Unable to enter password when resuming after hibernation
New laptop, new problems! Fresh 26.0 Xfce install except that I indiscriminately copied over my old home folder which has caused a few problems here and there.
I successfully resumed from hibernation for the first time today and when the password prompt comes up I am simply unable to enter any text in the password field. I am able to select the “Enter password” text but that’s it. This popup/box looks different to the one that shows up on inital login and I don’t think I’ve seen it before (I don’t use LightDM on my other laptop). Had to switch over to another tty and kill the process to get in. What gives?
$ inxi -zv8
  Kernel: 6.18.3-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    clocksource: hpet avail: acpi_pm
    root=UUID=870eb8ae-c48f-436c-99c2-6b62527a9763 rw
    cryptdevice=UUID=83bd77f2-59d0-475f-b947-2039918775e0:luks-83bd77f2-59d0-475f-b947-2039918775e0
    root=/dev/mapper/luks-83bd77f2-59d0-475f-b947-2039918775e0 apparmor=1
    security=apparmor
    resume=/dev/mapper/luks-75306fbc-763c-4b9f-a218-3c334deee23f
    udev.log_priority=3
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.51 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver, xscreensaver,
    xscreensaver-systemd avail: light-locker vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: LENOVO product: 21ENS05300 v: ThinkPad P15v Gen 3
  Mobo: LENOVO model: 21ENS05300 serial: <superuser required>
    part-nu: LENOVO_MT_21EN_BU_Think_FM_ThinkPad P15v Gen 3
    uuid: <superuser required> Firmware: UEFI vendor: LENOVO
    v: N3KET34W (1.12 ) date: 12/19/2022
  ID-1: BAT0 charge: 52.2 Wh (93.4%) condition: 55.9/68 Wh (82.2%) power: 14 W
    volts: 12.16 min: 11.52 model: Celxpert 5B10W13961 type: Li-poly
    serial: <filter> charging: status: discharging control: start: 0%
    end: 100% cycles: 370
  System RAM: total: 32 GiB available: 30.62 GiB used: 4.42 GiB (14.5%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 4800 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Hynix
    part-no: HMCG78MEBSA092N serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: KF548S38-16 serial: <filter>
  Info: model: AMD Ryzen 5 PRO 6650H with Radeon Graphics bits: 64
    type: MT MCP arch: Zen 3+ gen: 3 level: v3 note: check built: 2022
    process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
    microcode: 0xA404108
    desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1396 min/max: 413/4566 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1396 2: 1396 3: 1396
    4: 1396 5: 1396 6: 1396 7: 1396 8: 1396 9: 1396 10: 1396 11: 1396 12: 1396
    bogomips: 79052
    xsaves xtopology
    affected
  Device-1: NVIDIA TU117GLM [T600 Laptop GPU] vendor: Lenovo driver: nvidia
    v: 570.207 alternate: nouveau,nova_core,nvidia_drm non-free: 550-580.xx+
    status: current (as of 2025-11; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:1fb6 class-ID: 0302
  Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
    vendor: Lenovo driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5,
    HDMI-A-1, Writeback-1 bus-ID: 67:00.0 chip-ID: 1002:1681 class-ID: 0300
    temp: 39.0 C
  Device-3: IMC Networks Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 13d3:56ff
    class-ID: 0e02
  Display: x11 server: X.org v: 1.21.1.21 compositor: xfwm4 v: 4.20.0
    driver: X: loaded: amdgpu,nvidia unloaded: modesetting,nouveau
    alternate: fbdev,nv,vesa dri: radeonsi gpu: amdgpu display-ID: :0.0
    screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 mapped: eDP model: Lenovo 0x40ba built: 2021 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red:
    x: 0.592 y: 0.369 green: x: 0.357 y: 0.576 blue: x: 0.161 y: 0.122 white:
    x: 0.314 y: 0.329 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800,
    1280x720, 1024x768, 800x600, 640x480
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.3.2-arch1.1
    rembrandt LLVM 21.1.6 DRM 3.64 6.18.3-2-MANJARO) device-ID: 1002:1681
    memory: 500 MiB unified: no
    gpu: nvidia-settings,nvidia-smi x11: xprop,xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 67:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
    driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 67:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Lenovo
    bus-ID: 67:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.18.3-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
  Device-1: Qualcomm QCNFA765 Wireless Network Adapter vendor: Lenovo
    driver: ath11k_pci v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 1
    bus-ID: 02:00.0 chip-ID: 17cb:1103 class-ID: 0280
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 6000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp4s0f0 state: down mac: <filter>
  Device-1: USI driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-3:2 chip-ID: 10ab:9309 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Device-1: luks-83bd77f2-59d0-475f-b947-2039918775e0 maj-min: 253:0
    type: LUKS dm: dm-0 size: 204.5 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 204.5 GiB
  Device-2: luks-75306fbc-763c-4b9f-a218-3c334deee23f maj-min: 253:1
