fvwm3-1.1.2/meson.build:227:9: ERROR: Program 'go' not found or not executable
Hello, I’m trying to install fvwm3 through AUR and I ran into this issue:
Build started at 2025-03-18T23:43:39.945772
Main binary: /home/chris/.local/share/pipx/venvs/meson/bin/python
Build Options: -Db_pie=true -Dpython.bytecompile=1 -Dmandoc=true -Dprefix=/usr -Dlibexecdir=lib -Dsbindir=bin -Dauto_features=enabled -Dbuildtype=plain -Dwrap_mode=nodownload
Python system: Linux
The Meson build system
Version: 1.7.0
Source dir: /var/tmp/pamac-build-chris/fvwm3/src/fvwm3-1.1.2
Build dir: /var/tmp/pamac-build-chris/fvwm3/src/build
Build type: native build
Project name: fvwm3
Project version: 1.1.2
Detecting compiler via: `cc --version` -> 0
stdout:
cc (GCC) 14.2.1 20250207
Copyright (C) 2024 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Running command: -cpp -x c -E -dM -
Detecting linker via: `cc -Wl,--version -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs -flto=auto -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto` -> 0
stdout:
GNU ld (GNU Binutils) 2.44
Copyright (C) 2025 Free Software Foundation, Inc.
This program is free software; you may redistribute it under the terms of
the GNU General Public License version 3 or (at your option) a later version.
This program has absolutely no warranty.
stderr:
collect2 version 14.2.1 20250207
/usr/bin/ld -plugin /usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/liblto_plugin.so -plugin-opt=/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/lto-wrapper -plugin-opt=-fresolution=/tmp/cc7PXh0V.res -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s --build-id --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -dynamic-linker /lib64/ld-linux-x86-64.so.2 -pie /usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/../../../../lib/Scrt1.o /usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/../../../../lib/crti.o /usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/crtbeginS.o -L/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1 -L/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/../../.. --version -O1 --sort-common --as-needed -z relro -z now -z pack-relative-relocs -lgcc --push-state --as-needed -lgcc_s --pop-state -lc -lgcc --push-state --as-needed -lgcc_s --pop-state /usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/crtendS.o /usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/../../../../lib/crtn.o
Sanity testing C compiler: cc
Is cross compiler: False.
Sanity check compiler command line: cc sanitycheckc.c -o sanitycheckc.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs
Sanity check compile stdout:
Sanity check compile stderr:
Running test binary command: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/sanitycheckc.exe
C compiler for the host machine: cc (gcc 14.2.1 "cc (GCC) 14.2.1 20250207")
C linker for the host machine: cc ld.bfd 2.44
Detecting archiver via: `gcc-ar --version` -> 0
stdout:
GNU ar (GNU Binutils) 2.44
the GNU General Public License version 3 or (at your option) any later version.
stdout:
stdout:
stderr:
/usr/bin/ld -plugin /usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/liblto_plugin.so -plugin-opt=/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/lto-wrapper -plugin-opt=-fresolution=/tmp/ccK3HP5R.res -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s --build-id --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -dynamic-linker /lib64/ld-linux-x86-64.so.2 -pie /usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/../../../../lib/Scrt1.o /usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/../../../../lib/crti.o /usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/crtbeginS.o -L/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1 -L/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/../../.. --version -O1 --sort-common --as-needed -z relro -z now -z pack-relative-relocs -lgcc --push-state --as-needed -lgcc_s --pop-state -lc -lgcc --push-state --as-needed -lgcc_s --pop-state /usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/crtendS.o /usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/../../../../lib/crtn.o
C compiler for the build machine: cc (gcc 14.2.1 "cc (GCC) 14.2.1 20250207")
C linker for the build machine: cc ld.bfd 2.44
stdout:
Build machine cpu family: x86_64
Build machine cpu: x86_64
Host machine cpu family: x86_64
Host machine cpu: x86_64
Target machine cpu family: x86_64
Target machine cpu: x86_64
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp3k7bj_cy
Code:
extern int i;
int i;
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp3k7bj_cy/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp3k7bj_cy/output.obj -c -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -U_FORTIFY_SOURCE` -> 0
