Hi there,
I just installed manjaro on my mac mini 2018 and I am missing wifi and audio drivers(mac mini has built in speaker).
I tried to update proprietary drivers, but for some reason I am missing that option in my os.
Can some good soul help me solving the problem?
thanks
provide formated output from:
inxi -Fazy
mhwd -l && mhwd -li
There are NO “propietary driver” or any driver for apple- ! Apple is designed to be apple and nothing else. if you want to use wifi and audio then buy a wifi and a audio usb-stick and don’t waste time to this crap of electronic.
The first command output
   ~  inxi -Fazy  ✔
Kernel: 5.17.1-1-rt17-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: root=UUID=a91b3fce-cf8f-47d1-8d5c-7f506dba9ccc rw quiet
initrd=boot\initramfs-5.17-rt-x86_64.img
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Apple product: Macmini8,1 v: 1.0
serial: <superuser required> Chassis: type: 9 v: Mac-7BA5B2DFE22DDD8C
Mobo: Apple model: Mac-7BA5B2DFE22DDD8C v: Macmini8,1
serial: <superuser required> UEFI: Apple
v: 1731.100.130.0.0 (iBridge: 19.16.14243.0.0,0) date: 03/17/2022
Info: model: Intel Core i5-8500B bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 9 MiB
desc: 1x9 MiB
Speed (MHz): avg: 3866 high: 4092 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 3501 2: 3682 3: 3992
4: 3987 5: 3946 6: 4092 bogomips: 36000
Type: l1tf
STIBP: disabled, RSB filling
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Apple
driver: i915 v: kernel ports: active: DP-3
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: DP-3 model: Dell U2312HM serial: <filter> built: 2013
res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2 size: 510x287mm (20.08x11.3")
diag: 585mm (23") ratio: 16:9 modes: max: 1920x1080 min: 720x400
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 22.0.3
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
Device-2: Apple Audio driver: N/A pcie: gen: 3 speed: 8 GT/s lanes: 4
bus-ID: 02:00.3 chip-ID: 106b:1803 class-ID: 0401
Sound Server-1: ALSA v: k5.17.1-1-rt17-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Broadcom BCM4364 802.11ac Wireless Network Adapter vendor: Apple
driver: N/A modules: brcmfmac pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14e4:4464 class-ID: 0280
Device-2: Broadcom NetXtreme BCM57766 Gigabit Ethernet PCIe vendor: Apple
driver: tg3 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A
bus-ID: 04:00.0 chip-ID: 14e4:1686 class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 465.92 GiB used: 26.03 GiB (5.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Apple model: SSD AP0512M
size: 465.92 GiB block-size: physical: 4096 B logical: 4096 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1274.100
temp: 34.9 C scheme: GPT
ID-1: / raw-size: 186.37 GiB size: 182.39 GiB (97.86%)
used: 26.02 GiB (14.3%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 300 MiB size: 299.3 MiB (99.76%)
used: 4.6 MiB (1.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 68.0 C pch: 52.0 C mobo: N/A
Processes: 298 Uptime: 1m wakeups: 0 Memory: 31.21 GiB used: 2.12 GiB (6.8%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1
Packages: pacman: 1352 lib: 351 flatpak: 0 Shell: Zsh v: 5.8.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.16
The second one:
   ~  mhwd -l && mhwd -li  ✔  3s 
> 0000:00:02.0 (0300:8086:3e9b) Display controller Intel Corporation:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> Installed PCI configs:
I could buy whole brand new pc
This does not solve the problem…
you have to search for your self if you want to use such exotic hardware. be aware that apple always does terrible hints to prevent using their hardware with different use. i own a apple myself but it’s a nightmare, never again. below is a link that might help you, wifi might work but audio with mac is adifferent story. very often they use several hardware suppliers and exotic hardware-chips from different suppliers that they mix. it’s a question of gamble to get them run.
arch-mac-mini.md
Install Arch Linux on Mac mini
We will be creating dual boot for OS X and Linux with no special boot loader. For other setup, refer to [1].
We will keep all data on an external hard drive, so we do not need huge amount of space for the linux system.
We will install from an USB thumb drive (will need at least 1GB in size), newer Minis do not have CD roms.
Prepare the disk in Mac OS X (El Capitan)
This file has been truncated. show original
for wifi install the broadcom-wl-dkms and the 5.17rt kernel headers
for audio install sof-firmware
then reboot and check
