inxi --admin --verbosity=7 --filter --width 1 ✘ 1m 11s
Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=4fb222bb-cc4f-4803-a376-819e074d82c4 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Vostro 3558 v: N/A
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 05W6N2 v: A00 serial: <superuser required> UEFI: Dell
v: A17 date: 09/11/2020
RAM: total: 7.67 GiB used: 2.31 GiB (30.1%)
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
gen: core 5 level: v3 note: check built: 2015-18 process: Intel 14nm
family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 500 min/max: 500/1900 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 15969
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 5500 vendor: Dell driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: Microdia Integrated Webcam type: USB driver: uvcvideo
bus-ID: 2-5:3 chip-ID: 0c45:6710 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15c5 built: 2014 res: 1366x768
dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel HD Graphics 5500 (BDW
GT2) direct-render: Yes
Device-1: Intel Broadwell-U Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
class-ID: 0403
API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:08b3 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: down mac: <filter>
bus-ID: 2-6:4 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 238.47 GiB used: 11.57 GiB (4.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intenso model: SSD Sata III
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 4A0 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A1C1
dev-links: cdrom
ID-1: / raw-size: 40 GiB size: 39.08 GiB (97.69%) used: 10 GiB (25.6%)
fs: ext4 dev: /dev/sda7 maj-min: 8:7 label: root
uuid: 4fb222bb-cc4f-4803-a376-819e074d82c4
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: F1D6-9A8A
ID-3: /home raw-size: 100 GiB size: 97.87 GiB (97.87%)
used: 1.57 GiB (1.6%) fs: ext4 dev: /dev/sda8 maj-min: 8:8 label: home
uuid: a3dc1290-4cd8-4e21-8d9f-d4946224c56c
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: e9fe1e37-91cc-4933-8ab7-2dba61c68e4f
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
uuid: 8415-4124
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 58.85 GiB fs: ntfs label: N/A
uuid: FA3A68C23A687D8F
ID-4: /dev/sda4 maj-min: 8:4 size: 521 MiB fs: ntfs label: N/A
uuid: 5C4A12DA4A12B12E
ID-5: /dev/sda9 maj-min: 8:9 size: 1.06 GiB fs: ntfs label: DELLSUPPORT
uuid: 30BAFF28BAFEE8EC
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:8001 class-ID: 0900
Hub-3: 2-0:1 info: Hi-speed hub with single TT ports: 11 rev: 2.0
Device-1: 2-3:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-2: 2-5:3 info: Microdia Integrated Webcam type: Video
Device-3: 2-6:4 info: Intel Bluetooth wireless interface type: Bluetooth
Device-4: 2-8:5 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-4: 3-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 50.0 C mobo: N/A sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0 fan-2: 0 fan-3: 0
Processes: 188 Uptime: 21m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: dpkg
pkgs: 0 pm: pacman pkgs: 1196 libs: 357 tools: pamac,yay pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
I can’t install font-ms
~ export LANG=C ✔ 2m 37s
~ yay -S ttf-ms-win10-auto ✔
AUR Explicit (1): ttf-ms-win10-auto-10.0.19042.789-5
AUR Make Dependency (1): httpfs2-2gbplus-0.1.5-1
:: PKGBUILD up to date, skipping download: ttf-ms-win10-auto
:: PKGBUILD up to date, skipping download: httpfs2-2gbplus
2 ttf-ms-win10-auto (Build Files Exist)
1 httpfs2-2gbplus (Build Files Exist)
==> Packages to cleanBuild?
==> [N]one [A]ll [Ab]ort [I]nstalled [No]tInstalled or (1 2 3, 1-3, ^4)
==> n
==> Diffs to show?
==> n
==> Making package: httpfs2-2gbplus 0.1.5-1 (lun 1 mag 2023, 22:43:36)
==> Retrieving sources...
-> Found httpfs2-0.1.5.tar.gz
-> Found httpfs.diff
httpfs2-0.1.5.tar.gz ... Passed
httpfs.diff ... Passed
==> Making package: ttf-ms-win10-auto 10.0.19042.789-5 (lun 1 mag 2023, 22:43:41)
-> Downloading 19042.631.201119-0144.20h2_release_svc_refresh_CLIENTENTERPRISEEVAL_OEMRET_x86FRE_en-us.iso...
