Hello,
after problems with the latest [Stable Update] 2025-08-30 (I will post there shortly and provide a link. EDIT: see here) I was unable to install a newer Kernel, which was one of the suggested solutions.
Updating gives this error:
[2025-09-01T20:11:09+0200] [ALPM-SCRIPTLET] ==> dkms install --no-depmod v4l2loopback/0.15.1 -k 6.12.44-2-MANJARO
[2025-09-01T20:11:10+0200] [ALPM-SCRIPTLET]
[2025-09-01T20:11:10+0200] [ALPM-SCRIPTLET] Error! Bad return status for module build on kernel: 6.12.44-2-MANJARO (x86_64)
[2025-09-01T20:11:10+0200] [ALPM-SCRIPTLET] Consult /var/lib/dkms/v4l2loopback/0.15.1/build/make.log for more information.
[2025-09-01T20:11:10+0200] [ALPM-SCRIPTLET] ==> WARNING: `dkms install --no-depmod v4l2loopback/0.15.1 -k 6.12.44-2-MANJARO' exited 10
The kernel shows up as “installed” in the kernel-manager, but does not show up in the boot menu.
This is the output of the above mentioned make.log:
DKMS (dkms-3.2.1) make.log for v4l2loopback/0.15.1 for kernel 6.12.44-2-MANJARO (x86_64)
Mon Sep 1 20:11:10 CEST 2025
Building module(s)
# command: make -j12 KERNELRELEASE=6.12.44-2-MANJARO KERNEL_DIR=/usr/lib/modules/6.12.44-2-MANJARO/build v4l2loopback
grep: /etc/dkms/framework.conf.d/*.conf: No such file or directory
++++++ To sign the module, you must set KBUILD_SIGN_KEY/KBUILD_SIGN_CERT to point to the signing key/certificate!
++++++ For your convenience, we try to read these variables as 'mok_signing_key' resp. 'mok_certificate' from /etc/dkms/framework.conf /etc/dkms/framework.conf.d/*.conf
++++++ If your certificate requires a password, pass it via the KBUILD_SIGN_PIN env-var!
++++++ E.g. using 'export KBUILD_SIGN_PIN; read -s -p "Passphrase for signing key : " KBUILD_SIGN_PIN; sudo --preserve-env=KBUILD_SIGN_PIN make sign'
Building v4l2-loopback driver...
make -C /usr/lib/modules/6.12.44-2-MANJARO/build M=/var/lib/dkms/v4l2loopback/0.15.1/build KCPPFLAGS="" modules
make[1]: Entering directory '/usr/lib/modules/6.12.44-2-MANJARO/build'
CC [M] /var/lib/dkms/v4l2loopback/0.15.1/build/v4l2loopback.o
gcc: fatal error: cannot execute 'cc1': posix_spawnp: No such file or directory
compilation terminated.
make[3]: *** [scripts/Makefile.build:229: /var/lib/dkms/v4l2loopback/0.15.1/build/v4l2loopback.o] Error 1
make[3]: *** Waiting for unfinished jobs....
make[2]: *** [/usr/lib/modules/6.12.44-2-MANJARO/build/Makefile:1945: /var/lib/dkms/v4l2loopback/0.15.1/build] Error 2
make[1]: *** [Makefile:224: __sub-make] Error 2
make[1]: Leaving directory '/usr/lib/modules/6.12.44-2-MANJARO/build'
make: *** [Makefile:53: v4l2loopback.ko] Error 2
# exit code: 2
# elapsed time: 00:00:00
As suggested here by philm, I tried to downgrade mesa but without any change. The firmware packages were already up-to-date.
The output of pacman.log after the last update, when I tried to install several kernels without success:
[2025-08-31T09:15:26+0200] [PACMAN] Running 'pacman -Syu'
[2025-08-31T09:15:26+0200] [PACMAN] synchronizing package lists
[2025-08-31T09:15:26+0200] [PACMAN] starting full system upgrade
[2025-08-31T09:33:51+0200] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -S linux612 linux612-headers'
[2025-08-31T09:34:28+0200] [ALPM] transaction started
[2025-08-31T09:34:29+0200] [ALPM] installed linux612 (6.12.44-2)
[2025-08-31T09:34:30+0200] [ALPM] installed linux612-headers (6.12.44-2)
[2025-08-31T09:34:31+0200] [ALPM] transaction completed
[2025-08-31T09:34:31+0200] [ALPM] running '30-systemd-update.hook'...
[2025-08-31T09:34:31+0200] [ALPM] running '60-depmod.hook'...
[2025-08-31T09:34:32+0200] [ALPM] running '70-dkms-install.hook'...
[2025-08-31T09:34:32+0200] [ALPM-SCRIPTLET] ==> dkms install --no-depmod v4l2loopback/0.15.1 -k 6.12.44-2-MANJARO
[2025-08-31T09:34:32+0200] [ALPM-SCRIPTLET] Error! Bad return status for module build on kernel: 6.12.44-2-MANJARO (x86_64)
[2025-08-31T09:34:32+0200] [ALPM-SCRIPTLET] Consult /var/lib/dkms/v4l2loopback/0.15.1/build/make.log for more information.
[2025-08-31T09:34:32+0200] [ALPM-SCRIPTLET] ==> WARNING: `dkms install --no-depmod v4l2loopback/0.15.1 -k 6.12.44-2-MANJARO' exited 10
[2025-08-31T09:34:35+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2025-08-31T09:34:36+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
[2025-08-31T09:34:36+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2025-08-31T09:34:36+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
[2025-08-31T09:34:36+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.12.44-2-MANJARO'
[2025-08-31T09:34:36+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2025-08-31T09:34:36+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2025-08-31T09:34:36+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2025-08-31T09:34:36+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2025-08-31T09:34:36+0200] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2025-08-31T09:34:38+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2025-08-31T09:34:39+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2025-08-31T09:34:39+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2025-08-31T09:34:39+0200] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2025-08-31T09:34:39+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-08-31T09:34:39+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2025-08-31T09:34:39+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2025-08-31T09:34:39+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-08-31T09:34:39+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
[2025-08-31T09:34:40+0200] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2025-08-31T09:34:40+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-08-31T09:34:40+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'fallback'
[2025-08-31T09:34:40+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2025-08-31T09:34:40+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64-fallback.img -S autodetect
[2025-08-31T09:34:40+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.12.44-2-MANJARO'
[2025-08-31T09:34:40+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2025-08-31T09:34:40+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2025-08-31T09:34:40+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2025-08-31T09:34:40+0200] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2025-08-31T09:34:43+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'ast'
[2025-08-31T09:34:45+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2025-08-31T09:34:46+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'wd719x'
[2025-08-31T09:34:46+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'aic94xx'
[2025-08-31T09:34:46+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci_renesas'
[2025-08-31T09:34:48+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2025-08-31T09:34:48+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2025-08-31T09:34:48+0200] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2025-08-31T09:34:48+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-08-31T09:34:48+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2025-08-31T09:34:49+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2025-08-31T09:34:51+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-08-31T09:34:51+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64-fallback.img'
[2025-08-31T09:34:52+0200] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2025-08-31T09:34:52+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-08-31T09:46:53+0200] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -R linux612 linux612-headers'
[2025-08-31T09:46:53+0200] [ALPM] running '60-mkinitcpio-remove.hook'...
[2025-08-31T09:46:53+0200] [ALPM] running '71-dkms-remove.hook'...
[2025-08-31T09:46:53+0200] [ALPM] transaction started
[2025-08-31T09:46:54+0200] [ALPM] removed linux612-headers (6.12.44-2)
[2025-08-31T09:46:55+0200] [ALPM] removed linux612 (6.12.44-2)
[2025-08-31T09:46:55+0200] [ALPM] transaction completed
[2025-08-31T09:46:55+0200] [ALPM] running '30-systemd-update.hook'...
[2025-08-31T09:46:55+0200] [ALPM] running '60-depmod.hook'...
[2025-08-31T09:47:13+0200] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -S linux612 linux612-headers'
[2025-08-31T09:47:13+0200] [ALPM] transaction started
[2025-08-31T09:47:14+0200] [ALPM] installed linux612 (6.12.44-2)
[2025-08-31T09:47:15+0200] [ALPM] installed linux612-headers (6.12.44-2)
[2025-08-31T09:47:15+0200] [ALPM] transaction completed
[2025-08-31T09:47:15+0200] [ALPM] running '30-systemd-update.hook'...
[2025-08-31T09:47:15+0200] [ALPM] running '60-depmod.hook'...
[2025-08-31T09:47:16+0200] [ALPM] running '70-dkms-install.hook'...
[2025-08-31T09:47:16+0200] [ALPM-SCRIPTLET] ==> dkms install --no-depmod v4l2loopback/0.15.1 -k 6.12.44-2-MANJARO
[2025-08-31T09:47:17+0200] [ALPM-SCRIPTLET]
[2025-08-31T09:47:17+0200] [ALPM-SCRIPTLET] Error! Bad return status for module build on kernel: 6.12.44-2-MANJARO (x86_64)
[2025-08-31T09:47:17+0200] [ALPM-SCRIPTLET] Consult /var/lib/dkms/v4l2loopback/0.15.1/build/make.log for more information.
[2025-08-31T09:47:17+0200] [ALPM-SCRIPTLET] ==> WARNING: `dkms install --no-depmod v4l2loopback/0.15.1 -k 6.12.44-2-MANJARO' exited 10
[2025-08-31T09:47:20+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2025-08-31T09:47:20+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
[2025-08-31T09:47:20+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2025-08-31T09:47:20+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
[2025-08-31T09:47:20+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.12.44-2-MANJARO'
[2025-08-31T09:47:20+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2025-08-31T09:47:20+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2025-08-31T09:47:21+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2025-08-31T09:47:21+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2025-08-31T09:47:21+0200] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2025-08-31T09:47:23+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2025-08-31T09:47:24+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2025-08-31T09:47:24+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2025-08-31T09:47:24+0200] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2025-08-31T09:47:24+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-08-31T09:47:24+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2025-08-31T09:47:24+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2025-08-31T09:47:24+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-08-31T09:47:24+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
[2025-08-31T09:47:24+0200] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2025-08-31T09:47:24+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-08-31T09:47:24+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'fallback'
[2025-08-31T09:47:24+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2025-08-31T09:47:24+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64-fallback.img -S autodetect
[2025-08-31T09:47:24+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.12.44-2-MANJARO'
[2025-08-31T09:47:24+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2025-08-31T09:47:24+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2025-08-31T09:47:25+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2025-08-31T09:47:25+0200] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2025-08-31T09:47:27+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'ast'
[2025-08-31T09:47:29+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2025-08-31T09:47:30+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'wd719x'
[2025-08-31T09:47:30+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'aic94xx'
[2025-08-31T09:47:31+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci_renesas'
[2025-08-31T09:47:32+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2025-08-31T09:47:33+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2025-08-31T09:47:33+0200] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2025-08-31T09:47:33+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-08-31T09:47:33+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2025-08-31T09:47:34+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2025-08-31T09:47:35+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-08-31T09:47:35+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64-fallback.img'
[2025-08-31T09:47:36+0200] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2025-08-31T09:47:36+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-08-31T09:48:10+0200] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -S linux616 linux616-headers'
[2025-08-31T09:48:41+0200] [ALPM] transaction started
[2025-08-31T09:48:42+0200] [ALPM] installed linux616 (6.16.4-2)
[2025-08-31T09:48:43+0200] [ALPM] installed linux616-headers (6.16.4-2)
[2025-08-31T09:48:43+0200] [ALPM] transaction completed
[2025-08-31T09:48:43+0200] [ALPM] running '30-systemd-update.hook'...
