Ultima actualizacion
Hola , buenas tardes cuando hice la ultima actualizacion del sistema esta mañana , todo bien hasta el momento de actualizar los paquetes, me sale esto,es largo, copio la última parte, quizás a alguien le pasó lo mismo
  Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
    root=UUID=0fb091fc-3271-483e-818a-5dc21ccbd08d rw quiet apparmor=1
    security=apparmor resume=UUID=e4ab7b14-ec9e-4155-b5eb-28717df67c17
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Laptop System: Dell product: Latitude 3420 v: N/A
  Mobo: Dell model: 0KMD3M v: A00 serial: <superuser required> UEFI: Dell
    v: 1.3.1 date: 04/23/2021
  ID-1: BAT0 charge: 16.1 Wh (39.5%) condition: 40.8/40.8 Wh (100.0%)
    volts: 12.2 min: 11.2 model: SMP DELL MGCM514 type: Li-poly serial: <filter>
    status: charging
  System RAM: total: 8 GiB note: est. available: 7.51 GiB
    used: 3.27 GiB (43.5%)
  Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xAC
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
    desc: 1x8 MiB
  Speed (MHz): avg: 477 high: 1020 min/max: 400/4200 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1020 2: 400 3: 400 4: 400
    5: 400 6: 400 7: 400 8: 400 bogomips: 22120
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
    movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
    sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell driver: i915
    v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
    active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49
    class-ID: 0300
  Device-2: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:3 chip-ID: 0c45:6d1a
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31")
  Monitor-1: eDP-1 model: BOE Display 0x07e8 built: 2019 res: 1366x768 hz: 60
    dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
    ratio: 16:9 modes: 1366x768
    device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.8-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
    device-ID: 8086:9a49 memory: 7.33 GiB unified: yes
  API: Vulkan v: 1.3.264 layers: 4 device: 0 type: integrated-gpu name: Intel
    Xe Graphics (TGL GT2) driver: mesa intel v: 23.1.8-manjaro1.1
    device-ID: 8086:9a49 surfaces: xcb,xlib
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0401
  API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.80 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active
    tools: pactl,pw-cat,pw-cli
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
    vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 2c:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp44s0 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 1.36 TiB used: 62.26 GiB (4.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS500G
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: EDFK0N01 temp: 38.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 01 scheme: GPT
  ID-1: / raw-size: 78.12 GiB size: 76.35 GiB (97.73%) used: 35.62 GiB (46.6%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 0fb091fc-3271-483e-818a-5dc21ccbd08d
  ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
    used: 304 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: NO_LABEL uuid: 1C6D-8153
  ID-3: /home raw-size: 381.48 GiB size: 374.43 GiB (98.15%)
    used: 26.65 GiB (7.1%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
    uuid: ae4fdda7-02c7-4b07-847d-0ca5d01636a3
  ID-1: swap-1 type: partition size: 5.86 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: e4ab7b14-ec9e-4155-b5eb-28717df67c17
  ID-1: /dev/sda1 maj-min: 8:1 size: 1000 MiB fs: vfat label: N/A
    uuid: 7616-A725
  ID-2: /dev/sda2 maj-min: 8:2 size: 921.73 GiB fs: ext4 label: endeavouros
    uuid: c5836b3c-5bb7-4d47-8d49-56202845d398
  ID-3: /dev/sda3 maj-min: 8:3 size: 8.8 GiB fs: swap label: swap
    uuid: 0a93cecb-4ed9-4925-aff6-72849d60ff7e
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-4:2 info: Logitech Unifying Receiver type: mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c52f class-ID: 0300
  Device-2: 3-6:3 info: Microdia Integrated_Webcam_HD type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 0c45:6d1a class-ID: 0e02
  Device-3: 3-10:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  System Temperatures: cpu: 45.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 262 Uptime: 44m wakeups: 2931 Init: systemd v: 254
  Packages: 1506 pm: pacman pkgs: 1488 libs: 432 tools: pamac,yay pm: flatpak
  pkgs: 18 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.30
glibc-locales: /usr/lib/locale/tl_PH.utf8/LC_ADDRESS existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tl_PH.utf8/LC_COLLATE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tl_PH.utf8/LC_CTYPE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tl_PH.utf8/LC_IDENTIFICATION existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tl_PH.utf8/LC_MEASUREMENT existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tl_PH.utf8/LC_MESSAGES/SYS_LC_MESSAGES existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tl_PH.utf8/LC_MONETARY existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tl_PH.utf8/LC_NAME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tl_PH.utf8/LC_NUMERIC existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tl_PH.utf8/LC_PAPER existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tl_PH.utf8/LC_TELEPHONE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tl_PH.utf8/LC_TIME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_CY.utf8/LC_ADDRESS existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_CY.utf8/LC_COLLATE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_CY.utf8/LC_CTYPE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_CY.utf8/LC_IDENTIFICATION existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_CY.utf8/LC_MEASUREMENT existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_CY.utf8/LC_MESSAGES/SYS_LC_MESSAGES existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_CY.utf8/LC_MONETARY existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_CY.utf8/LC_NAME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_CY.utf8/LC_NUMERIC existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_CY.utf8/LC_PAPER existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_CY.utf8/LC_TELEPHONE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_CY.utf8/LC_TIME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_TR.utf8/LC_ADDRESS existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_TR.utf8/LC_COLLATE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_TR.utf8/LC_CTYPE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_TR.utf8/LC_IDENTIFICATION existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_TR.utf8/LC_MEASUREMENT existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_TR.utf8/LC_MESSAGES/SYS_LC_MESSAGES existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_TR.utf8/LC_MONETARY existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_TR.utf8/LC_NAME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_TR.utf8/LC_NUMERIC existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_TR.utf8/LC_PAPER existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_TR.utf8/LC_TELEPHONE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/tr_TR.utf8/LC_TIME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uk_UA.utf8/LC_ADDRESS existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uk_UA.utf8/LC_COLLATE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uk_UA.utf8/LC_CTYPE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uk_UA.utf8/LC_IDENTIFICATION existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uk_UA.utf8/LC_MEASUREMENT existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uk_UA.utf8/LC_MESSAGES/SYS_LC_MESSAGES existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uk_UA.utf8/LC_MONETARY existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uk_UA.utf8/LC_NAME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uk_UA.utf8/LC_NUMERIC existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uk_UA.utf8/LC_PAPER existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uk_UA.utf8/LC_TELEPHONE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uk_UA.utf8/LC_TIME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uz_UZ.utf8/LC_ADDRESS existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uz_UZ.utf8/LC_COLLATE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uz_UZ.utf8/LC_CTYPE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uz_UZ.utf8/LC_IDENTIFICATION existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uz_UZ.utf8/LC_MEASUREMENT existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uz_UZ.utf8/LC_MESSAGES/SYS_LC_MESSAGES existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uz_UZ.utf8/LC_MONETARY existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uz_UZ.utf8/LC_NAME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uz_UZ.utf8/LC_NUMERIC existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uz_UZ.utf8/LC_PAPER existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uz_UZ.utf8/LC_TELEPHONE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/uz_UZ.utf8/LC_TIME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/wa_BE.utf8/LC_ADDRESS existe en el sistema de archivos
glibc-locales: /usr/lib/locale/wa_BE.utf8/LC_COLLATE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/wa_BE.utf8/LC_CTYPE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/wa_BE.utf8/LC_IDENTIFICATION existe en el sistema de archivos
glibc-locales: /usr/lib/locale/wa_BE.utf8/LC_MEASUREMENT existe en el sistema de archivos
glibc-locales: /usr/lib/locale/wa_BE.utf8/LC_MESSAGES/SYS_LC_MESSAGES existe en el sistema de archivos
glibc-locales: /usr/lib/locale/wa_BE.utf8/LC_MONETARY existe en el sistema de archivos
glibc-locales: /usr/lib/locale/wa_BE.utf8/LC_NAME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/wa_BE.utf8/LC_NUMERIC existe en el sistema de archivos
glibc-locales: /usr/lib/locale/wa_BE.utf8/LC_PAPER existe en el sistema de archivos
glibc-locales: /usr/lib/locale/wa_BE.utf8/LC_TELEPHONE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/wa_BE.utf8/LC_TIME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/xh_ZA.utf8/LC_ADDRESS existe en el sistema de archivos
glibc-locales: /usr/lib/locale/xh_ZA.utf8/LC_COLLATE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/xh_ZA.utf8/LC_CTYPE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/xh_ZA.utf8/LC_IDENTIFICATION existe en el sistema de archivos
glibc-locales: /usr/lib/locale/xh_ZA.utf8/LC_MEASUREMENT existe en el sistema de archivos
glibc-locales: /usr/lib/locale/xh_ZA.utf8/LC_MESSAGES/SYS_LC_MESSAGES existe en el sistema de archivos
glibc-locales: /usr/lib/locale/xh_ZA.utf8/LC_MONETARY existe en el sistema de archivos
glibc-locales: /usr/lib/locale/xh_ZA.utf8/LC_NAME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/xh_ZA.utf8/LC_NUMERIC existe en el sistema de archivos
glibc-locales: /usr/lib/locale/xh_ZA.utf8/LC_PAPER existe en el sistema de archivos
glibc-locales: /usr/lib/locale/xh_ZA.utf8/LC_TELEPHONE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/xh_ZA.utf8/LC_TIME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/yi_US.utf8/LC_ADDRESS existe en el sistema de archivos
glibc-locales: /usr/lib/locale/yi_US.utf8/LC_COLLATE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/yi_US.utf8/LC_CTYPE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/yi_US.utf8/LC_IDENTIFICATION existe en el sistema de archivos
