As far as I know KDE is at 5.23.5 in Testing branch, and same in Unstable. Something is weird here.
Can you tell us what you hide from your system? What did you do that you’re not telling us?
We did try - until we finally found this.
I would not waste my time trying to find out
KDE Plasma Version: 5.24.80
KDE Frameworks Version: 5.91.0
This combination is something home made - it’s neither stable nor testing nor unstable.
Instead I’d restore to some supported branch
and then be asking questions if the problem remains.
It is not even the KDE Unstable repo/branch, it is literally the KDE BETA… so… obviously no support here.
Plasma 5.24 Beta is aimed at testers, developers, and bug-hunters.
The final version of Plasma 5.24 will become available for the general public on the 8th of February.
DISCLAIMER: This release contains untested and unstable software. Do not use in a production environment and do not use as your daily work environment. You risk crashes and loss of data.
What a waste of time of people trying to help…
Wow , I didn’t expect that kind of reaction here. Debian yes but not here.
I didn’t know that this was something unsupported. I will go get what is supported if that will help.
Please forgive me .
I don’t remember how I got this version but it was offered somehow.
Can you help me get to unstable then or am I on my own?
I got it from adding this to pacman.conf
[kde-unstable]
Include = /etc/pacman.d/mirrorlist
Should I get rid of this so I can get support?
As far as I can see, KDE Unstable branch/repo is also on 5.23 so I think you’re still hiding something because I do not see any KDE package at 5.24 version in any Manjaro repo.
I am not hiding anything. Ignorance maybe but not hiding anything.
Host: manjaro Kernel: 5.10.93-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 11.1.0 Desktop: KDE Plasma 5.24.80 tk: Qt 5.15.2 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Convertible System: HP product: HP Spectre x360 Convertible 15-df1xxx
v: N/A serial: <superuser required> Chassis: type: 31
Mobo: HP model: 863F v: 54.24 serial: <superuser required> UEFI: AMI
v: F.26 date: 07/09/2021
ID-1: BAT0 charge: 53.2 Wh (79.2%) condition: 67.2/67.2 Wh (100.0%)
volts: 12.3 min: 11.6 model: HP Primary type: Li-ion serial: SerialNumber
status: N/A cycles: 170
Device-1: hid-0018:04F3:2992.0001-battery model: ELAN2514:00 04F3:2992
serial: N/A charge: N/A status: N/A
Info: quad core model: Intel Core i7-10510U bits: 64 type: MT MCP
smt: enabled arch: Comet/Whiskey Lake note: check rev: C cache: L1: 256 KiB
L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 700 min/max: 400/4900 cores: 1: 700 2: 700 3: 700
4: 700 5: 700 6: 700 7: 700 8: 700 bogomips: 36812
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
driver: nvidia v: 495.46 bus-ID: 3b:00.0 chip-ID: 10de:1d13 class-ID: 0302
Device-3: Chicony HP Wide Vision FHD Camera type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 04f2:b67b class-ID: 0e02 serial: 200901010001
Display: x11 server: X.org 1.21.1.3 compositor: kwin_x11 driver:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
driver: sof-audio-pci bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0401
Sound Server-1: ALSA v: k5.10.93-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
IF: wlp0s20f3 state: up mac: 0c:dd:24:ab:82:13
Local Storage: total: 931.51 GiB used: 106.4 GiB (11.4%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
size: 931.51 GiB speed: 31.6 Gb/s lanes: 4 type: SSD
serial: S59ANS0N809758J rev: 2B2QEXM7 temp: 32.9 C scheme: GPT
ID-1: / size: 235 GiB used: 59.96 GiB (25.5%) fs: ext4 dev: /dev/nvme0n1p11
ID-2: /boot/efi size: 96 MiB used: 66.7 MiB (69.5%) fs: vfat
dev: /dev/nvme0n1p2
System Temperatures: cpu: 40.0 C pch: 37.0 C mobo: N/A
Packages: pacman: 1342
1: https://mirror.math.princeton.edu/pub/manjaro/unstable/$repo/$arch
2: https://repo.ialab.dsu.edu/manjaro/unstable/$repo/$arch
Processes: 260 Uptime: 11h 16m wakeups: 1855 Memory: 15.27 GiB
used: 3.09 GiB (20.2%) Init: systemd v: 250 Compilers: gcc: 11.1.0
clang: 13.0.0 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.12
Using your current mirror used, check by yourself here Index of /pub/manjaro/unstable/kde-unstable/x86_64 search for 5.23
(CTRL+F in any decent application) and all KDE packages will be found, search for 5.24
, none, zero, nada. Your 5.24 KDE installation doesn’t come from here to me.
//EDIT: Now if you don’t know what you have done to your Manjaro installation, I think it is on you to remember what you have done and to find out. It takes some nerve to ask people to fix your after wasting their time for 40+ posts.
I’m trying to figure out how I got this. I’m not sure.
I guess I will reinstall and see what happens.
I think this is what I read and this is how I got to here.
https://forum.manjaro.org/t/pacman-conf-stable-v-testing-v-unstable-kde-unstable-entries/66263
OK I took the kde-unstable out or pacman.conf and downgraded.
This is what I have now:
KDE Plasma Version: 5.23.5
KDE Frameworks Version: 5.90.0
Qt Version: 5.15.2
Kernel Version: 5.16.2-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 8 × Intel® Core™ i7-10510U CPU @ 1.80GHz
Memory: 15.3 GiB of RAM
Graphics Processor: Mesa Intel® UHD Graphics
OK problem solved.
So that is what it was.
Let’s call it lesson learned.
I apologize for misleading anyone. Not my intention.
I am now going to see if I can get my /home moved as what started this post.
Thanks everyone for your help and I will be careful next time with what I am doing.
Please don’t forum shame me.
Don’t waste people’s time, and nobody will mention it.
As I said before and have apologized I didn’t mean to do that.
I will be better in the future. Sorry Sorry Sorry. What more can I do?
Rethink twice next time before asking for help. What you did can’t happen without knowing it.
