Tying to install matlab via aur package it fails installing qt5-webkit
Hello i try to install matlab aur package to install matlab but it fails installing qt5-webkit… has anyone an idea?
 sudo pamac install matlab         ✔
[sudo] password for lukasb:
Warning: matlab is only available from AUR
Preparing...
Cloning matlab build files...
Running as unit: run-u137.service
fatal: not a git repository (or any parent up to mount point /var/cache/private)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
Finished with result: exit-code
Main processes terminated with: code=exited/status=128
Service runtime: 46ms
CPU time consumed: 14ms
Running as unit: run-u138.service
Finished with result: success
Main processes terminated with: code=exited/status=0
Service runtime: 60ms
CPU time consumed: 13ms
Running as unit: run-u139.service
Service runtime: 461ms
CPU time consumed: 108ms
Generating matlab information...
Running as unit: run-u140.service
Service runtime: 1.925s
CPU time consumed: 2.130s
Checking matlab dependencies...
Cloning matlab-meta build files...
Running as unit: run-u141.service
Service runtime: 14ms
Running as unit: run-u142.service
Service runtime: 22ms
Running as unit: run-u143.service
Service runtime: 342ms
CPU time consumed: 73ms
Generating matlab-meta information...
Running as unit: run-u144.service
Service runtime: 1.888s
CPU time consumed: 2.088s
Checking matlab-meta dependencies...
Cloning qt5-webkit build files...
Running as unit: run-u145.service
Service runtime: 11ms
CPU time consumed: 10ms
Running as unit: run-u146.service
Service runtime: 582ms
CPU time consumed: 474ms
Running as unit: run-u147.service
Service runtime: 352ms
CPU time consumed: 80ms
Generating qt5-webkit information...
Running as unit: run-u148.service
Service runtime: 1.940s
CPU time consumed: 2.150s
Checking qt5-webkit dependencies...
Resolving dependencies...
Checking inter-conflicts...
To build (3):
  qt5-webkit   5.212.0alpha4-20    AUR
  matlab-meta  9.14.0.2239454-1    AUR
  matlab       9.14.0.2337262-1    AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Building qt5-webkit...
Running as unit: run-u149.service
Press ^] three times within 1s to disconnect TTY.
==> Making package: qt5-webkit 5.212.0alpha4-20 (Mi 11 Okt 2023 17:26:50)
==> Retrieving sources...
  -> Downloading qtwebkit-5.212.0-alpha4.tar.xz...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100 11.9M  100 11.9M    0     0  5264k      0  0:00:02  0:00:02 --:--:-- 6182k
  -> Downloading qtwebkit-cstdint.patch...
100   496  100   496    0     0    230      0  0:00:02  0:00:02 --:--:--   230
  -> Found icu68.patch
  -> Found glib-2.68.patch
  -> Found qt5-webkit-python-3.9.patch
  -> Found qt5-webkit-bison-3.7.patch
    qtwebkit-5.212.0-alpha4.tar.xz ... Passed
    qtwebkit-cstdint.patch ... Passed
    icu68.patch ... Passed
    glib-2.68.patch ... Passed
    qt5-webkit-python-3.9.patch ... Passed
    qt5-webkit-bison-3.7.patch ... Passed
==> Extracting sources...
  -> Extracting qtwebkit-5.212.0-alpha4.tar.xz with bsdtar
==> Starting prepare()...
patching file Source/WebCore/platform/text/TextCodecICU.cpp
patching file Source/WebCore/platform/text/icu/UTextProvider.h
patching file Source/WebCore/platform/text/icu/UTextProviderLatin1.cpp
patching file Source/WebCore/platform/text/icu/UTextProviderUTF16.cpp
patching file Source/WTF/wtf/glib/GRefPtr.h
Hunk #1 succeeded at 29 with fuzz 2.
patching file Source/JavaScriptCore/generate-bytecode-files
patching file Source/WebCore/css/makegrammar.pl
patching file Source/ThirdParty/ANGLE/src/common/mathutil.h
==> Starting build()...
CMake Deprecation Warning at CMakeLists.txt:1 (cmake_minimum_required):
  Compatibility with CMake < 3.5 will be removed from a future version of
  CMake.
  Update the VERSION argument <min> value or use a ...<max> suffix to tell
  CMake that the project does not need compatibility with older versions.
-- The C compiler identification is GNU 13.2.1
-- The CXX compiler identification is GNU 13.2.1
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Found BISON: /usr/bin/bison (found suitable version "3.8.2", minimum required is "2.1")
-- Found Gperf: /usr/bin/gperf (Required is at least version "3.0.1")
-- Found Perl: /usr/bin/perl (found suitable version "5.38.0", minimum required is "5.10.0")
CMake Warning (dev) at Source/cmake/WebKitCommon.cmake:28 (find_package):
  Policy CMP0148 is not set: The FindPythonInterp and FindPythonLibs modules
  are removed.  Run "cmake --help-policy CMP0148" for policy details.  Use
  the cmake_policy command to set the policy and suppress this warning.
Call Stack (most recent call first):
  CMakeLists.txt:137 (include)
This warning is for project developers.  Use -Wno-dev to suppress it.
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.11.5", minimum required is "2.7.0")
-- Found Ruby: /usr/bin/ruby (found suitable version "3.0.6", minimum required is "1.9")
-- Looking for include file features.h
-- Looking for include file features.h - found
-- Could NOT find PkgConfig (missing: PKG_CONFIG_EXECUTABLE)
-- Found Sqlite: /usr/include
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
-- Found Threads: TRUE
-- Found JPEG: /usr/lib/libjpeg.so (found version "80")
-- Found ZLIB: /usr/lib/libz.so (found version "1.3")
-- Found PNG: /usr/lib/libpng.so (found version "1.6.40")
-- Found ICU header files in /usr/include
-- Found ICU libraries: /usr/lib/libicuuc.so
-- Found LibXml2: /usr/lib/libxml2.so (found suitable version "2.11.5", minimum required is "2.8.0")
-- Found LibXslt: /usr/lib/libxslt.so (found suitable version "1.1.38", minimum required is "1.1.7")
-- Could NOT find Dwz (missing: DWZ_EXECUTABLE) (Required is at least version "0.13")
-- Found WebP: /usr/include
-- Qt OpenGL implementation: GL
-- Qt OpenGL libraries: Qt5::Gui_GL
-- Qt EGL libraries: Qt5::Gui_EGL
-- Performing Test Qt5Gui_PRIVATE_HEADER_FOUND
-- Performing Test Qt5Gui_PRIVATE_HEADER_FOUND - Success
-- Performing Test Qt5Network_PRIVATE_HEADER_FOUND
-- Performing Test Qt5Network_PRIVATE_HEADER_FOUND - Success
-- Performing Test Qt5Quick_PRIVATE_HEADER_FOUND
-- Performing Test Qt5Quick_PRIVATE_HEADER_FOUND - Success
-- Found X11: /usr/include
-- Looking for XOpenDisplay in /usr/lib/libX11.so;/usr/lib/libXext.so
-- Looking for XOpenDisplay in /usr/lib/libX11.so;/usr/lib/libXext.so - found
-- Looking for gethostbyname
-- Looking for gethostbyname - found
-- Looking for connect
-- Looking for connect - found
-- Looking for remove
-- Looking for remove - found
-- Looking for shmat
-- Looking for shmat - found
-- Looking for IceConnectionNumber in ICE
-- Looking for IceConnectionNumber in ICE - found
-- Found GLIB: /usr/include/glib-2.0;/usr/lib/glib-2.0/include (found suitable version "2.78.0", minimum required is "2.36")
-- Found GStreamer: GSTREAMER_INCLUDE_DIRS;GSTREAMER_LIBRARIES;GSTREAMER_VERSION;GSTREAMER_BASE_INCLUDE_DIRS;GSTREAMER_BASE_LIBRARIES;GSTREAMER_APP_INCLUDE_DIRS;GSTREAMER_APP_LIBRARIES;GSTREAMER_PBUTILS_INCLUDE_DIRS;GSTREAMER_PBUTILS_LIBRARIES;GSTREAMER_VIDEO_INCLUDE_DIRS;GSTREAMER_VIDEO_LIBRARIES;GSTREAMER_MPEGTS_INCLUDE_DIRS;GSTREAMER_MPEGTS_LIBRARIES;GSTREAMER_TAG_INCLUDE_DIRS;GSTREAMER_TAG_LIBRARIES;GSTREAMER_GL_INCLUDE_DIRS;GSTREAMER_GL_LIBRARIES;GSTREAMER_AUDIO_INCLUDE_DIRS;GSTREAMER_AUDIO_LIBRARIES;GSTREAMER_FFT_INCLUDE_DIRS;GSTREAMER_FFT_LIBRARIES (Required is at least version "1.0.3")
CMake Error at Source/cmake/OptionsQt.cmake:816 (message):
  WebAudio requires the audio and fft GStreamer libraries.  Please check your
  gst-plugins-base installation.
  Source/cmake/WebKitCommon.cmake:51 (include)
-- Configuring incomplete, errors occurred!
==> ERROR: A failure occurred in build().
    Aborting...
Main processes terminated with: code=exited/status=4
Service runtime: 19.964s
CPU time consumed: 14.095s
sudo pacman -Q gst-plugins-base         1 ✘
gst-plugins-base 1.22.6-1
Stop using sudo when it is not called for.
In the case of pamac, for example, it has been shown to improperly set filesystem permissions, breaking pamac.
Ok thank u you for the tip. have u any suggestions to resolve this?
You’re missing the prerequisites for using the AUR.
got it thank u
