I’m posting here because I want to set a shortcut to type the characters ‘<’ and ‘>’.
Indeed, my keyboard doesn’t include this keys and I need them to code.
So, when I try to set a new shotcut to type these characters, it works partially: the inferior character shortcut just prints the superior character without any reason, whatever the key combination I can set, even when I disable the superior character shortcut.
You don’t have to directly set > or < keys in “Action” tab. For example on a us layout one has to press Shift+. to get > and Shift+, to get <. So set action accordingly. I can’t figure out which language and layout you are using but I hope you get the idea here.
But that gaves me the idea to try all AltGr and AltGr + Shift combinations, and I finally found it : AltGr + Shift + Z and AltGR + Shift + X (this doesn’t work on Windows so this is specific to Manjaro I guess)
However the solution of @Tomek looks working perfectly and would be fine for other characters, so thank you both for the solution
