Trying to run xtrkcad (installed from AUR)
I’m using Manjaro 26 XFCE and installed xtrkcad from the AUR (the only place I could find it in pamac). Installation seems to have succeeded but
  1. I can´t find the application in the start menu; this might be normal, it’s the first time that I installed from AUR. If it’snormal I can create a launcher.
  2. I get the following error when I try to run it (in a terminal)
/usr/bin/xtrkcad                                                 ✔
/usr/bin/xtrkcad: error while loading shared libraries: libgtk-x11-2.0.so.0: cannot open shared object file: No such file or directory
OK, a little searching the web gives that I have to install gtk2 and that results in the following error:
sudo pacman -S gtk2        [sudo] password for wim:
error: target not found: gtk2
More research on that says that I have to install glibc2 but that is installed
pamac info glibc        Name                  : glibc
Version               : 2.43+r5+g856c426a7534-1
Description           : GNU C Library
URL                   : https://www.gnu.org/software/libc
Licences              : GPL-2.0-or-later LGPL-2.1-or-later
Repository            : core
And now I’m a little lost and need advice.
In case it’s helpful the inxi -Zv8 output
  Host: wim-vivobookasuslaptopx Kernel: 6.18.12-1-MANJARO arch: x86_64
    bits: 64 compiler: gcc v: 15.2.1 clocksource: tsc avail: acpi_pm
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=cfc5eec3-33ba-454a-a9cc-e19dced381ab rw rootflags=subvol=@
    cryptdevice=UUID=b9921292-9ce2-4526-967a-b55d846799cf:luks-b9921292-9ce2-4526-967a-b55d846799cf
    root=/dev/mapper/luks-b9921292-9ce2-4526-967a-b55d846799cf apparmor=1
    security=apparmor udev.log_priority=3 pcie_aspm=off
    sysrq_always_enabled=1
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.51 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop X1502ZA_X1502ZA
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: X1502ZA v: 1.0 serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
    v: X1502ZA.315 date: 09/20/2023
  ID-1: BAT0 charge: 35.6 Wh (91.7%) condition: 38.8/42.1 Wh (92.3%)
    volts: 12.49 min: 11.85 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    charging: status: not charging control: start: N/A end: 80% cycles: 107
  System RAM: total: 16 GiB available: 15.31 GiB used: 3.92 GiB (25.6%)
  Device-1: Controller0-ChannelA type: DDR4 detail: synchronous size: 8 GiB
    speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: Micron Technology
    part-no: 4ATF1G64HZ-3G2F1 serial: N/A
  Device-2: Controller1-ChannelA-DIMM0 type: DDR4 detail: synchronous
    size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Samsung part-no: N/A
    serial: 00001329
  Info: model: 12th Gen Intel Core i3-1220P bits: 64 type: MST AMCP
    arch: Alder Lake level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
    microcode: 0x43B
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 10 threads: 12 mt: 2 tpc: 2
    st: 8 smt: enabled cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32
    KiB, 8x64 KiB L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB
    desc: 1x12 MiB
  Speed (MHz): avg: 400 min/max: 400/4400:3300 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 47923
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdtscp rep_good sdbg sep serialize sha_ni smap smep split_lock_detect ss
    ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    xtopology xtpr
    conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Alder Lake-UP3 GT1 [UHD Graphics] vendor: ASUSTeK
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 0000:00:02.0
    chip-ID: 8086:46b3 class-ID: 0300
  Device-2: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:6 chip-ID: 322e:210e
    class-ID: 0e02
  Display: x11 server: X.org v: 1.21.1.21 compositor: xfwm4 v: 4.20.0
    driver: X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
