I want To install RAW Therapee and when I try to I get an error message :
Failed to generate gcc11-libs information
I’ve read elsewhere on here that the solution is to remove gcc11-libs and gcc11, and then to update.
When I try to delete them I get the same message.
I have to admit that I don’t update regularly: at the minute there are 1252 updates at 9.2GB available.
but i cannot update and now cannot add new software.
Any help greatly appreciated !
Here’s Inxi if that helps :
Kernel: 6.0.14-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=17480e2f-6383-4189-8c7d-ca2681b5aefd rw quiet apparmor=1
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: M5A97 R2.0 v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 2603
date: 06/26/2015
RAM: total: 15.52 GiB used: 4.03 GiB (26.0%)
Info: model: AMD FX-6350 bits: 64 type: MT MCP arch: Piledriver level: v2
built: 2012-13 process: GF 32nm family: 0x15 (21) model-id: 2 stepping: 0
microcode: 0x6000852
Topology: cpus: 1x cores: 6 smt: enabled cache: L1: 288 KiB
desc: d-6x16 KiB; i-3x64 KiB L2: 6 MiB desc: 3x2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1431 high: 1582 min/max: 1400/3900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1404 2: 1400
3: 1582 4: 1400 5: 1400 6: 1400 bogomips: 46975
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht
hw_pstate ibpb ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor
msr mtrr nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean
vme vmmcall wdt xop xsave
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: eVga.com. driver: nvidia
v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1b81 class-ID: 0300
Device-2: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-5.3:5 chip-ID: 046d:081b class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: N/A
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 157 s-size: 621x341mm (24.45x13.43")
s-diag: 708mm (27.89")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 157
size: 621x341mm (24.45x13.43") diag: 708mm (27.89") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce GTX
1070/PCIe/SSE2 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: ASUSTeK driver: snd_hda_intel
bus-ID: 1-5.3:5 v: kernel bus-ID: 00:14.2 chip-ID: 046d:081b class-ID: 0102
chip-ID: 1002:4383 class-ID: 0403 serial: <filter>
Device-2: NVIDIA GP104 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo
Sound API: ALSA v: k6.0.14-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
vendor: ASUSTeK P8 series driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8812AE 802.11ac PCIe Wireless Network Adapter
vendor: ASUSTeK driver: rtl8821ae v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: c000 bus-ID: 05:00.0 chip-ID: 10ec:8812 class-ID: 0280
IF: wlp5s0 state: down mac: <filter>
Local Storage: total: 2.94 TiB used: 296.25 GiB (9.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
type: SSD serial: <filter> rev: 1B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: J4.3 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Hitachi model: HDS721010CLA332
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: A3EA scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 model: SATA3 240GB SSD size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 0A0 scheme: MBR
ID-5: /dev/sdf maj-min: 8:80 vendor: Seagate model: ST3250820AS Q
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: E scheme: GPT
ID-6: /dev/sdg maj-min: 8:96 vendor: Seagate model: ST3500620AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: <unknown>
type: HDD rpm: 7200 serial: <filter> rev: HP21 scheme: MBR
ID-1: / raw-size: 931.51 GiB size: 915.81 GiB (98.31%)
used: 167.69 GiB (18.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 17480e2f-6383-4189-8c7d-ca2681b5aefd
ID-2: /run/timeshift/2847/backup raw-size: N/A size: 463.73 GiB
used: 128.56 GiB (27.7%) fs: btrfs dev: /dev/sde1 label: N/A uuid: N/A
ID-1: /dev/sdb1 maj-min: 8:17 size: 512 MiB fs: vfat label: N/A
uuid: 993C-E256
ID-2: /dev/sdb2 maj-min: 8:18 size: 1 KiB fs: <superuser required>
ID-3: /dev/sdb5 maj-min: 8:21 size: 223.07 GiB fs: ext4 label: N/A
uuid: e03f1481-6694-465e-9597-1352991e2612
ID-4: /dev/sdc1 maj-min: 8:33 size: 931.51 GiB fs: ntfs
label: WIN LINUX SHARE 1TB uuid: 7D28ABF135B57E28
ID-5: /dev/sdd1 maj-min: 8:49 size: 223 GiB fs: ntfs label: WIN10
uuid: 01D6F7FD2E83E270
ID-6: /dev/sdd2 maj-min: 8:50 size: 585 MiB fs: ntfs label: N/A
uuid: 28E8365DE8362A08
ID-7: /dev/sdf1 maj-min: 8:81 size: 200 MiB fs: vfat label: EFI
uuid: 70D6-1701
ID-8: /dev/sdf2 maj-min: 8:82 size: 232.57 GiB fs: ntfs label: WIN10-ONLY
uuid: 3FDF7FE034CD88F6
ID-9: /dev/sdg1 maj-min: 8:97 size: 463.73 GiB fs: btrfs label: TIMESHIFTS
uuid: 083e92ef-2e41-468e-b990-9f2812062321
ID-10: /dev/sdg2 maj-min: 8:98 size: 2 GiB fs: swap label: swapMX
uuid: 04316724-de63-4ac9-bc52-c7c8ed434688
Hub-1: 1-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-5:2 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-5.1:3 info: Sunplus Innovation Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 98mA
chip-ID: 1bcf:0005 class-ID: 0301
Device-2: 1-5.2:4 info: SteelSeries ApS Apex 3 TKL type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s power: 400mA
chip-ID: 1038:1622 class-ID: 0300
Device-3: 1-5.3:5 info: Logitech Webcam C310 type: Video,Audio
power: 500mA chip-ID: 046d:081b class-ID: 0102 serial: <filter>
Hub-3: 1-5.4:6 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-4: 1-5.4.1:7 info: ASIX AX68004 ports: 7 rev: 1.0 speed: 12 Mb/s
power: 100mA chip-ID: 0b95:6804 class-ID: 0900
Hub-5: 2-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s
Hub-6: 3-0:1 info: Full speed or root hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-7: 4-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-8: 5-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
Hub-9: 6-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-10: 7-0:1 info: Full speed or root hub ports: 4 rev: 1.1 speed: 12 Mb/s
Hub-11: 8-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-12: 9-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-13: 10-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-14: 11-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 27.6 C mobo: N/A gpu: nvidia temp: 47 C
Processes: 223 Uptime: 36m wakeups: 0 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages: 1849
pm: pacman pkgs: 1823 libs: 363 tools: pamac pm: flatpak pkgs: 14 pm: snap
pkgs: 12 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.24
