TTY console problem - screen is completely filled with "<" symbols
Hello.
After Stable update 2025-12 / 2026-01 all TTY consoles (Ctrl+Alt+F2…F6) fully filled with “<” symbols.
All non-readable.
Kernel 5.4.302. Downgrade kernel to 5.4.299 solved problem.
Unfortunately, at the moment I can only use kernel 5.4.xxx.
How to fix?
My vconsole.conf:
# This is the fallback vconsole configuration provided by systemd.
#KEYMAP=us
FONT=UniCyr_8x16
[test_user@manjarobox ~]$ LC_ALL=C pacman -Q manjaro-release
manjaro-release 26.0.0-1
[test_user@manjarobox ~]$ LC_ALL=C uname -a
Linux manjarobox 5.4.302-1-MANJARO #1 SMP PREEMPT Thu Dec 4 08:13:06 UTC 2025 x86_64 GNU/Linux
Screenshot
Maybe install (in addition to what you have now) another LTS kernel, like:
6.12
6.6
5.15
5.10
The higher the LTS version, the longer it will be supported, counted from now.
5.4 is the oldest - and will be obsoleted first, before the others
It should (still) work - I have no idea how something as you describe could happen.
Have never seen anything like it.
I have a similar thing with neverending ^@-characters (like CTRL+@)occasionally. I wonder if the difference is from keyboard layout or from something else. If it starts after boot up, it affects both tty-login and SDDM-login, making it impossible to do either. Luckily, it usually starts either by opening a new Konsole -instance, or during shutdown after the GUI is shut down. It might continue after a reboot, or (as is usual) not.
It hasn’t happened in a while now, so I’d remember thought am not sure, that it didn’t affect any applications besides Konsole in Plasma. Now that I think about it, I think it hasn’t happened even once after I switched to zsh instead of bash.
Old keyboard ?
bubbletype and a bubble is broken ?
I am surprised this is the first major problem running on unsupported kernels, especially this old. As all the binaries and libraries get upgraded around it.
LTS kernels of course get back patched for security, but sometimes functionality, at least to make it work properly.
What @anon33601770 already said would be my first thing to try if possible.
I think it is your only option if you want a sane system moving forward. But even 5.X EOL is coming.
Version Released Projected EOL
5.15 2021-10-31 Dec, 2026
5.10 2020-12-13 Dec, 2026
I imagine 5.15 will be bumped later? But still.
It’s not the keyboard’s fault.
In console i can type commands blindly and they work.
For example, login/password for authorization or reboot command.
You are right, of course, but in the topic “[Stable update] 2026-01-04” kernel 5.4.302 is still present:
Our current supported kernels
  • linux54 5.4.302 [EOL]*
The previous version kernel 5.4.299 does not have this problem.
This means regression. It is unlikely that the EOL-kernel will be fixed.
But maybe there is a workaround?
I was just going off:
So I stuck with only 5.X kernels. But if you want to go backwards, by all means. :grinning_face:
The “workaround” is to install a more recent, still supported LTS kernel.
a bit strange:
I just did an update - and linux54
5.4.302-1 … is still listed as a suggested LTS kernel in the graphical Manjaro Settings Manager
although the update announcement seems to say different
I read it as: it will be EOL
Install a more recent kernel - you’ll kind of have to anyway at some point in the near future.
I installed kernel 5.10.247 (latest 5.10 LTS), but TTY console also broken.
sudo pacman -S linux510 linux510-headers
Linux manjarobox 5.10.247-1-MANJARO #1 SMP PREEMPT Sun Dec 7 07:12:35 UTC 2025 x86_64 GNU/Linux
Latest 5.10 LTS (5.10.247) also has regression.
But after downgrade kernel to 5.10.240 no problem:
sudo manjaro-downgrade linux510 linux510-headers
In latest 5.15 LTS (5.15.197) no problem:
tty4
The TTY console fail in the latest kernels 5.4.302 and 5.10.247 is likely due to a common cause.
That is not the recommended method to install a kernel in Manjaro - the dedicated tool for that is mhwd-kernel
or the GUI variant of it
because with pacman, you might miss some kernel-modules for your graphics hardware, for example.
But it should work just the same.
As for your issue, I have no clue:
You only need the corresponding headers if you want to compile kernel modules - for DKMS for example.
I installed kernel 5.10.247 in a VM and it worked fine. Console looks as always.
If you want to try to solve it yourself, the list of changes in the kernel from 5.10.240 to 5.10.247 is this.
So, if necessary, stick with 5.15.
However, it is highly recommended to switch to a truly up-to-date kernel (specifically using mhwd-kernel !). Either 6.12 or 6.18 (both LTS). If these run without problems for you, you shouldn’t use an older kernel.
Best: keep 5.15, and add 6.12 and 6.18
:footprints:
Thanks to everyone who responded. I’ll look into upgrading the kernel as a possible solution.
In the meantime, I continue the experiment with 5.4.302.
I change the font in the console and this is what see:
setfont ter-v32b
setfont lat2-16
setfont cyr-sun16
The commands are executed, but what the hell is happening?
Please tell me what font are you using in the console?
Well, I made a radical decision and installed KMSCon:
pamac install kmscon
Then I enabled kmscon on all virtual terminals (except TTY1):
sudo ln -s '/usr/lib/systemd/system/kmsconvt@.service' '/etc/systemd/system/autovt@.service'
I’m happy with the result:
