Just tried to report my first issue on manjaro gitlab about the grub package, but my issue is classified as spam and i am told to change this text?!
Topic: grub 2.12rc1.r49.ge58b870ff-1 Manjaro stable branch
On manjaro Gitlab i am user: john Landmesser (JohnML)
The strange formatting is not from me but gitlab after spam warning
This settings in /etc/default/grub are not applied at boot:
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=countdown
Whole /etc/defaulr/grub
**********************************************GRUB_DEFAULT=savedGRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=countdownGRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3"
GRUB_CMDLINE_LINUX=""If you want to enable the save default function,
uncomment the followingline, and set GRUB_DEFAULT to
saved.GRUB_SAVEDEFAULT=trueUncomment to disable submenus in boot
menu#GRUB_DISABLE_SUBMENU=yPreload both GPT and MBR modules so that
they are not missedGRUB_PRELOAD_MODULES="part_gpt part_msdos"Uncomment
to enable booting from LUKS encrypted
devices#GRUB_ENABLE_CRYPTODISK=yUncomment to use basic
consoleGRUB_TERMINAL_INPUT=consoleUncomment to disable graphical
terminal#GRUB_TERMINAL_OUTPUT=consoleThe resolution used on graphical
terminalnote that you can use only modes which your graphic card
supports via VBEyou can see them in real GRUB with the command
'videoinfo'GRUB_GFXMODE=autoGRUB_GFXMODE=800x600Uncomment to allow the
kernel use the same resolution used by
grubGRUB_GFXPAYLOAD_LINUX=keepUncomment if you want GRUB to pass to the
Linux kernel the old parameterformat "root=/dev/xxx" instead of
"root=/dev/disk/by-uuid/xxx"#GRUB_DISABLE_LINUX_UUID=trueUncomment to
disable generation of recovery mode menu
entriesGRUB_DISABLE_RECOVERY=trueUncomment this option to enable
os-prober execution in the grub-mkconfig
commandGRUB_DISABLE_OS_PROBER=falseUncomment and set to the desired
menu colors. Used by normal and wallpapermodes only. Entries specified
as foreground/background.GRUB_COLOR_NORMAL="light-gray/black"
GRUB_COLOR_HIGHLIGHT="green/black"Uncomment one of them for the gfx
desired, a image background or a
gfxtheme#GRUB_BACKGROUND="/usr/share/grub/background.png"
#GRUB_THEME="/path/to/gfxtheme"Uncomment to get a beep at GRUB
start#GRUB_INIT_TUNE="480 440 1"Uncomment to ensure that the root
filesystem is mounted read-only so thatsystemd-fsck can run the check
automatically. We use 'fsck' by default, whichneeds 'rw' as boot
parameter, to avoid delay in boot-time. 'fsck' needs to beremoved from
'mkinitcpio.conf' to make 'systemd-fsck' work.See also Arch-Wiki:
https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking#GRUB_ROOT_FS_RO=trueSysinfo
at:
