I installed virt-manager 3.2 from software manager. and have this issue:
unable to connect to libvirt lxc:///.
log details:
Unable to connect to libvirt lxc:///.
Verify that the ‘libvirtd’ daemon is running.
Libvirt URI is: lxc:///
File “/usr/share/virt-manager/virtManager/connection.py”, line 922, in _do_open
self._backend.open(cb, data)
File “/usr/share/virt-manager/virtinst/connection.py”, line 153, in open
conn = libvirt.openAuth(self._open_uri,
File “/usr/lib/python3.9/site-packages/libvirt.py”, line 148, in openAuth
raise libvirtError(‘virConnectOpenAuth() failed’)
libvirt.libvirtError: Failed to connect socket to ‘/var/run/libvirt/libvirt-sock’: No such file or directory
if anybody will need a solution, just use the above commands. But at first install virt-manager from terminal or from software manager. will share also terminal command which installs it:
Thank you for sharing and those T° look normal to me… If you run into the high 80°C most of the time, that’s not good, but 50-60, is perfectly fine as your system itself tells you:
At 100°C you’ll reach the critical T° at which point the CPU will shut down your system brutally…
(Just letting you know you should stop worrying even though those kind of questions are in the grey area whether or not they’re on-topic)
