Okay. Lets try this. Go to this link, download manjaro-kde-20.1-rc5-200828-linux58.iso
and try to boot into that ISO, instead of the one you are using.
This has a newer kernel, so I want to see if that fixes anything.
ok i try this
Ok im back with the new iso and its same no image on the second screen
ok i have try this… uncheck Enable to DVI monitor on Display Configuration and re click to Enable and now work dunno why lol
Oh! So it works now?! If so, that’s good! I don’t know why you had to do that to get it to work.
yes work fine dunno if its for all time or i need make it all time i reboot
Unfortunately, we won’t know until you actually install Manjaro on your computer.
You can try installing Manjaro now, and see.
Yes i install manjaro now thx for you time and help
Ok after installed manjaro i have need uncheck second screen and check again in Display Configuration and now work fine i reboot and the two screen work thx
For future reference, it’s a lot safer to not use a converter if you can. Like instead of using DVI to HDMI, use DVI to DVI, HDMI to HDMI, DisplayPort to DisplayPort.
I think for some reason xrandr
couldn’t correctly display your video output due to the converter initially.
