karen
11 July 2021 01:06
1
error while loading shared libraries: libncurses.so.5: cannot open shared object file: No such file or directory
I tried creating a sym link called libncurses.so.5 like was suggested here:
only wait new android-studio aur version we can use vscode for edit code (i not use android-studio )
adb not work with flutter ? you can create a sym link libncurses.so → libncurses.so.5
This results in error:
error while loading shared libraries: /usr/lib/libncurses.so.5: file too short
That won’t work, remove it. ncurses5-compatlibs
(available in the AUR) provides that library.
karen
11 July 2021 02:41
4
Using add/remove software:
Preparing...
Checking lib32-ncurses5-compat-libs dependencies...
Checking ncurses5-compat-libs dependencies...
Resolving dependencies...
Checking inter-conflicts...
Building lib32-ncurses5-compat-libs...
Cloning lib32-ncurses5-compat-libs build files...
==> Making package: lib32-ncurses5-compat-libs 6.2-1 (Sat 10 Jul 2021 07:39:29 PM)
==> Retrieving sources...
-> Downloading ncurses-6.2.tar.gz...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
38 3345k 38 1296k 0 0 1256k 0 0:00:02 0:00:01 0:00:01 1255k
100 3345k 100 3345k 0 0 2954k 0 0:00:01 0:00:01 --:--:-- 2952k
-> Downloading ncurses-6.2.tar.gz.sig...
100 95 100 95 0 0 251 0 --:--:-- --:--:-- --:--:-- 251
==> Validating source files with sha512sums...
ncurses-6.2.tar.gz ... Passed
ncurses-6.2.tar.gz.sig ... Skipped
==> Verifying source file signatures with gpg...
ncurses-6.2.tar.gz ... FAILED (unknown public key 702353E0F7E48EDB)
==> ERROR: One or more PGP signatures could not be verified!
Failed to build lib32-ncurses5-compat-libs
I’m guessing i need to import someone’s key? but idk
Yes, but the default keyserver is dead. The issue is resolved with gnupg
2.2.29 which will come along in the next stable update. You can import the key like this for now:
gpg --keyserver keyserver.ubuntu.com --recv-keys 702353E0F7E48EDB
system
Closed
26 July 2021 02:55
6
