Hello everyone!
I am running an Asus PA329Q on an Nvidia GTX980 with proprietary drivers. The monitor is usually connected via DP. A couple of days ago I was forced to use an HDMI cable for a short time. Since that time my monitor is not using the whole screenspace anymore, resulting in a black frame around my desktop. This happens all the time, regardless of which device I connect to the screen. Question: How do I get this back to a normal state?
What I have tried so far:
- resetting the monitor to factory settings
- using the Nvidia Control Center on a Windows machine to find a proper setting
- using
nvidia-settings
on my Manjaro machine to do the same
Kernel: 6.1.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=f8146f0a-3c43-4409-9067-22432d9f961e rw
resume=UUID=550acf7a-c1a1-4b84-a302-e803150a3b4d
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: P8Z77-V LX v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2501
date: 07/21/2014
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
status: discharging
RAM: total: 7.71 GiB used: 3.81 GiB (49.4%)
Info: model: Intel Core i5-3570 bits: 64 type: MCP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1600 min/max: 1600/3800 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1600 2: 1600 3: 1600 4: 1600 bogomips: 27294
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
x2apic xsave xsaveopt xtopology xtpr
disabled
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: NVIDIA GM204 [GeForce GTX 980] vendor: Micro-Star MSI
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:13c0 class-ID: 0300
Device-2: Logitech HD Webcam C510 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 2-1.7:3 chip-ID: 046d:081d class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.8
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 137 s-size: 712x400mm (28.03x15.75")
s-diag: 817mm (32.15")
Monitor-1: DP-0 res: 3840x2160 hz: 60 dpi: 138
size: 708x399mm (27.87x15.71") diag: 813mm (32") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce GTX
980/PCIe/SSE2 direct-render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: ASUSTeK P8Z77-V LX driver: snd_hda_intel bus-ID: 2-1.7:3 v: kernel
bus-ID: 00:1b.0 chip-ID: 046d:081d chip-ID: 8086:1e20 class-ID: 0e02
serial: <filter> class-ID: 0403
Device-2: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
Device-3: Logitech HD Webcam C510 type: USB driver: snd-usb-audio,uvcvideo
Sound API: ALSA v: k6.1.19-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
vendor: ASUSTeK P8P67 and other motherboards driver: r8168 v: 8.050.03-NAPI
modules: r8169 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 1.74 TiB used: 97.84 GiB (5.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 830 Series
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 3B1Q scheme: MBR
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 PRO 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: HD501LJ
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 0-10 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: A-Data model: SE800
size: 953.87 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> scheme: MBR
Optical-1: /dev/sr0 vendor: PLEXTOR model: DVDR PX-810SA rev: 1.00
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 229.37 GiB size: 224.71 GiB (97.97%)
used: 97.84 GiB (43.5%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18 label: N/A uuid: f8146f0a-3c43-4409-9067-22432d9f961e
used: 304 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
label: N/A uuid: 9433-FEB8
dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: 550acf7a-c1a1-4b84-a302-e803150a3b4d
ID-1: /dev/sda1 maj-min: 8:1 size: 350 MiB fs: ntfs label: System-reserviert
uuid: 50F88E70F88E545E
ID-2: /dev/sda2 maj-min: 8:2 size: 118.41 GiB fs: ntfs label: System
uuid: B8969037968FF3E2
ID-3: /dev/sda3 maj-min: 8:3 size: 503 MiB fs: ntfs label: N/A
uuid: E67CB4097CB3D313
ID-4: /dev/sdc1 maj-min: 8:33 size: 465.76 GiB fs: ntfs label: Daten
uuid: B0984DD5984D9B2C
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.7:3 info: Logitech HD Webcam C510 type: Audio,Video
power: 500mA chip-ID: 046d:081d class-ID: 0e02 serial: <filter>
Device-2: 2-1.8:4 info: Logitech Illuminated Keyboard type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 300mA
chip-ID: 046d:c318 class-ID: 0300
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-6: 3-4:10 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 3-4.3:11 info: ASUSTek ProArt Calibration Device
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 0b05:1828 class-ID: 0000
Hub-7: 3-4.4:12 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Hub-8: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 4-2:2 info: Genesys Logic All-in-One Cardreader
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 896mA chip-ID: 05e3:0732 class-ID: 0806 serial: <filter>
Device-2: 4-3:3 info: A-DATA SE800 type: Mass Storage driver: uas
interfaces: 1 rev: 3.2 speed: 5 Gb/s chip-ID: 125f:a89a class-ID: 0806
serial: <filter>
Hub-9: 4-4:10 info: Genesys Logic Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
Hub-10: 4-4.4:11 info: Genesys Logic Hub ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 4-4.4.4:12 info: Genesys Logic SDXC and microSDXC CardReader
power: 896mA chip-ID: 05e3:0743 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 49 C
Processes: 224 Uptime: 37m wakeups: 2 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1821 libs: 408 tools: pamac,yay Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.25
Display:
Screen 0: minimum 8 x 8, current 3840 x 2160, maximum 16384 x 16384
DVI-I-0 disconnected (normal left inverted right x axis y axis)
DVI-I-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-0 connected primary 3840x2160+0+0 (normal left inverted right x axis y axis) 708mm x 399mm
3840x2160 60.00*+ 50.00 29.99 29.97 25.00 24.00 23.98
2560x1440 59.95
1920x1200 59.95 59.88
1920x1080 60.00 59.94 50.00
1680x1050 59.95
1600x1200 60.00
1440x900 59.89
1440x576 50.00
1440x480 59.94
1280x1024 75.02 60.02
1280x960 60.00
1280x720 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