    display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
  Monitor-1: eDP-1 model: AU Optronics 0x05a7 built: 2022 res: 1920x1080
    dpi: 142 gamma: 1.2 chroma: red: x: 0.573 y: 0.341 green: x: 0.349 y: 0.569
    blue: x: 0.161 y: 0.129 white: x: 0.314 y: 0.329
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1920x1080
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
    device-ID: 8086:46b3 memory: 14.95 GiB unified: yes
  Info: Tools: api: eglinfo,glxinfo de: xfce4-display-settings x11: xprop
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
    bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
  API: ALSA v: k6.18.12-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    vendor: AzureWave driver: rtw88_8821ce v: kernel port: 3000
    bus-ID: 0000:02:00.0 chip-ID: 10ec:c821 class-ID: 0280
  IF: wlo1 state: up mac: 1c:ce:51:3a:fb:15
  IP v4: 192.168.8.100/24 type: dynamic noprefixroute scope: global
    broadcast: 192.168.8.255
  IP v6: fe80::9321:b7e4:758a:4b4/64 type: noprefixroute scope: link
  WAN IP: 197.64.171.113
  Device-1: IMC Networks Bluetooth Radio driver: btusb v: 0.8 type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:9 chip-ID: 13d3:3556
    class-ID: e001 serial: 00e04c000001
  Device-1: luks-b9921292-9ce2-4526-967a-b55d846799cf maj-min: 253:0
    type: LUKS dm: dm-0 size: 297.79 GiB
  Components:
  p-1: sda2 maj-min: 8:2 size: 297.8 GiB
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
  Local Storage: total: 775.03 GiB used: 9.41 GiB (1.2%)
    model: MZVL4512HBLU-00BTW size: 476.94 GiB block-size: physical: 512 B
    logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial: S73DNX0WC49183
    fw-rev: HXC70W1Q temp: 34.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 model: ̀ T VT It a n z U A size: 298.09 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
    lanes: 1 mode: 2.0 tech: HDD rpm: 41035 serial: tr scheme: GPT
  ID-1: / raw-size: 297.79 GiB size: 297.79 GiB (100.00%)
    used: 9.41 GiB (3.2%) fs: btrfs dev: /dev/dm-0 maj-min: 253:0
    mapped: luks-b9921292-9ce2-4526-967a-b55d846799cf label: N/A
    uuid: cfc5eec3-33ba-454a-a9cc-e19dced381ab
    used: 984 KiB (0.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: C9D2-0A9C
  ID-3: /home raw-size: 297.79 GiB size: 297.79 GiB (100.00%)
  ID-4: /var/cache raw-size: 297.79 GiB size: 297.79 GiB (100.00%)
  ID-5: /var/log raw-size: 297.79 GiB size: 297.79 GiB (100.00%)
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM
    uuid: F48F-9838
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 475.32 GiB fs: ntfs label: OS
    uuid: 0E2C91312C911535
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 1.09 GiB fs: ntfs label: N/A
    uuid: 28B67388B6735572
  ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 260 MiB fs: vfat label: MYASUS
    uuid: 0492-F995
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-1:2 info: KYE Systems (Mouse Systems) NetScroll+ Mini
    Traveler / Genius NetScroll 120 type: mouse driver: hid-generic,usbhid
    interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
    power: 100mA chip-ID: 0458:003a class-ID: 0301
  Hub-2: 1-3:3 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
  Hub-3: 1-3.1:5 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
  Device-1: 1-3.1.1:8 info: Arduino SA Leonardo (CDC ACM HID)
    type: abstract (modem),CDC-data driver: cdc_acm interfaces: 2 rev: 2.0
    chip-ID: 2341:8036 class-ID: 0a00
  Device-2: 1-3.1.2:11 info: Arduino SA Micro
    chip-ID: 2341:8037 class-ID: 0a00
  Device-3: 1-3.1.3:12 info: Arduino SA Mega 2560 R3 (CDC ACM)
    type: abstract (modem),CDC-data driver: cdc_acm interfaces: 2 rev: 1.1
    chip-ID: 2341:0042 class-ID: 0a00 serial: 5573932373735140D150
  Device-4: 1-3.1.4:13 info: QinHeng CH340 serial converter
    type: <vendor specific> driver: ch341,ch341-uart interfaces: 1 rev: 1.1
    chip-ID: 1a86:7523 class-ID: ff00
