I have a fresh install of linux, and i am trying to play one of the games on my steam libary and i keep getting this error.
yes i have proton and wine and lutris installed
Kernel: 6.1.23-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=2af066b4-a607-4939-aa93-34bd9ba18e2a rw splash apparmor=1
bootsplash.bootfile=/bootsplash-themes/kde/bootsplash
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Alienware product: Alienware X51 R2 v: 00
serial: <superuser required> Chassis: type: 3 v: 00
Mobo: Alienware model: 0PGRP5 v: A01 serial: <superuser required>
UEFI: Alienware v: A12 date: 03/20/2017
RAM: total: 7.68 GiB used: 5 GiB (65.1%)
Info: model: Intel Core i5-4440 bits: 64 type: MCP arch: Haswell gen: core 4
level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 3138 high: 3174 min/max: 800/3300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 3109 2: 3174 3: 3109
4: 3161 bogomips: 24809
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xsave xsaveopt xtopology xtpr
disabled
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Dell Alienware X51 R2 driver: i915 v: kernel arch: Gen-7.5
process: Intel 22nm built: 2013 ports: active: none empty: HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:0412 class-ID: 0380
Device-2: NVIDIA GK106 [GeForce GTX 645 OEM] driver: nvidia v: 470.182.03
alternate: nouveau,nvidia_drm non-free: series: 470.xx+
status: legacy-active (EOL~2023/24) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-18 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 2 speed: 5 GT/s bus-ID: 01:00.0 chip-ID: 10de:11c4
class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: nvidia gpu: i915,nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
s-diag: 583mm (22.95")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102
size: 480x270mm (18.9x10.63") diag: 551mm (21.68") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 470.182.03 renderer: NVIDIA GeForce GTX
645/PCIe/SSE2 direct-render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Dell Alienware X51 R2 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Device-3: NVIDIA GK106 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0e0b
class-ID: 0403
API: ALSA v: k6.1.23-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.68 status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl,pavucontrol
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Dell
driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 168c:0032 class-ID: 0280
vendor: Dell Alienware X51 R2 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f060
bus-ID: 00:1f.2 chip-ID: 8086:2822 rev: N/A class-ID: 0104
Local Storage: total: 931.51 GiB used: 78.21 GiB (8.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-75M2NA0
type: HDD rpm: 7200 serial: <filter> rev: 1A01 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GA50N rev: A100
dev-links: cdrom
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 78.21 GiB (8.5%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 2af066b4-a607-4939-aa93-34bd9ba18e2a
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: F6B1-7E28
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 3-7:2 info: Alienware TactX Mouse type: Mouse,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 200mA
chip-ID: 187c:0515 class-ID: 0300 serial: <filter>
Device-2: 3-8:3 info: Dell KB216 Wired Keyboard type: Keyboard,HID
power: 100mA chip-ID: 413c:2113 class-ID: 0300
Hub-6: 4-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 60.0 C mobo: N/A gpu: nvidia temp: 78 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 43%
Processes: 244 Uptime: 4h 15m wakeups: 0 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1111 pm: pacman pkgs: 1108 libs: 347 tools: pamac pm: flatpak
pkgs: 0 pm: snap pkgs: 3 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.26