[2025-08-31T09:48:43+0200] [ALPM] running '60-depmod.hook'...
[2025-08-31T09:48:44+0200] [ALPM] running '70-dkms-install.hook'...
[2025-08-31T09:48:44+0200] [ALPM-SCRIPTLET] ==> dkms install --no-depmod v4l2loopback/0.15.1 -k 6.16.4-2-MANJARO
[2025-08-31T09:48:45+0200] [ALPM-SCRIPTLET]
[2025-08-31T09:48:45+0200] [ALPM-SCRIPTLET] Error! Bad return status for module build on kernel: 6.16.4-2-MANJARO (x86_64)
[2025-08-31T09:48:45+0200] [ALPM-SCRIPTLET] Consult /var/lib/dkms/v4l2loopback/0.15.1/build/make.log for more information.
[2025-08-31T09:48:45+0200] [ALPM-SCRIPTLET] ==> WARNING: `dkms install --no-depmod v4l2loopback/0.15.1 -k 6.16.4-2-MANJARO' exited 10
[2025-08-31T09:48:48+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2025-08-31T09:48:48+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux616.preset: 'default'
[2025-08-31T09:48:48+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2025-08-31T09:48:48+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.16-x86_64 -g /boot/initramfs-6.16-x86_64.img
[2025-08-31T09:48:48+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.16.4-2-MANJARO'
[2025-08-31T09:48:48+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2025-08-31T09:48:48+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2025-08-31T09:48:49+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2025-08-31T09:48:49+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2025-08-31T09:48:49+0200] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2025-08-31T09:48:51+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2025-08-31T09:48:52+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2025-08-31T09:48:52+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2025-08-31T09:48:52+0200] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2025-08-31T09:48:52+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-08-31T09:48:52+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2025-08-31T09:48:52+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2025-08-31T09:48:52+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-08-31T09:48:52+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.16-x86_64.img'
[2025-08-31T09:48:52+0200] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2025-08-31T09:48:52+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-08-31T09:48:52+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux616.preset: 'fallback'
[2025-08-31T09:48:52+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2025-08-31T09:48:52+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.16-x86_64 -g /boot/initramfs-6.16-x86_64-fallback.img -S autodetect
[2025-08-31T09:48:52+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.16.4-2-MANJARO'
[2025-08-31T09:48:52+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2025-08-31T09:48:52+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2025-08-31T09:48:53+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2025-08-31T09:48:53+0200] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2025-08-31T09:48:56+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'ast'
[2025-08-31T09:48:58+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2025-08-31T09:48:59+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'wd719x'
[2025-08-31T09:48:59+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'aic94xx'
[2025-08-31T09:48:59+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci_renesas'
[2025-08-31T09:49:01+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2025-08-31T09:49:02+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2025-08-31T09:49:02+0200] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2025-08-31T09:49:02+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-08-31T09:49:02+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2025-08-31T09:49:02+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2025-08-31T09:49:04+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-08-31T09:49:04+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.16-x86_64-fallback.img'
[2025-08-31T09:49:05+0200] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2025-08-31T09:49:05+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-09-01T20:00:00+0200] [PACMAN] Running 'pacman -Syu'
[2025-09-01T20:00:00+0200] [PACMAN] synchronizing package lists
[2025-09-01T20:00:06+0200] [PACMAN] starting full system upgrade
[2025-09-01T20:00:12+0200] [ALPM] running '00-timeshift-autosnap.hook'...
[2025-09-01T20:00:12+0200] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2025-09-01T20:00:12+0200] [ALPM] transaction started
[2025-09-01T20:00:12+0200] [ALPM] upgraded libpamac (11.7.3-5 -> 11.7.3-7)
[2025-09-01T20:00:12+0200] [ALPM] upgraded libpamac-flatpak-plugin (11.7.3-5 -> 11.7.3-7)
[2025-09-01T20:00:12+0200] [ALPM] upgraded libpamac-snap-plugin (11.7.3-5 -> 11.7.3-7)
[2025-09-01T20:00:12+0200] [ALPM] transaction completed
[2025-09-01T20:00:12+0200] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2025-09-01T20:00:13+0200] [ALPM] running '30-systemd-restart-marked.hook'...
[2025-09-01T20:00:13+0200] [ALPM] running '30-systemd-update.hook'...
[2025-09-01T20:00:13+0200] [ALPM] running '30-update-mime-database.hook'...