Compiler for C supports arguments -U_FORTIFY_SOURCE: YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmppfoi__6s
Code:
int main(void) { return 0; }
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmppfoi__6s/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmppfoi__6s/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -lm -Wl,--allow-shlib-undefined -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
Library m found: YES
Running command: /var/tmp/pamac-build-chris/fvwm3/src/fvwm3-1.1.2/./utils/fvwm-version-str.sh
--- stdout ---
released
--- stderr ---
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp1s6um49p
Code:
#ifdef __has_include
#if !__has_include("fcntl.h")
#error "Header 'fcntl.h' could not be found"
#endif
#else
#include <fcntl.h>
#endif
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp1s6um49p/testfile.c -E -P -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -P -O0 -std=c11` -> 0
Has header "fcntl.h" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpnraj8te4
Code:
#if !__has_include("float.h")
#error "Header 'float.h' could not be found"
#endif
#else
#include <float.h>
#endif
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpnraj8te4/testfile.c -E -P -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -P -O0 -std=c11` -> 0
Has header "float.h" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp2mc6ejrd
Code:
#if !__has_include("getopt.h")
#error "Header 'getopt.h' could not be found"
#endif
#else
#include <getopt.h>
#endif
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp2mc6ejrd/testfile.c -E -P -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -P -O0 -std=c11` -> 0
Has header "getopt.h" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpcg6h527e
Code:
#if !__has_include("inttypes.h")
#error "Header 'inttypes.h' could not be found"
#endif
#else
#include <inttypes.h>
#endif
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpcg6h527e/testfile.c -E -P -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -P -O0 -std=c11` -> 0
Has header "inttypes.h" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpv_88puhu
Code:
#if !__has_include("limits.h")
#error "Header 'limits.h' could not be found"
#endif
#else
#include <limits.h>
#endif
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpv_88puhu/testfile.c -E -P -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -P -O0 -std=c11` -> 0
Has header "limits.h" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp915tnkxb
Code:
#if !__has_include("malloc.h")
#error "Header 'malloc.h' could not be found"
#endif
#else
#include <malloc.h>
#endif
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp915tnkxb/testfile.c -E -P -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -P -O0 -std=c11` -> 0
Has header "malloc.h" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpdckvxu18
Code:
#if !__has_include("memory.h")
#error "Header 'memory.h' could not be found"
#endif
#else
#include <memory.h>
#endif
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpdckvxu18/testfile.c -E -P -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -P -O0 -std=c11` -> 0
Has header "memory.h" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpivqtcw2a
Code:
#if !__has_include("stdarg.h")
#error "Header 'stdarg.h' could not be found"
#endif
#else
#include <stdarg.h>
#endif
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpivqtcw2a/testfile.c -E -P -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -P -O0 -std=c11` -> 0
Has header "stdarg.h" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmplxt7g7z3
Code:
#if !__has_include("stdint.h")
#error "Header 'stdint.h' could not be found"
#endif
#else
#include <stdint.h>
#endif
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmplxt7g7z3/testfile.c -E -P -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -P -O0 -std=c11` -> 0
Has header "stdint.h" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpgoki4ukg
Code:
#if !__has_include("stdlib.h")
#error "Header 'stdlib.h' could not be found"
#endif
#else
#include <stdlib.h>
#endif
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpgoki4ukg/testfile.c -E -P -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -P -O0 -std=c11` -> 0
Has header "stdlib.h" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp2ep2ny8q
Code:
#if !__has_include("string.h")
#error "Header 'string.h' could not be found"
#endif
#else
#include <string.h>
#endif
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp2ep2ny8q/testfile.c -E -P -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -P -O0 -std=c11` -> 0
Has header "string.h" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmppnoq9aoz
Code:
#if !__has_include("strings.h")
#error "Header 'strings.h' could not be found"
#endif
#else
#include <strings.h>
#endif
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmppnoq9aoz/testfile.c -E -P -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -P -O0 -std=c11` -> 0
Has header "strings.h" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp_zzw_esg
Code:
#if !__has_include("sys/select.h")
#error "Header 'sys/select.h' could not be found"
#endif
#else
#include <sys/select.h>
#endif
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp_zzw_esg/testfile.c -E -P -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -P -O0 -std=c11` -> 0
Has header "sys/select.h" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpkwaszucp
Code:
#if !__has_include("sys/stat.h")
#error "Header 'sys/stat.h' could not be found"
#endif
#else
#include <sys/stat.h>
#endif
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpkwaszucp/testfile.c -E -P -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -P -O0 -std=c11` -> 0
Has header "sys/stat.h" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp4bbdq7i8
Code:
#if !__has_include("sys/systeminfo.h")
#error "Header 'sys/systeminfo.h' could not be found"
#endif
#else
#include <sys/systeminfo.h>
#endif
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp4bbdq7i8/testfile.c -E -P -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -P -O0 -std=c11` -> 1
stderr:
/var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp4bbdq7i8/testfile.c:4:12: error: #error "Header 'sys/systeminfo.h' could not be found"
4 | #error "Header 'sys/systeminfo.h' could not be found"
Has header "sys/systeminfo.h" : NO
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp3cb6yc4n
Code:
#if !__has_include("sys/time.h")
#error "Header 'sys/time.h' could not be found"
#endif
#else
#include <sys/time.h>
#endif
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp3cb6yc4n/testfile.c -E -P -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -P -O0 -std=c11` -> 0
Has header "sys/time.h" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp15b9fz3l
Code:
#if !__has_include("sys/wait.h")
#error "Header 'sys/wait.h' could not be found"
#endif
#else
#include <sys/wait.h>
#endif
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp15b9fz3l/testfile.c -E -P -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -P -O0 -std=c11` -> 0
Has header "sys/wait.h" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmprsu6h2u9
Code:
#if !__has_include("unistd.h")
#error "Header 'unistd.h' could not be found"
#endif
#else
#include <unistd.h>
#endif
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmprsu6h2u9/testfile.c -E -P -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -P -O0 -std=c11` -> 0
Has header "unistd.h" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpqltmiuyk
Code:
#include <libcharset.h>
int main(void) {
/* If it's not defined as a macro, try to use as a symbol */
#ifndef locale_charset
locale_charset;
#endif
return 0;
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpqltmiuyk/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpqltmiuyk/output.obj -c -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11` -> 1
stderr:
/var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpqltmiuyk/testfile.c:2:18: fatal error: libcharset.h: No such file or directory
2 | #include <libcharset.h>
compilation terminated.
Header "libcharset.h" has symbol "locale_charset" : NO
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpc26ii7g9
Code:
#define div meson_disable_define_of_div
#include <limits.h>
#undef div
#ifdef __cplusplus
extern "C"
#endif
char div (void);
#if defined __stub_div || defined __stub___div
fail fail fail this function is not going to work
#endif
int main(void) {
return div ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpc26ii7g9/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpc26ii7g9/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
In file included from /usr/include/bits/libc-header-start.h:33,
from /usr/include/limits.h:26,
from /usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/include/limits.h:210,
from /usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/include/syslimits.h:7,
from /usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/include/limits.h:34,
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpc26ii7g9/testfile.c:4:
/usr/include/features.h:435:4: warning: #warning _FORTIFY_SOURCE requires compiling with optimization (-O) [-Wcpp]
435 | # warning _FORTIFY_SOURCE requires compiling with optimization (-O)
Checking for function "div" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpu9bpau1p
Code:
#define getpwuid meson_disable_define_of_getpwuid
#include <limits.h>
#undef getpwuid
#ifdef __cplusplus
extern "C"
#endif
char getpwuid (void);
#if defined __stub_getpwuid || defined __stub___getpwuid
#endif
int main(void) {
return getpwuid ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpu9bpau1p/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpu9bpau1p/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpu9bpau1p/testfile.c:4:
Checking for function "getpwuid" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpeoibaaat
Code:
#define gettimeofday meson_disable_define_of_gettimeofday
#include <limits.h>
#undef gettimeofday
#ifdef __cplusplus
extern "C"
#endif
char gettimeofday (void);
#if defined __stub_gettimeofday || defined __stub___gettimeofday
#endif
int main(void) {
return gettimeofday ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpeoibaaat/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpeoibaaat/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpeoibaaat/testfile.c:4:
Checking for function "gettimeofday" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpzmsxedt2
Code:
#define lstat meson_disable_define_of_lstat
#include <limits.h>
#undef lstat
#ifdef __cplusplus
extern "C"
#endif
char lstat (void);
#if defined __stub_lstat || defined __stub___lstat
#endif
int main(void) {
return lstat ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpzmsxedt2/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpzmsxedt2/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpzmsxedt2/testfile.c:4:
Checking for function "lstat" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpd1l1bby5
Code:
#define memcpy meson_disable_define_of_memcpy
#include <limits.h>
#undef memcpy
#ifdef __cplusplus
extern "C"
#endif
char memcpy (void);
#if defined __stub_memcpy || defined __stub___memcpy
#endif
int main(void) {
return memcpy ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpd1l1bby5/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpd1l1bby5/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpd1l1bby5/testfile.c:4:
/var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpd1l1bby5/testfile.c:10:14: warning: conflicting types for built-in function 'memcpy'; expected 'void *(void *, const void *, long unsigned int)' [-Wbuiltin-declaration-mismatch]
10 | char memcpy (void);
/var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpd1l1bby5/testfile.c:5:1: note: 'memcpy' is declared in header '<string.h>'
4 | #include <limits.h>
+++ |+#include <string.h>
5 | #undef memcpy
Checking for function "memcpy" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpdd1fqfdw
Code:
#define memmove meson_disable_define_of_memmove
#include <limits.h>
#undef memmove
#ifdef __cplusplus
extern "C"
#endif
char memmove (void);
#if defined __stub_memmove || defined __stub___memmove
#endif
int main(void) {
return memmove ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpdd1fqfdw/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpdd1fqfdw/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpdd1fqfdw/testfile.c:4:
/var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpdd1fqfdw/testfile.c:10:14: warning: conflicting types for built-in function 'memmove'; expected 'void *(void *, const void *, long unsigned int)' [-Wbuiltin-declaration-mismatch]
10 | char memmove (void);
/var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpdd1fqfdw/testfile.c:5:1: note: 'memmove' is declared in header '<string.h>'
5 | #undef memmove
Checking for function "memmove" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpm4btzgo8
Code:
#define mkfifo meson_disable_define_of_mkfifo
#include <limits.h>
#undef mkfifo
#ifdef __cplusplus
extern "C"
#endif
char mkfifo (void);
#if defined __stub_mkfifo || defined __stub___mkfifo
#endif
int main(void) {
return mkfifo ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpm4btzgo8/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpm4btzgo8/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpm4btzgo8/testfile.c:4:
Checking for function "mkfifo" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp4dhymktb
Code:
#define nl_langinfo meson_disable_define_of_nl_langinfo
#include <limits.h>
#undef nl_langinfo
#ifdef __cplusplus
extern "C"
#endif
char nl_langinfo (void);
#if defined __stub_nl_langinfo || defined __stub___nl_langinfo
#endif
int main(void) {
return nl_langinfo ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp4dhymktb/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp4dhymktb/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp4dhymktb/testfile.c:4:
Checking for function "nl_langinfo" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpotxr0qxc
Code:
#define putenv meson_disable_define_of_putenv
#include <limits.h>
#undef putenv
