Typing Lag Issues on Manjaro KDE
Hi to everyone
Foreword
I have been using Manjaro KDE on all the family computers (2 desktops and 3 laptops) without any problems for years, including a Lenovo Ideapad Pro 5 AMD (CPU 7840HS).
I have now bought a Lenovo Ideapad Pro 5 AMD (CPU 8845HS) on which I unfortunately experience the same problem as mentioned in this thread
Typing Lag Issues on Manjaro XFCE After Installing Development Tools
What I have done
Laptop without OS,
I installed the latest Manjaro KDE ISO and ran the latest updates.
I immediately noticed the problem and tried changing the kernel (6.6, 6.12, 6.13) but to no result.
So I tried to redo the installation and realised that the problem is already there with Live, before I even started the installation: I press the keys and the display is delayed.
What can I do? I don’t want to have to install Windows!
as English is not my language, translated with Deepl
I sometimes experience something similar with Manjaro (and other distributions) when running in a VM, but never on real hardware.
Let’s start by providing some system information (see below), which will help others to identify possible contributors.
System Information:
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
In the meantime I tried other distributions. Similar behaviour with cachy-os.
No typing problem with Neon and MX (but WIFI does not work with this one out of the box).
As I currently have Neon installed and want to test it thoroughly, I booted from the latest manjaro kde image (without installing) here is the output of inxi -z8v
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=it_CH keytable=ch tz=UTC
    misobasedir=manjaro misolabel=MANJARO_KDE_2421 quiet
    systemd.show_status=1 splash driver=nonfree nouveau.modeset=0
    i915.modeset=1 radeon.modeset=1
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Type: Laptop System: LENOVO product: 83D3 v: IdeaPad Pro 5 14AHP9
    serial: <superuser required> Chassis: type: 10 v: IdeaPad Pro 5 14AHP9
  Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
    part-nu: LENOVO_MT_83D3_BU_idea_FM_IdeaPad Pro 5 14AHP9
    uuid: <superuser required> UEFI: LENOVO v: NBCN17WW date: 03/12/2024
  ID-1: BAT0 charge: 78.0 Wh (91.2%) condition: 85.5/84.0 Wh (101.8%)
    power: 5.8 W volts: 17.4 min: 15.6 model: Sunwoda L23D4PF1 type: Li-poly
    serial: <filter> status: discharging cycles: 3
  System RAM: total: 32 GiB available: 27.21 GiB used: 2.12 GiB (7.8%)
  Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
  Device-1: Channel-A DIMM 0 type: LPDDR5 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 6400 MT/s volts: curr: 0.5 min: 0.5
    max: 0.5 width (bits): data: 32 total: 32 manufacturer: Hynix
    part-no: H58G66BK7BX067 serial: N/A
  Device-2: Channel-B DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-3: Channel-C DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-4: Channel-D DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 8845HS w/ Radeon 780M Graphics bits: 64
    type: MT MCP arch: Zen 4 gen: 4 level: v4 note: check built: 2022+
    process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x75 (117) stepping: 2
    microcode: 0xA705206
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1098 min/max: 400/6681 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1098 2: 1098 3: 1098
    4: 1098 5: 1098 6: 1098 7: 1098 8: 1098 9: 1098 10: 1098 11: 1098 12: 1098
    13: 1098 14: 1098 15: 1098 16: 1098 bogomips: 121419
  Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avx avx2
    avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
    avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean
    vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1 xsave
    xsavec xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
    BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Phoenix3 vendor: Lenovo
    driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
    built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
    empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, HDMI-A-1, Writeback-1
    bus-ID: 63:00.0 chip-ID: 1002:1900 class-ID: 0300 temp: 28.0 C
  Device-2: Bison Integrated RGB Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 5986:2169
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2880x1800 s-dpi: 96 s-size: 762x476mm (30.00x18.74")
    s-diag: 898mm (35.37")
  Monitor-1: eDP-1 mapped: eDP model: Samsung 0x419f built: 2023
    res: 2880x1800 hz: 120 dpi: 242 gamma: 1.2 chroma: red: x: 0.682 y: 0.322
    green: x: 0.235 y: 0.725 blue: x: 0.137 y: 0.047 white: x: 0.314 y: 0.329
    size: 302x189mm (11.89x7.44") diag: 356mm (14") ratio: 16:10
    modes: 2880x1800, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024,
    1440x900, 1280x800, 1280x720, 1024x768, 800x600, 640x480
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
    gfx1103_r1 LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO) device-ID: 1002:1900
    memory: 3.91 GiB unified: no
  API: Vulkan v: 1.4.303 layers: N/A device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV GFX1103_R1) driver: N/A device-ID: 1002:1900
    surfaces: xcb,xlib
  Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
    Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 63:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: Lenovo driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x,
    snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
    snd_rpl_pci_acp6x, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 63:00.5 chip-ID: 1022:15e2 class-ID: 0480
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 63:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8852BE PCIe 802.11ax Wireless Network vendor: Lenovo
    driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 6000 bus-ID: 02:00.0 chip-ID: 10ec:b852 class-ID: 0280
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 0bda:4853
  Local Storage: total: 1.05 TiB used: 0 KiB (0.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
    SN740 SDDPMQD-1T00-1101 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 73116001 temp: 25.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Verbatim model: STORE N GO
    size: 117.19 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 1.00 scheme: MBR
  Message: No partition data found.