[2025-09-01T20:00:13+0200] [ALPM] running 'dbus-reload.hook'...
[2025-09-01T20:00:15+0200] [PACMAN] Running 'pacman -Syu'
[2025-09-01T20:00:15+0200] [PACMAN] synchronizing package lists
[2025-09-01T20:00:15+0200] [PACMAN] starting full system upgrade
[2025-09-01T20:00:24+0200] [PACMAN] Running 'pacman -Syu'
[2025-09-01T20:00:24+0200] [PACMAN] synchronizing package lists
[2025-09-01T20:00:24+0200] [PACMAN] starting full system upgrade
[2025-09-01T20:00:36+0200] [PACMAN] Running 'pacman -Syu'
[2025-09-01T20:00:36+0200] [PACMAN] synchronizing package lists
[2025-09-01T20:00:36+0200] [PACMAN] starting full system upgrade
[2025-09-01T20:01:02+0200] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -R linux616 linux616-headers'
[2025-09-01T20:01:02+0200] [ALPM] running '60-mkinitcpio-remove.hook'...
[2025-09-01T20:01:03+0200] [ALPM] running '71-dkms-remove.hook'...
[2025-09-01T20:01:03+0200] [ALPM] transaction started
[2025-09-01T20:01:04+0200] [ALPM] removed linux616-headers (6.16.4-2)
[2025-09-01T20:01:04+0200] [ALPM] removed linux616 (6.16.4-2)
[2025-09-01T20:01:04+0200] [ALPM] transaction completed
[2025-09-01T20:01:04+0200] [ALPM] running '30-systemd-update.hook'...
[2025-09-01T20:01:05+0200] [ALPM] running '60-depmod.hook'...
[2025-09-01T20:01:18+0200] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -R linux612 linux612-headers'
[2025-09-01T20:01:18+0200] [ALPM] running '60-mkinitcpio-remove.hook'...
[2025-09-01T20:01:19+0200] [ALPM] running '71-dkms-remove.hook'...
[2025-09-01T20:01:19+0200] [ALPM] transaction started
[2025-09-01T20:01:20+0200] [ALPM] removed linux612-headers (6.12.44-2)
[2025-09-01T20:01:20+0200] [ALPM] removed linux612 (6.12.44-2)
[2025-09-01T20:01:20+0200] [ALPM] transaction completed
[2025-09-01T20:01:20+0200] [ALPM] running '30-systemd-update.hook'...
[2025-09-01T20:01:20+0200] [ALPM] running '60-depmod.hook'...
[2025-09-01T20:01:47+0200] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -S linux66 linux66-headers'
[2025-09-01T20:02:13+0200] [ALPM] transaction started
[2025-09-01T20:02:13+0200] [ALPM] installed linux66 (6.6.103-2)
[2025-09-01T20:02:15+0200] [ALPM] installed linux66-headers (6.6.103-2)
[2025-09-01T20:02:15+0200] [ALPM] transaction completed
[2025-09-01T20:02:15+0200] [ALPM] running '30-systemd-update.hook'...
[2025-09-01T20:02:15+0200] [ALPM] running '60-depmod.hook'...
[2025-09-01T20:02:16+0200] [ALPM] running '70-dkms-install.hook'...
[2025-09-01T20:02:16+0200] [ALPM-SCRIPTLET] ==> dkms install --no-depmod v4l2loopback/0.15.1 -k 6.6.103-2-MANJARO
[2025-09-01T20:02:17+0200] [ALPM-SCRIPTLET]
[2025-09-01T20:02:17+0200] [ALPM-SCRIPTLET] Error! Bad return status for module build on kernel: 6.6.103-2-MANJARO (x86_64)
[2025-09-01T20:02:17+0200] [ALPM-SCRIPTLET] Consult /var/lib/dkms/v4l2loopback/0.15.1/build/make.log for more information.
[2025-09-01T20:02:17+0200] [ALPM-SCRIPTLET] ==> WARNING: `dkms install --no-depmod v4l2loopback/0.15.1 -k 6.6.103-2-MANJARO' exited 10
[2025-09-01T20:02:19+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2025-09-01T20:02:20+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
[2025-09-01T20:02:20+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2025-09-01T20:02:20+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
[2025-09-01T20:02:20+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.6.103-2-MANJARO'
[2025-09-01T20:02:20+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2025-09-01T20:02:20+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2025-09-01T20:02:20+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2025-09-01T20:02:20+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2025-09-01T20:02:20+0200] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2025-09-01T20:02:22+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2025-09-01T20:02:22+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2025-09-01T20:02:23+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2025-09-01T20:02:23+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2025-09-01T20:02:23+0200] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2025-09-01T20:02:23+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-09-01T20:02:23+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2025-09-01T20:02:23+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2025-09-01T20:02:23+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-09-01T20:02:23+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
[2025-09-01T20:02:23+0200] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2025-09-01T20:02:23+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-09-01T20:02:23+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'fallback'
[2025-09-01T20:02:23+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2025-09-01T20:02:23+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64-fallback.img -S autodetect
[2025-09-01T20:02:23+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.6.103-2-MANJARO'
[2025-09-01T20:02:23+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2025-09-01T20:02:23+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2025-09-01T20:02:24+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2025-09-01T20:02:24+0200] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2025-09-01T20:02:26+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'ast'
[2025-09-01T20:02:28+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2025-09-01T20:02:29+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'wd719x'
[2025-09-01T20:02:29+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'aic94xx'
[2025-09-01T20:02:29+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2025-09-01T20:02:30+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2025-09-01T20:02:31+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2025-09-01T20:02:31+0200] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2025-09-01T20:02:31+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-09-01T20:02:31+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2025-09-01T20:02:32+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2025-09-01T20:02:33+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-09-01T20:02:33+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64-fallback.img'
[2025-09-01T20:02:34+0200] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2025-09-01T20:02:34+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-09-01T20:06:57+0200] [ALPM] running '00-timeshift-autosnap.hook'...