glibc-locales: /usr/lib/locale/yi_US.utf8/LC_MEASUREMENT existe en el sistema de archivos
glibc-locales: /usr/lib/locale/yi_US.utf8/LC_MESSAGES/SYS_LC_MESSAGES existe en el sistema de archivos
glibc-locales: /usr/lib/locale/yi_US.utf8/LC_MONETARY existe en el sistema de archivos
glibc-locales: /usr/lib/locale/yi_US.utf8/LC_NAME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/yi_US.utf8/LC_NUMERIC existe en el sistema de archivos
glibc-locales: /usr/lib/locale/yi_US.utf8/LC_PAPER existe en el sistema de archivos
glibc-locales: /usr/lib/locale/yi_US.utf8/LC_TELEPHONE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/yi_US.utf8/LC_TIME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_CN.utf8/LC_ADDRESS existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_CN.utf8/LC_COLLATE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_CN.utf8/LC_CTYPE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_CN.utf8/LC_IDENTIFICATION existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_CN.utf8/LC_MEASUREMENT existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_CN.utf8/LC_MESSAGES/SYS_LC_MESSAGES existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_CN.utf8/LC_MONETARY existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_CN.utf8/LC_NAME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_CN.utf8/LC_NUMERIC existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_CN.utf8/LC_PAPER existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_CN.utf8/LC_TELEPHONE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_CN.utf8/LC_TIME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_HK.utf8/LC_ADDRESS existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_HK.utf8/LC_COLLATE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_HK.utf8/LC_CTYPE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_HK.utf8/LC_IDENTIFICATION existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_HK.utf8/LC_MEASUREMENT existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_HK.utf8/LC_MESSAGES/SYS_LC_MESSAGES existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_HK.utf8/LC_MONETARY existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_HK.utf8/LC_NAME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_HK.utf8/LC_NUMERIC existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_HK.utf8/LC_PAPER existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_HK.utf8/LC_TELEPHONE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_HK.utf8/LC_TIME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_SG.utf8/LC_ADDRESS existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_SG.utf8/LC_COLLATE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_SG.utf8/LC_CTYPE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_SG.utf8/LC_IDENTIFICATION existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_SG.utf8/LC_MEASUREMENT existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_SG.utf8/LC_MESSAGES/SYS_LC_MESSAGES existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_SG.utf8/LC_MONETARY existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_SG.utf8/LC_NAME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_SG.utf8/LC_NUMERIC existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_SG.utf8/LC_PAPER existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_SG.utf8/LC_TELEPHONE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_SG.utf8/LC_TIME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_TW.utf8/LC_ADDRESS existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_TW.utf8/LC_COLLATE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_TW.utf8/LC_CTYPE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_TW.utf8/LC_IDENTIFICATION existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_TW.utf8/LC_MEASUREMENT existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_TW.utf8/LC_MESSAGES/SYS_LC_MESSAGES existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_TW.utf8/LC_MONETARY existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_TW.utf8/LC_NAME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_TW.utf8/LC_NUMERIC existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_TW.utf8/LC_PAPER existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_TW.utf8/LC_TELEPHONE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zh_TW.utf8/LC_TIME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zu_ZA.utf8/LC_ADDRESS existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zu_ZA.utf8/LC_COLLATE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zu_ZA.utf8/LC_CTYPE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zu_ZA.utf8/LC_IDENTIFICATION existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zu_ZA.utf8/LC_MEASUREMENT existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zu_ZA.utf8/LC_MESSAGES/SYS_LC_MESSAGES existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zu_ZA.utf8/LC_MONETARY existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zu_ZA.utf8/LC_NAME existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zu_ZA.utf8/LC_NUMERIC existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zu_ZA.utf8/LC_PAPER existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zu_ZA.utf8/LC_TELEPHONE existe en el sistema de archivos
glibc-locales: /usr/lib/locale/zu_ZA.utf8/LC_TIME existe en el sistema de archivos
Ocurrieron errores, por lo que no se actualizarán los paquetes
Eso es lo que me aparece, no copié todo, pero es todo igual, no se como resolver esto ,alguien puede darme algún tip , lo agradecería profundamente por favor.
Muchas gracias :grinning:
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Recent announcement
Thank you very much, problem solved, I am very grateful to you :smiley: :+1:
