Unable to build optimus-manager-qt 1.6.9-1
Attempting to install the optimus-manager-qt 1.6.9-1 to make my rtx2060 the primary GPU, but when I reach the build() phase, it reads out:
==> Starting build()…
CMake Error: CMake was unable to find a build program corresponding to “Unix Makefiles”. CMAKE_MAKE_PROGRAM is not set. You probably need to select a different build tool.
CMake Error: CMAKE_CXX_COMPILER not set, after EnableLanguage
– Configuring incomplete, errors occurred!
See also “/home/user/.cache/yay/optimus-manager-qt/src/optimus-manager-qt-1.6.9/build/CMakeFiles/CMakeOutput.log”.
==> ERROR: A failure occurred in build().
I believe it involves "EnableLanguage: as my CMAKE is up to date. Or maybe in need to install the C/C++ language.
:point_down:
God bless you, you absolute genius. Finally, after 72 hours, my problems were solved.
