Hello i have install Manjaro Plasma and i have only one monitor work the second is black i have reinstall windows so i really want merge to Manjaro anyone can help me please (sorry for my english)
Please provide the output of inxi -Fza
and xrandr --verbose
(while both monitors are plugged in).
Wrap your output via the </>
button, ```
, or <code>
Are your monitors plugged into a laptop? Into the motherboard? Or into your dGPU directly?
Also, on KDE Plasma, if you go to “Displays”, you can check if both monitors show up there as well.
yes two monitor is detected only one have image my two monitor is plugged on my AMD RX 570 Sapphire one on HDMI and one in DVI
I have a similar problem. My laptop’s external monitor only works for three seconds after being turned on then I can’t get any image at all.
I tried to run the inxi -Fza and xrandr --verbose commands but cannot post it because “no links are allowed”.
Hope you can help me.
You are not supposed to link to them, you are supposed to copy the output of the inxi command and then post that in the thread, but do format the posted code with the </> button.
I try install fresh manjaro and post what xrandr done after today
May be I was not clear enough. I cannot post the results of the commands because the forum doesn’t allow me to do so because they are recognized as a link.
I tried placing </> before and after the output of the command but didn’t work. Can you give some more specific instructions (baby steps!) please?
on live cd i have this
driver: r8169
IF: enp27s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 3.30 TiB used: 154.8 MiB (0.0%)
ID-1: /dev/nvme0n1 vendor: Corsair model: Force MP510 size: 447.13 GiB
block size: physical: 512 B logical: 512 B
ID-2: /dev/sda vendor: Kingston model: SA400S37120G size: 111.79 GiB
ID-3: /dev/sdb vendor: Western Digital model: WD10EZEX-08WN4A0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B
ID-4: /dev/sdc vendor: Seagate model: ST2000DM001-1E6164 size: 1.82 TiB
ID-5: /dev/sdd type: USB vendor: Kingston model: DataTraveler 3.0
size: 28.90 GiB block size: physical: 512 B logical: 512 B
ID-1: / raw size: N/A size: 11.74 GiB used: 154.8 MiB (1.3%)
fs: overlay source: ERR-102
System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 38 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1457
Processes: 344 Uptime: 4m Memory: 15.65 GiB used: 1.47 GiB (9.4%)
Shell: bash inxi: 3.0.37
720x480 (0x6e) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
640x480 (0x6f) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x70) 25.200MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.50KHz
v: height 480 start 490 end 492 total 525 clock 60.00Hz
640x480 (0x71) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
720x400 (0x72) 28.320MHz -HSync +VSync
h: width 720 start 738 end 846 total 900 skew 0 clock 31.47KHz
v: height 400 start 412 end 414 total 449 clock 70.08Hz
anyone
Please paste the whole output of the command, not just the last couple lines.
is all i have when i type this command
Looks like you didn’t post the whole output of either commands. It’s missing a ton of info that would normally come up with those commands.
yes i have copy all i have in terminal when i have type the command
Did you scroll up the terminal to copy everything above…? You only copied the end of the outputs.
give me 5 minutes i retry command and repast here after
Yes i have lost line sorry for this and sorry for waiting i copy here.