  ID-1: /dev/dm-0 maj-min: 254:0 mapped: ventoy size: 4.03 GiB fs: iso9660
  ID-2: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: N/A
    uuid: 4ED2-945A
  ID-3: /dev/nvme0n1p2 maj-min: 259:2 size: 923.64 GiB fs: ext4 label: N/A
    uuid: 742a9b30-311f-4398-881d-26e2f401af4c
  ID-4: /dev/nvme0n1p3 maj-min: 259:3 size: 29.93 GiB fs: swap label: swap
    uuid: 13295f19-c3ca-40f5-a93c-25236fbf5176
  ID-5: /dev/sda1 maj-min: 8:1 size: 117.16 GiB fs: exfat label: Ventoy
    uuid: B026-50C2
  ID-6: /dev/sda2 maj-min: 8:2 size: 32 MiB fs: vfat label: VTOYEFI
    uuid: 223C-F3F8
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
  Device-1: 1-2:2 info: Lenovo Wireless Mouse type: mouse
    lanes: 1 mode: 1.1 power: 98mA chip-ID: 17ef:60d1 class-ID: 0301
  Device-2: 1-5:3 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:4853 class-ID: e001 serial: <filter>
  Device-1: 2-1:2 info: Verbatim Flash Drive (StorenGo) type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 304mA chip-ID: 18a5:0243 class-ID: 0806
    serial: <filter>
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 3-1:2 info: Bison Integrated RGB Camera type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 5986:2169 class-ID: fe01
    serial: <filter>
  Hub-4: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 29.4 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1248 libs: 327 tools: pamac pm: flatpak pkgs: 0
  removed by me
Processes:
  CPU top: 5 of 312
  1: cpu: 1.6% command: Xorg pid: 1604 mem: 163.5 MiB (0.5%)
  2: cpu: 1.1% command: kwin_x11 pid: 1762 mem: 226.5 MiB (0.8%)
  3: cpu: 1.1% command: plasmashell pid: 1811 mem: 405.2 MiB (1.4%)
  4: cpu: 0.6% command: systemsettings pid: 2789 mem: 270.2 MiB (0.9%)
  5: cpu: 0.4% command: [irq/93-rtw89_pci] pid: 1036 mem: 0.00 MiB (0.0%)
  Memory top: 5 of 312
  1: mem: 405.2 MiB (1.4%) command: plasmashell pid: 1811 cpu: 1.1%
  2: mem: 270.2 MiB (0.9%) command: systemsettings pid: 2789 cpu: 0.6%
  3: mem: 226.5 MiB (0.8%) command: kwin_x11 pid: 1762 cpu: 1.1%
  4: mem: 163.5 MiB (0.5%) command: Xorg pid: 1604 cpu: 1.6%
  5: mem: 156.3 MiB (0.5%) command: konsole pid: 2880 cpu: 0.4%
  Processes: 312 Power: uptime: 11m states: freeze,mem,disk suspend: s2idle
    image: 10.84 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 256 default: graphical tool: systemctl
  Compilers: N/A Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.36
Thanks
If you’re experiencing this on multiple distributions, it’s likely not an issue with Manjaro; possibly insufficient graphic performance.
Nonetheless, once you have Manjaro installed again, and a sync has been performed with yesterday’s slew of updates, this would be the prime time to test again and provide your system information.
Touch base again when you can provide that, and those wishing to help can then have a common frame of reference.
When you install Manjaro again, some swap space may be beneficial. If you won’t be hibernating, then allow the same amount of space as (rule of thumb) half your RAM.
I note that you’re using AMD graphics and X11.
The combination of AMD graphics and Wayland results in a more performant system, generally. Perhaps switch to Wayland soon after installing to witness the difference yourself.
After performing necessary updates, provide system information again.
I have just finished installing Manjaro with swap and starting with wayland.
