specs on the site tells:
2×DDR4 2400MHz 8 Dual channel (SODIMM Slots×2)
please fix that single 8 w/o a payload unit.
Luanch Time
Luanch Time
Memory 2×DDR4 2400MHz 8 Dual channel (SODIMM Slots×2)
What is wrong?
8 perhaps GB, not broken alone 8 number: like eight dual channel.
Ah OK, it is missing GB after the 8. And Launch is misspelled.
Your message is very cryptic. Also I guess it should be addressed by MinisForum, not sure the Manjaro team can fix typo on their website.
yes. got it, thank you. will let them know ![]()
Also on the Specifications tab:
3 * SB3.1 Port(Gen2 , Blue)
Should be:
3 * USB3.1 Port(Gen2 , Blue)
Also
1 * USB3.0 Port×1(Gen1 , 2.0A Max output , shutdown charging , Yellow)
that single USB port item posted twice in the line: 1 * and ×1
I removed Solution mark from the thread according to that new posts.
