Hey there,
when I enable bluetooth I have two active bluetooth icons in the system tray. When its off there is just one as expected. It was working some updates ago. Bluetooth itself works just fine.
Any idea how to fix it or in which direction to look at?
Best regards!
- What DE are you using ?
- Did you already try to look into the configuration of your desktop-tray
- Did you already try to config the tray-icon (right mouse click in xfce)
Welcome to Manjaro!
- Please read the information behind this link. It will help you to post necessary information.
- Please press the three dots … below your post and then press the
- If you give us information about your system, we can see what we’re talking about and make better suggestions.
- You can do this by using
inxiin a terminal or in console.
- Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
- Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
- Copy the output from inxi (including the command) and paste it into your post.
- To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already
for your problem in the forum ? (Wisdom lies in asking → listening → reading
oh yeah I shouldn’t add just the tag “KDE Plasma” and just mention the DE right away. Sorry about that. Actually I was already looking into the configuration, but last time I didn’t changed something.
Removing one of icons manually already did the trick… should had tried that earlier!
Thanks for quick help:)