If I open a konsole and type a command (or any sequence of characters) nothing appears for a few seconds; the display delay seems even worse.
Anyway, here is the result of inxi
  Kernel: 6.12.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=d0abaf3e-f19c-4adf-a256-58b5c57c9cb0 rw quiet splash
    resume=UUID=471a264e-1b14-41fe-ba01-b6c08f6e4574 udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
  ID-1: BAT0 charge: 38.9 Wh (45.9%) condition: 84.7/84.0 Wh (100.8%)
    power: 7.7 W volts: 15.4 min: 15.6 model: Sunwoda L23D4PF1 type: Li-poly
  System RAM: total: 32 GiB available: 27.21 GiB used: 1.66 GiB (6.1%)
    13: 1098 14: 1098 15: 1098 16: 1098 bogomips: 121420
    BHI: Not affected
    bus-ID: 63:00.0 chip-ID: 1002:1900 class-ID: 0300 temp: 35.0 C
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: Samsung 0x419f built: 2023 res: mode: 2880x1800
    hz: 120 scale: 200% (2) to: 1440x900 dpi: 242 gamma: 1.2 chroma: red:
    x: 0.682 y: 0.322 green: x: 0.235 y: 0.725 blue: x: 0.137 y: 0.047 white:
    x: 0.314 y: 0.329 size: 302x189mm (11.89x7.44") diag: 356mm (14")
    ratio: 16:10 modes: 2880x1800, 1920x1200, 1920x1080, 1600x1200,
    1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600,
    640x480
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
    gfx1103_r1 LLVM 19.1.7 DRM 3.61 6.12.17-1-MANJARO) device-ID: 1002:1900
    memory: 3.91 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.304 layers: N/A device: 0 type: integrated-gpu name: AMD
    surfaces: xcb,xlib,wayland
  API: ALSA v: k6.12.17-1-MANJARO status: kernel-api with: aoss
  Local Storage: total: 953.87 GiB used: 10.8 GiB (1.1%)
    fw-rev: 73116001 temp: 31.9 C scheme: GPT
  ID-1: / raw-size: 123.75 GiB size: 120.75 GiB (97.58%)
    used: 10.74 GiB (8.9%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
    label: N/A uuid: d0abaf3e-f19c-4adf-a256-58b5c57c9cb0
    used: 32.3 MiB (6.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 4E06-ABC9
  ID-3: /home raw-size: 797.09 GiB size: 783.51 GiB (98.30%)
    used: 30.6 MiB (0.0%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
    uuid: 458b7b29-16c6-4836-b0d7-e01678f236a0
  ID-1: swap-1 type: partition size: 32.53 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: swap
    uuid: 471a264e-1b14-41fe-ba01-b6c08f6e4574
    serial: <filter>
  System Temperatures: cpu: 36.6 C mobo: N/A gpu: amdgpu temp: 35.0 C
  Packages: pm: pacman pkgs: 1211 libs: 348 tools: pamac pm: flatpak pkgs: 0
    1: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    2: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    3: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 355
  1: cpu: 11.1% command: plasmashell pid: 1170 mem: 374.8 MiB (1.3%)
  2: cpu: 10.4% command: konsole pid: 1740 mem: 162.1 MiB (0.5%)
  3: cpu: 6.2% command: kwin_wayland pid: 911 mem: 253.1 MiB (0.9%)
  4: cpu: 5.1% command: zsh pid: 1761 mem: 10.0 MiB (0.0%)
  5: cpu: 2.5% command: partitionmanager pid: 1568 mem: 166.6 MiB (0.5%)
  Memory top: 5 of 355
  1: mem: 374.8 MiB (1.3%) command: plasmashell pid: 1170 cpu: 11.1%
  2: mem: 253.1 MiB (0.9%) command: kwin_wayland pid: 911 cpu: 6.2%
  3: mem: 166.6 MiB (0.5%) command: partitionmanager pid: 1568 cpu: 2.5%
  4: mem: 162.1 MiB (0.5%) command: konsole pid: 1740 cpu: 10.4%
  5: mem: 153.8 MiB (0.5%) command: polkit-kde-authentication-agent-1
    pid: 1217 cpu: 1.0%
  Processes: 355 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
    image: 10.86 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 257 default: graphical tool: systemctl
  Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.37
Thanks
I know that this solved issue is about an HP device but cpu/graphics are the same and solution of adding amdgpu.dcdebugmask=0x10 to kernel parameters should be easy to test.
This is the solution! Now it works perfectly.
Thank you very much!
By the way … this flag will disable the totality of PSR.
( which may or may not be desirable )
A fuller explanation of that and other options can be found here:
