System Information:
Kernel: 6.1.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=9d2cdcb1-49e0-442c-8ac8-bee8129a84b5 rw quiet apparmor=1
security=apparmor resume=UUID=8d75268b-2826-4521-abab-c258102e3822
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20MF000BUS v: ThinkPad X1 Extreme
Mobo: LENOVO model: 20MF000BUS v: SDK0R32862 WIN
serial: <superuser required> UEFI: LENOVO v: N2EET61W (1.43 )
date: 12/20/2022
ID-1: BAT0 charge: 38.5 Wh (62.5%) condition: 61.6/80.4 Wh (76.6%)
power: 52.2 W volts: 16.8 min: 15.4 model: Celxpert 01AY969 type: Li-poly
serial: <filter> status: charging cycles: 1919
System RAM: total: 32 GiB note: est. available: 30.81 GiB
used: 5.93 GiB (19.2%)
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 799 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 801 12: 800 bogomips: 52815
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep sgx sgx_lc smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Lenovo
driver: nvidia v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0300
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 04f2:b61e
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
dri: iris gpu: i915 display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0792 built: 2017 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
API: ALSA v: k6.1.49-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.78 status: off with: pipewire-media-session
status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
Report: bt-adapter ID: hci0 rfk-id: 2 state: up address: <filter> status:
discoverable: no active: no pairing: yes class-ID: 7c010c
System is dual-booted with Windows 10.
Steps that led to the problem:
- Attempted to
rsync
to an external flash drive. Operation failed due to “no storage left on device” error. - Many parts of the OS started failing due to no space. Distinctly remember
zellij
failing. - After restarting system, GUI would not start, so I booted into a TTY, confirmed that
/dev/
had 0% free space. - Ran
pacman -Sc
to clear out the disk space. GUI successfully booted after restarting. - Strangely, the Whisker menu icons all reset to the defaults, with only Web Browser, Mail Reader, File Manager, and Terminal Emulator.
- OS seemed to work as usual, with the notable exception of Thunar not opening upon clicking the application. Worked again after a simple restart. Similar pattern over the last few days.
- Now, applications like Thunar, Timeshift, GParted, QDirStat, etc. no longer work, even after restarting. Here is the result of
cat .xsession-errors
/usr/bin/iceauth: creating new authority file /run/user/1000/ICEauthority
gpg-agent: a gpg-agent is already running - not starting a new one
** (wrapper-2.0:1906): WARNING **: 22:12:20.643: could not get output property
xfce4-notifyd-Message: 22:12:21.785: Your sqlite library does not support OFFSET/LIMIT with DELETE; falling back to less-efficient deletion method
(xfce4-power-manager:2043): xfce4-power-manager-WARNING **: 22:12:22.673: could not map keysym 1008ffa8 to keycode
blueman-applet 22.12.22 WARNING PluginManager:151 __load_plugin: Not loading DhcpClient because its conflict has higher priority
blueman-applet 22.12.22 WARNING PluginManager:151 __load_plugin: Not loading PPPSupport because its conflict has higher priority
** (xfce4-power-manager:2043): WARNING **: 22:12:22.753: could not get output property
xfce4-power-manager-Message: 22:12:22.901: Set kernel brightness switch to 0
(xfce4-power-manager:2043): xfconf-WARNING **: 22:12:22.923: Failed to set property "xfce4-power-manager::/xfce4-power-manager/brightness-switch": Operation was cancelled
xfce4-power-manager-Message: 22:12:23.001: Set kernel brightness switch to 0
[1984:0902/221225.460939:ERROR:object_proxy.cc(623)] Failed to call method: org.freedesktop.DBus.StartServiceByName: object_path= /org/freedesktop/DBus: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
xfsettingsd: Another instance took over. Leaving...
(node:1984) UnhandledPromiseRejectionWarning: TypeError: Cannot read properties of null (reading 'checked')
at /usr/lib/caprine/dist-js/browser.js:208:34
at async EventEmitter.listener (/usr/lib/caprine/node_modules/electron-better-ipc/source/renderer.js:46:34)
(Use `electron --trace-warnings ...` to show where the warning was created)
(node:1984) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict`. (rejection id: 1)
ATTENTION: default value of option mesa_glthread overridden by environment.
** Message: 22:40:40.797: updates_checker.vala:71: check updates
** Message: 22:40:45.147: updates_checker.vala:101: 2 updates found
(Thunar:1893): GVFS-WARNING **: 22:40:52.142: The peer-to-peer connection failed: Timeout was reached. Falling back to the session bus. Your application is probably missing --filesystem=xdg-run/gvfsd privileges.
Failed to register: Timeout was reached
(thunar-volman-settings:6731): IBUS-WARNING **: 22:52:08.699: Unable to connect to ibus: Could not connect: Connection refused
Error org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
DEBUG:root:_DATA_DIR is /usr/share/application-utility
DEBUG:root:_PREF_FILE is /usr/share/application-utility/preferences.json
DEBUG:root:self.file is {'desktop': '', 'main': '/usr/share/application-utility/default.json'}
INFO:root:json to merge : /usr/share/application-utility/default.json
DEBUG:root:json : /tmp/manjaro-hello-preferences.json
WARNING:root:File not exist ? /usr/share/application-utility/xfce.json
/usr/bin/manjaro-hello:95: DeprecationWarning: Gtk.Widget.set_margin_left is deprecated
grid.set_margin_left(5)
DEBUG:root:
--- read data.json with FILTERS ---
DEBUG:root:my desktop: xfce
DEBUG:root:filter :
DEBUG:root:groups : *
DEBUG:root: filter app: Epiphany ['advanced'] <
DEBUG:root: filter app: Falkon ['advanced'] <
DEBUG:root: filter app: Konqueror ['advanced'] <
DEBUG:root: filter app: Claws Mail ['advanced'] <
DEBUG:root: filter app: Atom ['advanced'] <
DEBUG:root: filter app: Vim ['advanced'] <
DEBUG:root: filter app: Visual Studio Code OSS ['advanced'] <
DEBUG:root: filter app: Gnome builder ['advanced'] <
DEBUG:root:filter group : File Sharing ['advanced'] <
DEBUG:root: filter app: Grsync ['advanced'] <
DEBUG:root: filter app: Borg ['advanced'] <
DEBUG:root:filter group : System Tools ['advanced'] <
DEBUG:root:filter group : Virtual Computing ['advanced'] <
DEBUG:root:
DEBUG:root:filter :
DEBUG:root:
DEBUG:root:filter :
** Message: 23:40:10.891: updates_checker.vala:71: check updates
** Message: 23:40:13.483: updates_checker.vala:101: 2 updates found
