Tuxedo Pulse15: Deactivating bluetooth/wifi in Bios leading to not working LAN (RJ-45 Cable) Connection
Hello,
I have a problem with my Tuxedo Pulse15 (AMD Laptop), can’t connect to the Internet when i have bluetooth/wifi in Bios disabled, why is that?
I use a normal RJ-45 Lan Cable and when i enable both in Bios again, everything working fine.
$ inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 6.1.69-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: hpet available: acpi_pm
    parameters: BOOT_IMAGE=/vmlinuz-6.1-x86_64
    root=UUID=117a5f35-5599-4992-850a-7d04cb4bca27 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
  Type: Laptop System: TUXEDO product: TUXEDO Pulse 15 Gen1 v: Standard
    serial: <superuser required>
  Mobo: NB02 model: PULSE1501 v: Standard serial: <superuser required>
    BIOS: American Megatrends v: N.1.07.A03 date: 05/11/2021
  ID-1: BAT0 charge: 20.2 Wh (22.1%) condition: 91.6/91.6 Wh (100.0%)
    volts: 10.9 min: 11.6 model: standard type: Li-ion serial: <filter>
    status: discharging
  System RAM: total: 16 GiB note: est. available: 15.05 GiB
    used: 1.93 GiB (12.8%)
  Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x8600103
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1681 high: 2900 min/max: 1400/2900 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2900 2: 1400
    3: 1400 4: 1400 5: 1400 6: 1400 7: 1400 8: 2900 9: 1400 10: 1400 11: 1400
    12: 1400 13: 1400 14: 1400 15: 1400 16: 2900 bogomips: 92660
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
    sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
    tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spec_rstack_overflow mitigation: safe RET
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Renoir [Radeon RX Vega 6 ] vendor: Tongfang Hongkong
    driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm
    built: 2017-20 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
    empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:1636 class-ID: 0300
    temp: 29.0 C
  Display: x11 server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0900 built: 2019
    res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
    16.0.6 DRM 3.49 6.1.69-1-MANJARO) device-ID: 1002:1636 memory: 500 MiB
    unified: no
  API: Vulkan v: 1.3.274 layers: 4 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.1.9-manjaro1.1
    device-ID: 1002:1636 surfaces: xcb,xlib
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Tongfang Hongkong
    bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Tongfang Hongkong
    driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Tongfang Hongkong
    bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.1.69-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp1s0 state: down mac: <filter>
    vendor: Tongfang Hongkong driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 02:00.0 chip-ID: 10ec:8168
    class-ID: 0200
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4.4:5 chip-ID: 8087:0029
    class-ID: e001
  Local Storage: total: 465.76 GiB used: 23.91 GiB (5.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO M.2 500GB
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: MBR
  ID-1: / raw-size: 240.66 GiB size: 235.82 GiB (97.99%) used: 17.76 GiB (7.5%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: Root
    uuid: 117a5f35-5599-4992-850a-7d04cb4bca27
  ID-2: /boot raw-size: 500 MiB size: 458.3 MiB (91.67%)
    used: 127.9 MiB (27.9%) fs: ext3 dev: /dev/sda1 maj-min: 8:1 label: Boot
    uuid: be5baa10-5f66-4e30-b9c6-a1788e510c69
  ID-3: /home raw-size: 175.78 GiB size: 171.96 GiB (97.83%)
    used: 6.02 GiB (3.5%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: Home
    uuid: 71a27b4e-f3fb-43e1-8e9d-8f5eec561bdd
  ID-1: /dev/sda4 maj-min: 8:4 size: 2.93 GiB fs: swap label: N/A
    uuid: a5d2ba7c-3b01-46f0-8f71-ebab43cf0582
  Hub-2: 1-4:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-4.3:3 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Device-2: 1-4.4:5 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Hub-3: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 30.4 C mobo: N/A gpu: amdgpu temp: 29.0 C
  Fan Speeds (rpm): N/A
  Processes: 301 Uptime: 37m wakeups: 0 Init: systemd v: 254 default: graphical
  tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 1428
  pm: pacman pkgs: 1423 libs: 381 tools: pamac pm: flatpak pkgs: 5 Shell: Bash
  v: 5.2.21 running-in: konsole inxi: 3.3.31
Spoiler alert: I created the inxi output while i had wifi/bluetooth enabled… otherwise it would be difficult to load it up on the Forum (without internet connection).
I disabled Wifi/Bluetooth in Bios and loaded in Manjaro and it looked strange, but i could enable Wifi in the OS, so only lan cable connection was disabled? A Bios bug or whats going on?
Probably a bug, I’d check for a ec/bios update first.
There’s also ‘tuxedo-control-centre’ in the official repos, although I’m not sure that helps with your issue unless it’s caused by bios settings interacting with power management settings.
I think i have this Bios already, my Bios is from “Build and Datetime: 05/11/2021”.
There is a newer Bios Update still possible but the only changes was a new option to disable fTPM, bios update was around 2022.
I created also a new inxi, while wifi/bluetooth disabled in Bios:
    udev.log_priority=3
  ID-1: BAT0 charge: 15.6 Wh (17.0%) condition: 91.6/91.6 Wh (100.0%)
    volts: 10.7 min: 11.6 model: standard type: Li-ion serial: <filter>
    status: discharging
    used: 1.24 GiB (8.2%)
    desc: 2x4 MiB
  Speed (MHz): avg: 1587 high: 2900 min/max: 1400/2900 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 2900
    3: 1400 4: 1400 5: 1400 6: 2900 7: 1400 8: 1400 9: 1400 10: 1400 11: 1397
    12: 1400 13: 1400 14: 1400 15: 1400 16: 1400 bogomips: 92668
    protection
    empty: HDMI-A-1 bus-ID: 02:00.0 chip-ID: 1002:1636 class-ID: 0300
    temp: 26.0 C
    unified: no
    bus-ID: 02:00.1 chip-ID: 1002:1637 class-ID: 0403
    lanes: 16 bus-ID: 02:00.5 chip-ID: 1022:15e2 class-ID: 0480
    bus-ID: 02:00.6 chip-ID: 1022:15e3 class-ID: 0403
  WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
    class-ID: e001
  Local Storage: total: 465.76 GiB used: 23.92 GiB (5.1%)
  ID-1: / raw-size: 240.66 GiB size: 235.82 GiB (97.99%) used: 17.77 GiB (7.5%)
  System Temperatures: cpu: 27.6 C mobo: N/A gpu: amdgpu temp: 26.0 C
  Processes: 322 Uptime: 1m wakeups: 0 Init: systemd v: 254 default: graphical
Still, do the update because bug fixes wouldn’t all be listed at the change log. Be aware that Tuxedo especially mentions the wide ranging security measures of their bios which mentions disabling lan.
firmware level using the UEFI the following functions can be completely deactivated:
  • iGPU VRAM („Graphics Aperture Size“)
  • TPM
  • AMD-V and AMD-Vi (IOMMU)
  • SMT (Simultaneous Hyper Threading)
  • SSD slots
  • WiFi, Bluetooth, microphone / audio, card reader, every single USB port
  • SSD security / encryption options
  • LAN boot via USB / LAN adapter or docking station
I don’t want to risk to destroy my Laptop, with Bios Updates… there is always the chance that something can go wrong.
I don’t want to trigger this, specially when its not 100% sure that this Bios Update will fix this issue.
  • If disabling wifi/bluetooth using the system’s firmware
    • And this also disables ethernet
      • Then this is a firmware bug
This has nothing to do with Manjaro and you should contact Tuxedo support.
I also have a Tuxedo, Pulse 15 Gen 2. I have 2 SSDs and after I deactivated the second SSD from BIOS, my WiFi didn’t work anymore … I didn’t investigate further but it seems this is related :smiley:
That is indeed a firmware bug
@Kobold @gigitek
Log into your tuxedo account and navigate to downloads - check if your firmware has been updated.
Wait a second, i think this both options are on the same Bios Register/Index Page… so maybe i just have to disable second SSD Slot to archive my goal to disable wifi/bluetooth, what a pre Alpha Bios gave Tuxedo to us :laughing:
I think you maybe need to change a bios option below “SSD Slot2” to really disable SSD2 Slot :rofl:
@gigitek
Can you please look which Bios Date are you using?
Okay i just deactivated NVMe Port #1 & #2 (on my Pulse 15 Gen1) and my Wifi is finally disabled now, thank you.
But related to my Journal errors, bluetooth is still active.
Jan 07 19:00:51 koboldx-tuxedopulse15 kernel: Bluetooth: hci0: FW download error recovery failed (-19)
Jan 07 19:00:51 koboldx-tuxedopulse15 kernel: Bluetooth: hci0: sending frame failed (-19)
Jan 07 19:00:51 koboldx-tuxedopulse15 kernel: Bluetooth: hci0: Failed to read MSFT supported features (-19)
Jan 07 19:00:53 koboldx-tuxedopulse15 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Jan 07 19:00:56 koboldx-tuxedopulse15 bluetoothd[662]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
Any idea how to deactivate this device?
BIOS Information
        Vendor: American Megatrends International, LLC.
        Version: N.1.06A13
        Release Date: 06/21/2023
BUT in the above mentioned scenario, when I disabled the second SSD I was using an older BIOS version. I didn’t tried after the update. So this info is not quite helpful.
I saw to late that you have Gen2 and i have a Gen1 Laptop… but its strange how both Bios versions still leads to disabling Wifi on total differend Bios Points.
My assumption is that multiple devices are connected to the same power lane, and the laptop is using a “generic” BIOS which isn’t aware about this…