  Device-5: 1-3.2:7 info: Future Devices FT232 Serial (UART) IC
    type: <vendor specific> driver: ftdi_sio,gpio_stub_drv interfaces: 1
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 90mA
    chip-ID: 0403:6001 class-ID: 0000 serial: A5025WMS
  Device-6: 1-3.3:10 info: SparkFun Pro Micro
    chip-ID: 1b4f:9204 class-ID: 0a00
  Device-7: 1-4:4 info: Verbatim Portable Hard Drive type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 2mA chip-ID: 18a5:0214 class-ID: 0806
    serial: 1019208A0679e
  Device-8: 1-9:6 info: Sonix USB2.0 HD UVC WebCam type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 322e:210e class-ID: 0e02
  Device-9: 1-10:9 info: IMC Networks Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 13d3:3556 class-ID: e001
  Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 41.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 1900
  Packages: pm: pacman pkgs: 1134 libs: 365 tools: pamac pm: flatpak pkgs: 0
    1: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    2: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
    4: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    5: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    6: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    7: https://mirror.23m.com/manjaro/stable/$repo/$arch
    8: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 311
  1: cpu: 2.8% command: firefox pid: 13748 mem: 740.6 MiB (4.7%)
  2: cpu: 1.6% command: firefox pid: 43431 mem: 336.3 MiB (2.1%)
  3: cpu: 0.8% command: Xorg pid: 979 mem: 94.2 MiB (0.6%)
  4: cpu: 0.6% command: pamac-manager pid: 23080 mem: 1569.0 MiB (10.0%)
  5: cpu: 0.2% command: [irq/18-rtw88_pci] pid: 576 mem: 0.00 MiB (0.0%)
  Memory top: 5 of 311
  1: mem: 1569.0 MiB (10.0%) command: pamac-manager pid: 23080 cpu: 0.6%
  2: mem: 740.6 MiB (4.7%) command: firefox pid: 13748 cpu: 2.8%
  3: mem: 336.3 MiB (2.1%) command: firefox pid: 43431 cpu: 1.6%
  4: mem: 269.8 MiB (1.7%) command: firefox pid: 43711 cpu: 0.1%
  5: mem: 242.8 MiB (1.5%) command: firefox pid: 14415 cpu: 0.2%
  Processes: 311 Power: uptime: 4h 35m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 6.1 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 259 default: graphical tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: xfce4-terminal
    inxi: 3.3.40
The comments below the AUR repository on AUR (en) - xtrkcad give some hints about which package requires to be installed
Thanks @Pille
I must have missed that. I did use the graphical installer for this.
lib32-gtk2 is now installing from the terminal but it takes a bit of time. I will let you know.
For Arch based distributions i would always recommend using the command line tools
pacman
yay (or any other aur helper)
I am using the pamac GUI only for getting notified that an update is live.
If you want it a bit more comfortable pamac also runs in a terminal session and is able to update core and aur packages.
Apart from that it is always highly recommended to verify what’s going on in the AUR package. Not simply install it unchecked.
and Beta1-1 is not the latest version available…
GA-1 is the latest version, and here, if you like, is a current PKGBUILD
PKGBUILD
# Maintainer: CupIvan <mail@cupivan.ru>
pkgname=xtrkcad
pkgver=5.3.1
pkgrel=2
pkgdesc="CAD program for designing model railroad layouts."
url="http://xtrkcad-fork.sourceforge.net"
arch=('x86_64')
license=('GPL2')
_postfix="GA-1"
_srcname="xtrkcad-setup-${pkgver}${_postfix}.${arch}.sh"
source=("https://downloads.sourceforge.net/project/xtrkcad-fork/XTrackCad/Version%20${pkgver}/xtrkcad-setup-${pkgver}${_postfix}.${arch}.sh")
md5sums=('913723cfcde550915b280f9cd6d67fab')
build() {
	chmod 0777 "${_srcname}"
	mkdir usr
	./${_srcname} --skip-license --prefix="usr"
package() {
	cp -r "./usr" "${pkgdir}"
OK, that solved the problem; took long as Manjaro is installed on an old external USB HD.