    type: LUKS dm: dm-1 size: 33.67 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 33.68 GiB
  Local Storage: total: 476.95 GiB used: 154.98 GiB (32.5%)
    model: MZVLB256HBHQ-000L7 size: 238.47 GiB block-size: physical: 512 B
    fw-rev: 5M2QEXH7 temp: 32.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Micron model: MTFDKBA256TFK
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 7003V5LN temp: 28.9 C
    scheme: GPT
  ID-1: / raw-size: 204.5 GiB size: 200.23 GiB (97.91%)
    used: 154.98 GiB (77.4%) fs: ext4 dev: /dev/dm-0 maj-min: 253:0
    mapped: luks-83bd77f2-59d0-475f-b947-2039918775e0 label: N/A
    uuid: 870eb8ae-c48f-436c-99c2-6b62527a9763
    used: 688 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 30DA-C1DE
  ID-1: swap-1 type: partition size: 33.67 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/dm-1 maj-min: 253:1
    mapped: luks-75306fbc-763c-4b9f-a218-3c334deee23f label: swap
    uuid: a110eea9-5e82-440a-acee-c7d165d6e7e2
  ID-1: /dev/nvme1n1p1 maj-min: 259:5 size: 260 MiB fs: vfat label: SYSTEM
    uuid: 5062-0000
  ID-2: /dev/nvme1n1p2 maj-min: 259:6 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme1n1p3 maj-min: 259:7 size: 236.25 GiB fs: bitlocker
    label: LAPTOP-J7V3QG4L Windows 17.07.2025
    uuid: f438e4a1-1684-48da-872c-ab33265ca59a
  ID-4: /dev/nvme1n1p4 maj-min: 259:8 size: 1.95 GiB fs: ntfs
    label: WinRE_DRV uuid: 5628648B28646BC5
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
  Device-1: 3-3:2 info: USI type: bluetooth driver: btusb interfaces: 2
    rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 5-1:2 info: IMC Networks Integrated Camera type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:56ff class-ID: 0e02
  Hub-6: 6-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-7: 7-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-8: 8-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-9: 9-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 39.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 0
  Packages: pm: pacman pkgs: 1292 libs: 361 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    2: https://mirror.23m.com/manjaro/stable/$repo/$arch
    3: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
    4: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    5: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    6: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    7: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    8: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 436
  1: cpu: 19.8% command: vivaldi-bin pid: 8543 mem: 680.7 MiB (2.1%)
  2: cpu: 18.2% command: vivaldi-bin pid: 8626 mem: 381.0 MiB (1.2%)
  3: cpu: 14.5% command: exe pid: 7788 mem: 650.1 MiB (2.0%)
  4: cpu: 10.2% command: vivaldi-bin pid: 9769 mem: 276.2 MiB (0.8%)
  5: cpu: 9.0% command: vivaldi-bin pid: 8596 mem: 343.3 MiB (1.0%)
  Memory top: 5 of 436
  1: mem: 680.7 MiB (2.1%) command: vivaldi-bin pid: 8543 cpu: 19.8%
  2: mem: 650.1 MiB (2.0%) command: exe pid: 7788 cpu: 14.5%
  3: mem: 438.0 MiB (1.3%) command: vivaldi-bin pid: 9403 cpu: 6.1%
  4: mem: 381.0 MiB (1.2%) command: vivaldi-bin pid: 8626 cpu: 18.2%
  5: mem: 350.4 MiB (1.1%) command: Xorg pid: 6157 cpu: 4.4%
  Processes: 436 Power: uptime: 2h 3m states: freeze,mem,disk suspend: s2idle
    image: 12.18 GiB services: upowerd,xfce4-power-manager Init: systemd
    v: 258 default: graphical tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Bash v: 5.3.9 running-in: xterm inxi: 3.3.40
Just opened my computer again and this time it apparently shut down instead of hibernating. This is not the first time.
I remember having this problem some time ago.
The solution was to make sure that only one screensaver/locker was enabled, preferably the xfce screensaver.
I have a similar problem after the screensaver set in. A workaround is clicking the username, after that it is possible to enter password.
HTH
schollsky
Thanks for the answers, I’ll look into it if I ever get the same problem again. Right now it’s just shutting down instead of hibernating. I do have xscreensaver installed but I have disabled screensaver in Xfce Power Manager.
Suspend results in a smoking hot laptop in my backpack with no other way out than power cycling it. Disheartening that suspend and hibernate is still not even close to being a solved problem on a 3-4 year old Thinkpad. Makes me wonder what it is that Microsoft is doing.
Making money at your expense.
Oops, that was rather off-topic, wasn’t it…
This is related: Kdewallet fails to start after hibernation
Basically, you need to cleanly stop kdewallet before the call to hibernation, or it will leave a lock file blocking the access
System Settings >> KDE wallet >> Activate “when screen saver starts” (disabled by default)
In XFCE there should be a similar blocking application
Xscreensaver, light locker and xfce4-screensaver will not coexist piecefully. Leave only xfce4 screensaver as locker service. If you then receive an error in a popup notification when trying to lock the screen or standby there is a small setting change in xfconfig to be made.
