Two displayport (dp) monitors lead to system freeze from kernel > 6.6
Hello together
With Kernel 6.6 (LTS), currently on 6.6.54-2, my setup work well. Both Monitors are connected via DisplayPort on my Dock and the Dock is via USB-C (3.2) connected to my Notebook. With all higher Kernels, my system freezes. Last test was with Kernel 6.12.0-rc2-2-MANJARO. Is only one Monitor connected → No Problem. As soon as the second monitor is connected, my system freezes.
Are both Monitors while boot connected, the login screen doesn’t shows up.
Hardware:
TUXEDO Pulse 14 Gen3
AMD Ryzen 7 7840HS w/ Radeon 780M Graphics
TUXEDO Triple Dock Lite v2 (C31TRIPLEDOCKPDPR02)
2 external HP Z27n G2 Monitors.
Both Monitors are connected via DisplayPort Cable. My Notebook is connected with USB-C on the Dock.
Journal from system freeze: https://0x0.st/Xn3X.txt
Full output from `inxi -v6`
  Host: marco-tuxedopulse14gen3 Kernel: 6.6.54-2-MANJARO arch: x86_64 bits: 64
    compiler: gcc v: 14.2.1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 dm: LightDM
  Type: Laptop System: TUXEDO product: TUXEDO Pulse 14 Gen3 v: Version 1.0
  Mobo: NB05 model: R14FA1 v: Version 1.0 serial: <superuser required>
    part-nu: PULSE1403 uuid: <superuser required> UEFI: American Megatrends LLC.
    v: 8.13 date: 03/25/2024
  ID-1: BAT0 charge: 32.5 Wh (52.9%) condition: 61.4/61.4 Wh (100.0%)
    volts: 11.7 min: 11.8 model: Standard SR Real Battery serial: 123456789
    status: not charging
  System RAM: total: 32 GiB available: 25.25 GiB used: 4.31 GiB (17.1%)
  Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
  Device-1: Channel-A DIMM 0 type: LPDDR5 size: 8 GiB speed: spec: 7500 MT/s
    actual: 6400 MT/s volts: 0.5 manufacturer: Micron Technology
    part-no: MT62F2G32D4DS-026 WT
  Device-2: Channel-B DIMM 0 type: LPDDR5 size: 8 GiB speed: spec: 7500 MT/s
  Device-3: Channel-C DIMM 0 type: LPDDR5 size: 8 GiB speed: spec: 7500 MT/s
  Device-4: Channel-D DIMM 0 type: LPDDR5 size: 8 GiB speed: spec: 7500 MT/s
  Info: 8-core model: AMD Ryzen 7 7840HS w/ Radeon 780M Graphics bits: 64
    type: MT MCP arch: Zen 4 rev: 1 cache: L1: 512 KiB L2: 8 MiB L3: 16 MiB
  Speed (MHz): avg: 3765 min/max: 400/5137 boost: enabled cores: 1: 3765
    2: 3765 3: 3765 4: 3765 5: 3765 6: 3765 7: 3765 8: 3765 9: 3765 10: 3765
    11: 3765 12: 3765 13: 3765 14: 3765 15: 3765 16: 3765 bogomips: 121430
  Device-1: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: IP3 Tech
    driver: amdgpu v: kernel arch: RDNA-3 pcie: speed: 16 GT/s lanes: 16 ports:
    active: DP-12,DP-8 off: eDP-1 empty: DP-1, DP-10, DP-11, DP-2, DP-3,
    DP-4, DP-5, DP-6, DP-7, DP-9, HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15bf
    temp: 40.0 C
  Device-2: Microdia USB 2.0 Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 bus-ID: 1-4:2 chip-ID: 0c45:636c
  Display: x11 server: X.Org v: 21.1.14 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 5120x1440 s-dpi: 96
  Monitor-1: DP-12 mapped: DisplayPort-11 pos: right model: HP Z27n G2
    res: 2560x1440 dpi: 109 diag: 685mm (27")
  Monitor-2: DP-8 mapped: DisplayPort-7 pos: primary,left model: HP Z27n G2
  Monitor-3: eDP-1 mapped: eDP note: disabled model: TL140ADXP24-0
    res: 2560x1440 dpi: 244 diag: 355mm (14")
  API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: swrast
    gbm: drv: kms_swrast surfaceless: drv: radeonsi x11: drv: radeonsi
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.4-arch1.0.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M (radeonsi
    gfx1103_r1 LLVM 18.1.8 DRM 3.54 6.6.54-2-MANJARO) device-ID: 1002:15bf
  API: Vulkan v: 1.3.295 surfaces: xcb,xlib device: 0 type: integrated-gpu
    driver: mesa radv device-ID: 1002:15bf
  Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
    Audio driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
    bus-ID: 03:00.1 chip-ID: 1002:1640
  Device-2: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
    vendor: Conexant Systems driver: snd_hda_intel v: kernel pcie:
    speed: 16 GT/s lanes: 16 bus-ID: 03:00.6 chip-ID: 1022:15e3
