Hello,
I’m trying to move a LUKS-encrypted NVMe disk to a new computer. I’m running an i3mw Manjaro with the encryption setup during the installation process (default one).
I’m unfortunately unable to boot from this disk when the disk is inside the new laptop (connected with NVMe). But, if I connect the disk to a USB-C NVMe adapter and boot from the USB disk, there is no issue.
What should I change / edit, to be able to boot from this disk when it is connected internally?
The old Laptop was a Dell Latitude 5400, the new one is an HP EliteBook 1030 G4. It’s using the UEFI boot (not Legacy).
This is what I get when the disk is plugged into the NVMe slot (internally). Unfortunately, in this Grub Rescue Mode, I don’t have access to much information
Enter passphrase for hd0,gpt2 (879689be-84d7-4eb1-a134-d74897347264) :
Attempting to decrypt master key...
error: failure reading sector 0x97040 from 'hdo'.
error: disk 'cryptouuid/875689e81074e614134879897347264' not found.
Entering rescue mode...
grub rescue >
grub rescue > cryptomount -a
error: failure reading sector 0x0 from 'hdo'
grub rescue> cryptomount -a -b
grub rescue > insmod normal
error: disk cruptouuid/879689be84474eb/a134474897347264' not found.
grub rescue > ls
(proc) (hd0)
grub rescue> ls (hd0))
error: failure reading sector 0x2 from 'hdo'
grub rescue> ls (proc)
(proc) : Filesystem is procfs.
grub rescue> ls (proc))
luks_script
grub rescue>
I tried this solution using sudo mkinitcpio -P, but unsuccessfully:
This is the information I extracted from the HP after booting from the USB-C adapter :
❯ cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=78D9-5343 /boot/efi vfat umask=0077 0 2
/dev/mapper/luks-879689be-84d7-4eb1-a134-d74897347264 / ext4 defaults,noatime 0 1
/swapfile swap swap defaults,noatime 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
❯ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 931.5G 0 disk
├─sda1 8:1 0 300M 0 part /boot/efi
└─sda2 8:2 0 931.2G 0 part
└─luks-879689be-84d7-4eb1-a134-d74897347264 254:0 0 931.2G 0 crypt /
Details from my machine (boot from USB)
❯ inxi -v7azy
Kernel: 6.5.13-7-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=8bf163f4-80a5-45a3-bf21-0edd7eed2217 rw
cryptdevice=UUID=879689be-84d7-4eb1-a134-d74897347264:luks-879689be-84d7-4eb1-a134-d74897347264
root=/dev/mapper/luks-879689be-84d7-4eb1-a134-d74897347264 apparmor=1
Desktop: i3 v: 4.23 with: i3bar tools: xautolock avail: i3lock vt: 7
dm: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
Type: Convertible System: HP product: HP EliteBook x360 1030 G4 v: N/A
serial: <superuser required> Chassis: type: 31 serial: <superuser required>
Mobo: HP model: 8637 v: KBC Version 68.32.00 serial: <superuser required>
part-nu: 6MJ73AV uuid: <superuser required> UEFI: HP v: R94 Ver. 01.12.00
date: 01/10/2022
Device-1: luks-879689be-84d7-4eb1-a134-d74897347264 maj-min: 254:0
type: LUKS dm: dm-0 size: 931.21 GiB
Components:
p-1: sda2 maj-min: 8:2 size: 931.22 GiB
Local Storage: total: 931.51 GiB used: 797.17 GiB (85.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS30 30 1000GB SS
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: N/A serial: <filter>
fw-rev: 3106 scheme: GPT
ID-1: / raw-size: 931.21 GiB size: 915.52 GiB (98.32%)
used: 796.14 GiB (87.0%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-879689be-84d7-4eb1-a134-d74897347264 label: N/A
uuid: 8bf163f4-80a5-45a3-bf21-0edd7eed2217
used: 464 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 78D9-5343
ID-3: /run/user/1000/keybase/kbfs raw-size: N/A size: 250 GiB
used: 1.03 GiB (0.4%) fs: fuse dev: /dev/fuse label: N/A uuid: N/A
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-8:2 info: Synaptics Fingerprint reader [HP G6]
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 06cb:00b7 class-ID: ff00 serial: <filter>
Device-2: 1-9:3 info: Quanta HP Full-HD Camera type: video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 0408:5390 class-ID: 0e02 serial: <filter>
Device-3: 1-10:4 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
Device-1: 4-1:2 info: JMicron / USA JMS583Gen 2 to PCIe Gen3x2 Bridge
type: mass storage driver: uas interfaces: 1 rev: 3.2
speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 power: 896mA
chip-ID: 152d:0583 class-ID: 0806 serial: <filter>
