Hey! I am new with manjaro linux distro. I am looking for a solution to have normal sound on my computer. I tested almost all the methods(such as alsa, alsamixer, pulse-audio, using preset on easy effects etc) to arch linux on webpage, it still does not work on my computer. The modell is as i mentioned in the title. I really appreciate for the help. If some important information you need is missing just write in the comment and i will answer as soon as possible! Thank you!
Can you post inxi -Fza or lspci | grep Audio ?
How am I possible to reply you with instructions from the terminal or picture here…. I think it’s fastened somewhere in this forum.
Sure!
Kernel: 6.1.21-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=074b9378-cf33-45a6-97b6-782e363093f1 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: ROG Strix G634JZ_G634JZ v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G634JZ v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G634JZ.307 date: 03/10/2023
ID-1: BAT0 charge: 90.5 Wh (100.0%) condition: 90.5/90.0 Wh (100.6%)
volts: 17.6 min: 16.0 model: AS3GYFG3KC R220358 type: Unknown
serial: <filter> status: full
Info: model: 13th Gen Intel Core i9-13980HX bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
microcode: 0x112
Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 2372 high: 2400 min/max: 800/5400:5600:4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 2400 2: 2400 3: 2400
4: 2400 5: 2400 6: 2400 7: 2400 8: 2400 9: 1507 10: 2400 11: 2400 12: 2400
13: 2400 14: 2400 15: 2400 16: 2400 17: 2400 18: 2400 19: 2400 20: 2400
21: 2400 22: 2400 23: 2400 24: 2400 25: 2400 26: 2400 27: 2400 28: 2400
29: 2400 30: 2400 31: 2400 32: 2400 bogomips: 154880
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Raptor Lake-S UHD Graphics vendor: ASUSTeK driver: i915
v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+ ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 0000:00:02.0
chip-ID: 8086:a788 class-ID: 0300
Device-2: Sonix USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-8:3 chip-ID: 322e:2122 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
s-diag: 798mm (31.43")
Monitor-1: eDP-1 model: BOE Display NE160QDM-NM4 built: 2022
res: 2560x1600 hz: 240 dpi: 188 gamma: 1.2 size: 345x215mm (13.58x8.46")
diag: 407mm (16") ratio: 16:10 modes: 2560x1600
API: OpenGL v: 4.6 Mesa 23.0.1 renderer: Mesa Intel Graphics (RPL-S)
direct-render: Yes
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:7a50
class-ID: 0403
API: ALSA v: k6.1.21-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.67 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 0000:00:14.3
chip-ID: 8086:7a70 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: 4000 bus-ID: 0000:6c:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp108s0 state: down mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-14:4
chip-ID: 8087:0033 class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 953.87 GiB used: 11.03 GiB (1.2%)
model: MZVL21T0HCLR-00B00 size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: GXA7601Q temp: 41.9 C scheme: GPT
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 10.96 GiB (11.2%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 68 MiB (26.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 38.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2000
Processes: 436 Uptime: 11m wakeups: 2 Memory: 30.97 GiB
used: 3.12 GiB (10.1%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1140 libs: 328 tools: pamac pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.26
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Here is the problem: the sound server for device 1 is not running.
How can i fix it? Thank you for the response
PulseAudio is shown as active
Replacing PulseAudio with PipeWire will not help if there are problems in ALSA
ROG Tech Specs show some features that may need attention to work correctly in ALSA.
Audio driver snd_hda_intel currently in use does not support digital array microphone. The alternate driver snd_sof_pci_intel_tgl would support the array microphone, but it may not be fully compatible with the audio codec on this system
System may only be using 2 out of 4 speakers and the ‘Smart Amplifiers’ may not be configured correctly for optimal audio level from speakers or headset jack
I suggest you install kernel v6.2, that might have better support for audio codec
sudo mhwd-kernel -i linux62
And get more information to show any issues with ALSA detecting onboard audio
sudo alsa-info.sh --upload
New users are not permitted to post active links, but an inactive link can be posted as preformatted text
e.g. http://alsa-project.org/db/?f=...
Hi! I have tried to write the command you posted here in the terminal. It still doesn’t work. What should i do now? Will it help if i reinstall everything again? Maybe it doesn’t work depends on something is missing when i googled and fixed something? But i have not changed anything since i posted this question in forum until today.
Thank you for the response! Please read the previous message. The previous message i wrote didn’t show the icon when replying someone. I don’t know what the problem is.
