Unable to automatically mount NTFS external harddrive in Thunar
Hello.
I’m having a issues getting Thunar to mount an NTFS external drive (/dev/sdd).
  Kernel: 6.6.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=6d335510-3b40-442b-a73c-bf3b5291adb1 rw quiet splash
    udev.log_priority=3
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
    v: 4.18.0 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: PRIME B250-PLUS v: Rev X.0x
    serial: <filter> UEFI: American Megatrends v: 0608 date: 03/24/2017
  System RAM: total: 40 GiB available: 39.12 GiB used: 4.04 GiB (10.3%)
  Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
  Device-1: ChannelA-DIMM1 type: DDR4 detail: synchronous size: 16 GiB
    speed: 2133 MT/s volts: curr: 1.2 width (bits): data: 64 total: 64
    manufacturer: Corsair part-no: CMK32GX4M2A2666C16 serial: N/A
  Device-2: ChannelA-DIMM2 type: DDR4 detail: synchronous size: 4 GiB
    manufacturer: Kingston part-no: 9905678-014.A00G serial: <filter>
  Device-3: ChannelB-DIMM1 type: DDR4 detail: synchronous size: 16 GiB
  Device-4: ChannelB-DIMM2 type: DDR4 detail: synchronous size: 4 GiB
  Info: model: Intel Core i5-7500 socket: LGA1151 bits: 64 type: MCP
    arch: Kaby Lake gen: core 7 level: v3 note: check built: 2018
    process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 9
    microcode: 0xF4
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
    desc: 1x6 MiB
  Speed (MHz): avg: 800 min/max: 800/3800 base/boost: 3400/8300 scaling:
    driver: intel_pstate governor: powersave volts: 1.0 V ext-clock: 100 MHz
    cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 27208
    dtherm dts erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
    hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid lahf_lm
    lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
    pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss ssbd sse sse2
    sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer
    vme x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: itlb_multihit status: KVM: VMX unsupported
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: disabled, RSB
    filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: eVga.com.
    driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2023-11; EOL~2026-12-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:1c02 class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.10 compositor: xfwm v: 4.18.0 driver:
    X: loaded: modesetting,nouveau,nvidia alternate: fbdev,nv,vesa gpu: nvidia
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: DVI-D-0 pos: primary res: 1920x1080 hz: 60 dpi: 82
    size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
  Monitor-2: None-1-1 size-res: N/A modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
    memory: 2.93 GiB
  Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a2f0
    class-ID: 0403
  Device-2: NVIDIA GP106 High Definition Audio vendor: eVga.com.
    bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
  API: ALSA v: k6.6.7-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: n/a (root, process) tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
    vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  Device-2: TP-Link 802.11ac WLAN Adapter driver: rtl88XXau type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:2 chip-ID: 2357:011f
    class-ID: 0000 serial: <filter>
  IF: wlp0s20f0u8 state: up mac: <filter>
  IF-ID-1: br-11db0f3eda11 state: down mac: <filter>
  IF-ID-2: br-6cb8d8edc578 state: down mac: <filter>
  IF-ID-3: br-b44f8ca0946b state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-4: docker0 state: down mac: <filter>
  IF-ID-5: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  IF-ID-6: vethdd2d53c state: up speed: 10000 Mbps duplex: full mac: <filter>
  Local Storage: total: 4.9 TiB used: 968.72 GiB (19.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SM2280S3G2120G
    size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 01.W scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM010-2EP102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT250MX500SSD1
    size: 232.89 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 023 scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: Expansion Desk
    size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: USB rev: 3.0
    spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 0915 scheme: GPT
  ID-5: /dev/sde maj-min: 8:64 vendor: SanDisk model: USB 3.2Gen1
    size: 14.32 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.0
    fw-rev: 1.00
  ID-1: / raw-size: 111.49 GiB size: 109.18 GiB (97.93%) used: 74.3 GiB (68.0%)
    fs: ext4 block-size: 4096 B dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 6d335510-3b40-442b-a73c-bf3b5291adb1
    used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
    label: N/A uuid: B506-00DE
  ID-3: /home raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
    used: 752.73 GiB (82.2%) fs: ext4 block-size: 4096 B dev: /dev/sdb1
    maj-min: 8:17 label: N/A uuid: fce93f8c-5a75-4c33-86b8-2cb6bbd1c212
  ID-4: /run/media/thorbjoernl/F63E7BE33E7B9B77 raw-size: 14.32 GiB
    size: 14.32 GiB (100.00%) used: 95.7 MiB (0.7%) fs: ntfs block-size: 4096 B
    dev: /dev/sde maj-min: 8:64 label: N/A uuid: F63E7BE33E7B9B77
  ID-5: /ssd raw-size: 217.29 GiB size: 212.82 GiB (97.94%)
    used: 141.61 GiB (66.5%) fs: ext4 block-size: 4096 B dev: /dev/sdc2
    maj-min: 8:34 label: N/A uuid: acdd184a-681c-4515-aae9-671efb4acdb6
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  ID-1: /dev/sdc1 maj-min: 8:33 size: 128 MiB fs: N/A label: N/A uuid: N/A
  ID-2: /dev/sdd1 maj-min: 8:49 size: 128 MiB fs: N/A label: N/A uuid: N/A
  ID-3: /dev/sdd2 maj-min: 8:50 size: 3.64 TiB fs: ntfs label: N/A
    uuid: FE906DB0906D7057
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-8:2 info: TP-Link 802.11ac WLAN Adapter type: Network
    driver: rtl88XXau interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 2357:011f class-ID: 0000
    serial: <filter>
  Device-2: 1-9:3 info: Dell QuietKey Keyboard type: keyboard
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 70mA chip-ID: 413c:2106 class-ID: 0301
  Device-3: 1-10:4 info: Pixart Imaging Optical Mouse type: mouse
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 093a:2510 class-ID: 0301
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  Device-1: 2-2:2 info: SanDisk Ultra Fit type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5583 class-ID: 0806
    serial: <filter>
  Device-2: 2-6:3 info: Seagate RSS LLC Desktop HDD 5TB (ST5000DM000)
    type: mass storage driver: uas interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 0bc2:331a class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 34.0 C mobo: N/A gpu: nvidia temp: 43 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
  Processes: 252 Uptime: 30m wakeups: 0 Init: systemd v: 254 default: graphical
  tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
  pkgs: 1330 libs: 357 tools: pamac,yay Shell: Sudo (sudo) v: 1.9.15p2
  default: Bash v: 5.2.21 running-in: terminator inxi: 3.3.31
lsblk -f
NAME   FSTYPE FSVER LABEL UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
sda
├─sda1 vfat   FAT32       B506-00DE                             299.1M     0% /boot/efi
└─sda2 ext4   1.0         6d335510-3b40-442b-a73c-bf3b5291adb1   29.3G    68% /
sdb
└─sdb1 ext4   1.0         fce93f8c-5a75-4c33-86b8-2cb6bbd1c212  116.5G    82% /home
sdc
├─sdc1
└─sdc2 ext4   1.0         acdd184a-681c-4515-aae9-671efb4acdb6   60.3G    67% /ssd
sdd
├─sdd1
└─sdd2 ntfs               FE906DB0906D7057
sde    ntfs               F63E7BE33E7B9B77                       14.2G     1% /run/media/thorbjoernl/F63E7BE33E7B9B77
fdisk -l /dev/sdd
Disk /dev/sdd: 3.64 TiB, 4000787029504 bytes, 7814037167 sectors
Disk model: Expansion Desk
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: A709CB37-94C8-4676-A2E4-4DE0A267801F
Device      Start        End    Sectors  Size Type
/dev/sdd1      34     262177     262144  128M Microsoft reserved
/dev/sdd2  264192 7814035455 7813771264  3.6T Microsoft basic data
Partition 1 does not start on physical sector boundary.
When Thunar attempts to mount the drive I get the following error message:
I have already run chkdisk on a Windows computer on the drive (without checking for bad sectors).
At this point I am able to mount it manually and browse the files using
mount /dev/sdd2 ./mnt
However, I would like to restore the capability of Thunar to mount it automatically.
I should also mention that /dev/sde is a NTFS formatted USB stick which mounts fine in Thunar so it appears to be an issue with this specific drive, not NTFS in general.
Have you blacklisted the ntfs3 driver so that the system uses the more current ntfs-3g driver?
In terminal:
sudo pacman -S ntfs-3g
echo 'blacklist ntfs3' | sudo tee /etc/modprobe.d/disable-ntfs3.conf
The newer kernels now use the in-kernel ntfs3 driver, which often fails. When you are mounting them manually, you are using ntfs-3g as the driver, which is the one that works. By blacklisting ntfs3, you make sure that it’ll always use ntfs-3g diver.
Thank you!
@singofy @jrichard326
To extend this:
ntfs3 fails if damage to an NTFS formatted drive is found; or, rather, if an indicator of damage (commonly called a dirty bit) is found.
ntfs-3g ignores this, and mounts the NTFS partition, regardless.
The important point here is that the NTFS filesystem may still be damaged, as you blissfully continue using the drive.
If an error exists, it must be corrected using chkdsk within a Windows environment. This can be achieved by launching an administrative command prompt, and using the command:
chkdsk /f x:
x: denotes the drive letter of the disk as it appears in Windows.
If a Windows installation is not available, chkdsk can also be run from the downloadable Hiren’s BootCD PE.
I hope this additional information is helpful.
Cheers.
