Hi All, I’m running Manjaro Mate on a Raspberry Pi 400. After an upgrade yesterday I can no longer connect to my VPN.
The wired network has changed from eth0 to end0. It will connect to other computers on the same network locally but I have to disable the UFW rules as they require a TUN connection via my VPN.
I re-flashed the sd card to a working backup done in late Oct 2022 and all is working well. Tried to update again with sudo pacman -Syu. It took a while but all seemed ok, until a reboot and then no VPN. I noticed that the wired connection had changed to wired connection 2 and the name in ‘ip a’ to end0.
I have done updates after Oct 2022 but none recently