I posted 2 commands.
If you click on the icon at the end of each command it will be copied to clipboard and can be pasted in terminal with Shift + Ctrl + V
If 1st command does not work kernel can also be installed using GUI tool Manjaro Settings Manager > Kernel
If 2nd command does not work please post error message response
Yes. I have followed the commands you posted and pasted in the terminal. I have installed the kernel you mentioned according to the first command. Then i have also pasted the second one in the terminal. It shows following:
strong text
[kevin@KevinHan ~]$ sudo alsa-info.sh --upload
/usr/bin/alsa-info.sh: line 661: tree: command not found
Uploading information to www.alsa-project.org … Done!
Your ALSA information is located at http://alsa-project.org/db/?f=d775940d7e0616ae40e1d106211ad51ee0b6b1a3
Please inform the person helping you.
After that, i reboot the computer and speakers still don’t work as normal. What i can hear is, when i go to a random video on youtube. I can hear some electronic buzzy sound or i can’t exactly explain how it sounds like, when i using arrow left or right to go forward 5 seconds or back.
It happens same to me when i had Arch linux on it. I am not sure what the real problem is right now.
I’m looking forward your response. Thank you again!
I don’t understand why when i pressed on the reply button on you message, it does not show i reply to your message. Please read the previous message i wrote. Thanks
I have now tried to reinstall whole linux to make sure everything is fresh as beginning and no misstake happen when installing packages without any crash. So when i try to paste the first command you write is showing following:
strong text
[kevin@KevinHan ~]$ sudo mhwd-kernel -i linux62
Error: Please make sure if the given kernel(s) exist(s).
available kernels:
- linux414
- linux419
- linux44
- linux49
- linux510
- linux513
- linux514
- linux515
- linux516
- linux54
- linux510-rt
- linux515-rt
[kevin@KevinHan ~]$
The second one is showing:
Your ALSA information is located at http://alsa-project.org/db/?f=4fc9d511c98bc9097c8d6c73d992a2ded472d5c9
[kevin@KevinHan ~]$
If kernel 6.1 and 6.2 is not displayed, then pacman -Syyu.
Perhaps the mirrorlist must be updated.
Hi. Even i tried write sudo pacman -Syyu. It shows a lots lines of warning and then
strong text
warning: zxing-cpp: local (2.0.0-1) is newer than extra (1.2.0-1)
resolving dependencies…
:: installing smbclient (4.15.2-1) breaks dependency ‘smbclient>=4.17.5’ required by samba
try this and pls give us the output from terminal … with Symbole </>
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
Thank you! It works now to download linux kernel as mentioned in the previous post.
It shows following message:
strong text
core 163,5 KiB 367 KiB/s 00:00 [####################################] 100%
extra 1860,9 KiB 7,15 MiB/s 00:00 [####################################] 100%
community 7,6 MiB 22,2 MiB/s 00:00 [####################################] 100%
multilib 167,6 KiB 2,56 MiB/s 00:00 [####################################] 100%
Packages (1) linux62-6.2.9-1
Total Download Size: 174,86 MiB
Total Installed Size: 179,22 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages…
linux62-6.2.9-1-x86_64 174,9 MiB 22,5 MiB/s 00:08 [####################################] 100%
(1/1) checking keys in keyring [####################################] 100%
(1/1) checking package integrity [####################################] 100%
(1/1) loading package files [####################################] 100%
(1/1) checking for file conflicts [####################################] 100%
(1/1) checking available disk space [####################################] 100%
:: Processing package changes…
(1/1) installing linux62 [####################################] 100%
Optional dependencies for linux62
wireless-regdb: to set the correct wireless channels of your country [installed]
:: Running post-transaction hooks…
(1/5) Arming ConditionNeedsUpdate…
(2/5) Updating module dependencies…
(3/5) Updating linux initcpios…
==> Building image from preset: /etc/mkinitcpio.d/linux62.preset: ‘default’
→ -k /boot/vmlinuz-6.2-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.2-x86_64.img --microcode /boot/intel-ucode.img
