pacman -Q | grep "mesa\|rocm"
lib32-mesa 1:24.1.5-1
lib32-mesa-demos 9.0.0-1
lib32-mesa-vdpau 1:24.1.5-1
libva-mesa-driver 1:24.1.5-1
mesa 1:24.1.5-1
mesa-demos 9.0.0-4
mesa-utils 9.0.0-4
rocm-core 6.0.2-2
rocm-device-libs 6.0.2-1
rocm-llvm 6.0.2-1
rocminfo 6.0.2-1
uname -r
6.1.103-1-MANJARO
inxi --full --admin --filter --width
Kernel: 6.1.103-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=9f38c2ae-21ca-4215-822a-0e478276b220 ro quiet splash apparmor=1
Desktop: GNOME v: 46.3.1 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
UEFI: American Megatrends v: 4021 date: 08/10/2021
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3267 high: 4007 min/max: 2200/5980 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3988 2: 3998
3: 3998 4: 3999 5: 4000 6: 2200 7: 4007 8: 2200 9: 2200 10: 3998 11: 2200
12: 4000 13: 3994 14: 3994 15: 3997 16: 2200 17: 3998 18: 4001 19: 3999
20: 2200 21: 2200 22: 2200 23: 2200 24: 2200 25: 2200 26: 2200 27: 3989
28: 3999 29: 2200 30: 4000 31: 3997 32: 3996 bogomips: 256064
Type: spec_rstack_overflow mitigation: safe RET, no microcode
affected
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] driver: amdgpu
v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
empty: DP-2,DP-3,HDMI-A-1 bus-ID: 0c:00.0 chip-ID: 1002:73bf class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: DP-1 mapped: DisplayPort-0 model: Sceptre Y27 serial: <filter>
built: 2020 res: 2560x1440 hz: 165 dpi: 109 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.5-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6900 XT (radeonsi
navi21 LLVM 18.1.8 DRM 3.49 6.1.103-1-MANJARO) device-ID: 1002:73bf
memory: 15.62 GiB unified: no
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: discrete-gpu name: AMD
Radeon RX 6900 XT (RADV NAVI21) driver: mesa radv v: 24.1.5-manjaro1.1
device-ID: 1002:73bf surfaces: xcb,xlib
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.1.103-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.2 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: down mac: <filter>
Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:2
chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 4.09 TiB used: 1.33 TiB (32.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: RKT401.2 temp: 43.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EZAZ-00GGJB0
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A80 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 033 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: SanDisk model: Ultra size: 460.27 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 1.00
scheme: MBR
ID-1: / raw-size: 488.28 GiB size: 479.55 GiB (98.21%)
used: 371.22 GiB (77.4%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 100 MiB size: 99.2 MiB (99.21%)
used: 31.9 MiB (32.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 42.2 C mobo: N/A gpu: amdgpu temp: 59.0 C
mem: 56.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Memory: total: 32 GiB available: 31.25 GiB used: 6.18 GiB (19.8%)
Processes: 516 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: 2008 pm: pacman pkgs: 1989 libs: 568 tools: gnome-software,pamac
pm: flatpak pkgs: 0 pm: snap pkgs: 19 Compilers: clang: 18.1.8 gcc: 14.1.1
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.35
I first tried building and installing opencl-amd
and opencl-amd-dev
from the AUR. Did not work, my 6900xt does not show under the HIP tab in blender. Then I removed those packages and tried following the instructions here: https://wiki.archlinux.org/title/Blender#HIP_on_AMD_open_source_drivers This did not work either. I of course rebooted after installing the packages. I am just trying to get my GPU to appear in blender so that I can use it for the Cycles renderer. Any help would be appreciated.