  API: ALSA v: k6.6.54-2-MANJARO status: kernel-api with: aoss
    type: oss-emulator
  Server-1: JACK v: 1.9.22 status: off
  Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
    v: kernel pcie: speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2725
  IF: wlp1s0 state: down mac: 72:30:50:bf:2f:ab
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 bus-ID: 6-1.4.4:4 chip-ID: 0bda:8153
  IF: enp5s0f3u1u4u4 state: up speed: 1000 Mbps duplex: full
    mac: 80:3f:5d:f8:e6:4c
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 bus-ID: 1-5:3 chip-ID: 8087:0032
  Local Storage: total: 931.51 GiB used: 330.95 GiB (35.5%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
    size: 931.51 GiB speed: 31.6 Gb/s lanes: 4 serial: S4EWNM0W930138R
    temp: 36.9 C
  ID-1: / size: 883.92 GiB used: 330.95 GiB (37.4%) fs: ext4 dev: /dev/dm-0
    mapped: luks-b7731a9f-d970-4485-b710-2c3bc1209acb label: N/A
    uuid: 9ca1dac9-56c3-4f40-ac60-f30635eeefa5
  ID-2: /boot/efi size: 299.4 MiB used: 448 KiB (0.1%) fs: vfat
    dev: /dev/nvme0n1p1 label: N/A uuid: D38A-D049
  ID-1: swap-1 type: partition size: 32.11 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/dm-1 mapped: luks-4d26d08f-1c3d-4ebb-afbb-5982b18acef3 label: swap
    uuid: 95be8c85-8ed5-47b4-8815-e41bf0e9b142
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
    speed: 480 Mb/s lanes: 1 chip-ID: 1d6b:0002
  Device-1: 1-4:2 info: Microdia USB 2.0 Camera type: video driver: uvcvideo
    rev: 2.0 speed: 480 Mb/s lanes: 1 chip-ID: 0c45:636c
  Device-2: 1-5:3 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
    rev: 2.0 speed: 12 Mb/s lanes: 1 chip-ID: 8087:0032
  Hub-2: 2-0:1 info: super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
    lanes: 1 chip-ID: 1d6b:0003
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-4: 3-1:2 info: USB2.0 HUB ports: 4 rev: 2.0 speed: 480 Mb/s lanes: 1
    chip-ID: 34d1:0608
  Hub-5: 4-0:1 info: super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-7: 5-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    lanes: 1 chip-ID: 05e3:0610
  Hub-8: 5-1.4:3 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  Hub-9: 5-1.4.1:4 info: Prolific USB 2.0 Hub ports: 4 rev: 2.0
    speed: 480 Mb/s lanes: 1 chip-ID: 067b:2586
  Device-1: 5-1.4.1.2:6 info: Fresco Logic Generic Billboard Device
    type: billboard driver: N/A rev: 2.0 speed: 12 Mb/s lanes: 1
    chip-ID: 1d5c:7102
  Device-2: 5-1.4.1.3:7 info: Razer USA Ornata V3 X type: keyboard,mouse
    driver: razerkbd,usbhid rev: 2.0 speed: 12 Mb/s lanes: 1 chip-ID: 1532:02a2
  Device-3: 5-1.4.2:5 info: Razer USA Viper 8KHz type: mouse,keyboard
    driver: razermouse,usbhid rev: 2.0 speed: 12 Mb/s lanes: 1
    chip-ID: 1532:0091
  Hub-10: 6-0:1 info: super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
  Hub-11: 6-1:2 info: Genesys Logic USB3.2 Hub ports: 4 rev: 3.2
    speed: 10 Gb/s lanes: 1 chip-ID: 05e3:0625
  Hub-12: 6-1.4:3 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.2
    speed: 5 Gb/s lanes: 1 chip-ID: 05e3:0620
  Device-1: 6-1.4.4:4 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 rev: 3.0 speed: 5 Gb/s lanes: 1
    chip-ID: 0bda:8153
  Hub-13: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-14: 8-0:1 info: super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
  Fan Speeds (rpm): cpu: 1542
  Processes: 396 Power: uptime: 13m wakeups: 0 Init: systemd v: 256
    default: graphical
  Packages: 1716 pm: pacman pkgs: 1710 pm: flatpak pkgs: 6 Compilers:
    clang: 18.1.8 gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: xfce4-terminal
    inxi: 3.3.36
Is there anything I could reconfigure or is it a bug, when it’s a bug to whom can I report it?
Best regards
dasBaum
there is this report
Kernel 6.9 amdgpu crash with multiple monitors via MST: NULL pointer dereference (#3405) · Issues · drm / amd · GitLab
it is solved ( 2 patchs coming in drm-next )
How did you get the drivers to install? Were there issues during the build? I can’t even get that far.
I can only test it next tuesday
