So the issue appear after installation or when booting the ISO?
If it does stop just at “Graphical Interface Reached”, then there is problem when switching from video basic mode to the graphical mode. Commonly more information are at /var/log/Xorg.0.log.
Switch to another TTY and login: user+password → manjaro
Have a look at the log: cat /var/log/Xorg.0.log | less
Upload it: cat /var/log/Xorg.0.log | curl -F'file=@-' https://0x0.st and post the link here.
This Appears While Booting the ISO.
I tried opening a TTY with multiple key combinations ctrl + alt + f2 and going on till f7
didn’t want to open, then i waited for 10 minutes but still did not work… :<
Then i removed quiet from the boot options and replaced it with 3 so that i boot into tty directly, it worked, but since the display manager did not start i have no logs, i can also connect to the wifi with nmcli
when i again do sudo systemctl start display-manager
or startx
it again goes to the black screen and i am not able to do anything
Tried this…
Logged into the tty , then started display-manager.service
i waited for 10 minutes then it showed me a cursor and after 5 minutes more it showed my the Welcome To Manjaro white colored box, but everything was black around it and i couldn’t switch to TTY again, as it was hung up
btw. after installing if you have a system with intel vmd and/or intel optane and when you boot manjaro or any arch distro , if you get an error like UUID=xxxxxx not found
then boot your live usb, and chroot to your installation and open /etc/mkinitcpio.conf
with vi or nano and add MODULES = (vmd) and save it,
then run mkinitcpio -P
and boot again should work