#ifdef __cplusplus
extern "C"
#endif
char putenv (void);
#if defined __stub_putenv || defined __stub___putenv
#endif
int main(void) {
return putenv ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpotxr0qxc/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpotxr0qxc/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpotxr0qxc/testfile.c:4:
Checking for function "putenv" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpv1nxlm30
Code:
#define setpgid meson_disable_define_of_setpgid
#include <limits.h>
#undef setpgid
#ifdef __cplusplus
extern "C"
#endif
char setpgid (void);
#if defined __stub_setpgid || defined __stub___setpgid
#endif
int main(void) {
return setpgid ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpv1nxlm30/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpv1nxlm30/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpv1nxlm30/testfile.c:4:
Checking for function "setpgid" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpi8s7qt_1
Code:
#define setpgrp meson_disable_define_of_setpgrp
#include <limits.h>
#undef setpgrp
#ifdef __cplusplus
extern "C"
#endif
char setpgrp (void);
#if defined __stub_setpgrp || defined __stub___setpgrp
#endif
int main(void) {
return setpgrp ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpi8s7qt_1/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpi8s7qt_1/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpi8s7qt_1/testfile.c:4:
Checking for function "setpgrp" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpq9mc7v6o
Code:
#define setvbuf meson_disable_define_of_setvbuf
#include <limits.h>
#undef setvbuf
#ifdef __cplusplus
extern "C"
#endif
char setvbuf (void);
#if defined __stub_setvbuf || defined __stub___setvbuf
#endif
int main(void) {
return setvbuf ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpq9mc7v6o/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpq9mc7v6o/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpq9mc7v6o/testfile.c:4:
Checking for function "setvbuf" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmph26n5clt
Code:
#define sigaction meson_disable_define_of_sigaction
#include <limits.h>
#undef sigaction
#ifdef __cplusplus
extern "C"
#endif
char sigaction (void);
#if defined __stub_sigaction || defined __stub___sigaction
#endif
int main(void) {
return sigaction ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmph26n5clt/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmph26n5clt/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmph26n5clt/testfile.c:4:
Checking for function "sigaction" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpod8imzzz
Code:
#define siginterrupt meson_disable_define_of_siginterrupt
#include <limits.h>
#undef siginterrupt
#ifdef __cplusplus
extern "C"
#endif
char siginterrupt (void);
#if defined __stub_siginterrupt || defined __stub___siginterrupt
#endif
int main(void) {
return siginterrupt ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpod8imzzz/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpod8imzzz/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpod8imzzz/testfile.c:4:
Checking for function "siginterrupt" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpkznwdff1
Code:
#define siglongjmp meson_disable_define_of_siglongjmp
#include <limits.h>
#undef siglongjmp
#ifdef __cplusplus
extern "C"
#endif
char siglongjmp (void);
#if defined __stub_siglongjmp || defined __stub___siglongjmp
#endif
int main(void) {
return siglongjmp ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpkznwdff1/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpkznwdff1/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpkznwdff1/testfile.c:4:
Checking for function "siglongjmp" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp1vooiurv
Code:
#define sigsetjmp meson_disable_define_of_sigsetjmp
#include <limits.h>
#undef sigsetjmp
#ifdef __cplusplus
extern "C"
#endif
char sigsetjmp (void);
#if defined __stub_sigsetjmp || defined __stub___sigsetjmp
#endif
int main(void) {
return sigsetjmp ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp1vooiurv/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp1vooiurv/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 1
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp1vooiurv/testfile.c:4:
/usr/bin/ld: /tmp/ccnGMi65.ltrans0.ltrans.o: in function `main':
<artificial>:(.text+0xa): undefined reference to `sigsetjmp'
collect2: error: ld returned 1 exit status
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpl6dul416
Code:
int main(void) {
/* With some toolchains (MSYS2/mingw for example) the compiler
* provides various builtins which are not really implemented and
* fall back to the stdlib where they aren't provided and fail at
* build/link time. In case the user provides a header, including
* the header didn't lead to the function being defined, and the
* function we are checking isn't a builtin itself we assume the
* builtin is not functional and we just error out. */
#if !1 && !defined(sigsetjmp) && !0
#error "No definition for __builtin_sigsetjmp found in the prefix"
#endif
#ifdef __has_builtin
#if !__has_builtin(__builtin_sigsetjmp)
#error "__builtin_sigsetjmp not found"
#endif
#elif ! defined(sigsetjmp)
__builtin_sigsetjmp;
#endif
return 0;
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpl6dul416/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpl6dul416/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 1
stderr:
/var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpl6dul416/testfile.c: In function 'main':
/var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpl6dul416/testfile.c:17:18: error: #error "__builtin_sigsetjmp not found"
17 | #error "__builtin_sigsetjmp not found"
Checking for function "sigsetjmp" : NO
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpl3q3vddm
Code:
#define socket meson_disable_define_of_socket
#include <limits.h>
#undef socket
#ifdef __cplusplus
extern "C"
#endif
char socket (void);
#if defined __stub_socket || defined __stub___socket
#endif
int main(void) {
return socket ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpl3q3vddm/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpl3q3vddm/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpl3q3vddm/testfile.c:4:
Checking for function "socket" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp7_6gmg66
Code:
#define strchr meson_disable_define_of_strchr
#include <limits.h>
#undef strchr
#ifdef __cplusplus
extern "C"
#endif
char strchr (void);
#if defined __stub_strchr || defined __stub___strchr
#endif
int main(void) {
return strchr ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp7_6gmg66/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp7_6gmg66/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp7_6gmg66/testfile.c:4:
/var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp7_6gmg66/testfile.c:10:14: warning: conflicting types for built-in function 'strchr'; expected 'char *(const char *, int)' [-Wbuiltin-declaration-mismatch]
10 | char strchr (void);
/var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp7_6gmg66/testfile.c:5:1: note: 'strchr' is declared in header '<string.h>'
5 | #undef strchr
Checking for function "strchr" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp5y3k8dbq
Code:
#define strdup meson_disable_define_of_strdup
#include <limits.h>
#undef strdup
#ifdef __cplusplus
extern "C"
#endif
char strdup (void);
#if defined __stub_strdup || defined __stub___strdup
#endif
int main(void) {
return strdup ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp5y3k8dbq/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp5y3k8dbq/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp5y3k8dbq/testfile.c:4:
Checking for function "strdup" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpxdkxu3zg
Code:
#define strstr meson_disable_define_of_strstr
#include <limits.h>
#undef strstr
#ifdef __cplusplus
extern "C"
#endif
char strstr (void);
#if defined __stub_strstr || defined __stub___strstr
#endif
int main(void) {
return strstr ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpxdkxu3zg/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpxdkxu3zg/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpxdkxu3zg/testfile.c:4:
/var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpxdkxu3zg/testfile.c:10:14: warning: conflicting types for built-in function 'strstr'; expected 'char *(const char *, const char *)' [-Wbuiltin-declaration-mismatch]
10 | char strstr (void);
/var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpxdkxu3zg/testfile.c:5:1: note: 'strstr' is declared in header '<string.h>'
5 | #undef strstr
Checking for function "strstr" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpd4b2l4cz
Code:
#define strtol meson_disable_define_of_strtol
#include <limits.h>
#undef strtol
#ifdef __cplusplus
extern "C"
#endif
char strtol (void);
#if defined __stub_strtol || defined __stub___strtol
#endif
int main(void) {
return strtol ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpd4b2l4cz/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpd4b2l4cz/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpd4b2l4cz/testfile.c:4:
Checking for function "strtol" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp9agewcj2
Code:
#define sysconf meson_disable_define_of_sysconf
#include <limits.h>
#undef sysconf
#ifdef __cplusplus
extern "C"
#endif
char sysconf (void);
#if defined __stub_sysconf || defined __stub___sysconf
#endif
int main(void) {
return sysconf ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp9agewcj2/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp9agewcj2/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp9agewcj2/testfile.c:4:
Checking for function "sysconf" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp92dn2rt7
Code:
#define intl meson_disable_define_of_intl
#include <limits.h>
#undef intl
#ifdef __cplusplus
extern "C"
#endif
char intl (void);
#if defined __stub_intl || defined __stub___intl
#endif
int main(void) {
return intl ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp92dn2rt7/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp92dn2rt7/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 1
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp92dn2rt7/testfile.c:4:
/usr/bin/ld: /tmp/cccjnie6.ltrans0.ltrans.o: in function `main':
<artificial>:(.text+0xa): undefined reference to `intl'
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp6achk6g0
Code:
int main(void) {
#if !1 && !defined(intl) && !0
#error "No definition for __builtin_intl found in the prefix"
#endif
#if !__has_builtin(__builtin_intl)
#error "__builtin_intl not found"
#endif
#elif ! defined(intl)
__builtin_intl;
#endif
return 0;
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp6achk6g0/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp6achk6g0/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 1
stderr:
/var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp6achk6g0/testfile.c: In function 'main':
/var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp6achk6g0/testfile.c:17:18: error: #error "__builtin_intl not found"
17 | #error "__builtin_intl not found"
Checking for function "intl" : NO
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpvprbq8gt
Code:
#define uname meson_disable_define_of_uname
#include <limits.h>
#undef uname
#ifdef __cplusplus
extern "C"
#endif
char uname (void);
#if defined __stub_uname || defined __stub___uname
#endif
int main(void) {
return uname ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpvprbq8gt/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpvprbq8gt/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpvprbq8gt/testfile.c:4:
Checking for function "uname" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp_ih0776y
Code:
#define wait3 meson_disable_define_of_wait3
#include <limits.h>
#undef wait3
#ifdef __cplusplus
extern "C"
#endif
char wait3 (void);
#if defined __stub_wait3 || defined __stub___wait3
#endif
int main(void) {
return wait3 ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp_ih0776y/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp_ih0776y/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp_ih0776y/testfile.c:4:
Checking for function "wait3" : YES
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpck9thib_
Code:
#define waitpid meson_disable_define_of_waitpid
#include <limits.h>
#undef waitpid
#ifdef __cplusplus
extern "C"
#endif
char waitpid (void);
#if defined __stub_waitpid || defined __stub___waitpid
#endif
int main(void) {
return waitpid ();
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpck9thib_/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpck9thib_/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -std=c11 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmpck9thib_/testfile.c:4:
Checking for function "waitpid" : YES
Pkg-config binary missing from cross or native file, or env var undefined.
Trying a default Pkg-config fallback at pkg-config
Found pkg-config: YES (/usr/bin/pkg-config) 2.3.0
Determining dependency 'fontconfig' with pkg-config executable '/usr/bin/pkg-config'
env[PKG_CONFIG_PATH]:
env[PKG_CONFIG]: /usr/bin/pkg-config
Called: `/usr/bin/pkg-config --modversion fontconfig` -> 0
stdout:
2.16.0
Called: `/usr/bin/pkg-config --cflags fontconfig` -> 0
stdout:
-I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-6 -pthread
env[PKG_CONFIG_ALLOW_SYSTEM_LIBS]: 1
Called: `/usr/bin/pkg-config --libs fontconfig` -> 0
stdout:
-L/usr/lib -lfontconfig -lfreetype
stdout:
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp43004scf
Code:
#include<stddef.h>
#include<stdio.h>
int main(void) {
printf("%ld\n", (long)(sizeof(void *)));
return 0;
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp43004scf/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp43004scf/output.exe -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 -Wl,-O1 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-z,pack-relative-relocs` -> 0
stderr:
from /usr/include/stdio.h:28,
from /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp43004scf/testfile.c:3:
Program stdout:
8
Program stderr:
Running compile:
Working directory: /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp2hukclp4
Code:
Command line: `cc /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp2hukclp4/testfile.c -o /var/tmp/pamac-build-chris/fvwm3/src/build/meson-private/tmp2hukclp4/output.obj -c -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -flto=auto -D_FILE_OFFSET_BITS=64 -O0 --print-search-dirs` -> 0
stdout:
install: /usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/
programs: =/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/:/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/:/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/../../../../x86_64-pc-linux-gnu/bin/x86_64-pc-linux-gnu/14.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/../../../../x86_64-pc-linux-gnu/bin/
libraries: =/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/../../../../x86_64-pc-linux-gnu/lib/x86_64-pc-linux-gnu/14.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/../../../../x86_64-pc-linux-gnu/lib/../lib/:/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/../../../x86_64-pc-linux-gnu/14.2.1/:/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/../../../../lib/:/lib/x86_64-pc-linux-gnu/14.2.1/:/lib/../lib/:/usr/lib/x86_64-pc-linux-gnu/14.2.1/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/../../../../x86_64-pc-linux-gnu/lib/:/usr/lib/gcc/x86_64-pc-linux-gnu/14.2.1/../../../:/lib/:/usr/lib/
Run-time dependency fontconfig found: YES 2.16.0
Determining dependency 'ice' with pkg-config executable '/usr/bin/pkg-config'
Called: `/usr/bin/pkg-config --modversion ice` -> 0
stdout:
1.1.2
Called: `/usr/bin/pkg-config --cflags ice` -> 0
Called: `/usr/bin/pkg-config --libs ice` -> 0
stdout:
-L/usr/lib -lICE
stdout:
-lICE
Run-time dependency ice found: YES 1.1.2
Determining dependency 'libevent' with pkg-config executable '/usr/bin/pkg-config'
Called: `/usr/bin/pkg-config --modversion libevent` -> 0
stdout:
2.1.12
Called: `/usr/bin/pkg-config --cflags libevent` -> 0
Called: `/usr/bin/pkg-config --libs libevent` -> 0
stdout:
-L/usr/lib -levent
stdout:
-levent
Run-time dependency libevent found: YES 2.1.12
Determining dependency 'x11' with pkg-config executable '/usr/bin/pkg-config'
Called: `/usr/bin/pkg-config --modversion x11` -> 0
stdout:
1.8.12
Called: `/usr/bin/pkg-config --cflags x11` -> 0
Called: `/usr/bin/pkg-config --libs x11` -> 0
stdout:
-L/usr/lib -lX11
stdout:
-lX11
Run-time dependency x11 found: YES 1.8.12
Determining dependency 'xft' with pkg-config executable '/usr/bin/pkg-config'
Called: `/usr/bin/pkg-config --modversion xft` -> 0
stdout:
2.3.8
Called: `/usr/bin/pkg-config --cflags xft` -> 0
stdout:
Called: `/usr/bin/pkg-config --libs xft` -> 0
stdout:
-L/usr/lib -lXft
stdout:
-lXft
Run-time dependency xft found: YES 2.3.8
Determining dependency 'xrandr' with pkg-config executable '/usr/bin/pkg-config'
Called: `/usr/bin/pkg-config --modversion xrandr` -> 0
stdout:
1.5.4
Called: `/usr/bin/pkg-config --cflags xrandr` -> 0
Called: `/usr/bin/pkg-config --libs xrandr` -> 0
stdout:
-L/usr/lib -lXrandr
stdout:
-lXrandr
Run-time dependency xrandr found: YES 1.5.4
Determining dependency 'xt' with pkg-config executable '/usr/bin/pkg-config'
Called: `/usr/bin/pkg-config --modversion xt` -> 0
stdout:
1.3.1
Called: `/usr/bin/pkg-config --cflags xt` -> 0
stdout:
-I/usr/include/uuid
Called: `/usr/bin/pkg-config --libs xt` -> 0
stdout:
-L/usr/lib -lXt -lX11
stdout:
-lXt -lX11
Run-time dependency xt found: YES 1.3.1
Determining dependency 'xtrans' with pkg-config executable '/usr/bin/pkg-config'
Called: `/usr/bin/pkg-config --modversion xtrans` -> 0
stdout:
1.6.0
Called: `/usr/bin/pkg-config --cflags xtrans` -> 0
stdout:
-D_DEFAULT_SOURCE -D_BSD_SOURCE -DHAS_FCHOWN -DHAS_STICKY_DIR_BIT
Called: `/usr/bin/pkg-config --libs xtrans` -> 0
Run-time dependency xtrans found: YES 1.6.0
Determining dependency 'xext' with pkg-config executable '/usr/bin/pkg-config'
Called: `/usr/bin/pkg-config --modversion xext` -> 0
stdout:
1.3.6
Called: `/usr/bin/pkg-config --cflags xext` -> 0
Called: `/usr/bin/pkg-config --libs xext` -> 0
stdout:
-L/usr/lib -lXext
stdout:
-lXext
Run-time dependency xext found: YES 1.3.6
Determining dependency 'xkbcommon' with pkg-config executable '/usr/bin/pkg-config'
Called: `/usr/bin/pkg-config --modversion xkbcommon` -> 0
stdout:
1.8.0
Called: `/usr/bin/pkg-config --cflags xkbcommon` -> 0
Called: `/usr/bin/pkg-config --libs xkbcommon` -> 0
stdout:
-L/usr/lib -lxkbcommon
stdout:
-lxkbcommon
Run-time dependency xkbcommon found: YES 1.8.0
Program python3 found: YES (/usr/bin/python3)
Program perl found: YES (/usr/bin/perl)
Program go found: NO
I googled for it, but I cannot find anything about this error anywhere.