==> Starting build: ‘6.2.9-1-MANJARO’
→ Running build hook: [base]
→ Running build hook: [udev]
→ Running build hook: [autodetect]
→ Running build hook: [modconf]
→ Running build hook: [block]
==> WARNING: Possibly missing firmware for module: ‘xhci_pci’
→ Running build hook: [keyboard]
→ Running build hook: [keymap]
→ Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
→ Running build hook: [plymouth]
→ Running build hook: [filesystems]
→ Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: ‘/boot/initramfs-6.2-x86_64.img’
==> Building image from preset: /etc/mkinitcpio.d/linux62.preset: ‘fallback’
→ -k /boot/vmlinuz-6.2-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.2-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
==> WARNING: Possibly missing firmware for module: ‘qed’
==> WARNING: Possibly missing firmware for module: ‘aic94xx’
==> WARNING: Possibly missing firmware for module: ‘bfa’
==> WARNING: Possibly missing firmware for module: ‘qla2xxx’
==> WARNING: Possibly missing firmware for module: ‘qla1280’
==> WARNING: Possibly missing firmware for module: ‘wd719x’
==> Creating gzip-compressed initcpio image: ‘/boot/initramfs-6.2-x86_64-fallback.img’
(4/5) Refreshing PackageKit…
(5/5) Updating Grub-Bootmenu
Generating grub configuration file …
Found linux image: /boot/vmlinuz-6.2-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.2-x86_64.img
Found initrd fallback image: /boot/initramfs-6.2-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
Adding boot menu entry for UEFI Firmware Settings …
Root filesystem isn’t btrfs
If you think an error has occurred, please file a bug report at “GitHub - Antynea/grub-btrfs: Include btrfs snapshots at boot options. (Grub menu)”
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
[kevin@KevinHan ~]$
It shows following message after i pasted in the second command as it mentioned before:
lspci: Unable to load libkmod resources: error -2
Your ALSA information is located at http://alsa-project.org/db/?f=e4fe85be124ed35c792aecebb176c510b0f2c6aa
[kevin@KevinHan ~]$
The sound is till not back…
quick overview:
loaded kernel = Kernel release: 6.1.19-1-MANJARO
current version to download is 6.1.22 ?!
no kernel 6.2 loaded !
pls format / edit your text
current inxi?
I know it’s a little bit complicated to follow to context…
I reinstalled whole linux after i posted the information to make sure everything is original and maybe easier to fix. So i decided to reinstall everything, which you can see that kernel has changed.
Now it’s showing after i wrote sudo inxi:
strong text
CPU: 24-core (8-mt/16-st) 13th Gen Intel Core i9-13980HX (-MST AMCP-)
speed/min/max: 2301/800/5400:5600:4000 MHz Kernel: 6.2.9-1-MANJARO x86_64
Up: 0m Mem: 2664.7/31714.2 MiB (8.4%) Storage: 953.87 GiB (1.1% used)
Procs: 444 Shell: Bash inxi: 3.3.26
If you want see more detailed: (i wrote inxi -Fza in terminal)
[kevin@KevinHan ~]$ inxi -Fza
Kernel: 6.2.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.2-x86_64
root=UUID=ee231002-7f6e-4986-88ec-e143a9c0c923 rw quiet splash
udev.log_priority=3
serial:
ID-1: BAT0 charge: 84.2 Wh (93.0%) condition: 90.5/90.0 Wh (100.6%)
volts: 16.7 min: 16.0 model: AS3GYFG3KC R220358 type: Unknown
serial: status: discharging
microcode: 0x112
Speed (MHz): avg: 2352 high: 2400 min/max: 800/5400:5600:4000 scaling:
4: 2400 5: 2400 6: 2400 7: 2400 8: 2400 9: 2400 10: 2400 11: 2400 12: 2400
13: 2400 14: 2400 15: 2400 16: 2400 17: 2400 18: 870 19: 2400 20: 2400
bus-ID: 2-8:3 chip-ID: 322e:2122 class-ID: 0e02
screens: 1
res: 2560x1600 dpi: 188 gamma: 1.2 size: 345x215mm (13.58x8.46")
direct-render: Yes
class-ID: 0403
API: ALSA v: k6.2.9-1-MANJARO status: kernel-api with: aoss
tools: pw-cli,wpctl
IF: wlo1 state: up mac:
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 2-14:4
class-ID: 0104
Local Storage: total: 953.87 GiB used: 10.8 GiB (1.1%)
rev: GXA7601Q temp: 38.9 C scheme: GPT
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 10.74 GiB (11.0%)
System Temperatures: cpu: 36.0 C mobo: N/A
Processes: 444 Uptime: 3m wakeups: 2 Memory: 30.97 GiB used: 2.61 GiB (8.4%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman pkgs: 1126 libs: 326
tools: pamac pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.26
Hope it is easier to understand now.
