I have not been able to change the default grub timeout from 10 to 0.
I have edited /etc/default/grub.cfg then ran sudo grub-mkconfig -o /boot/grub/grub.cfg with no errors and the default is still set to 10?
The proper file to edit is /etc/default/grub
─ note: not grub.cfg
─ and the command…
sudo update-grub
… should then normally set everything as it should.
My mistype, I did edit /etc/default/grub and also tried sudo update-grub and it will not set the timeout to 0. I did get to set to 1 second so good enough, I have 2 ssd’s so I use the BIOS to select OS for the once every couple months I need to use Windows.
