Uid 0? setuid bit?
lol, those are the exception. SystemRescue is a good live system?
another way to access your system to try and fix it is:
at the grub prompt (hit ESC after the Bios POST to see it)
press E for edit
and add a 1 to the end of the grub command line
(the line starts with “linux” and usually ends with loglevel=3 or udev_log_priority=3)
add a space and a 1 to the end
then F10 or CTRL-X
to boot
This should land you in a root shell.
I don’t have much confidence to use the Bios, I will first try to solve the problem with live system. And again, thanks for the help
You would not be using/accessing the Bios - but the Grub prompt
which is usually hidden - you don’t get to see it normally.
Only when you press “Esc” at the right moment.
But this will not work when you have no root password set.
… I guess …
The usb live system is probably better.
SystemRescue is a good option?
not familiar with it
Is it a linux system?
then: yes
literally any linux live cd will do
one with a graphical user interface may make things easier to navigate
all you want to do is mount the / filesystem of your disk and
chmod u+s ...
the sudo binary
I already boot the system with live system, but how do I access /filesystem from the console? or the graphical user is better?
:mag: mount the / filesystem of your installed system!
Are you root in your live system?
whoami
tells you
lsblk -f
shows you your disk and partitions on it
note the name of the partition with the / filesystem on it
get root if you are not yet
sudo su -
mount the partition your root filesystem is on (the name you noted)
to /mnt
mount /dev/xyz /mnt
ls -al /mnt/usr/bin/sudo
to verify that you are indeed “above target”
it should list the file and permissions just as before in this thread
If that is the case, proceed:
chmod u+s /mnt/usr/bin/sudo
verify once again - the output should now show an “s” where there was an “x” before
if that is so, you are done
umount /mnt
reboot
I don’t understand this part [quote=“Nachlese, post:31, topic:131972”]
to /mnt
mount /dev/xyz /mnt
[/quote]
i am already root, and i put “lsblk -f” so i get
“NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0
squash 4.0 0 100% /run/archiso/sfs/airootfs
sda
-sda1
vfat FAT32 something
-sda2
ext4 1.0 somthing
-sda3
swap 1 somthing
sdb
sdb1
vfat FAT32 RESCUE804
sr0”
as root:
fdisk -l
maybe that output is more clear to you
/dev/xyz stands for whatever the name of your device is - I can’t know that, but you can see …
It is likely that this is /dev/sda3
so:
mount /dev/sda3 /mnt
… format your output - it’s hard to read like that
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
  2. Please press the three dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
    (Wisdom lies in reading :wink: )
with “fdisk -l” i get 3 devices and its type “file swap”, “linux filesystem” and “efi system”. so i guess is the /dev/xxx with the filesystem type
the one with linux filesystem
not “swap”, obviously - and not “efi system” either
so it should be:
mount /dev/sda2 /mnt
when /dev/sda2 is the linux filesystem
I managed to return the root permissions. Thanks
