I am new to linux and I wanted to try manjaro and I fell in love, at first everything seemed to be going well when suddenly the bluetooth stopped working every time I restart my laptop the bluetooth starts and shows me devices but after a minute it stops working and shows no bluetooth adapters
i have an asus tuf fx505dy with ryzen 5 3550h and rx560x and i am using 5.10.52-3-rt42
help please and be patient with me it’s my first look at linux i don’t understand much
Spartan2502:
nxi --admin --verbosity=7 --filter --no-host --width
zsh: correct ‘nxi’ to ‘inxi’ [nyae]? y
Kernel: 5.10.52-3-rt47-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-rt-x86_64
root=UUID=b9ddd8c4-1b69-4e1e-861d-4520728f3557 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: TUF Gaming FX505DY_FX505DY v: 1.0
serial: <filter>
Mobo: ASUSTeK model: FX505DY v: 1.0 serial: <filter>
UEFI: American Megatrends v: FX505DY.315 date: 03/09/2020
ID-1: BAT0 charge: 34.4 Wh (86.9%) condition: 39.6/48.0 Wh (82.5%)
volts: 11.7 min: 11.7 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Discharging
RAM: total: 15.38 GiB used: 3.03 GiB (19.7%)
Info: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108102 cache: L2: 2 MiB bogomips: 33538
Speed: 1263 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1263 2: 1637 3: 1550 4: 1269 5: 1208 6: 1221 7: 1433 8: 1924
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X] vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:67ef
class-ID: 0380
Device-2: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 05:00.0 chip-ID: 1002:15d8 class-ID: 0300
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0
5.10.52-3-rt47-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 05:00.1 chip-ID: 1002:15de
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.52-3-rt47-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: e000
bus-ID: 03:00.0 chip-ID: 10ec:c821 class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
Local Storage: total: 1.14 TiB used: 13.44 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate model: XPG SPECTRIX S40G
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: VB411D41 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
type: HDD rpm: 5400 serial: <filter> rev: SDM1 scheme: GPT
ID-1: / raw-size: 48.83 GiB size: 47.76 GiB (97.81%) used: 13.41 GiB (28.1%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: b9ddd8c4-1b69-4e1e-861d-4520728f3557
used: 32.9 MiB (34.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 0E7F-E881
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 189.53 GiB fs: ntfs label: N/A
uuid: D6A68887A68869B7
ID-2: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ntfs label: 1TB
uuid: 2204551C0454F3EF
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 37.9 C mobo: 37.0 C
Fan Speeds (RPM): cpu: 2500
GPU: device: amdgpu temp: 37.0 C device: amdgpu temp: 37.0 C watts: 7.12
Processes: 355 Uptime: 23m wakeups: 7 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1228 pacman: 1225 lib: 330 flatpak: 0
snap: 3 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: yakuake
inxi: 3.3.08
Welcome to the forum!
Have you tried searching the forum ?
Tip: When pasting terminal output on Discourse forums, one can either…
Highlight it and use the Preformatted text </> toolbar button.
Add three backticks ` above and below the text (Markdown):
text
Use HTML:
<pre><code>
text
</pre></code>