[manjaro@manjaro ~]$ inxi -Fza
Host: manjaro Kernel: 5.6.15-1-MANJARO x86_64 bits: 64
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us
tz=UTC driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
misobasedir=manjaro misolabel=MANJARO_KDE_2003 quiet
systemd.show_status=1 apparmor=1 security=apparmor
Desktop: KDE Plasma 5.18.5 Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: A320M PRO-M2 V2 (MS-7B84) v: 2.0
serial: <filter> UEFI: American Megatrends v: 3.10 date: 01/30/2019
Topology: 8-Core model: AMD Ryzen 7 2700 bits: 64 type: MT MCP
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D
L2 cache: 4096 KiB
Speed: 2392 MHz min/max: 1550/3200 MHz Core speeds (MHz): 1: 1634
2: 1905 3: 1378 4: 1393 5: 1381 6: 1383 7: 1549 8: 1549 9: 1363
10: 1440 11: 1284 12: 1377 13: 1327 14: 1338 15: 1446 16: 1383
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
STIBP: disabled, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
driver: amdgpu v: kernel
Display: x11 server: X.Org 1.20.8 driver: amdgpu FAILED: ati
unloaded: modesetting resolution: 1920x1080~75Hz, 1920x1080~75Hz
OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.36.0
5.6.15-1-MANJARO LLVM 10.0.0)
v: 4.6 Mesa 20.0.7
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
driver: snd_hda_intel
Device-2: AMD Family 17h HD Audio driver: snd_hda_intel
Device-3: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo
Device-4: Corsair Corsair VOID PRO Wireless Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server: ALSA v: k5.6.15-1-MANJARO
driver: r8169
Local Storage: total: 3.30 TiB used: 166.5 MiB (0.0%)
ID-1: / raw size: N/A size: 11.74 GiB used: 166.5 MiB (1.4%)
System Temperatures: cpu: 45.6 C mobo: N/A gpu: amdgpu temp: 37 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1451
Processes: 313 Uptime: 9m Memory: 15.65 GiB used: 1.42 GiB (9.1%)
[manjaro@manjaro ~]$ xrandr --verbose
Screen 0: minimum 320 x 200, current 3840 x 1080, maximum 16384 x 16384
DisplayPort-0 disconnected (normal left inverted right x axis y axis)
Identifier: 0x55
Timestamp: 414257
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3 4 5
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
GAMMA_LUT_SIZE: 4096
range: (0, -1)
DEGAMMA_LUT_SIZE: 4096
range: (0, -1)
GAMMA_LUT: 0
range: (0, 65535)
CTM: 0
DEGAMMA_LUT: 0
range: (0, 65535)
TearFree: auto
supported: off, on, auto
vrr_capable: 0
range: (0, 1)
max bpc: 8
range: (8, 16)
underscan vborder: 0
range: (0, 128)
underscan hborder: 0
range: (0, 128)
underscan: off
scaling mode: None
supported: None, Full, Center, Full aspect
link-status: Good
supported: Good, Bad
CONNECTOR_ID: 59
supported: 59
non-desktop: 0
range: (0, 1)
HDMI-A-0 connected primary 1920x1080+0+0 (0x59) normal (normal left inverted right x axis y axis) 480mm x 270mm
Identifier: 0x56
Timestamp: 414257
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1 2 3 4 5
filter:
EDID:
00ffffffffffff001e6d555bfde30c00
031d010380301b78ea3135a5554ea126
0c5054a54b00714f81809500b300a9c0
810081c090402a4480a0703827403020
3500e00e1100001e000000fd00324b1e
5512000a202020202020000000fc004c
472046554c4c2048440a2020023a8018
71382d40582c4500e00e1100001e01c4
020324f148900403011012131f230907
078301000065030c001000681a000001
01324c00023a801871382d40582c4500
e00e1100001e00000000000000000000
0000000000000000011d007251d01e20
6e285500e00e1100001e8c0ad08a20e0
2d10103e9600e00e1100001800000000
0000000000000000000000000000007f
range: (0, -1)
range: (0, -1)
GAMMA_LUT: 0
range: (0, 65535)
CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
0 1
DEGAMMA_LUT: 0
range: (0, 65535)
TearFree: auto
vrr_capable: 0
range: (0, 1)
max bpc: 8
range: (8, 16)
range: (0, 128)
range: (0, 128)
underscan: off
scaling mode: None
link-status: Good
CONNECTOR_ID: 63
supported: 63
non-desktop: 0
range: (0, 1)
1920x1080 (0x59) 174.500MHz +HSync +VSync *current +preferred
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 83.89KHz
v: height 1080 start 1083 end 1088 total 1119 clock 74.97Hz