[2025-09-01T20:06:57+0200] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2025-09-01T20:06:57+0200] [ALPM] transaction started
[2025-09-01T20:06:57+0200] [ALPM] reinstalled dkms (3.2.1-1)
[2025-09-01T20:06:57+0200] [ALPM] transaction completed
[2025-09-01T20:06:57+0200] [ALPM] running '30-systemd-update.hook'...
[2025-09-01T20:08:20+0200] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -S linux61-rt linux61-rt-headers'
[2025-09-01T20:08:44+0200] [ALPM] transaction started
[2025-09-01T20:08:44+0200] [ALPM] installed linux61-rt (6.1.146_rt53-3)
[2025-09-01T20:08:46+0200] [ALPM] installed linux61-rt-headers (6.1.146_rt53-3)
[2025-09-01T20:08:46+0200] [ALPM] transaction completed
[2025-09-01T20:08:46+0200] [ALPM] running '30-systemd-update.hook'...
[2025-09-01T20:08:46+0200] [ALPM] running '60-depmod.hook'...
[2025-09-01T20:08:47+0200] [ALPM] running '70-dkms-install.hook'...
[2025-09-01T20:08:47+0200] [ALPM-SCRIPTLET] ==> dkms install --no-depmod v4l2loopback/0.15.1 -k 6.1.146-3-rt53-MANJARO
[2025-09-01T20:08:47+0200] [ALPM-SCRIPTLET] Error! Bad return status for module build on kernel: 6.1.146-3-rt53-MANJARO (x86_64)
[2025-09-01T20:08:47+0200] [ALPM-SCRIPTLET] Consult /var/lib/dkms/v4l2loopback/0.15.1/build/make.log for more information.
[2025-09-01T20:08:47+0200] [ALPM-SCRIPTLET] ==> WARNING: `dkms install --no-depmod v4l2loopback/0.15.1 -k 6.1.146-3-rt53-MANJARO' exited 10
[2025-09-01T20:08:50+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2025-09-01T20:08:50+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux61-rt.preset: 'default'
[2025-09-01T20:08:50+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2025-09-01T20:08:50+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.1-rt-x86_64 -g /boot/initramfs-6.1-rt-x86_64.img
[2025-09-01T20:08:50+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.1.146-3-rt53-MANJARO'
[2025-09-01T20:08:50+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2025-09-01T20:08:51+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2025-09-01T20:08:51+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2025-09-01T20:08:51+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2025-09-01T20:08:51+0200] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2025-09-01T20:08:53+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2025-09-01T20:08:53+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2025-09-01T20:08:53+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2025-09-01T20:08:53+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2025-09-01T20:08:53+0200] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2025-09-01T20:08:53+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-09-01T20:08:53+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2025-09-01T20:08:53+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2025-09-01T20:08:54+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-09-01T20:08:54+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.1-rt-x86_64.img'
[2025-09-01T20:08:54+0200] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2025-09-01T20:08:54+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-09-01T20:08:54+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux61-rt.preset: 'fallback'
[2025-09-01T20:08:54+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2025-09-01T20:08:54+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.1-rt-x86_64 -g /boot/initramfs-6.1-rt-x86_64-fallback.img -S autodetect
[2025-09-01T20:08:54+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.1.146-3-rt53-MANJARO'
[2025-09-01T20:08:54+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2025-09-01T20:08:54+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2025-09-01T20:08:54+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2025-09-01T20:08:54+0200] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2025-09-01T20:08:56+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'ast'
[2025-09-01T20:08:58+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2025-09-01T20:08:59+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'wd719x'
[2025-09-01T20:08:59+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'aic94xx'
[2025-09-01T20:08:59+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2025-09-01T20:09:00+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2025-09-01T20:09:01+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2025-09-01T20:09:01+0200] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2025-09-01T20:09:01+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-09-01T20:09:01+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2025-09-01T20:09:02+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2025-09-01T20:09:03+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-09-01T20:09:03+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.1-rt-x86_64-fallback.img'
[2025-09-01T20:09:04+0200] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2025-09-01T20:09:04+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-09-01T20:09:44+0200] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -R linux61 linux61-headers linux61-rt-headers linux61-rt'
[2025-09-01T20:09:44+0200] [ALPM] running '60-mkinitcpio-remove.hook'...
[2025-09-01T20:09:45+0200] [ALPM] running '71-dkms-remove.hook'...
[2025-09-01T20:09:46+0200] [ALPM-SCRIPTLET] ==> dkms remove --no-depmod v4l2loopback/0.15.1 -k 6.1.149-2-MANJARO
[2025-09-01T20:09:46+0200] [ALPM-SCRIPTLET] ==> depmod 6.1.149-2-MANJARO
[2025-09-01T20:09:49+0200] [ALPM] transaction started
[2025-09-01T20:09:49+0200] [ALPM] removed linux61-rt (6.1.146_rt53-3)
[2025-09-01T20:09:50+0200] [ALPM] removed linux61-rt-headers (6.1.146_rt53-3)
[2025-09-01T20:09:51+0200] [ALPM] removed linux61-headers (6.1.149-2)
[2025-09-01T20:09:51+0200] [ALPM] removed linux61 (6.1.149-2)
[2025-09-01T20:09:51+0200] [ALPM] transaction completed
[2025-09-01T20:09:51+0200] [ALPM] running '30-systemd-update.hook'...
[2025-09-01T20:09:51+0200] [ALPM] running '60-depmod.hook'...
[2025-09-01T20:09:59+0200] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -R linux66 linux66-headers'
[2025-09-01T20:09:59+0200] [ALPM] running '60-mkinitcpio-remove.hook'...
[2025-09-01T20:09:59+0200] [ALPM] running '71-dkms-remove.hook'...
[2025-09-01T20:09:59+0200] [ALPM] transaction started
[2025-09-01T20:10:00+0200] [ALPM] removed linux66-headers (6.6.103-2)
[2025-09-01T20:10:00+0200] [ALPM] removed linux66 (6.6.103-2)
[2025-09-01T20:10:01+0200] [ALPM] transaction completed
[2025-09-01T20:10:01+0200] [ALPM] running '30-systemd-update.hook'...
[2025-09-01T20:10:01+0200] [ALPM] running '60-depmod.hook'...
[2025-09-01T20:10:08+0200] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -S linux61 linux61-headers'
[2025-09-01T20:10:08+0200] [ALPM] transaction started
[2025-09-01T20:10:09+0200] [ALPM] installed linux61 (6.1.149-2)
[2025-09-01T20:10:10+0200] [ALPM] installed linux61-headers (6.1.149-2)
[2025-09-01T20:10:10+0200] [ALPM] transaction completed
[2025-09-01T20:10:11+0200] [ALPM] running '30-systemd-update.hook'...
[2025-09-01T20:10:11+0200] [ALPM] running '60-depmod.hook'...
[2025-09-01T20:10:11+0200] [ALPM] running '70-dkms-install.hook'...
[2025-09-01T20:10:11+0200] [ALPM-SCRIPTLET] ==> dkms install --no-depmod v4l2loopback/0.15.1 -k 6.1.149-2-MANJARO
[2025-09-01T20:10:12+0200] [ALPM-SCRIPTLET]
[2025-09-01T20:10:12+0200] [ALPM-SCRIPTLET] Error! Bad return status for module build on kernel: 6.1.149-2-MANJARO (x86_64)
[2025-09-01T20:10:12+0200] [ALPM-SCRIPTLET] Consult /var/lib/dkms/v4l2loopback/0.15.1/build/make.log for more information.
[2025-09-01T20:10:12+0200] [ALPM-SCRIPTLET] ==> WARNING: `dkms install --no-depmod v4l2loopback/0.15.1 -k 6.1.149-2-MANJARO' exited 10
[2025-09-01T20:10:15+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2025-09-01T20:10:15+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
[2025-09-01T20:10:15+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2025-09-01T20:10:15+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.1-x86_64 -g /boot/initramfs-6.1-x86_64.img
[2025-09-01T20:10:15+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.1.149-2-MANJARO'
[2025-09-01T20:10:15+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2025-09-01T20:10:15+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2025-09-01T20:10:15+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2025-09-01T20:10:16+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2025-09-01T20:10:16+0200] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2025-09-01T20:10:17+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2025-09-01T20:10:18+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2025-09-01T20:10:18+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2025-09-01T20:10:18+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2025-09-01T20:10:18+0200] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2025-09-01T20:10:18+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-09-01T20:10:18+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2025-09-01T20:10:18+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2025-09-01T20:10:18+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-09-01T20:10:18+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.1-x86_64.img'
[2025-09-01T20:10:18+0200] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2025-09-01T20:10:19+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-09-01T20:10:19+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
[2025-09-01T20:10:19+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2025-09-01T20:10:19+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.1-x86_64 -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect
[2025-09-01T20:10:19+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.1.149-2-MANJARO'
[2025-09-01T20:10:19+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2025-09-01T20:10:19+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2025-09-01T20:10:19+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2025-09-01T20:10:19+0200] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2025-09-01T20:10:21+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'ast'
[2025-09-01T20:10:23+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2025-09-01T20:10:24+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'wd719x'
[2025-09-01T20:10:24+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'aic94xx'
[2025-09-01T20:10:24+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2025-09-01T20:10:25+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2025-09-01T20:10:26+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2025-09-01T20:10:26+0200] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2025-09-01T20:10:26+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-09-01T20:10:26+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2025-09-01T20:10:27+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2025-09-01T20:10:28+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-09-01T20:10:28+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.1-x86_64-fallback.img'
[2025-09-01T20:10:29+0200] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2025-09-01T20:10:29+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-09-01T20:10:39+0200] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -S linux66 linux66-headers'
[2025-09-01T20:10:40+0200] [ALPM] transaction started
[2025-09-01T20:10:40+0200] [ALPM] installed linux66 (6.6.103-2)
[2025-09-01T20:10:42+0200] [ALPM] installed linux66-headers (6.6.103-2)
[2025-09-01T20:10:42+0200] [ALPM] transaction completed
[2025-09-01T20:10:42+0200] [ALPM] running '30-systemd-update.hook'...
