HI Guys, I hope everyone is okay and well.
I got the CD of OALD8, which is an oxford dictionary. So I remember that I did install it on Ubuntu with no problems. I think i made it work by opening the file (run-oald8.sh) or (oald8) in the terminal.
But now on Manjaro it dosen’t work, whenever I run it in terminal it says:
./oald8-bin: error while loading shared libraries: libpangox-1.0.so.0: cannot open shared object file: No such file or directory
I think it needs this package: libpangox-1.0.so.0?
By the way: some guides said that I should get the setup file and the Linux folder from the cd but i don’t find them at all, what I did is that I copied the entire cd files/folders and put them on the HD and run the oald8 file and it worked on Ubuntu.
