I tried to use lots of tools to flash the USB drive. And it can boot in another of my laptop. So, I think the USB drive and the iso is good.
But failed on this one with this error:
mount: /run/miso/sfs/livefs: wrong fs type, bad option, bad superblock on /dev/loop0, missing codepage or helper program, or other error
ERROR: Failed to mount ‘/dev/loop0’’
The device is Xiaomi’s laptop:
CPU: AMD R7-5800H
RAM: 16G DDR 4
DISK: ZhiTai TiPlus 5000 1T
I think it may be caused by the disk.
At first. I use a 500G disk to be the primary disk of this laptop. It works fine.
But after I switch the disk to this 1T disk, it can’t boot.
Additionally, I tried to use VM to boot and connect the external disk directly.
At first, it boots well, but after some time reboots. it throws the same error.
It’s so puzzling.
