.config import Config
File "/usr/lib/python3.8/site-packages/application_utility/browser/config.py", line 27, in <module>
from .data import Data
File "/usr/lib/python3.8/site-packages/application_utility/browser/data.py", line 31, in <module>
gi.require_version("Pamac", "9.0")
File "/usr/lib/python3.8/site-packages/gi/__init__.py", line 129, in require_version
raise ValueError('Namespace %s not available for version %s' %
ValueError: Namespace Pamac not available for version 9.0
I had this issue. Removing the flatpak plugin worked. When I reinstalled the plugin, everything was still okay. But when I re-enabled flatpak support in Pamac, the issue returned.
I faced the same issue and package manger was opening only after removing flatpak plugin. sudo pacman -R pamac-flatpak-plugin
So, I resolved the issue by removing plugin, and ran the below command to reinstall flatpak and plugin. sudo pacman -S flatpak sudo pacman -S pamac-flatpak-plugin
You can try this workaround as it resolved the issue for me and is working perfect now.
