Tty1 is stuck on /dev/nvme0n1p5: clean, # files, # blocks
A couple of days ago I was trying to reboot my laptop but it was frozen, so I turned it off through the power button, when it came up tty1 was stuck on recovering journal, tty2 goes into Desktop session: (plasma X11).
I followed some fixes from forums with a similar problem:
  1. boot into a live USB (I booted into Gparted)
  2. run fsck -f /dev/nvme0n1p5
  3. after it is done reboot
    I now have tty1 always displaying /dev/nvme0n1p5: clean, # files, # blocks
    and tty2 boots into the desktop session.
Result of inxi -v7azy
Ξ ~ git:(master) ▶ inxi -v7azy
inxiSystem:
  Kernel: 6.1.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: hpet available: acpi_pm
    root=UUID=b395b351-d6f7-40f1-88ff-43ee89d7e608 rw quiet acpi_osi=Linux
    apparmor=1 security=apparmor udev.log_priority=3 acpi_backlight=native
    nowatchdog
  Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 info: latte-dock
    wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05
    serial: <superuser required> Chassis: type: 10 v: Lenovo Legion 5 15ARH05
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
    serial: <superuser required> UEFI: LENOVO v: EUCN37WW date: 04/14/2022
  ID-1: BAT0 charge: 37.0 Wh (76.0%) condition: 48.7/60.0 Wh (81.2%)
    power: 22.6 W volts: 16.0 min: 15.4 model: SMP L19M4PC0 type: Li-poly
    serial: <filter> status: discharging cycles: 913
  System RAM: total: 16 GiB note: est. available: 15 GiB used: 7.27 GiB (48.5%)
  Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x8600106
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1550 high: 2420 min/max: 1400/3000 boost: enabled
    scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 1397 2: 1397
    3: 1295 4: 1247 5: 1397 6: 1461 7: 2420 8: 2418 9: 1387 10: 1400 11: 1382
    12: 1400 bogomips: 71886
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
    sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
    tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spec_rstack_overflow mitigation: safe RET
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo
    driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-09) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f95
    class-ID: 0300
  Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: eDP-1 empty: none bus-ID: 05:00.0
    chip-ID: 1002:1636 class-ID: 0300 temp: 47.0 C
  Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 5986:212b
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: amdgpu,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0xd1ed built: 2019
    res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
    diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm:
    drv: kms_swrast surfaceless: drv: nvidia x11: drv: radeonsi
    inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
    16.0.6 DRM 3.49 6.1.55-1-MANJARO) device-ID: 1002:1636 memory: 500 MiB
    unified: no
  API: Vulkan v: 1.3.264 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 1650 Ti driver: nvidia v: 535.113.01 device-ID: 10de:1f95
    surfaces: xcb,xlib device: 1 type: integrated-gpu name: AMD Radeon
    Graphics (RADV RENOIR) driver: mesa radv v: 23.1.9-manjaro1.1
    device-ID: 1002:1636 surfaces: xcb,xlib
  Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
    class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
    snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
    snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.1.55-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.81 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pulsemixer
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 8087:0029
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
  Local Storage: total: 1.16 TiB used: 947.08 GiB (80.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB256HBHQ-000L2
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3L1QEXH7 temp: 59.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPSX-08A6W
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 1A01 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: SMI (STMicroelectronics)
    model: USB DISK size: 14.56 GiB block-size: physical: 512 B logical: 512 B
    type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A
    serial: <filter> fw-rev: 1100 scheme: MBR
  ID-1: / raw-size: 51.29 GiB size: 50.31 GiB (98.08%) used: 32.53 GiB (64.7%)
    fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
    uuid: b395b351-d6f7-40f1-88ff-43ee89d7e608
    used: 50.7 MiB (52.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 0C75-E2CB
  ID-3: /home raw-size: 68.07 GiB size: 66.45 GiB (97.62%)
    used: 51.37 GiB (77.3%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
    label: N/A uuid: 8688e415-56b2-481d-827b-210e7dfd1197
  ID-4: /run/media/yamo/9640794240792A5F raw-size: 98.02 GiB
    size: 98.02 GiB (100.00%) used: 84.96 GiB (86.7%) fs: ntfs
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A uuid: 9640794240792A5F
  ID-5: /run/media/yamo/EDU raw-size: 292.97 GiB size: 292.97 GiB (100.00%)
    used: 228.77 GiB (78.1%) fs: ntfs dev: /dev/sda3 maj-min: 8:3 label: EDU
    uuid: 366C4A282D6F052F
  ID-6: /run/media/yamo/Main raw-size: 638.53 GiB size: 638.53 GiB (100.00%)
    used: 548.76 GiB (85.9%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: Main
    uuid: 3AEC09DCEC099375
  ID-1: swap-1 type: partition size: 20.48 GiB used: 644.5 MiB (3.1%)
    priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: ae9bb7f8-1320-4d92-9e21-1ebd6e555f8a
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 508 MiB fs: ntfs label: N/A
    uuid: 0E82B29B82B286AD
  ID-3: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
  ID-4: /dev/sdb1 maj-min: 8:17 size: 14.56 GiB fs: vfat label: GPARTED-LIV
    uuid: 2458-F9DF
  Device-1: 1-2:2 info: Silicon Motion - Taiwan (formerly Feiya ) Flash Drive
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
    chip-ID: 090c:1000 class-ID: 0806 serial: <filter>
  Device-2: 1-3:3 info: Bison Integrated Camera type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 5986:212b class-ID: 0e02
  Hub-4: 3-1:2 info: Genesys Logic Hub ports: 2 rev: 2.1
  Device-1: 3-1.1:5 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
    type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 1bcf:08a0 class-ID: 0301
  Device-2: 3-3:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Device-3: 3-4:4 info: Integrated Express ITE Device(8910) type: keyboard
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c100 class-ID: 0301
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 4-1:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
  System Temperatures: cpu: 48.4 C mobo: N/A gpu: amdgpu temp: 47.0 C
  Fan Speeds (rpm): N/A
  Processes: 366 Uptime: 8m wakeups: 11 Init: systemd v: 254 default: graphical
  tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 1853 pm: dpkg
  pkgs: 0 pm: pacman pkgs: 1835 libs: 466 tools: pamac,yay pm: flatpak pkgs: 5
  pm: snap pkgs: 13 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.30
Hi @Yamo,
AFAIK this is correct. Mine also does it. Has always done so.
No need to worry, as long as it gets to the desktop.
Same here; just as additional confirmation.
@Mirdarthos @soundofthunder Thanks for the fast response.
Since it’s apparently not a problem I will mark this as solved.
Since no-one has said why…tty1 is used for boot messages.
I can’t remember if this is true for manjaro, but pretty sure it’s not true for all distros (memory’s not as good nowadays). AFAIK tty1 used to be a normal tty.
