I have the Tuxedo Pulse 15 - Gen2 connected to a Tuxedo Triple Dock Lite [1] (i-tec USB-C/Thunderbolt Triple Display Docking Station).
An external monitor is connected to the dock and also a network cable for wired network.
My box is a Manjaro Linux, KDE, up to date with Kernel 6.6.5 - LTS kernel.
The problem I have is that if the computer goes to sleep, after waking up, the monitor is not available, the system doesn’t detect it. Also I have no network - ip doesn’t list the network adapter. I have to power cycle the docking station in order to re-detect the devices.
Does anyone know a fix for this? e.g. Firmware update for dock, some BIOS setting etc. ?
With Kernel 6.5 it was working - but Kernel 6.5 is marked EOL.
This may be caused by the USB port being power down.
Some system ports may not be detected after a waking up. They may need a unplug/plug to be recognised.
You can check states manually as described in the man page
$ man systemctl
System Commands:
is-system-running Check whether system is fully running
default Enter system default mode
rescue Enter system rescue mode
emergency Enter system emergency mode
halt Shut down and halt the system
poweroff Shut down and power-off the system
reboot Shut down and reboot the system
kexec Shut down and reboot the system with kexec
soft-reboot Shut down and reboot userspace
exit [EXIT_CODE] Request user instance or container exit
switch-root [ROOT [INIT]] Change to a different root file system
suspend Suspend the system
hibernate Hibernate the system
hybrid-sleep Hibernate and suspend the system
suspend-then-hibernate Suspend the system, wake after a period of
time, and hibernate