-> Downloading arial.ttf...
-> Downloading arialbd.ttf...
-> Downloading ariali.ttf...
-> Downloading arialbi.ttf...
-> Downloading ariblk.ttf...
-> Downloading bahnschrift.ttf...
-> Downloading calibri.ttf...
-> Downloading calibrib.ttf...
-> Downloading calibrii.ttf...
-> Downloading calibriz.ttf...
-> Downloading calibril.ttf...
-> Downloading calibrili.ttf...
-> Downloading cambria.ttc...
-> Downloading cambriab.ttf...
-> Downloading cambriai.ttf...
-> Downloading cambriaz.ttf...
-> Downloading Candara.ttf...
-> Downloading Candarab.ttf...
-> Downloading Candarai.ttf...
-> Downloading Candaraz.ttf...
-> Downloading Candaral.ttf...
-> Downloading Candarali.ttf...
-> Downloading comic.ttf...
-> Downloading comicbd.ttf...
-> Downloading comici.ttf...
-> Downloading comicz.ttf...
-> Downloading consola.ttf...
-> Downloading consolab.ttf...
-> Downloading consolai.ttf...
-> Downloading consolaz.ttf...
-> Downloading constan.ttf...
-> Downloading constanb.ttf...
-> Downloading constani.ttf...
-> Downloading constanz.ttf...
-> Downloading cour.ttf...
-> Downloading courbd.ttf...
-> Downloading couri.ttf...
-> Downloading courbi.ttf...
-> Downloading corbel.ttf...
-> Downloading corbelb.ttf...
-> Downloading corbeli.ttf...
-> Downloading corbelz.ttf...
-> Downloading corbell.ttf...
-> Downloading corbelli.ttf...
-> Downloading framd.ttf...
-> Downloading framdit.ttf...
-> Downloading Gabriola.ttf...
-> Downloading georgia.ttf...
-> Downloading georgiab.ttf...
-> Downloading georgiai.ttf...
-> Downloading georgiaz.ttf...
-> Downloading impact.ttf...
-> Downloading Inkfree.ttf...
-> Downloading lucon.ttf...
-> Downloading l_10646.ttf...
-> Downloading marlett.ttf...
-> Downloading micross.ttf...
-> Downloading pala.ttf...
-> Downloading palab.ttf...
-> Downloading palai.ttf...
-> Downloading palabi.ttf...
-> Downloading segoepr.ttf...
-> Downloading segoeprb.ttf...
-> Downloading segoesc.ttf...
-> Downloading segoescb.ttf...
-> Downloading segmdl2.ttf...
-> Downloading segoeui.ttf...
-> Downloading segoeuib.ttf...
-> Downloading segoeuii.ttf...
-> Downloading segoeuiz.ttf...
-> Downloading seguibl.ttf...
-> Downloading seguibli.ttf...
-> Downloading seguiemj.ttf...
-> Downloading seguihis.ttf...
-> Downloading segoeuil.ttf...
-> Downloading seguili.ttf...
-> Downloading seguisb.ttf...
-> Downloading seguisbi.ttf...
-> Downloading segoeuisl.ttf...
-> Downloading seguisli.ttf...
-> Downloading seguisym.ttf...
-> Downloading Sitka.ttc...
-> Downloading SitkaB.ttc...
-> Downloading SitkaI.ttc...
-> Downloading SitkaZ.ttc...
-> Downloading sylfaen.ttf...
-> Downloading symbol.ttf...
-> Downloading tahoma.ttf...
-> Downloading tahomabd.ttf...
-> Downloading times.ttf...
-> Downloading timesbd.ttf...
-> Downloading timesi.ttf...
-> Downloading timesbi.ttf...
-> Downloading trebuc.ttf...
-> Downloading trebucbd.ttf...
-> Downloading trebucit.ttf...
-> Downloading trebucbi.ttf...
-> Downloading verdana.ttf...
-> Downloading verdanab.ttf...
-> Downloading verdanai.ttf...
-> Downloading verdanaz.ttf...
-> Downloading webdings.ttf...
-> Downloading wingding.ttf...
-> Downloading msgothic.ttc...
-> Downloading YuGothR.ttc...
-> Downloading YuGothB.ttc...
-> Downloading YuGothM.ttc...
-> Downloading YuGothL.ttc...
-> Downloading malgun.ttf...
-> Downloading malgunbd.ttf...
-> Downloading malgunsl.ttf...
-> Downloading javatext.ttf...
-> Downloading himalaya.ttf...
-> Downloading ntailu.ttf...
-> Downloading ntailub.ttf...
-> Downloading phagspa.ttf...
-> Downloading phagspab.ttf...
-> Downloading taile.ttf...
-> Downloading taileb.ttf...
-> Downloading msyi.ttf...
-> Downloading monbaiti.ttf...
-> Downloading mmrtext.ttf...
-> Downloading mmrtextb.ttf...
-> Downloading Nirmala.ttf...
-> Downloading NirmalaB.ttf...
-> Downloading NirmalaS.ttf...
-> Downloading LeelawUI.ttf...
-> Downloading LeelaUIb.ttf...
-> Downloading LeelUIsl.ttf...
-> Downloading simsun.ttc...
-> Downloading simsunb.ttf...
-> Downloading msyh.ttc...
-> Downloading msyhbd.ttc...
-> Downloading msyhl.ttc...
-> Downloading msjh.ttc...
-> Downloading msjhbd.ttc...
-> Downloading msjhl.ttc...
-> Downloading mingliub.ttc...
-> Downloading ebrima.ttf...
-> Downloading ebrimabd.ttf...
-> Downloading gadugi.ttf...
-> Downloading gadugib.ttf...
-> Downloading mvboli.ttf...
-> Downloading license.rtf...
19042.631.201119-0144.20h2_release_svc_refresh_CLIENTENTERPRISEEVAL_OEMRET_x86FRE_en-us.iso ... Skipped
arial.ttf ... Skipped
arialbd.ttf ... Skipped
ariali.ttf ... Skipped
arialbi.ttf ... Skipped
ariblk.ttf ... Skipped
bahnschrift.ttf ... Skipped
calibri.ttf ... Skipped
calibrib.ttf ... Skipped
calibrii.ttf ... Skipped
calibriz.ttf ... Skipped
calibril.ttf ... Skipped
calibrili.ttf ... Skipped
cambria.ttc ... Skipped
cambriab.ttf ... Skipped
cambriai.ttf ... Skipped
cambriaz.ttf ... Skipped
Candara.ttf ... Skipped
Candarab.ttf ... Skipped
Candarai.ttf ... Skipped
Candaraz.ttf ... Skipped
Candaral.ttf ... Skipped
Candarali.ttf ... Skipped
comic.ttf ... Skipped
comicbd.ttf ... Skipped
comici.ttf ... Skipped
comicz.ttf ... Skipped
consola.ttf ... Skipped
consolab.ttf ... Skipped
consolai.ttf ... Skipped
consolaz.ttf ... Skipped
constan.ttf ... Skipped
constanb.ttf ... Skipped
constani.ttf ... Skipped
constanz.ttf ... Skipped
cour.ttf ... Skipped
courbd.ttf ... Skipped
couri.ttf ... Skipped
courbi.ttf ... Skipped
corbel.ttf ... Skipped
corbelb.ttf ... Skipped
corbeli.ttf ... Skipped
corbelz.ttf ... Skipped
corbell.ttf ... Skipped
corbelli.ttf ... Skipped
framd.ttf ... Skipped
framdit.ttf ... Skipped
Gabriola.ttf ... Skipped
georgia.ttf ... Skipped
georgiab.ttf ... Skipped
georgiai.ttf ... Skipped
georgiaz.ttf ... Skipped
impact.ttf ... Skipped
Inkfree.ttf ... Skipped
lucon.ttf ... Skipped
l_10646.ttf ... Skipped
marlett.ttf ... Skipped
micross.ttf ... Skipped
pala.ttf ... Skipped
palab.ttf ... Skipped
palai.ttf ... Skipped
palabi.ttf ... Skipped
segoepr.ttf ... Skipped
segoeprb.ttf ... Skipped
segoesc.ttf ... Skipped
segoescb.ttf ... Skipped
segmdl2.ttf ... Skipped
segoeui.ttf ... Skipped
