Good day to you all. I tried to install winapps using Virtual Machine Manager, however, after I clicked Begin Installation, it showed me this error
Unable to complete install: 'Requested operation is not valid: network 'default' is not active'
File "/usr/share/virt-manager/virtManager/asyncjob.py", line 65, in cb_wrapper
callback(asyncjob, *args, **kwargs)
File "/usr/share/virt-manager/virtManager/createvm.py", line 2001, in _do_async_install
installer.start_install(guest, meter=meter)
File "/usr/share/virt-manager/virtinst/install/installer.py", line 701, in start_install
domain = self._create_guest(
File "/usr/share/virt-manager/virtinst/install/installer.py", line 649, in _create_guest
domain = self.conn.createXML(install_xml or final_xml, 0)
File "/usr/lib/python3.9/site-packages/libvirt.py", line 4376, in createXML
raise libvirtError('virDomainCreateXML() failed')
libvirt.libvirtError: Requested operation is not valid: network 'default' is not active
sudo virsh net-list --all
Name State Autostart Persistent
default inactive yes yes
sudo virsh net-start default
error: Failed to start network default
error: internal error: Failed to initialize a valid firewall backend
What should I do to fix this?
neofetch
██████████████████ ████████ soumi@Hori
██████████████████ ████████ OS: Manjaro Linux x86_64
██████████████████ ████████ Host: Aspire A514-53 V1.16
████████ ████████ Kernel: 5.14.7-2-MANJARO
████████ ████████ ████████ Uptime: 5 hours, 52 mins
████████ ████████ ████████ Packages: 1428 (pacman)
████████ ████████ ████████ Shell: bash 5.1.8
████████ ████████ ████████ Resolution: 1366x768
████████ ████████ ████████ DE: Plasma 5.22.5
████████ ████████ ████████ WM: KWin
████████ ████████ ████████ Theme: Breeze Light [Plasma], Breeze [GTK2/3]
████████ ████████ ████████ Icons: breeze [Plasma], breeze [GTK2/3]
████████ ████████ ████████ Terminal: konsole
CPU: Intel i3-1005G1 (4) @ 3.400GHz
GPU: Intel Iris Plus Graphics G1
Memory: 4762MiB / 7630MiB
inxi -Fazy
Kernel: 5.14.7-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=3e711149-8ebe-45af-8e9a-78a1cdacff3f rw quiet apparmor=1
security=apparmor resume=UUID=d27dc7f4-ce4f-48b8-ba69-9971d9cc4ca0
udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Aspire A514-53 v: V1.16 serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: IL model: Sneezy_IL v: V1.16 serial: <filter> UEFI: Insyde v: 1.16
date: 01/18/2021
ID-1: BAT0 charge: 10.7 Wh (33.8%) condition: 31.7/53.0 Wh (59.9%)
volts: 16.0 min: 15.4 model: PANASONIC KT004 AP19B5L type: Li-ion
serial: <filter> status: Charging cycles: 386
Info: Dual Core model: Intel Core i3-1005G1 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A6 cache:
L2: 4 MiB
bogomips: 9524
Speed: 2567 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 2567 2: 2543
3: 2525 4: 2745
Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-6:4
chip-ID: 04f2:b64f class-ID: 0e02 serial: <filter>
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 112 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.2.2
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0401
Device-2: C-Media USB PnP Sound Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:9 chip-ID: 0d8c:013a
class-ID: 0300
Sound Server-1: ALSA v: k5.14.7-2-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.37 running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
port: 4000 bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
bus-ID: 1-10:5 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: N/A rfk-block:
hardware: no software: no address: see --recommends
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 30 class-ID: 0104
Device-1: md126 maj-min: 9:126 type: mdraid level: N/A status: inactive
Info: report: N/A blocks: 2136 chunk-size: N/A
Components: Online: N/A Spare:
0: nvme0n1 maj-min: 259:0 size: 476.94 GiB state: S
Device-2: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
Info: report: N/A blocks: 2944 chunk-size: N/A
0: nvme1n1 maj-min: 259:5 size: 27.25 GiB state: S
Local Storage: total: 1.4 TiB used: 190.83 GiB (13.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: HBRPEKNX0202A
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: G002 temp: 27.9 C
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Intel model: HBRPEKNX0202AO
size: 27.25 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: K5110440 temp: 30.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: MBR
ID-1: / raw-size: 400 GiB size: 392.65 GiB (98.16%) used: 78.25 GiB (19.9%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 816 KiB (0.2%) fs: vfat dev: /dev/sda4 maj-min: 8:4
ID-1: swap-1 type: partition size: 8 GiB used: 183.2 MiB (2.2%) priority: -2
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 54.0 C mobo: N/A
Processes: 219 Uptime: 5h 52m wakeups: 1 Memory: 7.45 GiB
used: 4.89 GiB (65.6%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: apt: 0 pacman: 1428 lib: 402 flatpak: 0 Shell: Zsh
v: 5.8 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
