I have been using Manjaro Linux on my Lenovo Yoga 9i for a bit over a year, and haven’t updated pamac for about half a year.
Recently, I tried to boot my computer, but was met with an unfamiliar login screen. Instead of my normal ‘Nordic’ theme that I downloaded from online, I had the Breeze theme loaded with a message saying
The current theme cannot be loaded due to the errors below, please select another theme
file:///usr/share/sddm/themes/Nordic/Main.qml:26:1: plugin cannot be loaded for module “org.kde.plasma.core”: Cannot load library /usr/lib/qt/qml/org/kde/plasma/core/libcorebindingsplugin.so: (libplost-2.0.so.3: cannot open shared o next file: No such file or directory)
This was fixed by editing /etc/sddm.conf.d/kde_settings.conf and changing the theme to Breeze.
But I was met with another issue. I have a select screen to change my DM, and the options are
Enlightenment (Wayland)
Enlightenment
Plasma (X11)
Here, when I select Enlightenment I can see the DM. But I can’t access WiFi. I tried using Ethernet, but ping says that the hostname cannot be resolved. pamac update gives the same error as ping.
When I select Plasma, which is my main DM, my system just reboots itself.
What can I do to get Plasma back?
