Hello, after reinstalling Manjaro Gnome on the new version 21.1.1, I ran into two problems. First, when I try to switch to another language through the alt + shift combination, the language changes, but the icon in the top panel does not change. How to solve this (Alt shift put it through Gnome Tweaks) Second: the basket is gone from the Dock, can I somehow return the basket?
Hi, about the trash bin icon, I think it’s within Dash to Dock settings.
It is a common for fixed release distributions to require reinstallation but Arch based distribution’s rolling nature do not require this.
If you regular sync your system with the official repositories your system will be updated long before the ISO is made available.