[2025-09-01T20:10:42+0200] [ALPM] running '60-depmod.hook'...
[2025-09-01T20:10:43+0200] [ALPM] running '70-dkms-install.hook'...
[2025-09-01T20:10:43+0200] [ALPM-SCRIPTLET] ==> dkms install --no-depmod v4l2loopback/0.15.1 -k 6.6.103-2-MANJARO
[2025-09-01T20:10:44+0200] [ALPM-SCRIPTLET]
[2025-09-01T20:10:44+0200] [ALPM-SCRIPTLET] Error! Bad return status for module build on kernel: 6.6.103-2-MANJARO (x86_64)
[2025-09-01T20:10:44+0200] [ALPM-SCRIPTLET] Consult /var/lib/dkms/v4l2loopback/0.15.1/build/make.log for more information.
[2025-09-01T20:10:44+0200] [ALPM-SCRIPTLET] ==> WARNING: `dkms install --no-depmod v4l2loopback/0.15.1 -k 6.6.103-2-MANJARO' exited 10
[2025-09-01T20:10:46+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2025-09-01T20:10:47+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
[2025-09-01T20:10:47+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2025-09-01T20:10:47+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
[2025-09-01T20:10:47+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.6.103-2-MANJARO'
[2025-09-01T20:10:47+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2025-09-01T20:10:47+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2025-09-01T20:10:47+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2025-09-01T20:10:47+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2025-09-01T20:10:47+0200] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2025-09-01T20:10:49+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2025-09-01T20:10:49+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2025-09-01T20:10:50+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2025-09-01T20:10:50+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2025-09-01T20:10:50+0200] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2025-09-01T20:10:50+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-09-01T20:10:50+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2025-09-01T20:10:50+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2025-09-01T20:10:50+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-09-01T20:10:50+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
[2025-09-01T20:10:50+0200] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2025-09-01T20:10:50+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-09-01T20:10:50+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'fallback'
[2025-09-01T20:10:50+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2025-09-01T20:10:50+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64-fallback.img -S autodetect
[2025-09-01T20:10:50+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.6.103-2-MANJARO'
[2025-09-01T20:10:50+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2025-09-01T20:10:50+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2025-09-01T20:10:51+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2025-09-01T20:10:51+0200] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2025-09-01T20:10:53+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'ast'
[2025-09-01T20:10:55+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2025-09-01T20:10:56+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'wd719x'
[2025-09-01T20:10:56+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'aic94xx'
[2025-09-01T20:10:56+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2025-09-01T20:10:57+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2025-09-01T20:10:58+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2025-09-01T20:10:58+0200] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2025-09-01T20:10:58+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-09-01T20:10:58+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2025-09-01T20:10:59+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2025-09-01T20:11:00+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-09-01T20:11:00+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64-fallback.img'
[2025-09-01T20:11:01+0200] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2025-09-01T20:11:01+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-09-01T20:11:05+0200] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -S linux612 linux612-headers'
[2025-09-01T20:11:06+0200] [ALPM] transaction started
[2025-09-01T20:11:06+0200] [ALPM] installed linux612 (6.12.44-2)
[2025-09-01T20:11:08+0200] [ALPM] installed linux612-headers (6.12.44-2)
[2025-09-01T20:11:08+0200] [ALPM] transaction completed
[2025-09-01T20:11:08+0200] [ALPM] running '30-systemd-update.hook'...
[2025-09-01T20:11:08+0200] [ALPM] running '60-depmod.hook'...
[2025-09-01T20:11:09+0200] [ALPM] running '70-dkms-install.hook'...
[2025-09-01T20:11:13+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2025-09-01T20:11:13+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
[2025-09-01T20:11:13+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2025-09-01T20:11:13+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
[2025-09-01T20:11:13+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.12.44-2-MANJARO'
[2025-09-01T20:11:13+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2025-09-01T20:11:13+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2025-09-01T20:11:13+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2025-09-01T20:11:13+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2025-09-01T20:11:13+0200] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2025-09-01T20:11:15+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2025-09-01T20:11:16+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2025-09-01T20:11:16+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2025-09-01T20:11:16+0200] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2025-09-01T20:11:16+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-09-01T20:11:16+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2025-09-01T20:11:16+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2025-09-01T20:11:16+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-09-01T20:11:17+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
[2025-09-01T20:11:17+0200] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2025-09-01T20:11:17+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2025-09-01T20:11:17+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'fallback'
[2025-09-01T20:11:17+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2025-09-01T20:11:17+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64-fallback.img -S autodetect
[2025-09-01T20:11:17+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.12.44-2-MANJARO'