Created a launcher and it seems to work.
pamac info does not list any dependencies; I think that I even checked that before I did post the question
pamac info xtrkcad
Version               : 5.3.1-1
Description           : CAD program for designing model railroad layouts.
URL                   : http://xtrkcad-fork.sourceforge.net
Licences              : GPL2
Repository            : AUR
Installed Size        : 28.4 MB
Groups                : --
Depends On            : --
Optional Dependencies : --
Make Dependencies     : --
Check Dependencies    : --
Required By           : --
Optional For          : --
Provides              : --
Replaces              : --
Conflicts With        : --
Packager              : Unknown Packager
Maintainer            : CupIvan
First Submitted       : Wed 19 Dec 2012 17:33:35
Last Modified         : Sat 21 Jun 2025 23:41:15
Votes                 : 5
Out of Date           : --
Build Date            : Sun 22 Mar 2026 11:14:58
Install Date          : Sun 22 Mar 2026 11:15:45
Install Reason        : Explicitly installed
Validated By          : None
Backup files          : --
FYI
Also started xtrkcad from the terminal and get the following
Gtk-Message: 13:48:05.378: Failed to load module "canberra-gtk-module"
Gtk-Message: 13:48:05.379: Failed to load module "canberra-gtk-module"
(xtrkcad:170222): Gtk-WARNING **: 13:48:05.382: Unable to locate theme engine in module_path: "adwaita",
(xtrkcad:170222): Gtk-WARNING **: 13:48:05.383: Unable to locate theme engine in module_path: "murrine",
(xtrkcad:170222): Gtk-WARNING **: 13:48:05.384: Unable to locate theme engine in module_path: "murrine",
If something will give me problems I will install the themes and possibly canberra (I need to look up what that is).
Thanks a lot for the help :+1:
Thanks
If it’s not in the repos I’m less interested; stuff in repos is supposed to be (kind-of) stable.
More to learn
How did you find the GA-1 (just trying to learn)? I initially downloaded the .deb from sourceforce but after looking up how to install a deb in Manjaro it did not sound like a good idea to try.
all versions can be found at
the PKGBUILD from the AUR still contains beta1-1. ( Version 5.3.1 Beta1 ) (2025-06-30)
line 12:
source=("https://downloads.sourceforge.net/project/xtrkcad-fork/XTrackCad/Version%20${pkgver}%20Beta1/xtrkcad-setup-${pkgver}Beta1-1.${arch}.sh")
the latest version is GA-1. ( Version 5.3.1 ) (2025-10-15)
i just check which version is the latest and then modify the PKGBUILD.
i’m learning a lot in the process, and it’s just a test.
(this time i ran into trouble with the patch file…)
have a nice weekend!
…which is still missing dependencies. :wink:
That module is provided by libcanberra-gtk2.
You’ll need gnome-themes-extra-gtk2 which is an optional dependency of gtk2.
The Debian control file lists the following dependencies:
Depends: xdg-utils, libc6 (>= 2.35), libcairo2 (>= 1.6.0), libgdk-pixbuf-2.0-0 (>= 2.22.0), libglib2.0-0 (>= 2.12.0), libgtk2.0-0 (>= 2.24.0), libpango-1.0-0 (>= 1.22.0), libpangocairo-1.0-0 (>= 1.22.0), zlib1g (>= 1:1.1.4)
That would translate to the following dependencies. Add a depends() array to the PKGBUILD:
depends(
  'cairo'
  'gdk-pixbuf2'
  'glib2'
  'glibc'
  'gtk2'
  'libcanberra-gtk2'
  'pango'
  'xdg-utils'
  'zlib'
