I know there is already a topic for this issue, but I can not activate it in my session.
I just can use 100% (sooo tiny) or 200% (reminds me of old 800x600 px displays).
For X11 session you need to install mutter-x11-scaling package.
Not sure if you will also need , or not, to install gnome-controll-center-x11-scaling too …
Could it be that fractional scaling is only enabled in wayland? Perhaps you could try to choose wayland at login and see if its available. Unless you use nvidia card, then no wayland…
Ty. mutter-x11-scis preinstalled (3.38.1-1) and gnome-control-center has no other “sub apps” like -x11-scaling in my repos (and is installed, v 3.38.2-1).
Will this be ready for the Manjaro Gnome 40 developmental spin?
An install try kicked out the error … "Warning: removing mutter breaks dependency ‘libmutter-8.so=0-64’ required by gnome-shell. Add gnome-shell to remove.
