Two Systems Updated, One Hitting Dependency Error
Morning All,
I updated two of my three Manjaro boxes without a hitch last night. My third one is hitting a dependency error:
    ~  sudo pacman -Syu         1 ✘  7s 
 core is up to date
 extra is up to date
 multilib is up to date
resolving dependencies...
:: installing libxml2 (2.14.3-1) breaks dependency 'libxml2.so=2-64' required by rest
There’s your problem.
Are you on ARM? That’s the only branch where I could even find the rest package. If not, I can’t find it, so don’t know how you installed it, so don’t think I can be of much help. However, if you are then the fix is rather simple:
Remove the package:
pamac remove rest
Do the update:
pamac upgrade --no-aur
Rebuild all AUR packages:
pamac build $(pamac list --foreign --quiet)
And then you can reinstall rest:
pamac install rest
No idea how that package snuck in there. Not using an ARM device. It’s actually my wife’s laptop which is a pretty minimal install of Manjaro (compared to mine at least). Thanks for the solution.