1920x1080 (0x5a) 148.500MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x5b) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1920x1080 (0x5c) 148.352MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1680x1050 (0x5d) 119.000MHz +HSync -VSync
h: width 1680 start 1728 end 1760 total 1840 skew 0 clock 64.67KHz
v: height 1050 start 1053 end 1059 total 1080 clock 59.88Hz
1400x1050 (0x5e) 101.000MHz +HSync -VSync
h: width 1400 start 1448 end 1480 total 1560 skew 0 clock 64.74KHz
v: height 1050 start 1053 end 1057 total 1080 clock 59.95Hz
1600x900 (0x5f) 108.000MHz +HSync +VSync
h: width 1600 start 1624 end 1704 total 1800 skew 0 clock 60.00KHz
v: height 900 start 901 end 904 total 1000 clock 60.00Hz
1280x1024 (0x60) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x61) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1440x900 (0x62) 88.750MHz +HSync -VSync
h: width 1440 start 1488 end 1520 total 1600 skew 0 clock 55.47KHz
v: height 900 start 903 end 909 total 926 clock 59.90Hz
1280x800 (0x63) 71.000MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 49.31KHz
v: height 800 start 803 end 809 total 823 clock 59.91Hz
1152x864 (0x64) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1280x720 (0x65) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x66) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1280x720 (0x67) 74.176MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1024x768 (0x68) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x69) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x6a) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x6b) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
720x576 (0x6c) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x480 (0x6d) 27.027MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.50KHz
v: height 480 start 489 end 495 total 525 clock 60.00Hz
DVI-D-0 connected 1920x1080+1920+0 (0x59) normal (normal left inverted right x axis y axis) 480mm x 270mm
Identifier: 0x57
Timestamp: 414257
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 1
CRTCs: 0 1 2 3 4 5
filter:
EDID:
00ffffffffffff001e6d555b2eaf0b00
71382d40582c4500e00e1100001e01c8
range: (0, -1)
range: (0, -1)
GAMMA_LUT: 0
range: (0, 65535)
0 1
DEGAMMA_LUT: 0
range: (0, 65535)
TearFree: auto
max bpc: 8
range: (8, 16)
range: (0, 128)
range: (0, 128)
underscan: off
scaling mode: None
link-status: Good
CONNECTOR_ID: 68
supported: 68
non-desktop: 0
range: (0, 1)
That shouldn’t be possible that this is the case, because you’re able to comment with text, as we can see right now. So an output should be exactly the same, because it’s literally just text. There are no url links in outputs.
I thought you said you have installed Manjaro, is there a reason why you’re posting from a LiveCD? Also, the LiveCD you’re using is pretty old. I can tell because:
Kernel 5.6 has been discontinued for a while.
It shows that you have a monitor connected to HDMI and DVI-D. Which one is the one that is working right now? And which one is the black screen?
hmm ok i have take lastest on manjaro website… and i not have installed for check if i can have my two monitor first for your question hdmi one work fine just dvi to hdmi no image found
Huh… you’re right. You are on the latest LiveISO. I guess Manjaro team hasn’t made a new ISO with the newer kernels unfortunately. My mistake.
If you have both plugged in, do both monitors come up in “Display Configuration”? You can find this by clicking on the Manjaro Icon (or click on Windows key), then type in “Display”. If they are both there, can you make sure if “Enabled” is checked for both?
Should look like this:
Else: What happens when you unplug your HDMI one, and only use the DVI to HDMI, then boot into the LiveISO?
Also, do both monitors work fine on Windows?
ok after reboot and look if DVI work with HDMI one disconnect the DVI have no image same when i look at display configuration i have my HDMI Enabled and Primary and DVI Enabled only and on window 10 my two monitor work fine when i have past xrandr line i have look amdgpu FAILED its normal