[2025-09-01T20:11:17+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2025-09-01T20:11:17+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2025-09-01T20:11:17+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2025-09-01T20:11:17+0200] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2025-09-01T20:11:22+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'ast'
[2025-09-01T20:11:24+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2025-09-01T20:11:25+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'wd719x'
[2025-09-01T20:11:25+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'aic94xx'
[2025-09-01T20:11:25+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci_renesas'
[2025-09-01T20:11:26+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2025-09-01T20:11:27+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2025-09-01T20:11:27+0200] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2025-09-01T20:11:27+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2025-09-01T20:11:27+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2025-09-01T20:11:28+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2025-09-01T20:11:29+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2025-09-01T20:11:30+0200] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64-fallback.img'
[2025-09-01T20:11:30+0200] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2025-09-01T20:11:31+0200] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
Here is inxi:
Kernel: 5.15.190-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=0d60a204-b1a6-4420-90ce-3adfc24742d0 rw quiet apparmor=1
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
Type: Desktop Mobo: Gigabyte model: B550 GAMING X V2 v: x.x
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: F13 date: 07/08/2021
System RAM: total: 16 GiB available: 15.51 GiB used: 2.22 GiB (14.3%)
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
part-no: F4-3200C16-8GVKB serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
microcode: 0xA500012
Topology: cpus: 1x dies: 1 cores: 6 threads: 12 tpc: 2 smt: enabled cache:
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1741 min/max: 1400/4465 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1741 2: 1741 3: 1741
4: 1741 5: 1741 6: 1741 7: 1741 8: 1741 9: 1741 10: 1741 11: 1741 12: 1741
bogomips: 93445
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spec_rstack_overflow mitigation: safe RET
prctl and seccomp
affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6650 XT /
6700S 6800S] vendor: XFX driver: amdgpu v: kernel arch: RDNA-2
code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 03:00.0 chip-ID: 1002:73ef class-ID: 0300
Display: x11 server: X.Org v: 21.1.18 compositor: xfwm4 v: 4.20.0 driver:
X: loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 509x286mm (20.04x11.26")
s-diag: 584mm (22.99")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Acer KG272 S serial: <filter>
built: 2021 res: mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 82 gamma: 1.2
chroma: red: x: 0.655 y: 0.314 green: x: 0.275 y: 0.643 blue: x: 0.153
y: 0.055 white: x: 0.314 y: 0.329 size: 598x336mm (23.54x13.23")
diag: 686mm (27") ratio: 16:9 modes: 1920x1080, 3840x2160, 1680x1050,
1280x1024, 1440x900, 1280x960, 1280x800, 1152x864, 1280x720, 1024x768,
832x624, 800x600, 720x576, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 78 2: parse_edid:
unhandled CEA mode 94 3: parse_edid: unhandled CEA mode 95 4: parse_edid:
unhandled CEA mode 96 5: parse_edid: unhandled CEA mode 97
API: Vulkan v: 1.4.321 layers: 4 device: 0 type: discrete-gpu name: AMD
Radeon RX 6650 XT (RADV NAVI23) driver: mesa radv v: 25.1.9-manjaro1.1
device-ID: 1002:73ef surfaces: N/A
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Info: Tools: api: clinfo,vulkaninfo de: xfce4-display-settings
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.1 chip-ID: 1002:1637
class-ID: 0403
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k5.15.190-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.7 status: off tools: pw-cli
Server-4: PulseAudio v: 17.0-43-g3e2bb status: active
with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
lanes: 1 port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: down mac: <filter>
Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5
chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 465.76 GiB used: 328.82 GiB (70.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: S8542105 temp: 31.9 C
scheme: GPT
ID-1: / raw-size: 66.41 GiB size: 64.81 GiB (97.60%) used: 47.22 GiB (72.9%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 0d60a204-b1a6-4420-90ce-3adfc24742d0
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 320 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 5BA2-97E0
ID-3: /home raw-size: 390.85 GiB size: 383.65 GiB (98.16%)
used: 281.59 GiB (73.4%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: da26921e-231e-4a4e-9757-215d606bc531
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 3a4e00d4-0469-4ec3-b155-1e19e83c347c
Device-1: 1-3:2 info: Integrated Express RGB LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
Device-2: 1-5:3 info: ROCCAT Kone Pro type: mouse,HID
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1e7d:2c88 class-ID: 0300
Device-3: 1-6:4 info: SINO WEALTH USB KEYBOARD type: keyboard,HID
chip-ID: 258a:0001 class-ID: 0300
Device-4: 1-9:5 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 42.4 C mobo: 26.0 C gpu: amdgpu temp: 41.0 C
mem: 38.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Packages: 1635 pm: pacman pkgs: 1621 libs: 476 tools: pamac,yay pm: flatpak
pkgs: 14
Active pacman repo servers in: /etc/pacman.conf
1: https://download.manjaro.org/pkgs/mesa
2: https://download.manjaro.org/pkgs/linux-firmware
1: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 337
1: cpu: 27.8% command: firefox pid: 2168 mem: 536.1 MiB (3.3%)
2: cpu: 15.5% command: firefox pid: 2445 mem: 388.7 MiB (2.4%)
3: cpu: 7.3% command: firefox pid: 2365 mem: 352.5 MiB (2.2%)
4: cpu: 6.9% command: /newerversion started-by: dropbox pid: 2087
mem: 246.3 MiB (1.5%)
5: cpu: 4.9% command: Xorg pid: 1243 mem: 134.7 MiB (0.8%)
Memory top: 5 of 337
1: mem: 536.1 MiB (3.3%) command: firefox pid: 2168 cpu: 27.8%
2: mem: 388.7 MiB (2.4%) command: firefox pid: 2445 cpu: 15.5%
3: mem: 352.5 MiB (2.2%) command: firefox pid: 2365 cpu: 7.3%
4: mem: 246.3 MiB (1.5%) command: /newerversion started-by: dropbox
pid: 2087 cpu: 6.9%
5: mem: 140.5 MiB (0.8%) command: firefox pid: 2290 cpu: 1.1%
Processes: 337 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.19 GiB services: upowerd,xfce4-power-manager
Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.3
running-in: xfce4-terminal inxi: 3.3.39
