Hi, i have two monitor 1 UW Samsung and 1 2k Dell both attached with display port.
The xrandr config is the following:
xrandr --output DisplayPort-0 --primary --mode 3840x1600 --pos 0x0 --rotate normal --rate 119.98 --output DisplayPort-1 --mode 2560x1600 --pos 3840x0 --rotate normal --rate 59.97 --output HDMI-A-0 --off --output HDMI-A-1 --off --output DVI-D-0 --off
When i try to switch to TTY both monitor say there was no signal and go in stand-by, when i switch back to x they both power on.
inxi -Gxxx (130) 16:58:37
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Limited Nitro+ driver: amdgpu v: kernel bus-ID: 0a:00.0
chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org 1.21.1.2 driver: loaded: amdgpu
unloaded: modesetting alternate: ati,fbdev,vesa resolution: 1: 3840x1600
2: 2560x1600~60Hz s-dpi: 96
OpenGL: renderer: AMD Radeon RX 580 Series (POLARIS10 DRM 3.40.0
5.10.89-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.3.2 direct render: Yes
Thanks.