segoeuib.ttf ... Skipped
segoeuii.ttf ... Skipped
segoeuiz.ttf ... Skipped
seguibl.ttf ... Skipped
seguibli.ttf ... Skipped
seguiemj.ttf ... Skipped
seguihis.ttf ... Skipped
segoeuil.ttf ... Skipped
seguili.ttf ... Skipped
seguisb.ttf ... Skipped
seguisbi.ttf ... Skipped
segoeuisl.ttf ... Skipped
seguisli.ttf ... Skipped
seguisym.ttf ... Skipped
Sitka.ttc ... Skipped
SitkaB.ttc ... Skipped
SitkaI.ttc ... Skipped
SitkaZ.ttc ... Skipped
sylfaen.ttf ... Skipped
symbol.ttf ... Skipped
tahoma.ttf ... Skipped
tahomabd.ttf ... Skipped
times.ttf ... Skipped
timesbd.ttf ... Skipped
timesi.ttf ... Skipped
timesbi.ttf ... Skipped
trebuc.ttf ... Skipped
trebucbd.ttf ... Skipped
trebucit.ttf ... Skipped
trebucbi.ttf ... Skipped
verdana.ttf ... Skipped
verdanab.ttf ... Skipped
verdanai.ttf ... Skipped
verdanaz.ttf ... Skipped
webdings.ttf ... Skipped
wingding.ttf ... Skipped
msgothic.ttc ... Skipped
YuGothR.ttc ... Skipped
YuGothB.ttc ... Skipped
YuGothM.ttc ... Skipped
YuGothL.ttc ... Skipped
malgun.ttf ... Skipped
malgunbd.ttf ... Skipped
malgunsl.ttf ... Skipped
javatext.ttf ... Skipped
himalaya.ttf ... Skipped
ntailu.ttf ... Skipped
ntailub.ttf ... Skipped
phagspa.ttf ... Skipped
phagspab.ttf ... Skipped
taile.ttf ... Skipped
taileb.ttf ... Skipped
msyi.ttf ... Skipped
monbaiti.ttf ... Skipped
mmrtext.ttf ... Skipped
mmrtextb.ttf ... Skipped
Nirmala.ttf ... Skipped
NirmalaB.ttf ... Skipped
NirmalaS.ttf ... Skipped
LeelawUI.ttf ... Skipped
LeelaUIb.ttf ... Skipped
LeelUIsl.ttf ... Skipped
simsun.ttc ... Skipped
simsunb.ttf ... Skipped
msyh.ttc ... Skipped
msyhbd.ttc ... Skipped
msyhl.ttc ... Skipped
msjh.ttc ... Skipped
msjhbd.ttc ... Skipped
msjhl.ttc ... Skipped
mingliub.ttc ... Skipped
ebrima.ttf ... Skipped
ebrimabd.ttf ... Skipped
gadugi.ttf ... Skipped
gadugib.ttf ... Skipped
mvboli.ttf ... Skipped
license.rtf ... Skipped
:: Remove make dependencies after install? [y/N]
:: (1/2) Parsing SRCINFO: ttf-ms-win10-auto
:: (2/2) Parsing SRCINFO: httpfs2-2gbplus
==> Making package: httpfs2-2gbplus 0.1.5-1 (lun 1 mag 2023, 22:43:50)
==> Extracting sources...
-> Extracting httpfs2-0.1.5.tar.gz with bsdtar
==> Starting prepare()...
/home/eduardolp3/.cache/yay/httpfs2-2gbplus/PKGBUILD: line 25: patch: command not found
==> ERROR: A failure occurred in prepare().
Aborting...
-> Failed to install layer, rolling up to next layer.error:error making: httpfs2-2gbplus - exit status 4
==> Making package: httpfs2-2gbplus 0.1.5-1 (lun 1 mag 2023, 22:43:51)
Aborting...
-> error making: httpfs2-2gbplus-exit status 4
==> Making package: ttf-ms-win10-auto 10.0.19042.789-5 (lun 1 mag 2023, 22:43:58)
==> Missing dependencies:
-> httpfs2-2gbplus
==> ERROR: Could not resolve all dependencies.
-> error making: ttf-ms-win10-auto-exit status 8
-> Failed to install the following packages. Manual intervention is required:
ttf-ms-win10-auto - exit status 8
